PTD322H68S15B35
PTD322H68S15B35
    PROSEMI(普罗森美)
    SOD-323
    ESD Bidirectional 16.7V 10V 350A 68W
PTD322H68S15B35 数据手册
High Capacitance Series ESD Protection PTD322HXXXB35 Features 350W peak pulse power (8/20us) Protects one data or power line Low leakage: nA level Stand−off Voltage: 3.3 V ~ 36 V Low clamping voltage Ro H S RoHS Compliant 2002/95/EC IEC COMPATIBILITY (EN61000-4) SOD-323 IEC 61000-4-2 ±30kV (contact) ±30kV (air) IEC61000-4-4 (EFT) 40A (5/50ns) Mechanical Data Applications Package: SOD-323 Cell Phone Handsets and Accessories Case Material: “Green” Molding Compound. Microprocessor based equipment UL Flammability Classification Rating 94V-0 Personal Digital Assistants (PDA’s) Moisture Sensitivity: Level 3 per J-STD-020 Notebooks, Desktops, and Servers Terminal Connections: See Diagram Below Portable Instrumentation Networking and Telecom Serial and Parallel Ports. Peripherals Schematic & PIN Configuration SOD-323 Specifications are subject to change without notice. C PROSEMI Document No:PG75117152S 1 of 8 www.prosemitech.com High Capacitance Series ESD Protection PTD322HXXXB35 Absolute Maximum Rating PTD322H450S3B35 Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 20 A ESD per IEC 61000−4−2 (Air) VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range ±30 ±30 kV TJ −55 to +125 °C Tstg −55 to +150 °C Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 17 A Storage Temperature Range PTD322H200S5B35 Parameter ESD per IEC 61000−4−2 (Air) VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range ±30 ±30 kV TJ −55 to +125 °C Tstg −55 to +150 °C Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 11 A Storage Temperature Range PTD322H75S12B35 Parameter ESD per IEC 61000−4−2 (Air) VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range ±30 ±30 kV TJ −55 to +125 °C Tstg −55 to +150 °C Specifications are subject to change without notice. C PROSEMI Document No:PG75117152S 2 of 8 www.prosemitech. com High Capacitance Series ESD Protection PTD322HXXXB35 Absolute Maximum Rating PTD322H68S15B35 Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 10 A ESD per IEC 61000−4−2 (Air) VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range ±30 ±30 kV TJ −55 to +125 °C Tstg −55 to +150 °C Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 7 A Storage Temperature Range PTD322H57S24B35 Parameter ESD per IEC 61000−4−2 (Air) VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range ±30 ±30 kV TJ −55 to +125 °C Tstg −55 to +150 °C Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 5 A Storage Temperature Range PTD322H35S36B35 Parameter ESD per IEC 61000−4−2 (Air) VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range ±30 ±30 kV TJ −55 to +125 °C Tstg −55 to +150 °C Specifications are subject to change without notice. C PROSEMI Document No:PG75117152S 3 of 8 www.prosemitech. com High Capacitance Series ESD Protection PTD322HXXXB35 Absolute Maximum Rating PTD322H450S3B35 Parameter Symbol Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Clamping Voltage VC Junction Capacitance CJ Min Typ Max Unit 3.3 V 4.0 40 7 19 450 Test Condition V IT = 1mA uA VRWM = 3.3V V IPP = 1A (8 x 20uS pulse) V IPP = 20A (8 x 20uS pulse) pF VR = 0V, f = 1MHz Max Unit Test Condition 5 V PTD322H200S5B35 Parameter Symbol Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Clamping Voltage VC Junction Capacitance CJ Min Typ 6.2 10 9.8 21 V IT = 1mA uA VRWM = 5V V IPP = 1A (8 x 20uS pulse) V IPP = 17A (8 x 20uS pulse) pF VR = 0V, f = 1MHz Max Unit Test Condition 12 V 200 PTD322H75S12B35 Parameter Symbol Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Clamping Voltage VC Junction Capacitance CJ Min Typ 13.3 1 19 32 75 V IT = 1mA uA VRWM = 12V V IPP = 1A (8 x 20uS pulse) V IPP =11A (8 x 20uS pulse) pF VR = 0V, f = 1MHz Specifications are subject to change without notice. C PROSEMI Document No:PG75117152S 4 of 8 www.prosemitech. com High Capacitance Series ESD Protection PTD322HXXXB35 Absolute Maximum Rating PTD322H68S15B35 Parameter Symbol Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Clamping Voltage VC Junction Capacitance CJ Min Typ Max Unit 15 V 16.7 1 24 38 68 Test Condition V IT = 1mA uA VRWM =15V V IPP = 1A (8 x 20uS pulse) V IPP = 10A (8 x 20uS pulse) pF VR = 0V, f = 1MHz Max Unit Test Condition 24 V PTD322H57S24B35 Parameter Symbol Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Clamping Voltage VC Junction Capacitance CJ Min Typ 26.7 1 43 52 V IT = 1mA uA VRWM = 24V V IPP = 1A (8 x 20uS pulse) V IPP =7A (8 x 20uS pulse) pF VR = 0V, f = 1MHz Max Unit Test Condition 36 V 57 PTD322H35S36B35 Parameter Symbol Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Clamping Voltage VC Junction Capacitance CJ Min Typ 40 1 63 80 35 V IT = 1mA uA VRWM =36V V IPP = 1A (8 x 20uS pulse) V IPP = 5A (8 x 20uS pulse) pF VR = 0V, f = 1MHz Specifications are subject to change without notice. C PROSEMI Document No:PG75117152S 5 of 8 www.prosemitech. com High Capacitance Series ESD Protection PTD322HXXXB35 Typical Performance Characteristics (TA=25°C unless otherwise Specified) Specifications are subject to change without notice. C PROSEMI Document No:PG75117152S 6 of 8 www.prosemitech. com High Capacitance Series ESD Protection PTD322HXXXB35 Pb-Free assembly (see as bellow) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Specifications are subject to change without notice. C PROSEMI Document No:PG75117152S 7 of 8 www.prosemitech. com High Capacitance Series ESD Protection PTD322HXXXB35 Outline Drawing Ordering information Order code PTD322HXXXB35 Package SOD323 Base qty 3K Delivery mode Tape and reel Specifications are subject to change without notice. C PROSEMI Document No:PG75117152S 8 of 8 www.prosemitech. com
PTD322H68S15B35 价格&库存
很抱歉,暂时无法提供与“PTD322H68S15B35”相匹配的价格&库存,您可以联系我们找货
