1206TD-10AS
1206TD-10AS
    PROSEMI(普罗森美)
    一次性保险丝(熔断) 10A 32V
1206TD-10AS 数据手册
Circuit Protection 1206TD AS Time Delay | 0.126x0.064 inch Thick Film Chip Fuses 1206TD Series are the fuses set the industry standard for performance, reliability and quality. The solder-free design provides excellent on-off and temperature cycling characteristics during use and also makes our SMD fuses more heat and shock tolerant than typical subminiature fuses. Features Q Compatible with reflow and wave solder Ceramic and glass construction L Halogen free, lead free and RoHS compliant Excellent environmental integrity One time positive disconnect AEC-Q200 Automotive Grade Certified Electrical Characteristics Appications Flat panel displays and televisions Automotive infotainment and ECU Computer servers Portable electronics Mobile device chargers Amp Rating % of Amp Rating Opening Time 4.5~40A 4.5~5A 4.5~5A 6~40A 4.5~5A 6~40A 100% 250% 300% 350% 4 Hours Min. 5 Seconds Max. 0.1sec~3sec 5 Seconds Max. 0.2ms~20ms 0.2ms~10ms 1000% Power Battery Packs Specifications Part Number Ampere Rating (A) 1206TD-4.5AS 1206TD-5AS 1206TD-6AS 1206TD-7AS 1206TD-8AS 1206TD-10AS 1206TD-12AS 1206TD-15AS 1206TD-20AS 1206TD-25AS 1206TD-30AS 4.50 5.00 6.00 7.00 8.00 10.0 12.0 15.0 20.0 25.0 30.0 1206TD-40AS 40.0 Voltage Rating Interrupting Rating 72Vdc @ 50A 63Vdc @ 50A 32Vdc @ 50A 48Vdc @ 150A 32Vdc @ 150A 36Vdc @ 150A 32Vdc @ 150A 35Vdc @ 200A 26Vdc @ 300A Typical Cold Resistance (Ohms) Typical Melting I 2 t (A 2 Sec) Typical Voltage Drop (V) Marking Code 0.022 0.019 0.015 0.010 0.007 0.0065 0.005 0.0033 0.0027 0.0022 0.0019 3.7 5 12.2 15 17 23 41 44 52 60 100 0.17 0.142 0.138 0.12 0.097 0.099 0.087 0.075 0.089 0.091 0.090 X T F 7 V U W Y Q L Z 0.0009 163 0.096 XL DC Interrupting Rating - Measured at designated voltage, time constant < 50 microseconds. DC Cold Resistance are measured at
1206TD-10AS 价格&库存
很抱歉,暂时无法提供与“1206TD-10AS”相匹配的价格&库存,您可以联系我们找货
1206TD-10AS
  • 5+0.69578
  • 50+0.55898
  • 600+0.43928
  • 1200+0.43269
库存:940
1206TD-10AS
  • 5+0.79100
  • 50+0.63548
  • 150+0.55772
  • 500+0.49940
  • 3000+0.40414
  • 6000+0.38070
库存:2297
