PDTC123TM,315
PDTC123TM,315
    NEXPERIA(安世)
    SOT883
    NPN电阻晶体管;R1=2.2 kΩ, R2=打开
PDTC123TM,315 数据手册
PDTC123T series NPN resistor-equipped transistors; R1 = 2.2 kΩ, R2 = open Rev. 01 — 10 March 2006 Product data sheet 1. Product profile 1.1 General description NPN Resistor-Equipped Transistors (RET) family in Surface Mounted Device (SMD) plastic packages. Table 1. Product overview Type number Package PNP complement Philips JEITA JEDEC PDTC123TE SOT416 SC-75 - PDTA123TE PDTC123TK SOT346 SC-59A TO-236 PDTA123TK PDTC123TM SOT883 SC-101 - PDTA123TM PDTC123TS[1] SOT54 SC-43A TO-92 PDTA123TS PDTC123TT SOT23 - TO-236AB PDTA123TT PDTC123TU SOT323 SC-70 - PDTA123TU [1] Also available in SOT54A and SOT54 variant packages (see Section 2). 1.2 Features n Built-in bias resistors n Simplifies circuit design n 100 mA output current capability n Reduces component count n Reduces pick and place costs 1.3 Applications n Digital applications n Control of IC inputs n Cost-saving alternative for BC847 series in digital applications n Switching loads 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 50 V IO output current - - 100 mA R1 bias resistor 1 (input) 1.54 2.2 2.86 kΩ PDTC123T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 2.2 kΩ, R2 = open 2. Pinning information Table 3. Pinning Pin Description Simplified outline Symbol SOT54 1 input (base) 2 output (collector) 3 GND (emitter) 2 1 2 3 R1 1 001aab347 3 006aaa218 SOT54A 1 input (base) 2 output (collector) 3 GND (emitter) 2 1 2 R1 1 3 001aab348 3 006aaa218 SOT54 variant 1 input (base) 2 output (collector) 3 GND (emitter) 2 1 2 3 R1 1 001aab447 3 006aaa218 SOT23; SOT323; SOT346; SOT416 1 input (base) 2 GND (emitter) 3 output (collector) 3 3 R1 1 1 2 2 006aaa144 sym012 SOT883 1 input (base) 2 GND (emitter) 1 3 output (collector) 2 3 3 R1 1 Transparent top view 2 sym012 © PDTC123T_SER_1 Product data sheet Rev. 01 — 10 March 2006 Nexperia B.V. 2017. All rights reserved 2 of 10 PDTC123T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 2.2 kΩ, R2 = open 3. Ordering information Table 4. Ordering information Type number Package Name Description Version SC-75 plastic surface mounted package; 3 leads SOT416 PDTC123TK SC-59A plastic surface mounted package; 3 leads SOT346 PDTC123TM SC-101 leadless ultra small plastic package; 3 solder lands; body 1.0 × 0.6 × 0.5 mm SOT883 PDTC123TS[1] SC-43A plastic single-ended leaded (through hole) package; 3 leads SOT54 PDTC123TT - plastic surface mounted package; 3 leads SOT23 PDTC123TU SC-70 plastic surface mounted package; 3 leads SOT323 PDTC123TE [1] Also available in SOT54A and SOT54 variant packages (see Section 2 and Section 9). 4. Marking Table 5. Marking codes Type number Marking code[1] PDTC123TE 2B PDTC123TK GB PDTC123TM FB PDTC123TS TC123T PDTC123TT ZM* PDTC123TU *1T [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China © PDTC123T_SER_1 Product data sheet Rev. 01 — 10 March 2006 Nexperia B.V. 2017. All rights reserved 3 of 10 PDTC123T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 2.2 kΩ, R2 = open 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 50 V VEBO emitter-base voltage open collector - 5 V IO output current - 100 mA ICM peak collector current single pulse; tp ≤ 1 ms - 100 mA Ptot total power dissipation Tamb ≤ 25 °C SOT416 [1] - 150 mW SOT346 [1] - 250 mW SOT883 [2][3] - 250 mW SOT54 [1] - 500 mW SOT23 [1] - 250 mW SOT323 [1] - 200 mW Tstg storage temperature −65 +150 °C Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Reflow soldering is the only recommended soldering method. [3] Device mounted on an FR4 PCB with 60 µm copper strip line, standard footprint. 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Typ Max Unit SOT416 [1] - - 833 K/W SOT346 [1] - - 500 K/W SOT883 [2][3] - - 500 K/W SOT54 [1] - - 250 K/W SOT23 [1] - - 500 K/W SOT323 [1] - - 625 K/W [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Reflow soldering is the only recommended soldering method. [3] Device mounted on an FR4 PCB with 60 µm copper strip line, standard footprint. © PDTC123T_SER_1 Product data sheet Min Rev. 01 — 10 March 2006 Nexperia B.V. 2017. All rights reserved 4 of 10 PDTC123T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 2.2 kΩ, R2 = open 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 50 V; IE = 0 A - - 100 nA ICEO collector-emitter cut-off current VCE = 30 V; IB = 0 A - - 1 µA VCE = 30 V; IB = 0 A; Tj = 150 °C - - 50 µA nA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 hFE DC current gain VCE = 5 V; IC = 20 mA 30 - - VCEsat collector-emitter saturation voltage IC = 10 mA; IB = 0.5 mA - - 150 mV R1 bias resistor 1 (input) 1.54 2.2 2.86 kΩ Cc collector capacitance - - 2.5 pF 006aaa696 500 VCB = 10 V; IE = ie = 0 A; f = 1 MHz 006aaa697 1 hFE (1) 400 VCEsat (V) (2) 300 10−1 (1) (2) (3) (3) 200 100 0 10−1 1 102 10 10−2 10−1 1 102 10 IC (mA) IC (mA) VCE = 5 V IC/IB = 20 (1) Tamb = 100 °C (1) Tamb = 100 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −40 °C (3) Tamb = −40 °C Fig 1. DC current gain as a function of collector current; typical values Fig 2. Collector-emitter saturation voltage as a function of collector current; typical values © PDTC123T_SER_1 Product data sheet Rev. 01 — 10 March 2006 Nexperia B.V. 2017. All rights reserved 5 of 10 PDTC123T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 2.2 kΩ, R2 = open 8. Package outline 3 3 0.45 0.15 0.6 0.2 3.0 1.7 2.5 1.3 1.75 0.9 1.45 0.7 1 2 1 0.30 0.15 2 0.25 0.10 Dimensions in mm 04-11-04 Fig 3. Package outline SOT416 (SC-75) 0.62 0.55 0.55 0.47 0.50 0.35 1.9 1 0.26 0.10 Dimensions in mm 04-11-11 Fig 4. Package outline SOT346 (SC-59A/TO-236) 0.50 0.46 0.45 0.38 4.2 3.6 3 0.30 0.22 2 0.48 0.40 1.02 0.95 0.65 0.30 0.22 1.3 1.0 3.1 2.7 0.95 0.60 1.8 1.4 1 2 4.8 4.4 1 0.20 0.12 2.54 3 5.2 5.0 0.35 Dimensions in mm 03-04-03 Fig 5. Package outline SOT883 (SC-101) 14.5 12.7 Dimensions in mm 04-11-16 Fig 6. Package outline SOT54 (SC-43A/TO-92) 0.45 0.38 0.45 0.38 4.2 3.6 1.27 4.2 3.6 1.27 0.48 0.40 3 max 1 2.5 max 0.48 0.40 1 2 4.8 4.4 5.08 2.54 2 4.8 4.4 2.54 3 1.27 3 5.2 5.0 5.2 5.0 14.5 12.7 Dimensions in mm Fig 7. Package outline SOT54A 04-06-28 Dimensions in mm 05-01-10 Fig 8. Package outline SOT54 variant © PDTC123T_SER_1 Product data sheet 14.5 12.7 Rev. 01 — 10 March 2006 Nexperia B.V. 2017. All rights reserved 6 of 10 PDTC123T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 2.2 kΩ, R2 = open 3.0 2.8 1.1 0.9 2.2 1.8 1.1 0.8 0.45 0.15 3 3 0.45 0.15 2.5 1.4 2.1 1.2 2.2 1.35 2.0 1.15 1 1 2 0.48 0.38 1.9 Dimensions in mm 0.25 0.10 1.3 04-11-04 Fig 9. Package outline SOT23 (TO-236AB) 2 0.4 0.3 0.15 0.09 Dimensions in mm 04-11-04 Fig 10. Package outline SOT323 (SC-70) 9. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description 3000 5000 10000 PDTC123TE SOT416 4 mm pitch, 8 mm tape and reel -115 - -135 PDTC123TK SOT346 4 mm pitch, 8 mm tape and reel -115 - -135 PDTC123TM SOT883 2 mm pitch, 8 mm tape and reel - - -315 PDTC123TS SOT54 bulk, straight leads - -412 - SOT54A tape and reel, wide pitch - - -116 tape ammopack, wide pitch - - -126 SOT54 variant bulk, delta pinning - -112 - PDTC123TT SOT23 4 mm pitch, 8 mm tape and reel -215 - -235 PDTC123TU SOT323 4 mm pitch, 8 mm tape and reel -115 - -135 [1] For further information and the availability of packing methods, see Section 12. © PDTC123T_SER_1 Product data sheet Packing quantity Rev. 01 — 10 March 2006 Nexperia B.V. 2017. All rights reserved 7 of 10 PDTC123T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 2.2 kΩ, R2 = open 10. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes PDTC123T_SER_1 20060310 Product data sheet - - © PDTC123T_SER_1 Product data sheet Rev. 01 — 10 March 2006 Nexperia B.V. 2017. All rights reserved 8 of 10 PDTC123T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 2.2 kΩ, R2 = open 11. Legal information 11.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.semiconductors.philips.com. 11.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Philips Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Philips Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 11.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Philips Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Philips Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Philips products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Philips product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Philips accepts no liability for inclusion and/or use of Philips products in such equipment or applications and therefore such inclusion and/or use is for the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Philips products are sold subject to the general terms and conditions of commercial sale, as published at http://www.semiconductors.philips.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Philips Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 11.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 12. Contact information For additional information, please visit: http://www.semiconductors.philips.com For sales office addresses, send an email to: sales.addresses@www.semiconductors.philips.com © PDTC123T_SER_1 Product data sheet Rev. 01 — 10 March 2006 Nexperia B.V. 2017. All rights reserved 9 of 10 PDTC123T series Philips Semiconductors NPN resistor-equipped transistors; R1 = 2.2 kΩ, R2 = open 13. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 11.1 11.2 11.3 11.4 12 13 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 3 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Thermal characteristics. . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6 Packing information. . . . . . . . . . . . . . . . . . . . . . 7 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Contact information. . . . . . . . . . . . . . . . . . . . . . 9 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 March 2006
PDTC123TM,315 价格&库存
很抱歉,暂时无法提供与“PDTC123TM,315”相匹配的价格&库存,您可以联系我们找货
