Circuit Protection
1206TD Series
Time Delay | 0.126x0.064 inch
Thick Film Chip Fuses
1206TD Series are the fuses set the industry standard for performance,
reliability and quality. The solder-free design provides excellent on-off and
temperature cycling characteristics during use and also makes our SMD fuses
more heat and shock tolerant than typical subminiature fuses.
RoHS
2015/863/EC
O
Features
P
High inrush current withstanding capability
AEC-Q200 Automotive Grade Certified
Compatible with reflow and wave solder
Ceramic and glass construction Excellent
environmental integrity
One time positive disconnect
Lead Free and Halogen free material
Electrical Characteristics
Appications
Flat panel displays and televisions
Amp Rating
Automotive infotainment and ECU
0.63~30A
0.63~3A
0.63~5A
0.63~5A
6~30A
0.63~30A
Computer servers
Portable electronics
Mobile device chargers
Power Battery Packs
% of Amp Rating
Opening Time
100%
200%
250%
300%
350%
1000%
4 Hours Min.
1sec~60sec
5 Seconds Max.
0.1sec~3sec
5 Seconds Max.
0.2ms~20ms
Specification
Part
Number
Ampere
Rating
(A)
1206TD-R630
1206TD-R750
1206TD-1A
1206TD-1.25A
1206TD-1.5A
1206TD-1.75A
1206TD-2A
1206TD-2.5A
1206TD-3A
1206TD-3.5A
1206TD-4A
1206TD-4.5A
1206TD-5A
1206TD-6A
1206TD-7A
1206TD-8A
1206TD-10A
1206TD-12A
1206TD-15A
1206TD-20A
1206TD-25A
1206TD-30A
0.63
0.75
1.00
1.25
1.50
1.75
2.00
2.50
3.00
3.50
4.00
4.50
5.00
6.00
7.00
8.00
10.0
12.0
15.0
20.0
25.0
30.0
Voltage
Rating
Interrupting
Rating
72Vdc @ 50A
63Vdc @ 50A
32Vdc @ 50A
24Vdc @ 300A
32Vdc @ 150A
24Vdc @ 300A
Typical Cold
Resistance
(Ohms)
Typical
Melting I 2 t
(A 2 Sec)
Typical
Voltage
Drop (V)
Marking
Code
1.08
0.85
0.48
0.33
0.23
0.18
0.135
0.075
0.047
0.038
0.034
0.029
0.024
0.016
0.0123
0.0083
0.0065
0.0050
0.0037
0.0034
0.0016
0.0013
0.009
0.01
0.11
0.15
0.17
0.20
0.41
0.68
1.5
2.0
2.5
2.65
4
12
14
16
22
11.5
16.5
50
60
100
0.950
0.900
0.510
0.500
0.465
0.450
0.316
0.240
0.187
0.180
0.173
0.164
0.145
0.140
0.130
0.123
0.110
0.085
0.078
0.080
0.090
0.090
B
0.75
H
H
K
E
N
O
P
R
S
X
T
F
7
M
U
12
15
Q
L
Z
DC Interrupting Rating (Measured at rated voltage, time constant of less than 50 microseconds, battery source)
DC Cold Resistance are measured at
很抱歉,暂时无法提供与“1206TD-2A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.19448
- 100+0.18088
- 300+0.16728
- 500+0.15368
- 2000+0.14688
- 5000+0.14280
- 国内价格
- 10+0.50199
- 100+0.39831
- 300+0.34647
- 3000+0.27357
- 6000+0.24246
- 9000+0.22680
