Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
PMBT2222; PMBT2222A
NPN switching transistors
Rev. 6 — 12 November 2010
Product data sheet
1. Product profile
1.1 General description
NPN switching transistors in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD)
plastic package.
Table 1.
Product overview
Type number
Package
PMBT2222
PNP complement
NXP
JEDEC
SOT23
TO-236AB
PMBT2907
PMBT2222A
PMBT2907A
1.2 Features and benefits
High current (max. 600 mA)
Low voltage (max. 40 V)
1.3 Applications
Switching and linear amplification
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
VCEO
collector-emitter voltage
open base
IC
hFE
[1]
Min
Typ
Max
Unit
PMBT2222
30
V
PMBT2222A
40
V
mA
collector current
600
100
300
DC current gain
VCE = 10 V;
IC = 150 mA
[1]
PMBT2222
VCE = 10 V;
IC = 500 mA
[1]
30
PMBT2222A
VCE = 10 V;
IC = 500 mA
[1]
40
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
PMBT2222; PMBT2222A
NXP Semiconductors
2. Pinning information
Table 3.
Pinning
Pin
Description
1
base
2
emitter
3
collector
Simplified outline
Graphic symbol
3
3
1
1
2
2
sym021
3. Ordering information
Table 4.
Type number
PMBT2222
Package
Name
Description
Version
plastic surface-mounted package; 3 leads
SOT23
PMBT2222A
4. Marking
Table 5.
Marking codes
Marking code[1]
Type number
PMBT2222
*1B
PMBT2222A
*1P
[1]
PMBT2222_PMBT2222A
Product data sheet
* = placeholder for manufacturing site code
All information provided in this document is subject to legal disclaimers.
© NXP B.V. 2010. All rights reserved.
2 of 12
PMBT2222; PMBT2222A
NXP Semiconductors
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
VCBO
collector-base voltage
open emitter
Min
Max
Unit
PMBT2222
60
V
PMBT2222A
75
V
30
V
40
V
PMBT2222
5
V
PMBT2222A
6
V
IC
collector current
600
mA
ICM
peak collector current
800
mA
IBM
peak base current
200
mA
250
mW
VCEO
open base
PMBT2222
PMBT2222A
VEBO
emitter-base voltage
open collector
Tamb ≤ 25 °C
[1]
Ptot
total power dissipation
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
6. Thermal characteristics
Table 7.
Symbol
Rth(j-a)
[1]
PMBT2222_PMBT2222A
Product data sheet
Parameter
thermal resistance from
junction to ambient
Conditions
in free air
[1]
Min
Typ
Max
Unit
500
K/W
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
3 of 12
PMBT2222; PMBT2222A
NXP Semiconductors
7. Characteristics
Table 8.
Characteristics
Tj = 25 °C unless otherwise specified.
Symbol
Parameter
ICBO
collector-base cut-off
current
PMBT2222
Conditions
Min
Typ
Max
Unit
VCB = 50 V; IE = 0 A
10
nA
VCB = 50 V; IE = 0 A;
Tj = 125 °C
10
μA
VCB = 60 V; IE = 0 A
10
nA
VCB = 60 V; IE = 0 A;
Tj = 125 °C
10
μA
10
nA
current
PMBT2222A
IEBO
emitter-base cut-off
current
VEB = 5 V; IC = 0 A
hFE
DC current gain
VCE = 10 V;
IC = 0.1 mA
35
VCE = 10 V;
IC = 1 mA
50
VCE = 10 V;
IC = 10 mA
75
VCE = 10 V;
IC = 10 mA;
Tamb = −55 °C
35
VCE = 10 V;
IC = 150 mA
[1]
100
300
VCE = 1 V;
IC = 150 mA
[1]
50
VCE = 10 V;
IC = 500 mA
[1]
30
40
400
mV
300
mV
PMBT2222
1.6
V
PMBT2222A
1
V
DC current gain
PMBT2222
PMBT2222A
VCEsat
collector-emitter
saturation voltage
IC = 150 mA;
IB = 15 mA
[1]
PMBT2222
PMBT2222A
collector-emitter
saturation voltage
PMBT2222_PMBT2222A
Product data sheet
IC = 500 mA;
IB = 50 mA
[1]
4 of 12
PMBT2222; PMBT2222A
NXP Semiconductors
Table 8.
Characteristics …continued
Symbol
VBEsat
Parameter
Conditions
base-emitter saturation IC = 150 mA;
voltage
IB = 15 mA
Product data sheet
Max
Unit
1.3
V
PMBT2222A
0.6
1.2
V
[1]
PMBT2222
2.6
V
PMBT2222A
2
V
8
pF
Cc
collector capacitance
VCB = 10 V;
IE = ie = 0 A;
f = 1 MHz
Ce
emitter capacitance
VEB = 500 mV;
IC = ic = 0 A;
f = 1 MHz
PMBT2222
30
pF
PMBT2222A
25
pF
PMBT2222
250
MHz
PMBT2222A
300
MHz
transition frequency
VCE = 20 V;
IC = 20 mA;
f = 100 MHz
NF
noise figure
VCE = 5 V;
IC = 100 μA;
RS = 1 kΩ;
f = 1 kHz
4
dB
td
delay time
15
ns
tr
rise time
ton
turn-on time
VCC = 10 V;
IC = 150 mA;
IBon = 15 mA;
IBoff = −15 mA
ts
ns
35
ns
storage time
200
ns
tf
fall time
60
ns
toff
turn-off time
250
ns
[1]
PMBT2222_PMBT2222A
Typ
PMBT2222
base-emitter saturation IC = 500 mA;
IB = 50 mA
voltage
fT
Min
[1]
5 of 12
PMBT2222; PMBT2222A
NXP Semiconductors
8. Test information
IB
input pulse
(idealized waveform)
90 %
IBon (100 %)
10 %
IBoff
output pulse
IC
90 %
IC (100 %)
10 %
t
td
ts
tr
ton
Fig 1.
tf
toff
006aaa003
Switching time definition
VBB
RB
VCC
RC
Vo
(probe)
oscilloscope
450 Ω
(probe)
450 Ω
oscilloscope
R2
VI
DUT
R1
mlb826
VCC = 10 V; IC = 150 mA; IBon = 15 mA; IBoff = −15 mA
Fig 2.
Test circuit for switching times
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
PMBT2222_PMBT2222A
Product data sheet
6 of 12
PMBT2222; PMBT2222A
NXP Semiconductors
9. Package outline
3.0
2.8
1.1
0.9
3
0.45
0.15
2.5 1.4
2.1 1.2
1
2
1.9
0.48
0.38
Dimensions in mm
Fig 3.
0.15
0.09
04-11-04
Package outline SOT23 (TO-236AB)
10. Packing information
Table 9.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
PMBT2222
Package
SOT23
Description
4 mm pitch, 8 mm tape and reel
Packing quantity
3000
10000
-215
-235
PMBT2222A
[1]
PMBT2222_PMBT2222A
Product data sheet
For further information and the availability of packing methods, see Section 14.
7 of 12
PMBT2222; PMBT2222A
NXP Semiconductors
11. Soldering
3.3
2.9
1.9
solder lands
solder resist
3
2
1.7
solder paste
0.6
(3×)
0.7
(3×)
occupied area
Dimensions in mm
0.5
(3×)
0.6
(3×)
1
Fig 4.
sot023_fr
Reflow soldering footprint SOT23 (TO-236AB)
2.2
1.2
(2×)
1.4
(2×)
solder lands
4.6
solder resist
2.6
occupied area
Dimensions in mm
1.4
preferred transport direction during soldering
2.8
4.5
Fig 5.
PMBT2222_PMBT2222A
Product data sheet
sot023_fw
Wave soldering footprint SOT23 (TO-236AB)
8 of 12
PMBT2222; PMBT2222A
NXP Semiconductors
12. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PMBT2222_PMBT2222A v.6
20101112
Product data sheet
PMBT2222_2222A_5
Modifications:
Section 4 “Marking”: updated
Figure 1 “Switching time definition”: added
Section 8 “Test information”: updated
Section 10 “Packing information”: added
Section 11 “Soldering”: added
Section 13 “Legal information”: updated
PMBT2222_2222A_5
20040122
Product specification
PMBT2222_2222A_4
PMBT2222_2222A_4
19990427
PMBT2222_3
PMBT2222_3
19970909
PMBT2222_PMBT2222A
Product data sheet
9 of 12
PMBT2222; PMBT2222A
NXP Semiconductors
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
NXP Semiconductors and its customer, unless NXP Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the NXP Semiconductors product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
13.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, NXP Semiconductors does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall NXP Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of NXP Semiconductors.
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using NXP Semiconductors products, and NXP Semiconductors
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the NXP
Semiconductors product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
NXP Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using NXP
Semiconductors products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). NXP does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — NXP Semiconductors
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nxp.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. NXP Semiconductors hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of NXP Semiconductors products by customer.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
PMBT2222_PMBT2222A
Product data sheet
10 of 12
PMBT2222; PMBT2222A
NXP Semiconductors
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
PMBT2222_PMBT2222A
Product data sheet
11 of 12
NXP Semiconductors
PMBT2222; PMBT2222A
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6
Quality information . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7
Packing information . . . . . . . . . . . . . . . . . . . . . 7
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9
Legal information. . . . . . . . . . . . . . . . . . . . . . . 10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2010.
Date of release: 12 November 2010
Document identifier: PMBT2222_PMBT2222A
