PDTC115TU,115
PDTC115TU,115
    NEXPERIA(安世)
    SOT-323
    TRANS PREBIAS NPN 200MW SOT323
PDTC115TU,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PDTC115T series NPN resistor-equipped transistors; R1 = 100 kΩ, R2 = open Rev. 04 — 17 February 2005 Product data sheet 1. Product profile 1.1 General description NPN resistor-equipped transistors. Table 1: Product overview Type number Package PNP complement Philips JEITA PDTC115TE SOT416 SC-75 PDTA115TE PDTC115TK SOT346 SC-59A PDTA115TK PDTC115TM SOT883 SC-101 PDTA115TM PDTC115TS [1] SOT54 (TO-92) SC-43A PDTA115TS PDTC115TT SOT23 - PDTA115TT PDTC115TU SOT323 SC-70 PDTA115TU [1] Also available in SOT54A and SOT54 variant packages (see Section 2). 1.2 Features ■ Built-in bias resistor ■ Simplifies circuit design ■ Reduces component count ■ Reduces pick and place costs 1.3 Applications ■ General-purpose switching and amplification ■ Inverter and interface circuits ■ Circuit drivers 1.4 Quick reference data Table 2: Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 50 V IO output current (DC) - - 100 mA R1 bias resistor 1 (input) 70 100 130 kΩ PDTC115T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 100 kΩ, R2 = open 2. Pinning information Table 3: Pinning Pin Description Simplified outline Symbol SOT54 1 input (base) 2 output (collector) 3 GND (emitter) 2 1 2 3 R1 1 001aab347 3 006aaa218 SOT54A 1 input (base) 2 output (collector) 3 GND (emitter) 2 1 2 R1 1 3 001aab348 3 006aaa218 SOT54 variant 1 input (base) 2 output (collector) 3 GND (emitter) 2 1 2 3 R1 1 001aab447 3 006aaa218 SOT23, SOT323, SOT346, SOT416 1 input (base) 2 GND (emitter) 3 output (collector) 3 3 R1 1 1 2 2 006aaa144 sym012 SOT883 1 input (base) 2 GND (emitter) 1 3 output (collector) 2 3 3 R1 Transparent top view 1 2 sym012 9397 750 14021 Product data sheet © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 04 — 17 February 2005 2 of 10 PDTC115T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 100 kΩ, R2 = open 3. Ordering information Table 4: Ordering information Type number PDTC115TE Package Name Description Version SC-75 plastic surface mounted package; 3 leads SOT416 PDTC115TK SC-59A plastic surface mounted package; 3 leads SOT346 PDTC115TM SC-101 leadless ultra small plastic package; 3 solder lands; body 1.0 × 0.6 × 0.5 mm SOT883 PDTC115TS [1] SC-43A plastic single-ended leaded (through hole) package; 3 leads SOT54 PDTC115TT - plastic surface mounted package; 3 leads SOT23 PDTC115TU SC-70 plastic surface mounted package; 3 leads SOT323 [1] Also available in SOT54A and SOT54 variant packages (see Section 2 and Section 9). 4. Marking Table 5: Marking codes Type number Marking code [1] PDTC115TE 17 PDTC115TK 28 PDTC115TM G5 PDTC115TS TC115T PDTC115TT *AK PDTC115TU *17 [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China 9397 750 14021 Product data sheet © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 04 — 17 February 2005 3 of 10 PDTC115T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 100 kΩ, R2 = open 5. Limiting values Table 6: Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 50 V VEBO emitter-base voltage open collector - 5 V IO output current (DC) - 100 mA ICM peak collector current - 100 mA Ptot total power dissipation SOT416 Tamb ≤ 25 °C [1] - 150 mW SOT346 Tamb ≤ 25 °C [1] - 250 mW SOT883 Tamb ≤ 25 °C [2] [3] - 250 mW SOT54 Tamb ≤ 25 °C [1] - 500 mW SOT23 Tamb ≤ 25 °C [1] - 250 mW SOT323 Tamb ≤ 25 °C [1] - 200 mW −65 +150 °C Tstg storage temperature Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C [1] Refer to standard mounting conditions. [2] Reflow soldering is the only recommended soldering method. [3] Refer to SOT883 standard mounting conditions; FR4 printed-circuit board with 60 µm copper strip line. 6. Thermal characteristics Table 7: Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Typ Max Unit SOT416 [1] - - 833 K/W SOT346 [1] - - 500 K/W SOT883 [2] [3] - - 500 K/W SOT54 [1] - - 250 K/W SOT23 [1] - - 500 K/W SOT323 [1] - - 625 K/W [1] Refer to standard mounting conditions. [2] Reflow soldering is the only recommended soldering method. [3] Refer to SOT883 standard mounting conditions; FR4 printed-circuit board with 60 µm copper strip line. 9397 750 14021 Product data sheet Min © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 04 — 17 February 2005 4 of 10 PDTC115T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 100 kΩ, R2 = open 7. Characteristics Table 8: Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 50 V; IE = 0 A - - 100 nA ICEO collector-emitter cut-off current VCE = 30 V; IB = 0 A - - 1 µA VCE = 30 V; IB = 0 A; Tj = 150 °C - - 50 µA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 nA hFE DC current gain VCE = 5 V; IC = 1 mA 100 - - VCEsat collector-emitter saturation voltage IC = 5 mA; IB = 0.25 mA - - 150 mV R1 bias resistor 1 (input) 70 100 130 kΩ Cc collector capacitance - - 2.5 pF IE = ie = 0 A; VCB = 10 V; f = 1 MHz 006aaa058 103 hFE 006aaa059 1 VCEsat (V) (1) (2) 10−1 (3) (1) (2) (3) 102 10−1 1 102 10 10−2 10−1 IC (mA) 102 10 IC (mA) VCE = 5 V IC/IB = 20 (1) Tamb = 100 °C (1) Tamb = 100 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −40 °C (3) Tamb = −40 °C Fig 1. DC current gain as a function of collector current; typical values Fig 2. Collector-emitter saturation voltage as a function of collector current; typical values 9397 750 14021 Product data sheet 1 © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 04 — 17 February 2005 5 of 10 PDTC115T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 100 kΩ, R2 = open 8. Package outline 3 3 0.45 0.15 0.6 0.2 3.0 1.7 2.5 1.3 1.75 0.9 1.45 0.7 1 2 1 0.30 0.15 2 0.25 0.10 Dimensions in mm 04-11-04 Fig 3. Package outline SOT416 (SC-75) 0.62 0.55 0.55 0.47 0.50 0.35 1.9 1 0.26 0.10 Dimensions in mm 04-11-11 Fig 4. Package outline SOT346 (SC-59A/TO-236) 0.50 0.46 0.45 0.38 4.2 3.6 3 0.30 0.22 2 0.48 0.40 1.02 0.95 0.65 0.30 0.22 1.3 1.0 3.1 2.7 0.95 0.60 1.8 1.4 1 2 4.8 4.4 1 0.20 0.12 2.54 3 5.2 5.0 0.35 Dimensions in mm 03-04-03 Fig 5. Package outline SOT883 (SC-101) 14.5 12.7 Dimensions in mm 04-11-16 Fig 6. Package outline SOT54 (SC-43A/TO-92) 0.45 0.38 0.45 0.38 4.2 3.6 1.27 4.2 3.6 1.27 0.48 0.40 3 max 1 2.5 max 0.48 0.40 1 2 4.8 4.4 5.08 2.54 2 4.8 4.4 2.54 3 1.27 3 5.2 5.0 5.2 5.0 14.5 12.7 Dimensions in mm Fig 7. Package outline SOT54A 04-06-28 Dimensions in mm 05-01-10 Fig 8. Package outline SOT54 variant 9397 750 14021 Product data sheet 14.5 12.7 © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 04 — 17 February 2005 6 of 10 PDTC115T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 100 kΩ, R2 = open 3.0 2.8 1.1 0.9 2.2 1.8 1.1 0.8 0.45 0.15 3 3 0.45 0.15 2.5 1.4 2.1 1.2 2.2 1.35 2.0 1.15 1 1 2 1.9 0.48 0.38 Dimensions in mm 2 0.4 0.3 0.15 0.09 1.3 04-11-04 Fig 9. Package outline SOT23 (TO-236AB) 0.25 0.10 Dimensions in mm 04-11-04 Fig 10. Package outline SOT323 (SC-70) 9. Packing information Table 9: Packing methods The indicated -xxx are the last three digits of the 12NC ordering code. [1] Type number Package Description Packing quantity 3000 5000 10000 PDTC115TE SOT416 4 mm pitch, 8 mm tape and reel -115 - -135 PDTC115TK SOT346 4 mm pitch, 8 mm tape and reel -115 - -135 PDTC115TM SOT883 2 mm pitch, 8 mm tape and reel - - -315 PDTC115TS SOT54 bulk, straight leads - -412 - PDTC115TS SOT54A tape and reel, wide pitch - - -116 PDTC115TS SOT54A tape ammopack, wide pitch - - -126 PDTC115TS SOT54 variant bulk, delta pinning - -112 - PDTC115TT SOT23 4 mm pitch, 8 mm tape and reel -215 - -235 PDTC115TU SOT323 4 mm pitch, 8 mm tape and reel -115 - -135 [1] For further information and the availability of packing methods, see Section 14. 9397 750 14021 Product data sheet © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 04 — 17 February 2005 7 of 10 PDTC115T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 100 kΩ, R2 = open 10. Revision history Table 10: Revision history Document ID Release date Data sheet status Change notice Doc. number Supersedes PDTC115T_SER_4 20050217 Product data sheet - 9397 750 14021 PDTC115TT_3 Modifications • The types PDTC115TE, PDTC115TK, PDTC115TM, PDTC115TS and PDTC115TU were added. • • • Table 1 “Product overview” added Figure 1 and 2 added Section 9 “Packing information” added PDTC115TT_3 20040727 Product data sheet - 9397 750 13505 PDTC115TT_2 PDTC115TT_2 20040510 Objective data sheet - 9397 750 13206 PDTC115TT_1 PDTC115TT_1 20040305 Objective data sheet - 9397 750 12554 - 9397 750 14021 Product data sheet © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 04 — 17 February 2005 8 of 10 PDTC115T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 100 kΩ, R2 = open 11. Data sheet status Level Data sheet status [1] Product status [2] [3] Definition I Objective data Development This data sheet contains data from the objective specification for product development. Philips Semiconductors reserves the right to change the specification in any manner without notice. II Preliminary data Qualification This data sheet contains data from the preliminary specification. Supplementary data will be published at a later date. Philips Semiconductors reserves the right to change the specification without notice, in order to improve the design and supply the best possible product. III Product data Production This data sheet contains data from the product specification. Philips Semiconductors reserves the right to make changes at any time in order to improve the design, manufacturing and supply. Relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). [1] Please consult the most recently issued data sheet before initiating or completing a design. [2] The product status of the device(s) described in this data sheet may have changed since this data sheet was published. The latest information is available on the Internet at URL http://www.semiconductors.philips.com. [3] For data sheets describing multiple type numbers, the highest-level product status determines the data sheet status. 12. Definitions 13. Disclaimers Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Life support — These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 60134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information — Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Right to make changes — Philips Semiconductors reserves the right to make changes in the products - including circuits, standard cells, and/or software - described or contained herein in order to improve design and/or performance. When the product is in full production (status ‘Production’), relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified. 14. Contact information For additional information, please visit: http://www.semiconductors.philips.com For sales office addresses, send an email to: sales.addresses@www.semiconductors.philips.com 9397 750 14021 Product data sheet © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 04 — 17 February 2005 9 of 10 PDTC115T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 100 kΩ, R2 = open 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description. . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Quick reference data. . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics. . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Packing information. . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Contact information . . . . . . . . . . . . . . . . . . . . . 1 1 1 1 1 2 3 3 4 4 5 6 7 8 9 9 9 9 © Koninklijke Philips Electronics N.V. 2005 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Date of release: 17 February 2005 Document number: 9397 750 14021 Published in The Netherlands
PDTC115TU,115 价格&库存
很抱歉,暂时无法提供与“PDTC115TU,115”相匹配的价格&库存,您可以联系我们找货
PDTC115TU,115
PDTC115TU,115
  • 3000+0.233963000+0.03017
