Circuit Protection
1206TD AS
Time Delay | 0.126x0.064 inch
Thick Film Chip Fuses
1206TD Series are the fuses set the industry standard for performance,
reliability and quality. The solder-free design provides excellent on-off
and temperature cycling characteristics during use and also makes our
SMD fuses more heat and shock tolerant than typical subminiature fuses.
Features
Q
Compatible with reflow and wave solder
Ceramic and glass construction
L
Halogen free, lead free and RoHS compliant
Excellent environmental integrity
One time positive disconnect
AEC-Q200 Automotive Grade Certified
Electrical Characteristics
Appications
Flat panel displays and televisions
Automotive infotainment and ECU
Computer servers
Portable electronics
Mobile device chargers
Amp Rating
% of Amp Rating
Opening Time
4.5~40A
4.5~5A
4.5~5A
6~40A
4.5~5A
6~40A
100%
250%
300%
350%
4 Hours Min.
5 Seconds Max.
0.1sec~3sec
5 Seconds Max.
0.2ms~20ms
0.2ms~10ms
1000%
Power Battery Packs
Specifications
Part
Number
Ampere
Rating
(A)
1206TD-4.5AS
1206TD-5AS
1206TD-6AS
1206TD-7AS
1206TD-8AS
1206TD-10AS
1206TD-12AS
1206TD-15AS
1206TD-20AS
1206TD-25AS
1206TD-30AS
4.50
5.00
6.00
7.00
8.00
10.0
12.0
15.0
20.0
25.0
30.0
1206TD-40AS
40.0
Voltage
Rating
Interrupting
Rating
72Vdc @ 50A
63Vdc @ 50A
32Vdc @ 50A
48Vdc @ 150A
32Vdc @ 150A
36Vdc @ 150A
32Vdc @ 150A
35Vdc @ 200A
26Vdc @ 300A
Typical Cold
Resistance
(Ohms)
Typical
Melting I 2 t
(A 2 Sec)
Typical
Voltage
Drop (V)
Marking
Code
0.022
0.019
0.015
0.010
0.007
0.0065
0.005
0.0033
0.0027
0.0022
0.0019
3.7
5
12.2
15
17
23
41
44
52
60
100
0.17
0.142
0.138
0.12
0.097
0.099
0.087
0.075
0.089
0.091
0.090
X
T
F
7
V
U
W
Y
Q
L
Z
0.0009
163
0.096
XL
DC Interrupting Rating - Measured at designated voltage, time constant < 50 microseconds.
DC Cold Resistance are measured at
很抱歉,暂时无法提供与“1206TD-20AS”相匹配的价格&库存,您可以联系我们找货
