SS54B
SS54B
    PROSEMI(普罗森美)
    SMB(DO-214AA)
    肖特基二极管 SMB 40V 5A 125A 500μA
SS54B 数据手册
SS54B THRU SS520B Surface Mounted Schottky Barrier Rectifiers Reverse Voltage 40 ~ 200 V Forward Current 5.0 A www.prosemitech.com Features Low reverse leakage High forward surge capability High reliability High temperature soldering guaranteed: 260℃/10seconds Lead and body according with RoHS stand Ro H S 2002/95/EC Green compound with suffix "-F" on Marking DO-214AA/SMB Mechanical Data Case:DO-214AA Molded plastic Epoxy: UL 94V-0 rate flame retardant Lead: Pure tin plated, lead free Maximum Ratings & Characteristics Ratings at 25℃ ambient temperature unless other wise specified. Parameter Symbols SS54B SS56B SS510B SS515B SS520B Unit Maximum repetitive peak reverse voltage VRRM 40 60 100 150 200 V Maximum RMS voltage VRMS 28 42 70 105 140 V Maximum DC blocking voltage VDC 40 60 100 150 200 V Maximum averagge forward rectified current IF(AV) 5.0 A IFSM 125 A Non-repetitive peak forward surge current 8.3 ms singlehalf sine-wave Maximum forward voltage @IF=5.0A Maximum reverse current @VD TA= 25℃ TA= 100℃ Typical thermal resistance (Note 1) VR=4.0V,f=1MHz Type junction capacitance Operating junction Storage temperature rang VF 0.50 IR 0.70 0.85 V 10 μA 20 5 mA 60 RθJL 20 Cj 250 -55 --- +125 TSTG 0.95 500 RθJA Tj 0.92 -55 --- +150 -55 --- +150 ℃/W pF ℃ ℃ Note: 1)) Thermal resistance from junction to ambient , PCB mounted. Specifications are subject to change without notice. C PROSEMI Document No:HEX356047Z 1 of 3 www.prosemitech.com SS54B THRU SS520B www.prosemitech.com Characteristic Curves FORWARD CURRENT DERATING CURVE 10 IF(A) Average Forward Rectified Current (A) IF Instantaneous Fo orward Current (A) TYPICAL FORWARD CHARACTERISTIC 1 0.1 0.2 0.6 1 1.4 6 5 4 3 2 1 0 1.8 0 25 VF Instantaneous Forward Voltage (V) 50 75 100 125 150 175 Tamb, ambient temperature (°C) MAXIMUM NON REPETITIVE Typical Reverse Characteristics PEAK FORWARD SURGE CURRENT 100 140 120 Reverse Current(uA) IFSM Peak Forward Surge Current (A) 160 100 80 60 40 10 1 20 0 0.1 1 10 100 0% Number of Cycles at 60 Hz. Specifications are subject to change without notice. C PROSEMI Document No:HEX356047Z 20% 40% 60% 80% 100% Percent Of Rated Peak Reverse voltage % 2 of 3 www.prosemitech.com SS54B THRU SS520B www.prosemitech.com Package Outline 0.155(3.94) 0.130(3.30) 0.086 (2.20) 0.071 (1.80) 0.183(4.65) 0.160(4.05) 0.012(0.305) 0.006(0.152) 0.096(2.45) 0.081(2.05) 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. 0.220(5.59) 0.200(5.08) Dimensions in inches and (millimeters) Package Information Qty:3,000 /Tape and reel Specifications are subject to change without notice. C PROSEMI Document No:HEX356047Z 3 of 3 www.prosemitech.com
SS54B 价格&库存
很抱歉,暂时无法提供与“SS54B”相匹配的价格&库存,您可以联系我们找货
SS54B
    • 5+1.16457
    • 50+0.97276
    • 150+0.87686
    • 500+0.80493
    • 3000+0.72339
    • 6000+0.69455
