PTN062L3M5B4
PTN062L3M5B4
    PROSEMI(普罗森美)
    DFN2
    ESD Bidirectional 5.5V 3.5V 40A 2.7W
PTN062L3M5B4 数据手册
Low Capacitance Series ESD Protection PTN062L3M5B4 Features 40Watts peak pulse power (tp = 8/20μs) Tiny DFN0603 package Bidirectional configurations Solid-state silicon-avalanche technology Low clamping voltage Low leakage current Low capacitance (Cj=2.7pF typ.) Pb lead-free Ro H S 2002/95/EC DFN0603 IEC COMPATIBILITY (EN61000-4) IEC 61000-4-2 ±10kV contact ±15kV air IEC 61000-4-4 (EFT) 40A (5/50ns) IEC 61000-4-5 (Lightning) 3.5A (8/20μs) Mechanical Characteristics Applications Cell Phone Handsets and Accessories Microprocessor based equipment Personal Digital Assistants (PDA’s) Notebooks, Desktops, and Servers Portable Instrumentation DFN0603package Molding compound flammability rating: UL 94V-0 Packaging: Tape and Reel RoHS/ WEEE Compliant Schematic & PIN Configuration DFN0603 Specifications are subject to change without notice C PROSEMI Document No:PGA05349784M 1 of 4 www.prosemitech.com Low Capacitance Series ESD Protection PTN062L3M5B4 Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 40 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 3.5 A VESD 15 10 kV ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 125 ℃ Storage Temperature Tstg -55 to + 125 ℃ Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Conditions Min Typical VRWM Reverse Breakdown Voltage VBR 5.5 Trigger Voltage VT Reverse Leakage Current IR V RWM=5V,T=25℃ Clamping Voltage VC IPP=3.5A,tp=8/20μs Junction Capacitance Cj VR = 0V, f = 1MHz IT=1mA 6.5 12 0.1 2.7 Max Units 5.0 V 8.5 V 18 V 0.5 μA 11 V 3.5 pF Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter IPP MaximumReversePeak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT VT IPP WorkingPeak Reverse Voltage VT Maximum Reverse Leakage Current @ VRWM Breakdown Voltage @ IT VBR VC VRWM IRIT ITIR VRWM VC VBR VT Test Current IPP Trigger Voltage Note:.8/20μs pulse waveform. Specifications are subject to change without notice C PROSEMI Document No:PGA05349784M 2 of 4 www.prosemitech.com Low Capacitance Series ESD Protection PTN062L3M5B4 Typical Characteristics Figure 1: Peak Pulse Power vs. Pulse Time Figure 2: Power Derating Curve 40w 8/20µs waveform Figure3: Pulse Waveform Figure 4: Clamping Voltage vs.Ipp Specifications are subject to change without notice C PROSEMI Document No:PGA05349784M 3 of 4 www.prosemitech.com Low Capacitance Series ESD Protection PTN062L3M5B4 Outline Drawing – DFN0603 E b b Symbol L D h h e TOP VIEW BOTTOM VIEW A C Dimensions in millimeters Min Nom Max A 0.28 0.30 0.32 A1 0.00 0.02 0.05 C 0.05 0.10 0.15 D 0.55 0.60 0.65 E 0.25 0.30 0.35 b 0.14 0.19 0.24 L 0.20 0.25 0.30 h 0 0.05 0.10 A1 SIDE VIEW Marking F Ordering information Order code PTN062L3M5B4 Package DFN0603 Base qty 10K Delivery mode Tape and reel Specifications are subject to change without notice C PROSEMI Document No:PGA05349784M 4 of 4 www.prosemitech.com
PTN062L3M5B4 价格&库存
很抱歉,暂时无法提供与“PTN062L3M5B4”相匹配的价格&库存,您可以联系我们找货
