General Capacitance Series
ESD Protection
PTD522G13M5B10
Features
100Watts peak pulse power (tp = 8/20μs)
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Ro H S
2002/95/EC
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 ±25kV contact ±25kV air
SOD-523
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 10A (8/20μs)
Mechanical Characteristics
Applications
Microprocessor based equipment
SOD523 package
Personal Digital Assistants (PDA’s)
Molding compound flammability rating:
Notebooks, Desktops, and Servers
UL 94V-0
Portable Instrumentation
Packaging: Tape and Reel
Pagers Peripherals
RoHS/WEEE Compliant
Schematic & PIN Configuration
SOD-523
Specifications are subject to change without notice.
C PROSEMI Document No:PG0217763452M
1 of 4
www.prosemitech.com
ESD Protection
PTD522G13M5B10
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
100
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
10
A
VESD
25
25
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 150
Storage Temperature
Tstg
-55 to + 150
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
Max
Units
5.0
V
6.0
VBR
IT=1mA
V
Reverse Leakage Current
IR
VRWM=5.0V,T=25℃
1
uA
Clamping Voltage
VC
IPP=10A,tp=8/20μs
10
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
15
pF
13
Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
VC VBR
VRWM
IT
IR
I
IT R
VRWM
VBR VC
V
Breakdown Voltage @ IT
Test Current
IPP
Note:. 8/20μs pulse waveform.
C PROSEMI
2 of 4
www.prosemitech.com
ESD Protection
PTD522G13M5B10
Typical Characteristics
10
1
100w 8/20μs waveform
0.1
0.01
0.1
1
10
100
Figure 2: Power Derating Curve
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
100
90
80
70
60
50
40
30
1,000
td – Pulse Duration - µs
50
75
100
125
150
Ambient Temperature - TA (℃)
Figure3: Pulse Waveform
110
80
70
9
Clamping Voltage–VC (V)
90
Ipp
10
Waveform
Paramters
tr=8µs
td=20µs
100
Percent
Figure 4: Clamping Voltage vs.Ipp
e-1
60
50
40
30
td=Ipp/2
Test
Waveform
Paramters
tr=8µs
td=20µs
8
7
6
5
4
3
2
10
10
15
Time (µs)
30
4
6
8
10
Peak Pulse Current–IPP (A)
3 of 4
www.prosemitech.com
ESD Protection
PTD522G13M5B10
Outline Drawing
D
-XDIMENSIONS
-YSYMBOL
E
1
2
A
b
C
D
E
HE
L
b 2x
0.08 (0.0032) X
Y
A
MILLIMETER
MIN
0.50
0.25
0.07
1.10
0.70
1.50
0.15
MAX
0.70
0.35
0.20
1.30
0.90
1.70
0.25
INCHES
MIN
0.020
0.010
0.0028
0.043
0.028
0.059
0.006
MAX
0.028
0.014
0.0079
0.051
0.035
0.067
0.010
C
L
HE
Marking
1
5C.
2
Ordering information
Order code
PTD522G13M5B10
C PROSEMI
Package
SOD523
Base qty
5K
4 of 4
Delivery mode
Tape and reel
www.prosemitech.com
很抱歉,暂时无法提供与“PTD522G13M5B10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18933
- 200+0.14850
- 600+0.12582
- 5000+0.10768
- 10000+0.09580
- 20000+0.08954
