Ultra-Low Capacitance Series
ESD Solutions
Description
The PROSEMI Polymer ESD Suppressors protect valuable high-speed data circuits from ESD
damage without distorting data signals as a result of its ultra-low (0.05pF typical) capacitance.
Pb
lead- free
RoHS
2015/863/EC
Features
ESD protection for high speed data lines to IEC61000-4-2
ESD contact discharge typical 8KV, max 15KV
ESD air discharge typical 15KV, max 25KV
Surface mount
Extremely low capacitance
Very low leakage current
Fast response time
Bi-directional ESD protection
Lead free solder termination
The best ESD protection for high frequency, low voltage applications
DP-1006
Applieation
Antenna circuit
USB2.0/3.0/3.1
IEEE-1394
DVI
HDMI1.3/1.4/2.0
Display
A/V Equipment
HDTV Hardware
Laptop/Desktop Computers
Network Hardware
Computer Peripherals
Digital Cameras
External Storage
Set-Top Boxes
Bi-directional
Part Numbering System
UPEP
2D 05
T 0402
ESD Suppressor
Size
0402:0402(1005)
Bi-directional
Packaging
10,000pcs
Operating Voltage
05: 5V
Specifications are subject to change without notice.
C PROSEMI
Document No:P0E1610133337001S
1 of 4
www.prosemitech.com
ESD Solutions
Absolute Maximum Ratings
Parameter
Symbol
Value
Unit
Maximum Contact discharge
voltage Per IEC61000-4-2
15KV
V
Maximum Air discharge
25KV
V
Maximum Operating temperature
TOPER
-55 to+125
Maximum Storage temperature
TSTG
-55 to+125
Maximum lead temperature
for soldering during 1 Os
TL
260
Electrical Characteristics
Parameter
(T A=25℃)
Symbol
Test Conditions
Min
Typ
Max
Unit
5
V
RatedVoltage
VR
Clamping Voltage
VC
IEC61000-4-2 8KV contact discharge
300
V
Trigger Voltage
VT
35
V
Leakage Current
IL
DC 5V shall be applied on component
0.01
0.10
uA
Capacitance
CP
VR = OV, f = 1MHz
0.05
pF
*Note: 1. Trigger and clamping voltage are measured per IEC 61000-4-2, 8KV contact discharge method.
2. After reliability tests such as high temp storage, temp cycles, continuous ESD strike etc, the
maximum leakage current is less than 10uA.
C PROSEMI
2 of 4
www.prosemitech.com
ESD Solutions
Dimensions
*OS
3OT
3G^
A
0.90
1.20
B
0.45
0.65
C
0.30
0.40
D
0.00
0.05
E
F
G
Unit:mm
3ORROSKZKY
H
0.125Ref.
0.40
0.50
0.65BSC
0.25
0.35
Soldering Pad
0.9 mm
0.65 mm
0.50 mm
Note:Print solder in thickness of 0.08mm to 0.10mm
ESD Clamping Test Waveforms
C PROSEMI
3 of 4
www.prosemitech.com
ESD Solutions
Carrier Tape Dimensions
Unit:mm
Type
UPEP
(0402)
A
B
0.68±0.05 1.17±0.05
W
F
8.0±0.2
E
3.5±0.05 1.75±0.1
P1
P2
P0
2.0±0.1
2.0±0.05
4.0±0.1
D0
Φ1.5
C
T
+0.1
0.45±0.1
-0
F
T
B
A
Unit:mm
A
B
C
F
T
180±1.5
51.0±1.0
13.0±1.0
9.4±1.0
12.4±2.0
Storage Conditions and Shelf Life
Temperature: 5℃~35℃, Humidity: 40%~75%
2 years from manufacturing date
Packaging
UPEP2D05T0402 :quantity10,000 pieces
C PROSEMI
4 of 4
www.prosemitech.com
很抱歉,暂时无法提供与“UPEP2D05T0402”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.05687
- 50+0.05261
- 200+0.04905
- 600+0.04550
- 1500+0.04265
- 3000+0.04088
- 国内价格
- 20+0.14397
- 200+0.11189
- 600+0.09407
- 2000+0.08338
- 10000+0.07161
- 20000+0.06653
