PDTC143/114/124/144EQA
series
50 V, 100 mA NPN resistor-equipped transistors
Rev. 1 — 30 October 2015
Product data sheet
1. Product profile
1.1 General description
100 mA NPN Resistor-Equipped Transistor (RET) family in a leadless ultra small
DFN1010D-3 (SOT1215) Surface-Mounted Device (SMD) plastic package with visible
and solderable side pads.
Table 1.
Product overview
Type number
R1
R2
Nexperia
PNP complement
PDTC143EQA
4.7 k
4.7 k
PDTA143EQA
PDTC114EQA
10 k
10 k
DFN1010D-3
(SOT1215)
PDTC124EQA
22 k
22 k
PDTA124EQA
PDTC144EQA
47 k
47 k
PDTA144EQA
PDTA114EQA
1.2 Features and benefits
100 mA output current capability
Built-in bias resistors
Simplifies circuit design
Reduces component count
Reduced pick and place costs
Low package height of 0.37 mm
AEC-Q101 qualified
Suitable for Automatic Optical
Inspection (AOI) of solder joint
1.3 Applications
Digital applications
Cost saving alternative for
BC847/BC857 series in digital
applications
Controlling IC inputs
Switching loads
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter voltage
open base
50
V
IO
output current
100
mA
PDTC143/114/124/144EQA series
Nexperia
2. Pinning information
Table 3.
Pinning
Pin
Symbol
Description
1
I
input (base)
2
GND
GND (emitter)
Simplified outline
Graphic symbol
O
1
3
O
output (collector)
4
O
output (collector)
R1
I
4
3
R2
GND
2
aaa-019964
Transparent top view
3. Ordering information
Table 4.
Type number
PDTC143EQA
PDTC114EQA
PDTC124EQA
Package
Name
Description
Version
DFN1010D-3
plastic thermal enhanced ultra thin small outline
package; no leads; 3 terminals;
body: 1.1 1.0 0.37 mm
SOT1215
PDTC144EQA
PDTC143_114_124_144EQA_SER
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 21
Nexperia
4. Marking
Table 5.
Marking codes
Type number
Marking code
PDTC143EQA
10 10 01
PDTC114EQA
11 01 10
PDTC124EQA
10 11 01
PDTC144EQA
10 01 10
4.1 Binary marking code description
READING
DIRECTION
MARKING CODE
(EXAMPLE)
YEAR DATE
CODE
VENDOR CODE
PIN 1
INDICATION MARK
MARK-FREE AREA
READING EXAMPLE:
11
01
10
aaa-008041
Fig 1.
Product data sheet
SOT1215 binary marking code description
3 of 21
Nexperia
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
50
V
VCEO
open base
VEBO
emitter-base voltage
VI
input voltage
50
V
10
V
PDTC143EQA
10
+30
V
PDTC114EQA
10
+40
V
PDTC124EQA
10
+40
V
PDTC144EQA
10
+40
V
output current
IO
Tamb 25 C
total power dissipation
Ptot
100
mA
[1]
280
mW
[2]
440
mW
Tj
junction temperature
150
C
Tamb
ambient temperature
55
+150
C
Tstg
storage temperature
65
+150
C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[2]
Device mounted on an FR4 PCB, 4-layer copper, tin-plated and standard footprint.
aaa-017637
500
Ptot
(mW)
(1)
400
300
(2)
200
100
-25
25
75
125
175
Tamb (°C)
(1) FR4 PCB, 4-layer copper, standard footprint
(2) FR4 PCB, standard footprint
Fig 2.
Product data sheet
Power derating curves
4 of 21
Nexperia
6. Thermal characteristics
Table 7.
Symbol
Parameter
Conditions
thermal resistance from junction
to ambient
Rth(j-a)
in free air
Min
Typ
Max
Unit
[1]
446
K/W
[2]
284
K/W
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
aaa-017638
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
0.50
102
0.33
0.20
0.10
0.05
10
0.02
0.01
10-5
10-4
10-3
10-2
10-1
1
10
102
103
tp (s)
Fig 3.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
aaa-017639
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
102
0.50
0.33
0.20
0.10
0.05
10
0.02
1
10-5
10-4
10-3
10-2
10-1
1
10
102
103
tp (s)
Fig 4.
Product data sheet
5 of 21
Nexperia
7. Characteristics
Table 8.
Characteristics
Tamb = 25 C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
collector-base cut-off
current
VCB = 50 V; IE = 0 A
100
nA
ICEO
collector-emitter cut-off VCE = 30 V; IB = 0 A
current
VCE = 30 V; IB = 0 A; Tj = 150 C
1
A
5
A
IEBO
emitter-base cut-off current
900
A
PDTC114EQA
400
A
PDTC124EQA
180
A
PDTC144EQA
90
A
PDTC143EQA
VEB = 5 V; IC = 0 A
DC current gain
hFE
PDTC143EQA
VCE = 5 V; IC = 10 mA
30
PDTC114EQA
VCE = 5 V; IC = 5 mA
30
60
PDTC124EQA
PDTC144EQA
VCEsat
collector-emitter
saturation voltage
VI(off)
off-state input voltage
R1
150
mV
VCE = 5 V; IC = 100 A
1.1
0.5
V
1.1
0.8
V
PDTC124EQA
1.1
0.8
V
PDTC144EQA
1.2
0.8
V
on-state input voltage
PDTC143EQA
VCE = 0.3 V; IC = 20 mA
2.5
1.9
V
PDTC114EQA
VCE = 0.3 V; IC = 10 mA
2.5
1.8
V
PDTC124EQA
VCE = 0.3 V; IC = 5 mA
2.5
1.7
V
PDTC144EQA
VCE = 0.3 V; IC = 2 mA
3
1.6
V
PDTC143EQA
3.3
4.7
6.1
k
PDTC114EQA
7
10
13
k
PDTC124EQA
15.4
22
28.6
k
PDTC144EQA
33
47
61
k
0.8
1
1.2
2.5
pF
230
MHz
[1]
bias resistor 1 (input)
R2/R1
bias resistor ratio
Cc
collector capacitance
fT
PDTC114EQA
PDTC143EQA
VI(on)
80
IC = 10 mA; IB = 0.5 mA
transition frequency
[1]
VCB = 10 V; IE = ie = 0 A; f = 1 MHz
VCE = 5 V; IC = 10 mA; f = 100 MHz
[1]
See Section 8 “Test information” for resistor calculation and test conditions.
[2]
Characteristics of built-in transistor.
Product data sheet
[2]
6 of 21
Nexperia
006aac831
103
aaa-018583
0.1
0.80 mA
IC
(A)
hFE
(1)
0.72 mA
0.64 mA
0.08
(2)
0.56 mA
(3)
102
0.48 mA
0.06
0.40 mA
0.32 mA
0.04
10
0.24 mA
0.02
IB = 0.16 mA
1
10-1
1
10
2
3
4
IC (mA)
5
VCE (V)
Tamb = 25 C
VCE = 5 V
(1) Tamb = 100 C
(2) Tamb = 25 C
(3) Tamb = 40 C
Fig 5.
PDTC143EQA: DC current gain as a function of
collector current; typical values
Fig 6.
006aac832
1
PDTC143EQA: Collector current as a function
of collector-emitter voltage; typical values
006aac833
10
VI(on)
(V)
VCEsat
(V)
(1)
(1)
(2)
(2)
(3)
10-1
(3)
1
10-2
1
102
10
10-1
10-1
1
102
10
IC (mA)
IC (mA)
IC/IB = 20
VCE = 0.3 V
(1) Tamb = 100 C
(1) Tamb = 40 C
(2) Tamb = 25 C
(2) Tamb = 25 C
(3) Tamb = 40 C
(3) Tamb = 100 C
Fig 7.
PDTC143EQA: Collector-emitter saturation
voltage as a function of collector current;
typical values
Product data sheet
Fig 8.
PDTC143EQA: On-state input voltage as a
function of collector current; typical values
7 of 21
Nexperia
006aac834
10
006aac835
3
Cc
(pF)
VI(off)
(V)
2
(1)
(2)
1
(3)
1
10-1
10-1
10
40
50
VCB (V)
IC (mA)
f = 1 MHz; Tamb = 25 C
VCE = 5 V
(1) Tamb = 40 C
(2) Tamb = 25 C
(3) Tamb = 100 C
Fig 9.
PDTC143EQA: Off-state input voltage as a
Product data sheet
Fig 10. PDTC143EQA: Collector capacitance as a
function of collector-base voltage; typical
values
8 of 21
Nexperia
006aac768
103
aaa-018663
0.1
0.60 mA
0.54 mA
0.48 mA
IC
(A)
hFE
(1)
(2)
(3)
102
0.08
0.42 mA
0.36 mA
0.06
0.30 mA
0.24 mA
0.04
0.18 mA
10
0.12 mA
0.02
IB = 0.06 mA
1
10-1
1
102
10
2
3
4
IC (mA)
5
VCE (V)
Tamb = 25 C
VCE = 5 V
(1) Tamb = 100 C
(2) Tamb = 25 C
(3) Tamb = 40 C
Fig 11. PDTC114EQA: DC current gain as a function of
006aac769
1
Fig 12. PDTC114EQA: Collector current as a function
006aac770
10
VI(on)
(V)
VCEsat
(V)
(1)
(2)
10-1
1
(3)
(1)
(2)
(3)
10-2
1
102
10
10-1
10-1
1
102
10
IC (mA)
IC (mA)
IC/IB = 20
VCE = 0.3 V
(1) Tamb = 100 C
(1) Tamb = 40 C
(2) Tamb = 25 C
(2) Tamb = 25 C
(3) Tamb = 40 C
(3) Tamb = 100 C
Fig 13. PDTC114EQA: Collector-emitter saturation
typical values
Product data sheet
Fig 14. PDTC114EQA: On-state input voltage as a
9 of 21
Nexperia
006aac771
10
006aac772
3
Cc
(pF)
VI(off)
(V)
2
(1)
(2)
1
(3)
1
10-1
10-1
10
40
50
VCB (V)
IC (mA)
VCE = 5 V
(1) Tamb = 40 C
(2) Tamb = 25 C
(3) Tamb = 100 C
Fig 15. PDTC114EQA: Off-state input voltage as a
Product data sheet
Fig 16. PDTC114EQA: Collector capacitance as a
values
10 of 21
Nexperia
006aac794
103
aaa-018665
0.1
0.60 mA
IC
(A)
hFE
(1)
0.54 mA
0.48 mA
0.42 mA
0.08
(2)
0.36 mA
(3)
102
0.30 mA
0.06
0.24 mA
0.18 mA
0.04
10
0.12 mA
0.02
IB = 0.06 mA
1
10-1
1
102
10
2
3
4
IC (mA)
5
VCE (V)
Tamb = 25 C
VCE = 5 V
(1) Tamb = 100 C
(2) Tamb = 25 C
(3) Tamb = 40 C
Fig 17. PDTC124EQA: DC current gain as a function of
aaa-018664
1
Fig 18. PDTC124EQA: Collector current as a function
006aac796
10
VI(on)
(V)
VCEsat
(V)
(1)
(2)
(3)
10-1
1
(1)
(2)
(3)
10-2
10-1
1
102
10
10-1
10-1
1
102
10
IC (mA)
IC (mA)
IC/IB = 20
VCE = 0.3 V
(1) Tamb = 100 C
(1) Tamb = 40 C
(2) Tamb = 25 C
(2) Tamb = 25 C
(3) Tamb = 40 C
(3) Tamb = 100 C
Fig 19. PDTC124EQA: Collector-emitter saturation
typical values
Product data sheet
Fig 20. PDTC124EQA: On-state input voltage as a
11 of 21
Nexperia
006aac797
10
006aac798
3
Cc
(pF)
VI(off)
(V)
2
(1)
(2)
(3)
1
1
10-1
10-1
10
40
50
VCB (V)
IC (mA)
VCE = 5 V
(1) Tamb = 40 C
(2) Tamb = 25 C
(3) Tamb = 100 C
Fig 21. PDTC124EQA: Off-state input voltage as a
Product data sheet
Fig 22. PDTC124EQA: Collector capacitance as a
values
12 of 21
Nexperia
006aac752
103
hFE
aaa-018667
0.1
0.08
0.60 mA 0.54 mA
0.48 mA
0.42 mA
0.06
0.30 mA
IC
(A)
(1)
(2)
(3)
102
0.36 mA
0.24 mA
0.04
0.18 mA
10
0.12 mA
0.02
IB = 0.06 mA
1
10-1
1
102
10
2
3
4
IC (mA)
5
VCE (V)
Tamb = 25 C
VCE = 5 V
(1) Tamb = 100 C
(2) Tamb = 25 C
(3) Tamb = 40 C
Fig 23. PDTC144EQA: DC current gain as a function of
aaa-018666
1
Fig 24. PDTC144EQA: Collector current as a function
006aac754
10
VI(on)
(V)
VCEsat
(V)
(1)
(2)
10-1
(3)
1
(1)
(2)
(3)
10-2
10-1
1
102
10
10-1
10-1
1
102
10
IC (mA)
IC (mA)
IC/IB = 20
VCE = 0.3 V
(1) Tamb = 100 C
(1) Tamb = 40 C
(2) Tamb = 25 C
(2) Tamb = 25 C
(3) Tamb = 40 C
(3) Tamb = 100 C
Fig 25. PDTC144EQA: Collector-emitter saturation
typical values
Product data sheet
Fig 26. PDTC144EQA: On-state input voltage as a
13 of 21
Nexperia
006aac755
10
006aac756
2.0
Cc
(pF)
1.6
VI(off)
(V)
(1)
1.2
(2)
(3)
1
0.8
0.4
10-1
10-1
0.0
1
10
40
50
VCB (V)
IC (mA)
VCE = 5 V
(1) Tamb = 40 C
(2) Tamb = 25 C
(3) Tamb = 100 C
Fig 27. PDTC144EQA: Off-state input voltage as a
Fig 28. PDTC144EQA: Collector capacitance as a
values
006aac757
103
fT
(MHz)
102
10
10-1
1
102
10
IC (mA)
VCE = 5 V; Tamb = 25 C
Fig 29. Transition frequency as a function of collector current; typical values of built-in transistor
Product data sheet
14 of 21
Nexperia
8. Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
8.2 Resistor calculation
• Calculation of bias resistor 1 (R1):
V I I2 – V I I1
R1 = -----------------------------------I I2 – I I1
• Calculation of bias resistor ratio (R2/R1):
V I I4 – V I I3
R2
-–1
------- = ----------------------------------R1
R1 I I4 – I 13
n.c.
II1; II2
R1
II3; II4
R2
GND
aaa-020082
Fig 30. Resistor test circuit
8.3 Resistor test conditions
Table 9.
Product data sheet
Type number
R1 (k)
R2 (k)
Test conditions
II1
II2
II3
II4
PDTC143EQA
4.7
4.7
600 A
700 A
-600 A
-700 A
PDTC114EQA
10
10
350 A
450 A
-350 A
-450 A
PDTC124EQA
22
22
150 A
230 A
-150 A
-230 A
PDTC144EQA
47
47
55 A
105 A
-55 A
-105 A
15 of 21
Nexperia
9. Package outline
0.87
0.95
0.75
1
0.95
1.05
2
0.34
0.40
Dimensions in mm
0.17
0.25
0.16
0.24
0.1
3
0.04
max
0.22
0.30
0.245
0.325
0.195
0.275
1.05
1.15
13-03-05
Fig 31. Package outline DFN1010D-3 (SOT1215)
Product data sheet
16 of 21
Nexperia
10. Soldering
Footprint information for reflow soldering of DFN1010D-3 package
SOT1215
1.2
0.45 (2x)
0.3
1.1
0.35 (2x)
0.4
0.25 (2x)
0.75
0.3
0.5
1.5
1.4
0.4
0.5
0.4
0.3
0.5
1.3
0.4
0.3
0.4
0.5
1.3
solder land
solder land plus solder paste
occupied area
solder resist
Dimensions in mm
Issue date
12-11-23
13-03-06
sot1215_fr
Fig 32. Reflow soldering footprint DFN1010D-3 (SOT1215)
Product data sheet
17 of 21
Nexperia
11. Revision history
Table 10.
Revision history
Document ID
Release date
PDTC143_114_124_144EQA 20151030
_SER v.1
Product data sheet
Data sheet status
Change notice Supersedes
Product data sheet
18 of 21
Nexperia
12. Legal information
12.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
19 of 21
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
12.4 Trademarks
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
13. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Product data sheet
20 of 21
Nexperia
14. Contents
1
1.1
1.2
1.3
1.4
2
3
4
4.1
5
6
7
8
8.1
8.2
8.3
9
10
11
12
12.1
12.2
12.3
12.4
13
14
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Binary marking code description. . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Thermal characteristics . . . . . . . . . . . . . . . . . . 5
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Test information . . . . . . . . . . . . . . . . . . . . . . . . 15
Quality information . . . . . . . . . . . . . . . . . . . . . 15
Resistor calculation . . . . . . . . . . . . . . . . . . . . 15
Resistor test conditions . . . . . . . . . . . . . . . . . 15
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 16
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 18
Legal information. . . . . . . . . . . . . . . . . . . . . . . 19
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 19
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Contact information. . . . . . . . . . . . . . . . . . . . . 20
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Date of release: 30 October 2015
