PTD322H120M5C36
PTD322H120M5C36
    PROSEMI(普罗森美)
    SOD-323
    单向ESD 5V截止 峰值浪涌电流:20A@8/20US
PTD322H120M5C36 数据手册
High Capacitance Series ESD Protection PTD322H120M5C36 Features 360Watts peak pulse power (tp = 8/20μs) Unidirectional configurations Solid-state silicon-avalanche technology Low clamping voltage Low leakage current Ro H S 2002/95/EC IEC COMPATIBILITY (EN61000-4) IEC 61000-4-2 ±30kV contact ±30kV air IEC 61000-4-4 (EFT) 40A (5/50ns) SOD-323 IEC 61000-4-5 (Lightning) 20A (8/20μs) Mechanical Characteristics Applications USB Vbus, SOD323 package Power Line Molding compound flammability rating: Power management UL 94V-0 Packaging: Tape and Reel RoHS/WEEE Compliant Schematic & PIN Configuration SOD-323 Specifications are subject to change without notice. C PROSEMI Document No:PG0201701F2M 1 of 4 www.prosemitech.com High Capacitance Series ESD Protection PTD322H120M5C36 Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 360 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 20 A VESD 30 30 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 150 ℃ Storage Temperature Tstg -55 to + 150 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Reverse Breakdown Voltage Conditions Min Typical VRWM VBR IT=1mA Reverse Leakage Current IR VRWM=5V,T=25℃ Clamping Voltage VC IPP=20A,tp=8/20μs Junction Capacitance Cj VR = 0V, f = 1MHz Max Units 5.0 V 6.0 V 1 uA 17 19 V 120 135 pF Electrical Parameters (TA = 25°C unless otherwise noted) Symbol IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I Parameter IF Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM Breakdown Voltage @ IT VC VBR VRWM IR VF IT V Test Current IPP Note:. 8/20μs pulse waveform. Specifications are subject to change without notice. C PROSEMI Document No:PG0201701F2M 2 of 4 www.prosemitech.com High Capacitance Series ESD Protection PTD322H120M5C36 Typical Characteristics 10k 360w 8/20μs waveform 1000 100 10 0.1 1 10 100 Figure 2: Power Derating Curve Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(W) Figure 1: Peak Pulse Power vs. Pulse Time 110 100 90 80 70 60 50 40 30 20 10 0 1,000 td – Pulse Duration - µs 100 125 150 Test Waveform Paramters tr=8µs td=20µs 40 Clamping Voltage–VC (V) 90 80 Ipp 75 45 Waveform Paramters tr=8µs td=20µs 100 Percent 50 Figure 4: Clamping Voltage vs.Ipp 110 70 e 25 Ambient Temperature - TA (℃) Figure3: Pulse Waveform 60 0 -1 50 40 30 td=Ipp/2 20 35 30 25 20 15 10 5 10 0 0 5 10 15 20 25 0 30 Time (µs) Document No:PG0201701F2M 10 15 25 Peak Pulse Current–IPP (A) Specifications are subject to change without notice. C PROSEMI 5 3 of 4 www.prosemitech.com High Capacitance Series ESD Protection PTD322H120M5C36 Outline Drawing C A DIMENSIONS SYMBOL A E B 1 2 MILLIMETER MIN 1.600 H L L1 MAX 0.071 B 0.250 0.350 0.010 0.014 2.500 2.700 0.098 0.106 1.000 0.039 E 1.200 1.400 0.047 0.055 F 0.080 0.150 0.003 0.006 L F MIN 0.063 C D D MAX 1.800 INCHES 0.475 REF 0.019REF L1 0.250 0.400 0.010 0.016 H 0.000 0.100 0.000 0.004 Marking 1 05W 2 Pin Style: 1. Cathode 2. Anode Ordering information Order code PTD322H120M5C36 Package SOD323 Base qty 3K Specifications are subject to change without notice. C PROSEMI Document No:PG0201701F2M 4 of 4 Delivery mode Tape and reel www.prosemitech.com
PTD322H120M5C36 价格&库存
很抱歉,暂时无法提供与“PTD322H120M5C36”相匹配的价格&库存,您可以联系我们找货
PTD322H120M5C36
    • 10+0.37120
    • 100+0.29344
    • 300+0.25456
    • 3000+0.22540
    • 6000+0.20207
    • 9000+0.19041
