SS520A
SS520A
    PROSEMI(普罗森美)
    SMA(DO-214AC)
    肖特基二极管 SMA 200V 5A 125A 100μA
SS520A 数据手册
SS52A THRU SS520A Surface Mounted Schottky Barrier Rectifiers Reverse Voltage 20 ~ 200 V Forward Current 5.0 A www.prosemitech.com Features Low reverse leakage High forward surge capability High reliability High temperature soldering guaranteed: 260℃/10seconds Lead and body according with RoHS standard Ro H S 2002/95/EC Green compound with suffix "-F" on Marking DO-214AC/SMA Mechanical Data Case:DO-214AC Molded plastic Epoxy: UL 94V-0 rate flame retardant Lead: Pure tin plated, lead free Maximum Ratings & Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbols SS52A SS53A SS54A SS55A SS56A SS58A SS510A SS515A SS520A Unit Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 80 100 150 200 V Maximum RMS voltage VRMS 14 21 28 35 42 56 70 105 140 V Maximum DC blocking voltage VDC 20 30 40 50 60 80 100 150 200 V Maximum average forward rectified current IF(AV) 5.0 A IFSM 125 A Non-repetitive peak forward surge current 8.3 ms singlehalf sine-wave @IF=5.0A VF Maximum forward voltage @VDC TA= 25℃ Maximum reverse current TA= 100℃ Typical thermal resistance (Note 1) VR=4.0V,f=1MHz Type junction capacitance Operating junction Storage temperature rang 0.55 0.70 IR 0.85 0.5 0.1 20 10 RθJA 105 RθJL 35 CJ 300 TJ -55 --- +125 TSTG 0.92 V mA ℃/W pF -55 --- +150 -55 --- +150 0.95 ℃ ℃ Note: 1) Thermal resistance from junction to ambient , PCB mounted. Specifications are subject to change without notice. C PROSEMI Document No:HEX35022147Z 1 of 3 www.prosemitech.com SS52A THRU SS520A www.prosemitech.com Characteristic Curves 1 0.1 0.1 0.5 0.9 1.3 1.7 FORWARD CURRENT DERATING CURVE IF(A) Average Forward Rectified Current (A) IF Instantaneous Forward Current (A) TYPICAL FORWARD CHARACTERISTIC 6 5 4 3 2 1 0 0 VF Instantaneous Forward Voltage (V) 25 50 75 100 125 150 175 Tamb, ambient temperature (°C) MAXIMUM NON REPETITIVE Typical Reverse Characteristics PEAK FORWARD SURGE CURRENT 1000 125 Reverse Current(uA) IFSM Peak Forward Surge Current (A) 150 100 75 50 100 10 25 0 1 1 10 100 0% 40% 60% 80% 100% Percent Of Rated Peak Reverse voltage % Number of Cycles at 60 Hz. Specifications are subject to change without notice. C PROSEMI Document No:HEX35022147Z 20% 2 of 3 www.prosemitech.com SS52A THRU SS520A www.prosemitech.com 0.006(0.145) 0.030(0.76) 0.208(5.28) 0.055(1.40) 0.071(1.80) 0.110(2.80) 0.188(4.80) 0.100(2.50) 0.008(0.203)MAX. 0.060(1.52) 0.075(1.90) 0.010(0.255) 0.096(2.45) Package Outline 0.181(4.60) 0.154(3.90) Unit: inch (mm) Package Information Qty:5,000 /Tape and reel Specifications are subject to change without notice. C PROSEMI Document No:HEX35022147Z 3 of 3 www.prosemitech.com
SS520A 价格&库存
很抱歉,暂时无法提供与“SS520A”相匹配的价格&库存,您可以联系我们找货
