SS14-W
SS14-W
    PROSEMI(普罗森美)
    SMA-W
    电压:40V 电流:1A
SS14-W 数据手册
SS14-W THRU SS120-W Surface Mounted Schottky Barrier Rectifiers Reverse Voltage 40 ~ 200 V Forward Current 1.0 A www.prosemitech.com Features Low reverse leakage High forward surge capability High reliability High temperature soldering guaranteed: 260℃/10seconds Lead and body according with RoHS standard Ro H S SMA-W Green compound with suffix "-F" on Marking 2002/95/EC Mechanical Data Case:SMA-W Molded plastic Epoxy: UL 94V-0 rate flame retardant Lead: Pure tin plated, lead free Maximum Ratings & Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbols SS14 SS15 SS16 SS18 SS110 SS115 SS120 -W -W -W -W -W -W -W Unit Maximum repetitive peak reverse voltage VRRM 40 50 60 80 100 150 200 V Maximum RMS voltage VRMS 28 35 42 56 70 105 140 V Maximum DC blocking voltage VDC 40 50 60 80 100 150 200 V Maximum average forward rectified current IF(AV) 1.0 A IFSM 30 A Non-repetitive peak forward surge current 8.3 ms singlehalf sine-wave @IF=1.0A VF Maximum forward voltage @VDC TA= 25℃ Maximum reverse current TA=100℃ Typical thermal resistance (Note 1) VR=4.0V,f=1MHz Type junction capacitance Operating junction and storage temperature rang 0.55 IR 0.70 0.85 0.95 V 500 100 μA 20 10 mA RθJA 88 ℃/W Cj 130 pF Tj, TSTG -55 --- +125 -55 --- +150 ℃ Note 1) Thermal resistance from junction to ambient, PCB mounted. Specifications are subject to change without notice. C PROSEMI Document No:AGE14F3GVF2 1 of 3 www.prosemitech.com SS14-W THRU SS120-W www.prosemitech.com Characteristic Curves FORWARD CURRENT DERATING CURVE 10 IF F(A) Average Forward R ectified Current (A) orward Current (A) IF Instantaneous Fo TYPICAL FORWARD CHARACTERISTIC 1 0.1 0.1 0.5 0.9 1.3 1.2 1 0.8 0.6 0.4 0.2 0 0 1.7 25 VF Instantaneous Forward Voltage (V) 50 75 100 125 150 175 200 Tamb, ambient temperature (°C) MAXIMUM NON REPETITIVE PEAK Typical Reverse Characteristics FORWARD SURGE CURRENT 1000 30 25 Reverse Current(uA) IFSM Peak Forward Surge Current (A) 35 20 15 10 100 10 1 5 0.1 0 1 10 100 0% Number of Cycles at 60 Hz. Specifications are subject to change without notice. C PROSEMI Document No:AGE14F3GVF2 20% 40% 60% 80% 100% Percent Of Rated Peak Reverse voltage % 2 of 3 www.prosemitech.com SS14-W THRU SS120-W www.prosemitech.com Package Outline 0.110(2.80) 0.096(2.45) 0.057(1.45) 0.045(1.15) 0.173(4.40) 0.154(3.90) 0.094(2.40) 0.075(1.90) 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX 0.207(5.25) 0.191(4.85) Unit: inch (mm) Package Information Qty:5,000 /Tape and reel Specifications are subject to change without notice. C PROSEMI Document No:AGE14F3GVF2 3 of 3 www.prosemitech.com
SS14-W 价格&库存
很抱歉,暂时无法提供与“SS14-W”相匹配的价格&库存,您可以联系我们找货
