PTN2510U036M5CA3
PTN2510U036M5CA3
    PROSEMI(普罗森美)
    DFN10_2.55X1.05MM
    ESD Bidirectional 6V 3V 30A 0.2W
PTN2510U036M5CA3 数据手册
Ultra-Low Capacitance Series ESD Protection PTN2510U036M5CA3 Features 30Watts peak pulse power (tp = 8/20μs) Unidirectional configurations Solid-state silicon-avalanche technology Low clamping voltage Low leakage current Ro H S Low capacitance (Cj=0.2pF typ. I/O to I/O) 2002/95/EC IEC COMPATIBILITY (EN61000-4) DFN2510-10L IEC 61000-4-2 ±12kV contact ±15kV air IEC 61000-4-4 (EFT) 40A (5/50ns) IEC 61000-4-5 (Lightning) 3A (8/20μs) Applications Mechanical Characteristics USB3.0, USB2.0,Ethernet Tiny DFN2510-10L(2.5mmx1.0mm) package HDMI 2.0, Displayport 1.3,eSATA Molding compound flammability rating: Unified Display interface UL 94V-0 Digital Visual Interface Packaging: Tape and Reel High speed serial interface RoHS/WEEE Compliant Schematic & PIN Configuration DFN2510-10L Specifications are subject to change without notice. C PROSEMI Document No:PG099154M 1 of 4 www.prosemitech.com Ultra-Low Capacitance Series ESD Protection PTN2510U036M5CA3 Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20µs ) PPP 30 Watts Peak Pulse Current ( tp =8/20µs ) (note1) IPP 3 A ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) VESD 15 12 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 125 ℃ Storage Temperature Tstg -55 to + 125 ℃ Electrical Characteristics Symbol Parameter Reverse Stand-Off Voltage Reverse Breakdown Voltage Conditions Typical Max Units 5.0 V 7.2 9.5 V 0.02 0.5 µA 3 A 11 V 15 V VRWM VBR IT=1mA Reverse Leakage Current IR VRWM=5V,T=25℃ Peak Pulse Current IPP tp =8/20µs Clamping Voltage VC IPP=3A,tp=8/20µs Clamping Voltage VCL IPP = 16 A; tp = TLP Junction Capacitance Min Cj 6.0 10 VR = 0V, f = 1MHz I/O to I/O 0.20 VR = 0V, f = 1MHz I/O to GND 0.36 pF Electrical Parameters (TA = 25°C unless otherwise noted) Parameter IPP MaximumReversePeak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I IPP WorkingPeak Reverse Voltage VC VBR Maximum Reverse Leakage Current @ VRWM VRWM IT IR I IT R VRWM VBR VC V Breakdown Voltage @ IT Test Current IPP Note:.8/20µs pulse waveform. Specifications are subject to change without notice. C PROSEMI Document No:PG099154M 2 of 4 www.prosemitech.com Ultra-Low Capacitance Series ESD Protection PTN2510U036M5CA3 Typical Characteristics Fig.1 Peak Pulse Power Rating Curve Fig.2 Pulse Derating Curve % of Rated Power (PPP) or IPP Peak Pulse Power –PPP(KW) 10 1 30W 0.1 0.01 0.1 1 10 100 Pulse Duration tp (μs) 40 20 0 0 25 50 75 100 125 Ambient Temperature—TA(℃) 100%IPP , 8μS 30ns 80 50%IPP, 20μS -t e 60 40 20 60ns 10% 5 0 10 15 20 25 30 tr 0.7 to 1ns 0 30 Time (μs) IPP (A) 150 100% 90% Percent of IPP Percent of IPP 60 Fig.4 Pulse Waveform-ESD(IEC61000-4-2) 100 0 80 1000 Fig.3 Pulse Waveform-8/20μs 120 110 100 60 Time (ns) Figure5: Positive Clamping voltage (TLP) Figure5: Negative Clamping voltage (TLP) 35 0 30 5 25 10 20 IPP (A) 15 Rdyn = 0.54 Ω 20 15 Rdyn = 0.54 Ω 10 25 5 30 0 -0.5 35 4.5 9.5 14.5 19.5 24.5 -24.5 -19.5 -14.5 -9.5 -4.5 0.5 VCL (V) VCL (V) Specifications are subject to change without notice. C PROSEMI Document No:PG099154M 3 of 4 www.prosemitech.com Ultra-Low Capacitance Series ESD Protection PTN2510U036M5CA3 Outline Drawing – DFN2510-10L Symbol Dimensions in millimeters Min Nom Max A 0.45 0.50 0.55 A1 - 0.02 0.05 A3 0.10 0.15 0.20 D 2.45 2.50 2.55 E 0.95 1.00 1.05 D1 0.35 0.40 0.45 b 0.15 0.20 0.25 e L 0.50BSC 0.35 0.40 0.45 Marking 05U Ordering information Order code Package Base qty Delivery mode PTN2510U036M5CA3 DFN2510-10L 3k Tape and reel Specifications are subject to change without notice. C PROSEMI Document No:PG099154M 4 of 4 www.prosemitech.com
PTN2510U036M5CA3 价格&库存
很抱歉,暂时无法提供与“PTN2510U036M5CA3”相匹配的价格&库存,您可以联系我们找货
