PHPT610030NK
NPN/NPN high power double bipolar transistor
20 October 2014
Product data sheet
1. General description
NPN/NPN high power double bipolar transistor in a SOT1205 (LFPAK56D) SurfaceMounted Device (SMD) power plastic package.
PNP/PNP complement: PHPT610030PK.
NPN/PNP complement: PHPT610030NPK.
2. Features and benefits
High thermal power dissipation capability
Suitable for high temperature applications up to 175 °C
Reduced Printed-Circuit Board (PCB) requirements comparing to transistors in DPAK
High energy efficiency due to less heat generation
AEC-Q101 qualified
3. Applications
Motor control
Power management
Load switch
Linear mode voltage regulator
Backlighting applications
Relay replacement
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter
voltage
open base
100
V
IC
collector current
3
A
75
110
mΩ
Per transistor
Per transistor
RCEsat
collector-emitter
saturation resistance
IC = 3 A; IB = 0.3 A; pulsed; tp ≤ 300 µs;
δ ≤ 0.02; Tamb = 25 °C
PHPT610030NK
Nexperia
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
E1
emitter TR1
2
B1
base TR1
3
E2
emitter TR2
4
B2
base TR2
5
C2
collector TR2
6
C2
collector TR2
7
C1
collector TR1
8
C1
collector TR1
Simplified outline
8
7
6
Graphic symbol
5
C1
B2
E2
TR2
TR1
E1
B1
C2
sym140
1
2
3
4
LFPAK56D (SOT1205)
6. Ordering information
Table 3.
Type number
Package
PHPT610030NK
Name
Description
Version
LFPAK56D
Plastic single ended surface mounted package (LFPAK56D); 8
leads
SOT1205
7. Marking
Table 4.
Marking codes
Type number
Marking code
PHPT610030NK
10030NK
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
100
V
VCEO
collector-emitter voltage
open base
100
V
VEBO
emitter-base voltage
open collector
7
V
IC
collector current
3
A
ICM
peak collector current
8
A
IB
base current
0.5
A
Per transistor
PHPT610030NK
Product data sheet
single pulse; tp ≤ 1 ms
All information provided in this document is subject to legal disclaimers.
20 October 2014
Nexperia B.V. 2017. All rights reserved
2 / 15
PHPT610030NK
Nexperia
Symbol
Parameter
Conditions
Ptot
total power dissipation
Tamb ≤ 25 °C
Min
Max
Unit
[1]
1
W
[2]
2.4
W
[3]
25
W
[1]
1.25
W
[4]
5
W
[2]
3
W
Per device
Ptot
Tamb ≤ 25 °C
Tj
junction temperature
175
°C
Tstg
storage temperature
-65
175
°C
Tamb
ambient temperature
-55
175
°C
[1]
[2]
[3]
[4]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm .
Power dissipation from junction to mounting base.
Device mounted on a ceramic PCB, Al2O3, standard footprint.
aaa-014341
4
Ptot
(W)
3
(1)
2
1
(2)
(1) FR4 PCB, mounting pad for collector 6 cm
(2) FR4 PCB, standard footprint
Fig. 1.
150
225
Tamb (°C)
2
Per transistor: power derating curves
PHPT610030NK
Product data sheet
20 October 2014
3 / 15
PHPT610030NK
Nexperia
9. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
thermal resistance
from junction to
ambient
in free air
Min
Typ
Max
Unit
[1]
150
K/W
[2]
62.5
K/W
6
K/W
[1]
120
K/W
[2]
50
K/W
[3]
30
K/W
Per transistor
Rth(j-a)
Rth(j-sp)
thermal resistance
from junction to solder
point
Per device
Rth(j-a)
thermal resistance
from junction to
ambient
[1]
[2]
[3]
in free air
aaa-014342
103
Zth(j-a)
(K/W)
102
duty cycle = 1
0.75
0.33
0.2
10
2
0.05
0.01
1
10-1
10-5
0.5
0.25
0.1
0.02
10-3
10-2
10-1
1
10
102
tp (s)
103
Fig. 2.
Per transistor: transient thermal impedance from junction to ambient as a function of pulse duration;
typical values
PHPT610030NK
Product data sheet
20 October 2014
4 / 15
PHPT610030NK
Nexperia
aaa-014343
102
Zth(j-a)
(K/W)
duty cycle = 1
0.75
0.5
0.33
10
0.25
0.2
0.1
0.05
1
0.02
10-1
10-5
10-4
10-3
10-2
Fig. 3.
10-1
1
102
10
tp (s)
103
2
typical values
10. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
collector-base cut-off
current
VCB = 80 V; IE = 0 A; Tamb = 25 °C
100
nA
VCB = 80 V; IE = 0 A; Tj = 150 °C
50
µA
Per transistor
ICBO
ICES
collector-emitter cut-off VCE = 80 V; VBE = 0 V; Tamb = 25 °C
current
100
nA
IEBO
emitter-base cut-off
current
VEB = 7 V; IC = 0 A; Tamb = 25 °C
100
nA
hFE
DC current gain
VCE = 10 V; IC = 500 mA; pulsed;
150
250
80
250
10
40
90
150
mV
225
330
mV
tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C
VCE = 10 V; IC = 1 A; pulsed;
VCE = 10 V; IC = 2 A; pulsed;
VCE = 10 V; IC = 3 A; pulsed;
VCEsat
collector-emitter
saturation voltage
IC = 1 A; IB = 50 mA; pulsed;
IC = 3 A; IB = 300 mA; pulsed;
PHPT610030NK
Product data sheet
20 October 2014
5 / 15
PHPT610030NK
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
RCEsat
collector-emitter
75
110
mΩ
0.86
1
V
1
1.2
V
0.67
0.85
V
VBEsat
base-emitter saturation IC = 1 A; IB = 50 mA; pulsed;
voltage
IC = 2 A; IB = 200 mA; pulsed;
VBEon
base-emitter turn-on
voltage
VCE = 2 V; IC = 0.1 A; pulsed;
td
delay time
VCC = 12.5 V; IC = 1 A; IBon = 50 mA;
ns
tr
rise time
IBoff = -50 mA; Tamb = 25 °C
300
ns
ton
turn-on time
320
ns
ts
storage time
830
ns
tf
fall time
470
ns
toff
turn-off time
1300
ns
fT
transition frequency
140
MHz
11
pF
VCE = 10 V; IC = 100 mA; f = 100 MHz;
Tamb = 25 °C
Cc
collector capacitance
VCB = 10 V; IE = 0 A; ie = 0 A;
f = 1 MHz; Tamb = 25 °C
aaa-010261
400
hFE
(1)
aaa-010267
3
IB = 50 mA
45
IC
(A)
300
40
35
30
2
(2)
200
25
10
(3)
1
5
100
1
10
102
104
IC (mA)
VCE = 10 V
1
2
3
4
VCE (V)
5
Tamb = 25 °C
(1) Tamb = 100 °C
Fig. 5.
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig. 4.
Collector current as a function of collectoremitter voltage; typical values
DC current gain as a function of collector
current; typical values
PHPT610030NK
Product data sheet
20 October 2014
6 / 15
PHPT610030NK
Nexperia
aaa-010262
1.2
aaa-010265
1.4
VBE
(V)
VBEsat
(V)
(1)
0.8
1.0
(2)
(1)
(3)
0.4
0.6
(2)
(3)
Fig. 6.
1
102
10
103
0.2
10-1
104
105
IC (mA)
1
102
10
VCE = 2 V
IC/IB = 20
(1) Tamb = −55 °C
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = 100 °C
Base-emitter voltage as a function of collector
Fig. 7.
aaa-010263
1
103
104
105
IC (mA)
Base-emitter saturation voltage as a function of
collector current; typical values
aaa-010264
10
VCEsat
(V)
VCEsat
(V)
1
10-1
(2)
(1)
(1)
(2)
(3)
10-1
(3)
10-2
10-2
10-3
10-1
1
10
102
10-3
10-1
103
104
IC (mA)
IC/IB = 20
Fig. 8.
1
(1) IC/IB = 50
(2) Tamb = 25 °C
(2) IC/IB = 20
(3) Tamb = −55 °C
(3) IC/IB = 10
Collector-emitter saturation voltage as a
function of collector current; typical values
Product data sheet
102
103
104
IC (mA)
Tamb = 25 °C
(1) Tamb = 100 °C
PHPT610030NK
10
Fig. 9.
20 October 2014
7 / 15
PHPT610030NK
Nexperia
aaa-010266
103
RCEsat
(Ω)
RCEsat
(Ω)
102
102
10
10
(1)
1
aaa-010268
103
1
(2)
10-1
10-2
10-1
(1)
(3)
1
10
102
(2)
10-1
10-2
10-1
103
104
IC (mA)
(3)
1
IC/IB = 20
Tamb = 25 °C
(1) Tamb = 100 °C
(1) IC/IB = 50
(2) Tamb = 25 °C
(2) IC/IB = 20
(3) Tamb = −55 °C
(3) IC/IB = 10
Fig. 10. Collector-emitter saturation resistance as a
PHPT610030NK
Product data sheet
10
102
103
104
IC (mA)
Fig. 11. Collector-emitter saturation resistance as a
20 October 2014
8 / 15
PHPT610030NK
Nexperia
11. Test information
IB
input pulse
(idealized waveform)
90 %
IBon (100 %)
10 %
IBoff
output pulse
IC
90 %
IC (100 %)
10 %
t
td
ts
tr
ton
tf
toff
006aaa003
Fig. 12. BISS transistor switching time definition
VBB
RB
VCC
RC
Vo
(probe)
oscilloscope
450 Ω
(probe)
450 Ω
R2
VI
oscilloscope
DUT
R1
mlb826
Fig. 13. Test circuit for switching times
11.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
PHPT610030NK
Product data sheet
20 October 2014
9 / 15
PHPT610030NK
Nexperia
12. Package outline
Plastic single ended surface mounted package LFPAK56D; 8 leads
E
SOT1205
A
A
b1
c1
L1
mounting
base
D
H
D1
D2
L
1
2
3
e
b
(8x)
4
w
X
c
A
E1
E2
A1
C
θ
Lp
detail X
A
max 1.05
nom
min
mm
5 mm
scale
Dimensions
Unit
y C
c
c1
D(1) D1(1)
A1
b
b1
0.1
0.50
4.4
0.25 0.30 4.70
0.0
0.35
4.1
0.19 0.24 4.45
4.8
D2
(ref)
3.5
E(1) E1(1)
5.30
1.8
4.95
1.6
E2
0.85
e
1.27
H
L
L1
Lp
6.2
1.3
0.55 0.85
5.9
0.8
0.30 0.40
w
y
0.25
0.1
Note
1. Plastic or metal protrusions of 0.2 mm maximum per side are not included.
Outline
version
References
IEC
JEDEC
JEITA
θ
8°
0°
sot1205_po
European
projection
Issue date
13-02-21
14-08-21
SOT1205
Fig. 14. Package outline LFPAK56D (SOT1205)
PHPT610030NK
Product data sheet
20 October 2014
10 / 15
PHPT610030NK
Nexperia
13. Soldering
Footprint information for reflow soldering of LFPAK56D package
SOT1205
5.85
3.81
1.27
0.7 (4x)
3.2
3.175
3.325
2.0
1.275
0.8
1.875
2.1
1.0 (2x)
2.7
3.85 3.975
0.0625
0.025
0.7 (4x)
1.44
1.27
1.1 (2x)
3.81
solder land
solder land plus solder paste
solder paste deposit
solder resist
occupied area
Dimensions in mm
sot1205_fr
Fig. 15. Reflow soldering footprint for LFPAK56D (SOT1205)
PHPT610030NK
Product data sheet
20 October 2014
11 / 15
PHPT610030NK
Nexperia
14. Revision history
Table 8.
Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PHPT610030NK v.1
20141020
Product data sheet
PHPT610030NK
Product data sheet
20 October 2014
12 / 15
PHPT610030NK
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
15. Legal information
15.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
15.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
PHPT610030NK
Product data sheet
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
20 October 2014
13 / 15
PHPT610030NK
Nexperia
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PHPT610030NK
Product data sheet
20 October 2014
14 / 15
PHPT610030NK
Nexperia
16. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 2
8
Limiting values .......................................................2
9
Thermal characteristics .........................................4
10
Characteristics ....................................................... 5
11
11.1
Test information ..................................................... 9
Quality information ............................................... 9
12
Package outline ................................................... 10
13
Soldering .............................................................. 11
14
Revision history ................................................... 12
15
15.1
15.2
15.3
15.4
Legal information .................................................13
Data sheet status ............................................... 13
Definitions ...........................................................13
Disclaimers .........................................................13
Trademarks ........................................................ 14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 20 October 2014
PHPT610030NK
Product data sheet
20 October 2014
15 / 15
