LMJ25NF2P0R006
LMJ25NF2P0R006
    PROSEMI(普罗森美)
    电流采样电阻 2512 6mΩ ±1% ±50ppm/℃ 2W
LMJ25NF2P0R006 数据手册
Current Sensing Resistors LMJ25 Series Description Proprietary processing technique produces extremely low resistance values Very low inductance Low thermal EMF Metallic Material Part Numbering System LMJ 25 M F 3P0 R001 Resistance Code R001 : 1mΩ R200 : 200 mΩ Power Rating 2P0 : 2W 3P0 : 3W Series Metal foil Size 25: 2512(6432) Material M:MnCu N :N i Cu Resistance Tol. F: ± 1% G: ±2% J: ±5% Standard Parameter 0.5m Ω ~100mΩ : 1~3W 101m Ω ~500m Ω : 1~2W Power Rating Resistance Value 0.5~500mΩ Operating Temperature Range -55 to +170°C Component Temperature Coefficient (TCR) ± 50 ppm/°C Maximum Working Voltage (V) (P x R)1/2 Dimensions L C W d Unit: Millimeters Style L W LMJ 25 6.4±0.2 3.2±0.2 Specifications are subject to change without notice. C PROSEMI Document No : EPG121001610 C d 2.0±0.2(R≤3mΩ ) 0.6 ±0.20 0.9±0.2(R>3mΩ ) 0.7 ±0.20 (≥2W, >10mΩ) 1 of 2 www.prosemitech.com Current Sensing Resistors LMJ25 Series Recommended land pattern a1 a Unit: Millimeters Resistance Range (Ω) a a1 d R > 0.004 4.1 2.1 4.0 R≦0.004 1.3 3.1 4.0 d Typical sensing traces Packaging Quantity: 4, 000pcs 8mm wide tape on 178mm(7 inch) diameter reel -specification EIA Standard 481. Performance Test Items Thermal shock Short time overload Low temperature operation High temperature exposure Moisture resistance Load life Resistance to bonding exposure Conditions of Test - 55 °C to + 150 °C, 300 cycles, 15 min at each extreme 5 x rated power for 5 s - 55 °C, 1000 h 1000h at + 170 °C MIL-STD- 202, method 106, 0 % power, 7b not required 1000 h at 70 °C , 1.5 h "ON", 0.5 h "OFF" 260 °C for 10 s Test Limits ± 1.0 % ± 0.5 % ± 0.5 % ± 1.0 % ± 1.0 % ± 1.0 % ± 0.5 % Power Ratio (%) Derating Curve 100 -55 70 170 Ambient Temperature (°C) Specifications are subject to change without notice. C PROSEMI Document No : EPG121001610 2 of 2 www.prosemitech.com
LMJ25NF2P0R006 价格&库存
很抱歉,暂时无法提供与“LMJ25NF2P0R006”相匹配的价格&库存,您可以联系我们找货
LMJ25NF2P0R006
  • 5+0.58890
  • 50+0.46553
  • 150+0.40383
  • 500+0.35757
  • 2500+0.32057
  • 4000+0.30203
库存:1213
