PTN102G30M5B20
PTN102G30M5B20
    PROSEMI(普罗森美)
    DFN2
    ESD Bidirectional 6V 18V 200A 30W
PTN102G30M5B20 数据手册
General Capacitance Series ESD Protection PTN102G30M5B20 Features 200Watts peak pulse power (tp = 8/20μs) Bidirectional configurations Solid-state silicon-avalanche technology Low clamping voltage Low leakage current Ro H S 2002/95/EC IEC COMPATIBILITY (EN61000-4) IEC 61000-4-2 ±30kV contact ±30kV air DFN1006 IEC 61000-4-4 (EFT) 40A (5/50ns) IEC 61000-4-5 (Lightning) 18A (8/20μs) Mechanical Characteristics Applications Microprocessor based equipment DFN1006 package Personal Digital Assistants (PDA’s) Molding compound flammability rating: Notebooks, Desktops, and Servers UL 94V-0 Portable Instrumentation Packaging: Tape and Reel RoHS/WEEE Compliant Schematic & PIN Configuration DFN1006 Specifications are subject to change without notice. C PROSEMI Document No:PG0967887242M 1 of 4 www.prosemitech.com General Capacitance Series ESD Protection PTN102G30M5B20 Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 200 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 18 A VESD 30 30 kV ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 125 ℃ Storage Temperature Tstg -55 to + 125 ℃ Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Reverse Breakdown Voltage Conditions Min Typical VRWM Max 5 VBR IT=1mA Reverse Leakage Current IR VRWM=5V,T=25℃ Peak Pulse Current IPP Clamping Voltage Junction Capacitance Units V 6 V 0.1 0.5 μA tp =8/20μs 18 A VC IPP=18A,tp=8/20μs 11.5 V Cj VR = 0V, f = 1MHz pF 30 Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I IPP Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM Breakdown Voltage @ IT VC VBR VRWM IT IR IR IT VRWM VBR VC V Test Current IPP Note:. 8/20μs pulse waveform. Specifications are subject to change without notice. C PROSEMI Document No:PG0967887242M 2 of 4 www.prosemitech.com General Capacitance Series ESD Protection PTN102G30M5B20 Typical Characteristics Fig.2 Pulse Derating Curve Fig.1 Peak Pulse Power Rating Curve % of Rated Power (PPP) or IPP Peak Pulse Power –PPP(KW) 10 200W 1 0.1 0.01 0.1 1 10 110 100 1000 100 80 60 40 20 0 0 Pulse Duration tp (μs) 100% 90% 50%IPP, 20μS -t e 40 20 0 5 10 15 125 150 60ns 10% 0 100 30ns Percent of IPP Percent of IPP 100 60 75 Fig.4 Pulse Waveform-ESD(IEC61000-4-2) 100%IPP , 8μS 80 50 Ambient Temperature—TA(℃) Fig.3 Pulse Waveform-8/20μs 120 25 20 25 30 0 30 60 Fig.5 IEC61000-4-2 +8kV Contact Discharge Fig.6 IEC61000-4-2 -8kV Contact Discharge Trigger and Clamping Voltage(V) Time (ns) Trigger and Clamping Voltage(V) Time (μs) tr 0.7 to 1ns Time (ns) Time (ns) Specifications are subject to change without notice. C PROSEMI Document No:PG0967887242M 3 of 4 www.prosemitech.com General Capacitance Series ESD Protection PTN102G30M5B20 Outline Drawing – DFN1006 SYMBOL MILLIMETER MIN NOM MAX A 0.45 0.50 0.55 A1 0.00 0.02 0.05 b 0.45 0.50 0.55 c 0.12 0.15 0.18 D 0.95 1.00 1.05 e 0.65BSC E 0.55 0.60 0.65 L 0.20 0.25 0.30 L1 h 0.07 0.05REF 0.12 0.17 Marking M5 Ordering information Order code PTN102G30M5B20 Package Base qty Delivery mode DFN1006 10k Tape and reel Specifications are subject to change without notice. C PROSEMI Document No:PG0967887242M 4 of 4 www.prosemitech.com
PTN102G30M5B20 价格&库存
很抱歉,暂时无法提供与“PTN102G30M5B20”相匹配的价格&库存,您可以联系我们找货
