PBSS4220V,115
PBSS4220V,115
    NEXPERIA(安世)
    SOT666
    TRANS NPN 20V 2A SOT666
PBSS4220V,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PBSS4220V 20 V, 2 A NPN low VCEsat (BISS) transistor Rev. 02 — 11 December 2009 Product data sheet 1. Product profile 1.1 General description NPN low VCEsat Breakthrough In Small Signal (BISS) transistor in a SOT666 Surface Mounted Device (SMD) plastic package. PNP complement: PBSS5220V. 1.2 Features „ „ „ „ „ Low collector-emitter saturation voltage VCEsat High collector current capability: IC and ICM High collector current gain (hFE) at high IC High efficiency due to less heat generation Smaller required Printed-Circuit Board (PCB) area than for conventional transistors 1.3 Applications „ „ „ „ „ „ DC-to-DC conversion MOSFET gate driving Motor control Charging circuits Low power switches (e.g. motors, fans) Portable applications 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit open base - - 20 V - - 2 A - - 4 A - 140 175 mΩ VCEO collector-emitter voltage IC collector current ICM peak collector current tp ≤ 300 μs RCEsat collector-emitter saturation resistance IC = 1 A; IB = 100 mA [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [1] PBSS4220V NXP Semiconductors 20 V, 2 A NPN low VCEsat (BISS) transistor 2. Pinning information Table 2. Pinning Pin Description 1 collector 2 collector 3 base 4 emitter 5 collector 6 collector Simplified outline 6 5 Symbol 1, 2, 5, 6 4 3 4 1 2 sym014 3 3. Ordering information Table 3. Ordering information Type number PBSS4220V Package Name Description Version - plastic surface mounted package; 6 leads SOT666 4. Marking Table 4. Marking codes Type number Marking code PBSS4220V N6 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 20 V VCEO collector-emitter voltage open base - 20 V VEBO emitter-base voltage open collector - 5 V IC collector current - 2 A ICM peak collector current IB base current IBM peak base current tp ≤ 300 μs total power dissipation Tamb ≤ 25 °C Ptot Tj tp ≤ 300 μs junction temperature PBSS4220V_2 Product data sheet - 4 A - 0.3 A - 0.6 A [1][4] - 0.3 W [2][4] - 0.5 W [3][4] - 0.9 W - 150 °C © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 2 of 13 PBSS4220V NXP Semiconductors 20 V, 2 A NPN low VCEsat (BISS) transistor Table 5. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Tamb Tstg Conditions Min Max Unit ambient temperature −65 +150 °C storage temperature −65 +150 °C [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. [4] Reflow soldering is the only recommended soldering method. 006aaa424 1.2 Ptot (W) (1) 0.8 (2) 0.4 (3) 0 0 40 80 120 160 Tamb (°C) (1) Ceramic PCB, Al2O3, standard footprint (2) FR4 PCB, mounting pad for collector 1 cm2 (3) FR4 PCB, standard footprint Fig 1. Power derating curves PBSS4220V_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 3 of 13 PBSS4220V NXP Semiconductors 20 V, 2 A NPN low VCEsat (BISS) transistor 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter thermal resistance from junction to ambient Rth(j-a) Zth(j-a) (K/W) 102 in free air Min Typ Max Unit [1][4] - - 410 K/W [2][4] - - 250 K/W [3][4] - - 140 K/W - - 80 K/W thermal resistance from junction to solder point Rth(j-sp) 103 Conditions [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. [4] Reflow soldering is the only recommended soldering method. 006aaa425 duty cycle = 1 0.75 0.5 0.33 0.2 0.1 0.05 10 1 0.02 0.01 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 t p (s) FR4 PCB, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse time; typical values PBSS4220V_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 4 of 13 PBSS4220V NXP Semiconductors 20 V, 2 A NPN low VCEsat (BISS) transistor 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit collector-base cut-off current VCB = 20 V; IE = 0 A - - 0.1 μA VCB = 20 V; IE = 0 A; Tj = 150 °C - - 50 μA ICES collector-emitter cut-off current VCE = 20 V; VBE = 0 V - - 0.1 μA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 0.1 μA hFE DC current gain VCE = 2 V; IC = 1 mA 220 480 - ICBO VCE = 2 V; IC = 100 mA VCEsat collector-emitter saturation voltage 220 440 - VCE = 2 V; IC = 500 mA [1] 220 410 - VCE = 2 V; IC = 1 A [1] 200 360 - VCE = 2 V; IC = 2 A [1] 120 220 - - 35 55 mV IC = 500 mA; IB = 50 mA IC = 100 mA; IB = 1 mA [1] - 70 95 mV IC = 1 A; IB = 50 mA [1] - 145 180 mV IC = 1 A; IB = 100 mA [1] - 140 175 mV IC = 2 A; IB = 100 mA [1] - 275 355 mV IC = 2 A; IB = 200 mA [1] - 270 350 mV 175 mΩ RCEsat collector-emitter saturation resistance IC = 1 A; IB = 100 mA [1] - 140 VBEsat base-emitter saturation IC = 1 A; IB = 50 mA voltage IC = 1 A; IB = 100 mA [1] - 0.95 1.1 V [1] - 1 1.2 V VBEon base-emitter turn-on voltage VCE = 5 V; IC = 1 A - 0.8 1.1 V IC = 1 A; IBon = 50 mA; IBoff = −50 mA - 9 - ns - 29 - ns td delay time tr rise time ton turn-on time - 38 - ns ts storage time - 200 - ns tf fall time - 40 - ns toff turn-off time - 240 - ns fT transition frequency VCE = 10 V; IC = 50 mA; f = 100 MHz - 210 - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - 11 - pF [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. PBSS4220V_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 5 of 13 PBSS4220V NXP Semiconductors 20 V, 2 A NPN low VCEsat (BISS) transistor 006aaa662 1000 hFE 006aaa663 1.0 VBE (V) 800 0.8 (1) 0.6 (2) (1) 600 (2) 400 (3) (3) 0.4 200 0 10−1 1 10 102 0.2 10−1 103 104 IC (mA) 1 VCE = 2 V VCE = 5 V (1) Tamb = 100 °C (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 3. 10 102 103 104 IC (mA) (3) Tamb = 100 °C DC current gain as a function of collector current; typical values Fig 4. 006aaa664 1 VCEsat (V) Base-emitter voltage as a function of collector current; typical values 006aaa665 1 VCEsat (V) 10−1 10−1 (1) (2) (3) (1) (2) 10−2 10−2 (3) 10−3 10−1 1 10 102 103 104 IC (mA) 10−3 10−1 1 (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Collector-emitter saturation voltage as a function of collector current; typical values Fig 6. 103 104 IC (mA) Collector-emitter saturation voltage as a function of collector current; typical values PBSS4220V_2 Product data sheet 102 Tamb = 25 °C IC/IB = 20 Fig 5. 10 © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 6 of 13 PBSS4220V NXP Semiconductors 20 V, 2 A NPN low VCEsat (BISS) transistor 006aaa666 1.2 VBEsat (V) 006aaa667 102 RCEsat (Ω) 1.0 (1) 10 0.8 (2) (3) 0.6 1 0.4 (1) (2) (3) 0.2 10−1 1 10 102 103 104 IC (mA) 10−1 10−1 IC/IB = 20 1 10 (1) Tamb = −55 °C (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = −55 °C Base-emitter saturation voltage as a function of collector current; typical values 006aaa668 2.0 IB (mA) = 8.0 IC (A) 103 104 IC (mA) IC/IB = 20 (2) Tamb = 25 °C Fig 7. 102 7.2 6.4 Collector-emitter saturation resistance as a function of collector current; typical values 006aaa669 103 RCEsat (Ω) 5.6 1.6 Fig 8. 102 4.8 4.0 (1) 1.2 3.2 10 2.4 (2) 0.8 1.6 1 0.4 (3) 0.8 0 0 1 2 3 4 5 10−1 10−1 1 VCE (V) Tamb = 25 °C 10 102 103 104 IC (mA) Tamb = 25 °C (1) IC/IB = 100 (2) IC/IB = 50 (3) IC/IB = 10 Fig 9. Collector current as a function of collector-emitter voltage; typical values Fig 10. Collector-emitter saturation resistance as a function of collector current; typical values PBSS4220V_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 7 of 13 PBSS4220V NXP Semiconductors 20 V, 2 A NPN low VCEsat (BISS) transistor 8. Test information IB input pulse (idealized waveform) 90 % IBon (100 %) 10 % IBoff output pulse (idealized waveform) IC 90 % IC (100 %) 10 % t td ts tr ton tf toff 006aaa003 Fig 11. BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω oscilloscope R2 VI DUT R1 mlb826 IC = 1 A; IBon = 50 mA; IBoff = −50 mA; R1 = open; R2 = 45 Ω; RB = 145 Ω; RC = 10 Ω Fig 12. Test circuit for switching times PBSS4220V_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 8 of 13 PBSS4220V NXP Semiconductors 20 V, 2 A NPN low VCEsat (BISS) transistor 9. Package outline 1.7 1.5 6 0.6 0.5 5 4 0.3 0.1 1.7 1.5 1.3 1.1 pin 1 index 1 2 3 0.27 0.17 0.5 0.18 0.08 1 Dimensions in mm 04-11-08 Fig 13. Package outline SOT666 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description Packing quantity 4000 PBSS4220V [1] SOT666 2 mm pitch, 8 mm tape and reel - -315 4 mm pitch, 8 mm tape and reel -115 - For further information and the availability of packing methods, see Section 14. PBSS4220V_2 Product data sheet 8000 © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 9 of 13 PBSS4220V NXP Semiconductors 20 V, 2 A NPN low VCEsat (BISS) transistor 11. Soldering 2.75 2.45 2.1 1.6 solder lands 0.4 (6×) 0.25 (2×) 0.538 2 1.7 1.075 0.3 (2×) 0.55 (2×) placement area solder paste occupied area 0.325 0.375 (4×) (4×) Dimensions in mm 1.7 0.45 (4×) 0.6 (2×) 0.5 (4×) 0.65 (2×) sot666_fr Reflow soldering is the only recommended soldering method. Fig 14. Reflow soldering footprint PBSS4220V_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 10 of 13 PBSS4220V NXP Semiconductors 20 V, 2 A NPN low VCEsat (BISS) transistor 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PBSS4220V_2 20091211 Product data sheet - PBSS4220V_1 Modifications: PBSS4220V_1 • This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content. • Figure 14 “Reflow soldering footprint”: updated 20060206 Product data sheet - PBSS4220V_2 Product data sheet - © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 11 of 13 PBSS4220V NXP Semiconductors 20 V, 2 A NPN low VCEsat (BISS) transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PBSS4220V_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 11 December 2009 12 of 13 PBSS4220V NXP Semiconductors 20 V, 2 A NPN low VCEsat (BISS) transistor 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Packing information . . . . . . . . . . . . . . . . . . . . . 9 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 11 December 2009 Document identifier: PBSS4220V_2
PBSS4220V,115 价格&库存
很抱歉,暂时无法提供与“PBSS4220V,115”相匹配的价格&库存,您可以联系我们找货
PBSS4220V,115
