PXTA42,115
PXTA42,115
    NEXPERIA(安世)
    SOT89-3
    TRANS NPN 300V 0.1A SOT89
PXTA42,115 数据手册
PXTA42 300 V, 100 mA NPN high-voltage transistor Rev. 5 — 11 July 2011 Product data sheet 1. Product profile 1.1 General description NPN high-voltage transistor in a medium power and flat lead SOT89 (SC-62) Surface-Mounted Device (SMD) plastic package. PNP complement: PXTA92. 1.2 Features and benefits  High breakdown voltage  AEC-Q101 qualified  Medium power and flat lead SMD plastic package 1.3 Applications       Electronic ballast for fluorescent lighting LED driver for LED chain module High Intensity Discharge (HID) front lighting Automotive motor management Hook switch for wired telecom Switch Mode Power Supply (SMPS) 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 300 V IC collector current - - 100 mA ICM peak collector current - - 200 mA hFE DC current gain 40 - - VCE = 10 V; IC = 30 mA PXTA42 Nexperia 300 V, 100 mA NPN high-voltage transistor 2. Pinning information Table 2. Pinning Pin Description 1 emitter 2 collector 3 base Simplified outline Graphic symbol 2 3 3 2 1 1 sym042 3. Ordering information Table 3. Ordering information Type number PXTA42 Package Name Description Version SC-62 plastic surface-mounted package; exposed die pad SOT89 for good heat transfer; 3 leads 4. Marking Table 4. Marking codes Type number Marking code[1] PXTA42 *1D [1] * = placeholder for manufacturing site code 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 300 V VCEO collector-emitter voltage open base - 300 V VEBO emitter-base voltage open collector - 6 V IC collector current - 100 mA ICM peak collector current - 200 mA IBM peak base current - 100 mA - 1300 mW Ptot total power dissipation Tj junction temperature - 150 C Tamb ambient temperature 65 +150 C Tstg storage temperature 65 +150 C [1] PXTA42 Product data sheet Tamb  25 C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for collector 6 cm2. All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 July 2011 © Nexperia B.V. 2017. All rights reserved 2 of 9 PXTA42 Nexperia 300 V, 100 mA NPN high-voltage transistor 6. Thermal characteristics Table 6. Symbol Thermal characteristics Parameter Conditions Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) thermal resistance from junction to solder point [1] in free air [1] Min Typ Max Unit - - 96 K/W - - 16 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. 7. Characteristics Table 7. Characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Min Typ Max Unit ICBO collector-base cut-off VCB = 200 V; IE = 0 A current Conditions - - 100 nA IEBO emitter-base cut-off current VEB = 6 V; IC = 0 A - - 100 nA hFE DC current gain VCE = 10 V; IC = 1 mA 25 - - VCE = 10 V; IC = 10 mA 40 - - VCE = 10 V; IC = 30 mA 40 - - VCEsat collector-emitter saturation voltage IC = 20 mA; IB = 2 mA - - 500 mV VBEsat base-emitter saturation voltage IC = 20 mA; IB = 2 mA - - 900 mV fT transition frequency VCE = 20 V; IC = 10 mA; f = 100 MHz 50 - - MHz Cre feedback capacitance VCB = 20 V; IC = ic = 0 A; f = 1 MHz - - 3 pF 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PXTA42 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 July 2011 © Nexperia B.V. 2017. All rights reserved 3 of 9 PXTA42 Nexperia 300 V, 100 mA NPN high-voltage transistor 9. Package outline 4.6 4.4 1.8 1.4 1.6 1.4 2.6 2.4 4.25 3.75 1 2 0.53 0.40 1.5 1.2 0.8 3 0.48 0.35 0.44 0.23 3 Dimensions in mm Fig 1. 06-08-29 Package outline PXTA42 (SOT89/SC-62) 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description Packing quantity 1000 PXTA42 [1] PXTA42 Product data sheet SOT89 4000 8 mm pitch, 12 mm tape and reel; T1 [2] -115 -135 8 mm pitch, 12 mm tape and reel; T3 [3] -120 - For further information and the availability of packing methods, see Section 14. [2] T1: normal taping [3] T3: 90 taping All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 July 2011 © Nexperia B.V. 2017. All rights reserved 4 of 9 PXTA42 Nexperia 300 V, 100 mA NPN high-voltage transistor 11. Soldering 4.75 2.25 2 1.9 1.2 0.2 0.85 solder lands 1.7 1.2 4.6 solder resist 0.5 4.85 solder paste occupied area 1.1 (2×) 1 (3×) 1.5 Dimensions in mm 1.5 0.6 (3×) 0.7 (3×) 3.95 Fig 2. sot089_fr Reflow soldering footprint PXTA42 (SOT89/SC-62) 6.6 2.4 3.5 solder lands 7.6 0.5 solder resist occupied area 1.8 (2×) Dimensions in mm preferred transport direction during soldering 1.9 1.5 (2×) 1.9 0.7 5.3 Fig 3. PXTA42 Product data sheet sot089_fw Wave soldering footprint PXTA42 (SOT89/SC-62) All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 July 2011 © Nexperia B.V. 2017. All rights reserved 5 of 9 PXTA42 Nexperia 300 V, 100 mA NPN high-voltage transistor 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PXTA42 v.5 20110711 Product data sheet - PXTA42 v.4 Modifications: • The format of this document has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • • • • • • • Legal texts have been adapted to the new company name where appropriate. Section 1.1 “General description”: amended Section 1.2 “Features and benefits”: amended Section 1.3 “Applications”: amended Section 1.4 “Quick reference data”: added Figure 1: superseded by minimized package outline drawing Section 8 “Test information”: added Section 10 “Packing information”: added Section 11 “Soldering”: added Section 13 “Legal information”: updated PXTA42 v.4 20041209 Product data sheet - PXTA42 v.3 PXTA42 v.3 19990426 Product specification - PXTA42_43_CNV v.2 PXTA42_43_CNV v.2 19970618 Product specification - - PXTA42 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 July 2011 © Nexperia B.V. 2017. All rights reserved 6 of 9 PXTA42 Nexperia 300 V, 100 mA NPN high-voltage transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. PXTA42 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 July 2011 © Nexperia B.V. 2017. All rights reserved 7 of 9 PXTA42 Nexperia 300 V, 100 mA NPN high-voltage transistor Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PXTA42 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 11 July 2011 © Nexperia B.V. 2017. All rights reserved 8 of 9 PXTA42 Nexperia 300 V, 100 mA NPN high-voltage transistor 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description . . . . . . . . . . . . . . . . . . . . . Features and benefits . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Quick reference data . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Test information . . . . . . . . . . . . . . . . . . . . . . . . . Quality information . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Packing information . . . . . . . . . . . . . . . . . . . . . Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Legal information. . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . Contact information. . . . . . . . . . . . . . . . . . . . . . Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 July 2011 1 1 1 1 1 2 2 2 2 3 3 3 3 4 4 5 6 7 7 7 7 8 8 9
PXTA42,115 价格&库存
很抱歉,暂时无法提供与“PXTA42,115”相匹配的价格&库存,您可以联系我们找货
PXTA42,115
    PXTA42,115
    • 1000+1.570331000+0.20315
    • 2000+1.418352000+0.18349
    • 3000+1.340903000+0.17347
    • 5000+1.253785000+0.16220
    • 7000+1.218967000+0.15770
    PXTA42,115
    • 1+6.198981+0.80194
    • 10+3.8157510+0.49363
    • 100+2.44812100+0.31670
    • 500+1.85578500+0.24008
