P2300SB
P2300SB
    PROSEMI(普罗森美)
    SMB(DO-214AA)
    190V 35PF 100A
P2300SB 数据手册
Over-voltage Protection Thyristor DO-214AA PxxxSx Series Description DO-214AA PxxxxSx series are designed to protect baseband equipment such as modems, line cards, CPE and DSL from damaging overvoltage transients. The PSMB series provides a surface mount solution that enables equipment to comply with global regulatory standards. HALOGEN HF FRE E Pb lead-free DO-214AA/SMB Features RoHS Bi-directional crowbar transient voltage protection High surge capability High off-state impedance, Low leakage current Short-circuit failure mode Low on-state voltage 2002/95/EC Bi-directional Applications Central office switching equipment, Analog and digital linecards. Customer Premises Equipment (CPE) such as phones, fax machines, modems, POS terminals, PBX systems and caller ID adjunct boxes. Data lines and security systems. CATV line amplifiers and power inserters. Sprinkler systems. Primary protection modules including Main Distribution Frames, building entrance equipment and station protection modules. Access network equipment such as remote terminals, line repeaters, multiplexers, cross-connects,WAN equipment,Network Interface Devices. Electrical Characteristics Part Number Marking VDRM @lDRM=5µA Vmin VBO @100V/µs Vmax IH mA min IBO mA max IT A max P0080SA P0300SA P0640SA P0720SA P0900SA P1100SA P1300SA P1500SA P1800SA P2000SA P2300SA P2600SA P3100SA P3500SA P4000SA P4200SA P008A P03A P06A P07A P09A P11A P13A P15A P18A P20A P23A P26A P31A P35A P40A P42A 6 25 58 65 75 90 120 140 170 180 190 220 275 320 360 400 25 40 77 88 98 130 160 180 220 240 260 300 350 400 460 540 50 50 150 150 150 150 150 150 150 150 150 150 150 150 150 150 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 Specifications are subject to change without notice. 、 C PROSEMI Document No:PG00X0S1609 1 of 4 VT @I=T 2.2 Amps V max 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 Capacitance @1MHz pF min pF max 25 15 40 35 25 30 25 25 25 20 25 20 20 20 20 20 150 140 60 60 55 50 45 40 35 35 35 35 35 35 35 35 www.prosemitech.com Over-voltage Protection Thyristor DO-214AA PxxxSx Series Electrical Characteristics Part Number Marking VDRM @lDRM=5µA V min VBO @100V/µs V max IH mA min IBO mA max IT A max VT @IT=2.2 Amps V max P008B P03B P06B P07B P09B P11B P13B P15B P18B P20B P23B P26B P31B P35B P40B P42B P008C P03C P06C P07C P09C P11C P13C P15C P18C P20C P23C P26C P31C P35C P40C P42C 6 25 58 65 75 90 120 140 170 180 190 220 275 320 360 400 6 25 58 65 75 90 120 140 170 180 190 220 275 320 360 400 25 40 77 88 98 130 160 180 220 240 260 300 350 400 460 540 25 40 77 88 98 130 160 180 220 240 260 300 350 400 460 540 50 50 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 800 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 2.2 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 P0080SB P0300SB P0640SB P0720SB P0900SB P1100SB P1300SB P1500SB P1800SB P2000SB P2300SB P2600SB P3100SB P3500SB P4000SB P4200SB P0080SC P0300SC P0640SC P0720SC P0900SC P1100SC P1300SC P1500SC P1800SC P2000SC P2300SC P2600SC P3100SC P3500SC P4000SC P4200SC Capacitance @1MHz pF min pF max 25 15 40 35 25 30 25 25 25 20 25 20 20 20 20 20 25 15 40 35 25 30 25 25 25 20 25 20 20 20 20 20 150 140 60 60 55 50 45 40 35 60 35 35 35 35 35 35 150 140 60 60 55 50 45 40 35 35 35 35 35 35 35 40 Surge Ratings IPP Series 2x10 A min 8x20 A min 10x160 A min 10x560 A min A 150 150 90 50 50 10x700 A min 10x1000 A min ITSM 60 Hz A min di/dt Amps/µs max 45 20 500 B 250 250 150 100 100 80 30 500 C 500 400 200 150 150 100 50 500 Notes: Peak pulse current rating (IPP) is repetitive and guaranteed for the life of the product. IPP ratings applicable over temperature range of -40ºC to +85ºC The device must initially be in thermal equilibrium with -40°C < TJ < +150°C Specifications are subject to change without notice. 、 C PROSEMI Document No:PG00X0S1609 2 of 4 www.prosemitech.com Over-voltage Protection Thyristor DO-214AA PxxxSx Series Thermal Considerations Package Symbol Parameter Value Unit DO-214AA/SMB TJ Operating Junction Temperature Range -40 to +150 °C TS Storage Temperature Range -40 to +150 °C R0JA Thermal Resistance: Junction to Ambient 90 °C/W Electrical Characteristics Curves t r x td Pulse Waveform V-I Characteristics IPP – Peak Pulse Current – %IPP +I IT I BO IH IDRM -V +V VT VDRM VBO 100 Waveform = tr x td 50 Half Value 0 0 -I Normalized VBO Change versus Junction Temperature tr = rise time to peak value td = decay time to half value Peak Value td tr t – Time (µs) Normalized DC Holding Current versus Case Temperature 8 6 25 °C 4 2 IH (TC = 25ºC) IH 10 Ratio of Percent of VS Change – % 2.0 14 12 0 -4 -6 1.8 1.6 1.4 1.0 0.8 0.6 0.4 -8 -40 -20 0 -40 20 40 60 80 100 120 140 160 Junction Temperature (TJ) – °C Specifications are subject to change without notice. 、 C PROSEMI Document No:PG00X0S1609 25°C 1.2 -20 0 20 40 60 80 100 120 140 160 Case Temperature (TC) - ºC 3 of 4 www.prosemitech.com Over-voltage Protection Thyristor DO-214AA PxxxSx Series Dimensions DO-214AA(SMB) C A Dimensions B H D F E Inches Millimeters Min Max Min Max A 0.071 B 0.160 0.086 1.800 2.200 0.183 4.050 4.650 C 0.130 0.155 3.300 3.940 D 0.081 0.096 2.050 2.450 E 0.030 0.060 0.760 1.520 F - 0.008 - 0.203 G G 0.200 0.220 5.080 5.590 K H 0.006 0.012 0.152 0.305 L I I 0.089 - 2.260 - K - 0.110 - 2.790 L 0.087 - 2.200 - Part Numbering System P xxxx S x IPP Rating (A: 50A; B: 100A; C: 150A) S: DO-214AA/SMB Package Typical Breakdown Voltage TSS Product Symbol Packaging Series PxxxxSx Series Description Quantity DO-214AA 2500 Specifications are subject to change without notice. 、 C PROSEMI Document No:PG00X0S1609 Industry Standard EIA STD RS-481 4 of 4 www.prosemitech.com
P2300SB 价格&库存
很抱歉,暂时无法提供与“P2300SB”相匹配的价格&库存,您可以联系我们找货
