PBSS306PZ,135
PBSS306PZ,135
    NEXPERIA(安世)
    SOT-223
    三极管 PNP Ic=-4.1A Vceo=-100V hfe=300 P=2W SOT223-4
PBSS306PZ,135 数据手册
PBSS306PZ 100 V, 4.1 A PNP low VCEsat (BISS) transistor Rev. 3 — 26 July 2011 Product data sheet 1. Product profile 1.1 General description PNP low VCEsat Breakthrough In Small Signal (BISS) transistor in a SOT223 (SC-73) small Surface-Mounted Device (SMD) plastic package. NPN complement: PBSS306NZ. 1.2 Features and benefits  Low collector-emitter saturation voltage VCEsat  High efficiency due to less heat generation  High collector current capability IC and ICM  Smaller Printed-Circuit Board (PCB) area than for conventional transistors  High collector current gain (hFE) at high IC  AEC-Q101 qualified 1.3 Applications  High-voltage DC-to-DC conversion  High-voltage MOSFET gate driving  High-voltage power switches (e.g. motors, fans)  High-voltage motor control  Automotive applications 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - -100 V IC collector current - - -4.1 A ICM peak collector current single pulse; tp ≤ 1 ms - - -8.2 A RCEsat collector-emitter saturation resistance IC = -4 A; IB = -400 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 56 80 mΩ PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 B base 2 C collector 3 E emitter 4 C collector Simplified outline Graphic symbol 2, 4 4 1 1 2 3 3 SOT223 (SC-73) sym028 3. Ordering information Table 3. Ordering information Type number Package PBSS306PZ Name Description Version SC-73 plastic surface-mounted package with increased heatsink; 4 leads SOT223 4. Marking Table 4. Marking codes Type number Marking code PBSS306PZ S306PZ 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - -100 V VCEO collector-emitter voltage open base - -100 V VEBO emitter-base voltage open collector - -5 V IC collector current - -4.1 A ICM peak collector current single pulse; tp ≤ 1 ms - -8.2 A Ptot total power dissipation Tamb ≤ 25 °C [1] - 0.7 W [2] - 1.7 W [3] - 2 W Tj junction temperature - 150 °C Tamb ambient temperature -65 150 °C Tstg storage temperature -65 150 °C [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. PBSS306PZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 2 of 15 PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor 006aaa560 2.5 Ptot (W) (1) 2.0 (2) 1.5 1.0 (3) 0.5 0 −75 −25 25 75 125 175 Tamb (°C) (1) Ceramic PCB, Al2O3, standard footprint (2) FR4 PCB, mounting pad for collector 6 cm2 (3) FR4 PCB, standard footprint Fig 1. Power derating curves 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) Conditions in free air thermal resistance from junction to solder point Min Typ Max Unit [1] - - 179 K/W [2] - - 74 K/W [3] - - 63 K/W - - 15 K/W [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. PBSS306PZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 3 of 15 PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor 006aaa561 103 Zth(j-a) (K/W) δ=1 0.75 102 0.50 0.33 0.20 0.10 0.05 10 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aaa562 102 δ=1 0.75 Zth(j-a) (K/W) 0.50 0.20 10 0.33 0.10 0.05 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, mounting pad for collector 6 cm2 Fig 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS306PZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 4 of 15 PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor 006aaa563 102 δ=1 0.75 Zth(j-a) (K/W) 0.50 0.20 0.33 10 0.10 0.05 0.02 1 0.01 0 10−1 10−5 10−4 10−3 10−2 10−1 1 102 10 103 tp (s) Ceramic PCB, Al2O3 standard footprint Fig 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 7. Characteristics Table 7. Characteristics Symbol Parameter ICBO collector-base cut-off current Conditions Min Typ Max Unit VCB = -80 V; IE = 0 A; Tamb = 25 °C - - -100 nA VCB = -80 V; IE = 0 A; Tj = 150 °C; Tamb = 25 °C - - -50 µA ICES collector-emitter cut-off VCE = -48 V; VBE = 0 V; Tamb = 25 °C current - - -100 nA IEBO emitter-base cut-off current VEB = -5 V; IC = 0 A; Tamb = 25 °C - - -100 nA hFE DC current gain VCE = -2 V; IC = -0.5 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 200 300 - VCE = -2 V; IC = -1 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 150 260 - VCE = -2 V; IC = -2 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 100 175 - VCE = -2 V; IC = -4 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 25 40 - IC = -0.5 A; IB = -50 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - -45 -65 mV IC = -1 A; IB = -50 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - -90 -130 mV IC = -4 A; IB = -400 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - -225 -320 mV IC = -4.1 A; IB = -410 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - -230 -325 mV IC = -4 A; IB = -400 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 56 80 mΩ VCEsat RCEsat collector-emitter saturation voltage collector-emitter saturation resistance PBSS306PZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 5 of 15 PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor Table 7. Characteristics …continued Symbol Parameter Min Typ Max Unit VBEsat base-emitter saturation IC = -1 A; IB = -100 mA; pulsed; voltage tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C Conditions - -0.81 -0.9 V IC = -4 A; IB = -400 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - -0.93 -1.05 V VBEon base-emitter turn-on voltage VCE = -2 V; IC = -2 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - -0.78 -0.85 V td delay time - 15 - ns tr rise time VCC = -12.5 V; IC = -3 A; IBon = -0.15 A; IBoff = 0.15 A; Tamb = 25 °C - 185 - ns ton turn-on time - 200 - ns ts storage time - 150 - ns tf fall time - 175 - ns toff turn-off time - 325 - ns fT transition frequency VCE = -10 V; IC = -100 mA; f = 100 MHz; Tamb = 25 °C - 100 - MHz Cc collector capacitance VCB = -10 V; IE = 0 A; ie = 0 A; f = 1 MHz; Tamb = 25 °C - 50 80 pF 006aaa645 600 hFE 006aaa651 −14 IC (A) −12 (1) IB (mA) = −1015 −10 −870 400 −580 −8 (2) −290 (3) −435 −145 −6 200 −725 −4 −2 0 −10−1 −1 −10 −102 0 −103 −104 IC (mA) 0 −1 −2 −3 −4 −5 VCE (V) Tamb = 25 °C VCE = -2 V (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 5. DC current gain as a function of collector current; typical values PBSS306PZ Product data sheet Fig 6. Collector current as a function of collector-emitter voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 6 of 15 PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor 006aaa646 −1.2 006aaa649 −1.2 VBE (V) VBEsat (V) −0.8 −0.8 (1) (1) (2) (2) −0.4 0 −10−1 Fig 7. −0.4 (3) −1 −10 −102 (3) 0 −10−1 −103 −104 IC (mA) −1 −10 VCE = -2 V IC/IB = 20 (1) Tamb = −55 °C (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = 100 °C Base-emitter voltage as a function of collector current; typical values 006aaa647 −10 Fig 8. −103 −104 IC (mA) Base-emitter saturation voltage as a function of collector current; typical values 006aaa648 −10 VCEsat (V) VCEsat (V) −1 −1 −10−1 −102 −10−1 (1) (2) (3) (1) (2) (3) −10−2 −10−1 Fig 9. −1 −10 −102 −103 −104 IC (mA) −10−2 −10−1 −1 IC/IB = 20 Tamb = 25 °C (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Collector-emitter saturation voltage as a function of collector current; typical values PBSS306PZ Product data sheet −10 −102 −103 −104 IC (mA) Fig 10. Collector-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 7 of 15 PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor 006aaa650 103 RCEsat (Ω) RCEsat (Ω) 102 102 10 10 1 1 (1) (2) (3) 10−1 10−2 −10−1 −1 −10 −102 006aaa652 103 (1) (2) (3) 10−1 −103 −104 IC (mA) 10−2 −10−1 −1 IC/IB = 20 Tamb = 25 °C (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig 11. Collector-emitter saturation resistance as a function of collector current; typical values PBSS306PZ Product data sheet −10 −102 −103 −104 IC (mA) Fig 12. Collector-emitter saturation resistance as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 8 of 15 PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor 8. Test information − IB input pulse (idealized waveform) 90 % − I Bon (100 %) 10 % − I Boff output pulse (idealized waveform) − IC 90 % − I C (100 %) 10 % t td ts tr t on tf t off 006aaa266 Fig 13. BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω oscilloscope R2 VI DUT R1 mgd624 VCC = -12.5 V; IC = -3 A; IBon = -0.15 A; IBoff = 0.15 A Fig 14. Test circuit for switching times 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors and is suitable for use in automotive applications. PBSS306PZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 9 of 15 PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor 9. Package outline Plastic surface-mounted package with increased heatsink; 4 leads D SOT223 E B A X c y HE v M A b1 4 Q A A1 1 2 3 Lp bp e1 w M B detail X e 0 2 4 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp b1 c D E e e1 HE Lp Q v w y mm 1.8 1.5 0.10 0.01 0.80 0.60 3.1 2.9 0.32 0.22 6.7 6.3 3.7 3.3 4.6 2.3 7.3 6.7 1.1 0.7 0.95 0.85 0.2 0.1 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT223 JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-10 06-03-16 SC-73 Fig 15. Package outline SOT223 (SC-73) PBSS306PZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 10 of 15 PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor 10. Soldering 7 3.85 3.6 3.5 0.3 1.3 1.2 (4×) (4×) solder lands 4 solder resist 3.9 6.1 7.65 solder paste occupied area 1 2 3 Dimensions in mm 2.3 2.3 1.2 (3×) 1.3 (3×) 6.15 sot223_fr Fig 16. Reflow soldering footprint for SOT223 (SC-73) 8.9 6.7 1.9 solder lands 4 solder resist 6.2 8.7 occupied area Dimensions in mm 1 2 3 1.9 (3×) 2.7 preferred transport direction during soldering 2.7 1.1 1.9 (2×) sot223_fw Fig 17. Wave soldering footprint for SOT223 (SC-73) PBSS306PZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 11 of 15 PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor 11. Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes PBSS306PZ v.3 20110726 Product data sheet - PBSS306PZ v.2 Modifications: • • • • 1.2 “Features and benefits” updated In 7 “Characteristics” new parameter added, ICES Fig 15. updated 12 “Legal information” updated PBSS306PZ v.2 20091211 Product data sheet - PBSS306PZ v.1 PBSS306PZ v.1 20060920 Product data sheet - - PBSS306PZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 12 of 15 PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor 12. Legal information 12.1 Data sheet status Document status [1] [2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective PBSS306PZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 13 of 15 PBSS306PZ Nexperia 100 V, 4.1 A PNP low VCEsat (BISS) transistor agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 13. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PBSS306PZ Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 26 July 2011 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia PBSS306PZ 100 V, 4.1 A PNP low VCEsat (BISS) transistor 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 9 10 11 12 12.1 12.2 12.3 12.4 13 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12 Legal information. . . . . . . . . . . . . . . . . . . . . . . .13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Contact information. . . . . . . . . . . . . . . . . . . . . .14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 26 July 2011
PBSS306PZ,135 价格&库存
很抱歉,暂时无法提供与“PBSS306PZ,135”相匹配的价格&库存,您可以联系我们找货
PBSS306PZ,135
  • 1+13.728761+1.72228
  • 10+8.5714310+1.07529
  • 100+5.60166100+0.70273
  • 500+4.32416500+0.54247
库存:510
PBSS306PZ,135
  • 4000+2.44620
  • 20000+2.20160
PBSS306PZ,135
