Ultra-Low Capacitance Series
ESD Protection
PTN102U04M5B6
Features
60Watts peak pulse power (tp = 8/20μs) Tiny
DFN1006 package
Bidirectional configurations
Solid-state silicon-avalanche technology Low
clamping voltage
Low leakage current
Low capacitance (Cj=0.4pF typ. IO to IO)
Pb
lead-free
RoHS
2002/95/EC
DFN1006
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 ±20kV contact ±20kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 3.5A (8/20μs)
Mechanical Characteristics
Applications
DFN1006 package
Molding compound flammability rating:
UL 94V-0
Packaging: Tape and Reel
RoHS/WEEE Compliant
Cell Phone Handsets and Accessories
Microprocessor based equipment
Personal Digital Assistants (PDA’s)
Notebooks, Desktops, and Servers
Portable Instrumentation
Schematic & PIN Configuration
DFN1006
Specifications are subject to change without notice
C PROSEMI
Document No:PGA0892315M
1 of 4
www.prosemitech. com
ESD Protection
PTN102U04M5B6
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
60
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
3.5
A
VESD
kV
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=5V,T=25℃
Peak Pulse Current
IPP
Clamping Voltage
Junction Capacitance
6.0
Max
Units
5.0
V
8.0
V
0.1
0.5
μA
tp =8/20μs
3.5
A
VC
IPP=3.5A,tp=8/20μs
15
V
Cj
IO to IO
VR = 0V, f = 1MHz
0.5
pF
0.4
Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
VC VBR
VRWM
IT
IR
I
IT R
VRWM
VBR VC
V
Breakdown Voltage @ IT
Test Current
IPP
Note:. 8/20μs pulse waveform.
C PROSEMI
2 of 4
www.prosemitech.com
ESD Protection
PTN102U04M5B6
Typical Characteristics
Figure 2: Power Derating Curve
110
10
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
1
60w 8/20µswaveform
0.1
0.01
0.1
1
10
90
80
70
60
50
40
30
100
100
td – Pulse Duration - µs
Figure3: Pulse Waveform
80
Ipp
125
150
18
Clamping Voltage–VC (V)
90
Percent
100
Waveform
Paramters
tr=8µs
td=20µs
100
70
e-1
50
40
30
td=Ipp/2
14
12
Test
Waveform
Paramters
tr=8µs
td=20µs
10
8
6
4
10
10
15
30
Time (µs)
IPP
(A)
75
Figure 4: Clamping Voltage vs.Ipp
110
60
50
Ambient Temperature - TA (℃)
1
2
3
4
5
6
Peak Pulse Current–IPP (A)
Figure5: Positive Clamping voltage (TLP)
Figure5: Negative Clamping voltage (TLP)
35
5
25
10
IPP
(A)
15
Rdyn = 0.55 Ω
Rdyn = 0.55 Ω
10
25
5
30
35
4.5
9.5
14.5
19.5
24.5
VCL (V)
-24.5
-19.5
-14.5
-9.5
-4.5
0.5
VCL (V)
C PROSEMI
3 of 4
ESD Protection
PTN102U04M5B6
Outline Drawing – DFN1006
SYMBOL
MILLIMETER
MIN
NOM
MAX
A
0.45
0.50
0.55
A1
0.00
0.02
0.05
b
0.45
0.50
0.55
c
0.12
0.15
0.18
D
0.95
1.00
1.05
e
0.65BSC
E
0.55
0.60
0.65
L
0.20
0.25
0.30
0.05REF
L1
h
0.07
0.12
0.17
Marking
5T
Ordering information
Order code
Package
Base qty
Delivery mode
PTN102U04M5B6
DFN1006
10k
Tape and reel
C PROSEMI
4 of 4
很抱歉,暂时无法提供与“PTN102U04M5B6”相匹配的价格&库存,您可以联系我们找货
