PTN102L6M5B6
PTN102L6M5B6
    PROSEMI(普罗森美)
    DFN2
    ESD Bidirectional 6V 6V 65A 6W
PTN102L6M5B6 数据手册
Low Capacitance Series ESD Protection PTN102L6M5B6 Features 65Watts peak pulse power (tp = 8/20μs) Pb Bidirectional configurations lead- free Solid-state silicon-avalanche technology Ro H S Low clamping voltage 2002/95/EC Low leakage current DFN1006-2 IEC COMPATIBILITY (EN61000-4) IEC 61000-4-2 ±25kV contact ±25kV air IEC 61000-4-4 (EFT) 40A (5/50ns) IEC 61000-4-5 (Lightning) 6A (8/20μs) Applications Mechanical Data Microprocessor based equipment DFN1006 package Personal Digital Assistants (PDA’s) Molding compound flammability rating: UL 94V-0 Notebooks, Desktops, and Servers Packaging: Tape and Reel Portable Instrumentation RoHS/WEEE Compliant Pagers Peripherals Schematic & PIN Configuration Bi-direction Specifications are subject to change without notice. ` PROSEMI Document No : PGES05NFC1706 1 of 4 www.prosemitech.com Low Capacitance Series ESD Protection PTN102L6M5B6 Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 65 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 6 A VESD 25 25 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 150 ℃ Storage Temperature Tstg -55 to + 150 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Reverse Breakdown Voltage Conditions Min Typical VRWM Max Units 5.0 V VBR IT=1mA 6.0 V Reverse Leakage Current IR VRWM=5V,T=25℃ 1 uA Clamping Voltage VC IPP=6A,tp=8/20μs 11 V Junction Capacitance Cj VR = 0V, f = 1MHz 8 pF 6 Electrical Parameters (TA = 25°C unless otherwise noted) Symbol IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I Parameter Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM V Breakdown Voltage @ IT Test Current Note:. 8/20μs pulse waveform. Specifications are subject to change without notice. ` PROSEMI Document No : PGES05NFC1706 2 of 4 www.prosemitech.com Low Capacitance Series ESD Protection PTN102L6M5B6 Typical Characteristics Figure 1: Peak Pulse Power vs. Pulse Time Figure 2: Power Derating Curve 10 110 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) 100 1 65w 8/20µs waveform 0.1 0.01 0.1 1 10 100 90 80 70 60 50 40 30 20 10 1,000 0 td – Pulse Duration - µs 0 25 50 75 100 125 150 Ambient Temperature - TA (℃) Fig.3 Pulse Waveform-8/20μs 120 Fig.4 Pulse Waveform-ESD(IEC61000-4-2) 100%IPP , 8μS 100% 90% 80 50%IPP, 20μS -t e 60 40 20 0 30ns Percent of IPP Percent of IPP 100 60ns 10% 0 5 10 15 20 25 30 0 Time (μs) tr 0.7 to 1ns 30 60 Fig.5 IEC61000-4-2 +8kV Contact Discharge Fig.6 IEC61000-4-2 -8kV Contact Discharge Trigger and Clamping Voltage(V) Trigger and Clamping Voltage(V) Time (ns) Time (ns) Specifications are subject to change without notice. ` PROSEMI Document No : PGES05NFC1706 Time (ns) 3 of 4 www.prosemitech.com Low Capacitance Series ESD Protection PTN102L6M5B6 Outline Drawing SYMBOL MILLIMETER MIN NOM MAX A 0.45 0.50 0.55 A1 0.00 0.02 0.05 b 0.45 0.50 0.55 c 0.12 0.15 0.18 D 0.95 1.00 1.05 e 0.65BSC E 0.55 L 0.20 L1 h 0.07 0.60 0.65 0.25 0.05REF 0.12 0.30 0.17 Marking PB Ordering information Order code PTN102L6M5B6 Specifications are subject to change without notice. ` PROSEMI Document No : PGES05NFC1706 Package DFN1006 Base qty 10K 4 of 4 Delivery mode Tape and reel www.prosemitech.com
PTN102L6M5B6 价格&库存
很抱歉,暂时无法提供与“PTN102L6M5B6”相匹配的价格&库存,您可以联系我们找货
