PTN062G15M3B18
PTN062G15M3B18
    PROSEMI(普罗森美)
    DFN2
    ESD Bidirectional 3.5V 12V 180A 15W
PTN062G15M3B18 数据手册
General Capacitance Series ESD Protection PTN062G15M3B18 Features 180Watts peak pulse power (TP = 8/20μs) Tiny DFN0603 package Bidirectional configurations Pb Solid-state silicon-avalanche technology lead-free Low clamping voltage Low leakage current Ro H S 2002/95/EC DFN0603 IEC Compatibility (EN61000-4) IEC 61000-4-2 ±30kV contact ±30kV air IEC 61000-4-4 (EFT) 40A (5/50ns) IEC 61000-4-5 (Lightning) 12A (8/20μs) Mechanical Data Applications DFN0603 package Cell Phone Handsets and Accessories Molding compound flammability rating: UL 94V-0 Microprocessor based equipment Packaging: Tape and Reel Personal Digital Assistants (PDA’s) RoHS/WEEE Compliant Notebooks, Desktops, and Servers Portable Instrumentation Schematic & PIN Configuration DFN0603 Specifications are subject to change without notice. C PROSEMI Document No:PS17010024M 1 of 4 www.prosemitech.com General Capacitance Series ESD Protection PTN062G15M3B18 Absolute Maximum Ratings Rating Symbol Value Unit PPPM 180 W IPP 12 A Peak Pulse Power ( TP =8/20μs ) Peak Pulse Current ( TP =8/20μs ) (note1) ESD per IEC 61000−4−2 (Air) 30 VESD ESD per IEC 61000−4−2 (Contact) kV 30 Lead Soldering Temperature TL 260(10seconds) °C Junction Temperature TJ −55 to +125 °C TSTG −55 to +125 °C Storage Temperature Range Electrical Characteristics Parameter Symbol Conditions Min Typical VRWM Reverse Stand-Off Voltage Max Units 3.3 V VBR IT=1mA Reverse Leakage Current IR VRWM=3.3V,T=25℃ Peak Pulse Current IPP TP =8/20μs 12 A Clamping Voltage VC IPP=12A,TP=8/20μs 15 V Junction Capacitance CJ VR = 0V, f = 1MHz 15 pF Reverse Breakdown Voltage 3.5 V μA 0.5 Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT IPP I Working Peak Reverse Voltage VCVBRVRWM Maximum Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IR IR IT VRWMVBR VC V Test Current IPP Note:. 8/20μs pulse waveform. Specifications are subject to change without notice. C PROSEMI Document No:PS17010024M 2 of 4 www.prosemitech.com General Capacitance Series ESD Protection PTN062G15M3B18 Typical Characteristics Figure 2: Power Derating Curve 10 Percent of Rated Power for IPP PPP – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time 180w 8/20µs waveform 1 0.1 0.01 0.1 1 100 10 110 100 90 80 70 60 50 40 30 20 10 0 1,000 0 TD – Pulse Duration - µs 70 e-1 60 50 40 30 td=Ipp/2 20 100 0 14 12 10 8 Test Waveform Paramters TR = 8µs TD = 20µs 6 4 0 5 10 15 20 25 30 C PROSEMI Document No:PS17010024M 0 2 4 6 8 10 12 Peak Pulse Current–IPP (A) Time (µs) Specifications are subject to change without notice. 150 16 2 10 0 125 18 Clamping Voltage–VC (V) Percent IPP 90 80 75 Figure 4: Clamping Voltage vs.Ipp Waveform Paramters TR = 8µs TD = 20µs 100 50 Ambient Temperature - TA (℃) Figure3: Pulse Waveform 110 25 3 of 4 www.prosemitech.com General Capacitance Series ESD Protection PTN062G15M3B18 Outline Drawing – DFN0603 Dimensions in millimeters Min Nom Max A 0.28 0.30 0.32 A1 0.00 0.02 0.05 C 0.05 0.10 0.15 D 0.55 0.60 0.65 E 0.25 0.30 0.35 b 0.14 0.19 0.24 L 0.20 0.25 0.30 h 0.00 0.05 0.10 E b b L h D Symbol h e BOTTOM VIEW TOP VIEW A C A1 SIDE VIEW Marking Information B Ordering Information Order code PTN062G15M3B18 Package Specifications are subject to change without notice. C PROSEMI Document No:PS17010024M Base qty DFN0603 10K 4 of 4 Delivery mode Tape and reel www.prosemitech.com
PTN062G15M3B18 价格&库存
很抱歉,暂时无法提供与“PTN062G15M3B18”相匹配的价格&库存,您可以联系我们找货
