PDTC114TU,115
PDTC114TU,115
    NEXPERIA(安世)
    SOT-323
    TRANS PREBIAS NPN 200MW SOT323
PDTC114TU,115 数据手册
PDTC114T series NPN resistor-equipped transistors; R1 = 10 kΩ, R2 = open Rev. 08 — 9 February 2006 Product data sheet 1. Product profile 1.1 General description NPN Resistor-Equipped Transistors (RET) family. Table 1: Product overview Type number Package PNP complement Philips JEITA JEDEC PDTC114TE SOT416 SC-75 - PDTA114TE PDTC114TK SOT346 SC-59A TO-236 PDTA114TK PDTC114TM SOT883 SC-101 - PDTA114TM PDTC114TS [1] SOT54 SC-43A TO-92 PDTA114TS PDTC114TT SOT23 - TO-236AB PDTA114TT PDTC114TU SOT323 SC-70 - PDTA114TU [1] Also available in SOT54A and SOT54 variant packages (see Section 2). 1.2 Features ■ Built-in bias resistors ■ Simplifies circuit design ■ 100 mA output current capability ■ Reduces component count ■ Reduces pick and place costs 1.3 Applications ■ Digital applications ■ Controlling IC inputs ■ Cost-saving alternative for BC847 series in digital applications ■ Switching loads 1.4 Quick reference data Table 2: Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 50 V IO output current - - 100 mA R1 bias resistor 1 (input) 7 10 13 kΩ PDTC114T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 10 kΩ, R2 = open 2. Pinning information Table 3: Pinning Pin Description Simplified outline Symbol SOT54 1 input (base) 2 output (collector) 3 GND (emitter) 2 1 2 3 R1 1 001aab347 3 006aaa218 SOT54A 1 input (base) 2 output (collector) 3 GND (emitter) 2 1 2 R1 1 3 001aab348 3 006aaa218 SOT54 variant 1 input (base) 2 output (collector) 3 GND (emitter) 2 1 2 3 R1 1 001aab447 3 006aaa218 SOT23; SOT323; SOT346; SOT416 1 input (base) 2 GND (emitter) 3 output (collector) 3 3 R1 1 1 2 2 006aaa144 sym012 SOT883 1 input (base) 2 GND (emitter) 1 3 output (collector) 2 3 3 R1 1 Transparent top view 2 sym012 © PDTC114T_SER_8 Product data sheet Rev. 08 — 9 February 2006 Nexperia B.V. 2017. All rights reserved 2 of 11 PDTC114T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 10 kΩ, R2 = open 3. Ordering information Table 4: Ordering information Type number PDTC114TE Package Name Description Version SC-75 plastic surface mounted package; 3 leads SOT416 PDTC114TK SC-59A plastic surface mounted package; 3 leads SOT346 PDTC114TM SC-101 leadless ultra small plastic package; 3 solder lands; body 1.0 × 0.6 × 0.5 mm SOT883 PDTC114TS [1] SC-43A plastic single-ended leaded (through hole) package; 3 leads SOT54 PDTC114TT - plastic surface mounted package; 3 leads SOT23 PDTC114TU SC-70 plastic surface mounted package; 3 leads SOT323 [1] Also available in SOT54A and SOT54 variant packages (see Section 2 and Section 9). 4. Marking Table 5: Marking codes Type number Marking code [1] PDTC114TE 24 PDTC114TK 24 PDTC114TM DT PDTC114TS TC114T PDTC114TT *12 PDTC114TU *24 [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China © PDTC114T_SER_8 Product data sheet Rev. 08 — 9 February 2006 Nexperia B.V. 2017. All rights reserved 3 of 11 PDTC114T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 10 kΩ, R2 = open 5. Limiting values Table 6: Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 50 V VEBO emitter-base voltage open collector - 5 V IO output current - 100 mA ICM peak collector current single pulse; tp ≤ 1 ms - 100 mA Ptot total power dissipation Tamb ≤ 25 °C SOT416 [1] - 150 mW SOT346 [1] - 250 mW SOT883 [2] [3] - 250 mW SOT54 [1] - 500 mW SOT23 [1] - 250 mW SOT323 [1] - 200 mW Tstg storage temperature −65 +150 °C Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Reflow soldering is the only recommended soldering method. [3] Device mounted on an FR4 PCB with 60 µm copper strip line, standard footprint. 6. Thermal characteristics Table 7: Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Typ Max Unit SOT416 [1] - - 833 K/W SOT346 [1] - - 500 K/W SOT883 [2] [3] - - 500 K/W SOT54 [1] - - 250 K/W SOT23 [1] - - 500 K/W SOT323 [1] - - 625 K/W [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Reflow soldering is the only recommended soldering method. [3] Device mounted on an FR4 PCB with 60 µm copper strip line, standard footprint. © PDTC114T_SER_8 Product data sheet Min Rev. 08 — 9 February 2006 Nexperia B.V. 2017. All rights reserved 4 of 11 PDTC114T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 10 kΩ, R2 = open 7. Characteristics Table 8: Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 50 V; IE = 0 A - - 100 nA ICEO collector-emitter cut-off current VCE = 30 V; IB = 0 A - - 1 µA VCE = 30 V; IB = 0 A; Tj = 150 °C - - 50 µA nA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 hFE DC current gain VCE = 5 V; IC = 1 mA 200 - - VCEsat collector-emitter saturation voltage IC = 10 mA; IB = 0.5 mA - - 150 mV R1 bias resistor 1 (input) 7 10 13 kΩ Cc collector capacitance - - 2.5 pF 006aaa552 600 VCB = 10 V; IE = ie = 0 A; f = 1 MHz 006aaa553 1 (1) hFE VCEsat (V) 400 (2) 10−1 (1) (2) (3) (3) 200 0 10−1 1 102 10 10−2 10−1 1 102 10 IC (mA) IC (mA) VCE = 5 V IC/IB = 20 (1) Tamb = 150 °C (1) Tamb = 100 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −40 °C (3) Tamb = −40 °C Fig 1. DC current gain as a function of collector current; typical values Fig 2. Collector-emitter saturation voltage as a function of collector current; typical values © PDTC114T_SER_8 Product data sheet Rev. 08 — 9 February 2006 Nexperia B.V. 2017. All rights reserved 5 of 11 PDTC114T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 10 kΩ, R2 = open 8. Package outline 3 3 0.45 0.15 0.6 0.2 3.0 1.7 2.5 1.3 1.75 0.9 1.45 0.7 1 2 1 0.30 0.15 2 0.25 0.10 Dimensions in mm 04-11-04 Fig 3. Package outline SOT416 (SC-75) 0.62 0.55 0.55 0.47 0.50 0.35 1.9 1 0.26 0.10 Dimensions in mm 04-11-11 Fig 4. Package outline SOT346 (SC-59A/TO-236) 0.50 0.46 0.45 0.38 4.2 3.6 3 0.30 0.22 2 0.48 0.40 1.02 0.95 0.65 0.30 0.22 1.3 1.0 3.1 2.7 0.95 0.60 1.8 1.4 1 2 4.8 4.4 1 0.20 0.12 2.54 3 5.2 5.0 0.35 Dimensions in mm 03-04-03 Fig 5. Package outline SOT883 (SC-101) 14.5 12.7 Dimensions in mm 04-11-16 Fig 6. Package outline SOT54 (SC-43A/TO-92) 0.45 0.38 0.45 0.38 4.2 3.6 1.27 4.2 3.6 1.27 0.48 0.40 3 max 1 2.5 max 0.48 0.40 1 2 4.8 4.4 5.08 2.54 2 4.8 4.4 2.54 3 1.27 3 5.2 5.0 5.2 5.0 14.5 12.7 Dimensions in mm Fig 7. Package outline SOT54A 04-06-28 Dimensions in mm 05-01-10 Fig 8. Package outline SOT54 variant © PDTC114T_SER_8 Product data sheet 14.5 12.7 Rev. 08 — 9 February 2006 Nexperia B.V. 2017. All rights reserved 6 of 11 PDTC114T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 10 kΩ, R2 = open 3.0 2.8 1.1 0.9 2.2 1.8 1.1 0.8 0.45 0.15 3 3 0.45 0.15 2.5 1.4 2.1 1.2 2.2 1.35 2.0 1.15 1 1 2 0.48 0.38 1.9 Dimensions in mm 0.25 0.10 1.3 04-11-04 Fig 9. Package outline SOT23 (TO-236AB) 2 0.4 0.3 0.15 0.09 Dimensions in mm 04-11-04 Fig 10. Package outline SOT323 (SC-70) 9. Packing information Table 9: Packing methods The indicated -xxx are the last three digits of the 12NC ordering code. [1] Type number Package Description 3000 5000 10000 PDTC114TE SOT416 4 mm pitch, 8 mm tape and reel -115 - -135 PDTC114TK SOT346 4 mm pitch, 8 mm tape and reel -115 - -135 PDTC114TM SOT883 2 mm pitch, 8 mm tape and reel - - -315 PDTC114TS SOT54 bulk, straight leads - -412 - SOT54A tape and reel, wide pitch - - -116 tape ammopack, wide pitch - - -126 SOT54 variant bulk, delta pinning - -112 - PDTC114TT SOT23 4 mm pitch, 8 mm tape and reel -215 - -235 PDTC114TU SOT323 4 mm pitch, 8 mm tape and reel -115 - -135 [1] For further information and the availability of packing methods, see Section 15. © PDTC114T_SER_8 Product data sheet Packing quantity Rev. 08 — 9 February 2006 Nexperia B.V. 2017. All rights reserved 7 of 11 PDTC114T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 10 kΩ, R2 = open 10. Revision history Table 10: Revision history Document ID Release date Data sheet status Change notice Doc. number Supersedes PDTC114T_SER_8 20060209 Product data sheet - PDTC114T_SER_7 Modifications: PDTC114T_SER_7 - • The format of this data sheet has been redesigned to comply with the new presentation and information standard of Philips Semiconductors. • • • • • • • • Type number PDTC114TEF removed Table 1 “Product overview”: EIAJ in table header amended to JEITA Section 1.2 “Features”: amended Section 1.3 “Applications”: amended Figure 1, 2, 7 and 8: added Figure 3, 4, 5, 6, 9 and 10: superseded by minimized package outline drawings Section 9 “Packing information”: added Section 14 “Trademarks”: added 20041011 Product specification - 9397 750 14186 PDTC114T_SERIES_6 PDTC114T_SERIES_6 20040817 Product specification - 9397 750 13664 PDTC114T_SERIES_5 PDTC114T_SERIES_5 20040119 Product specification - 9397 750 11731 PDTC114T_SERIES_4 PDTC114T_SERIES_4 20030414 Product specification - 9397 750 11011 PDTC114TE_2 PDTC114TK_2 PDTC114TS_2 PDTC114TT_3 PDTC114TU_3 PDTC114TU_3 19990416 Preliminary specification - 9397 750 05599 PDTC114TU_2 PDTC114TU_2 19980519 Preliminary specification - 9397 750 03908 PDTC114TU_1 PDTC114TU_1 19970716 Preliminary specification - 9397 750 01149 - PDTC114TT_3 19990416 Objective specification - 9397 750 05598 PDTC114TT_2 PDTC114TT_2 19980519 Objective specification - 9397 750 03912 PDTC114TT_1 PDTC114TT_1 19970714 Objective specification - 9397 750 01371 - PDTC114TS_2 19980518 Product specification - 9397 750 03891 PDTC114TS_1 PDTC114TS_1 19970703 Product specification - 9397 750 02297 - PDTC114TK_2 19980519 Product specification - 9397 750 03899 PDTC114TK_1 © PDTC114T_SER_8 Product data sheet Rev. 08 — 9 February 2006 Nexperia B.V. 2017. All rights reserved 8 of 11 PDTC114T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 10 kΩ, R2 = open Table 10: Revision history …continued Document ID Release date Data sheet status Change notice Doc. number PDTC114TK_1 19970528 Product specification - 9397 750 01367 - PDTC114TE_2 19980803 Product specification - 9397 750 04123 PDTC114TE_1 PDTC114TE_1 19970711 Product specification - 9397 750 02628 - © PDTC114T_SER_8 Product data sheet Supersedes Rev. 08 — 9 February 2006 Nexperia B.V. 2017. All rights reserved 9 of 11 PDTC114T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 10 kΩ, R2 = open 11. Data sheet status Level Data sheet status [1] Product status [2] [3] Definition I Objective data Development This data sheet contains data from the objective specification for product development. Philips Semiconductors reserves the right to change the specification in any manner without notice. II Preliminary data Qualification This data sheet contains data from the preliminary specification. Supplementary data will be published at a later date. Philips Semiconductors reserves the right to change the specification without notice, in order to improve the design and supply the best possible product. III Product data Production This data sheet contains data from the product specification. Philips Semiconductors reserves the right to make changes at any time in order to improve the design, manufacturing and supply. Relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). [1] Please consult the most recently issued data sheet before initiating or completing a design. [2] The product status of the device(s) described in this data sheet may have changed since this data sheet was published. The latest information is available on the Internet at URL http://www.semiconductors.philips.com. [3] For data sheets describing multiple type numbers, the highest-level product status determines the data sheet status. 12. Definitions customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Right to make changes — Philips Semiconductors reserves the right to make changes in the products - including circuits, standard cells, and/or software - described or contained herein in order to improve design and/or performance. When the product is in full production (status ‘Production’), relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified. Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 60134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information — Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. 14. Trademarks 13. Disclaimers Notice — All referenced brands, product names, service names and trademarks are the property of their respective owners. Life support — These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors 15. Contact information For additional information, please visit: http://www.semiconductors.philips.com For sales office addresses, send an email to: sales.addresses@www.semiconductors.philips.com © PDTC114T_SER_8 Product data sheet Rev. 08 — 9 February 2006 Nexperia B.V. 2017. All rights reserved 10 of 11 PDTC114T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 10 kΩ, R2 = open 16. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 3 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Thermal characteristics. . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6 Packing information. . . . . . . . . . . . . . . . . . . . . . 7 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Contact information . . . . . . . . . . . . . . . . . . . . 10 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 09 February 2006
PDTC114TU,115 价格&库存
很抱歉,暂时无法提供与“PDTC114TU,115”相匹配的价格&库存,您可以联系我们找货
PDTC114TU,115
PDTC114TU,115
  • 3000+0.233543000+0.03024
  • 6000+0.207206000+0.02683
  • 9000+0.193749000+0.02509
  • 15000+0.1785915000+0.02313
  • 21000+0.1696121000+0.02196
  • 30000+0.1608730000+0.02083
库存:2029
PDTC114TU,115
    PDTC114TU,115
    • 1+0.56650
    • 200+0.18920
    • 1500+0.11770
    • 3000+0.09372
    库存:39
