PTN162H750S5C180
PTN162H750S5C180
    PROSEMI(普罗森美)
    DFN2
    ESD Unidirectional 6V 135V 1800A 750W
PTN162H750S5C180 数据手册
High Capacitance Series ESD Protection PTN162H750S5C180 Features Ultra small package: 1.6x1.0x0.5mm Protects one date or power line Working voltage: 5V 2-pin leadless package Ro H S RoHS compliant 2002/95/EC DFN1610 IEC COMPATIBILITY (EN61000-4) IEC 61000-4-2 ±30kV contact ±30kV air IEC 61000-4-5 (Lightning) 135A (8/20μs) Mechanical Characteristics Applications Mobile Phones Package: DFN1610-2 (1.6x1.0x0.5mm) Battery Protection Case Material: “Green” Molding Compound. Power Line Protection UL Flammability Classification Rating 94V-0 Vbat pin for Mobile Devices Moisture Sensitivity: Level 3 per J-STD-020 Hand Held Portable Applications Terminal Connections: See Diagram Below Schematic & PIN Configuration DFN1610 Specifications are subject to change without notice. C PROSEMI Document No:PG99715422S 1 of 4  www.prosemitech.com High Capacitance Series ESD Protection PTN162H750S5C180 Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 1800 Watts Peak Pulse Current ( tp =8/20μs ) Ipp 135 A ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) VESD 30 30 kV Junction Temperature TJ -55 to + 125 ℃ Storage Temperature Tstg -55 to + 150 ℃ Electrical Characteristics Parameter Test Condition Reverse Working Voltage Symbol Min Typ VRWM Breakdown Voltage IT = 1mA VBR Reverse Leakage Current VRWM = 5V IR Forward Voltage IF=10mA VF Clamping Voltage IPP = 10A (8 x 20µs pulse) Clamping Voltage Junction Capacitance Max Unit 5 V 6 V 1 uA 1.2 V VC 8.5 V IPP = 120A (8 x 20µs pulse) VC 15 V VR = 0V, f = 1MHz CJ 750 pF 1.0 Electrical Parameters (TA = 25°C unless otherwise noted) Symbol IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I Parameter IF Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM Breakdown Voltage @ IT VC VBR VRWM IR VF IT V Test Current IPP Note:. 8/20μs pulse waveform. Specifications are subject to change without notice. C PROSEMI Document No:PG99715422S 2 of 4 www.prosemitech.com High Capacitance Series ESD Protection PTN162H750S5C180 Typical Characteristics Specifications are subject to change without notice. C PROSEMI Document No:PG99715422S 3 of 4 www.prosemitech.com High Capacitance Series ESD Protection PTN162H750S5C180 Outline Drawing DIMENSIONS SYM MILLIMETERS NOM MAX 0.50 0.55 INCHES MIN NOM MAX 0.018 0.020 0.022 A MIN 0.45 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.75 0.80 0.85 0.030 0.032 0.034 c 0.10 0.15 0.20 0.004 0.006 0.007 D 1.55 1.60 1.65 0.062 0.064 0.066 e 1.10 BSC 0.044 BSC E 0.95 1.00 1.05 0.038 0.040 0.042 L 0.35 0.40 0.45 0.014 0.016 0.018 h 0.15 0.20 0.25 0.006 0.008 0.010 Suggested Land Pattern SYM DIMENSIONS MILLIMETERS INCHES X 1.00 0.040 Y1 0.62 0.025 Y2 0.60 0.024 Y3 1.22 0.049 Z 1.85 0.074 Marking 4.5P Pin Style: 1. Cathode 2. Anode Ordering information Order code PTN162H750S5C180 Package DFN1610 Base qty 3k Delivery mode Tape and reel Specifications are subject to change without notice. C PROSEMI Document No:PG99715422S 4 of 4 www.prosemitech.com
PTN162H750S5C180 价格&库存
很抱歉,暂时无法提供与“PTN162H750S5C180”相匹配的价格&库存,您可以联系我们找货
