PESDxS2UQ series
Double ESD protection diodes in SOT663 package
Rev. 04 — 26 January 2010
Product data sheet
1. Product profile
1.1 General description
Unidirectional double ElectroStatic Discharge (ESD) protection diodes in a SOT663 ultra
small and flat lead Surface-Mounted Device (SMD) plastic package designed to protect
up to two signal lines from the damage caused by ESD and other transients.
1.2 Features
Unidirectional ESD protection of up to
ESD protection up to 30 kV
two lines
IEC 61000-4-2; level 4 (ESD)
Max. peak pulse power: PPP = 150 W
at tp = 8/20 μs
IEC 61000-4-5 (surge); IPP = 15 A
Low clamping voltage: VCL = 20 V
at IPP = 15 A
at tp = 8/20 μs
Low reverse leakage current: IRM < 1 nA
1.3 Applications
Computers and peripherals
Audio and video equipment
Communication systems
High-speed data lines
Parallel ports
1.4 Quick reference data
Table 1.
Symbol
Parameter
VRWM
reverse standoff voltage
Conditions
PESD3V3S2UQ
Cd
Min
Typ
Max
Unit
3.3
V
PESD5V0S2UQ
5
V
PESD12VS2UQ
12
V
PESD15VS2UQ
15
V
PESD24VS2UQ
24
V
PESD3V3S2UQ
200
275
pF
PESD5V0S2UQ
150
215
pF
PESD12VS2UQ
38
100
pF
PESD15VS2UQ
32
70
pF
PESD24VS2UQ
23
50
pF
diode capacitance
f = 1 MHz; VR = 0 V
PESDxS2UQ series
Nexperia
2. Pinning information
Table 2.
Pinning
Pin
Description
1
cathode 1
2
cathode 2
3
common anode
Simplified outline
Graphic symbol
3
1
3
2
1
2
006aaa154
3. Ordering information
Table 3.
Type number
PESD3V3S2UQ
Package
Name
Description
Version
plastic surface-mounted package; 3 leads
SOT663
PESD5V0S2UQ
PESD12VS2UQ
PESD15VS2UQ
PESD24VS2UQ
4. Marking
Table 4.
Marking codes
Type number
Marking code
PESD3V3S2UQ
E1
PESD5V0S2UQ
E2
PESD12VS2UQ
E3
PESD15VS2UQ
E4
PESD24VS2UQ
E5
PESDXS2UQ_SER_4
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 13
PESDxS2UQ series
Nexperia
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
PPP
peak pulse power
tp = 8/20 μs
[1][2]
IPP
peak pulse current
tp = 8/20 μs
[1][2]
150
W
PESD3V3S2UQ
15
A
PESD5V0S2UQ
15
A
PESD12VS2UQ
5
A
PESD15VS2UQ
5
A
PESD24VS2UQ
3
A
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
Per diode
Per device
[1]
Non-repetitive current pulse 8/20 μs exponential decay waveform according to IEC 61000-4-5.
[2]
Measured across either pins 1 and 3 or pins 2 and 3.
Table 6.
ESD maximum ratings
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
electrostatic discharge
voltage
IEC 61000-4-2
(contact discharge)
Min
Max
Unit
30
kV
Per diode
VESD
PESD3V3S2UQ
PESD5V0S2UQ
30
kV
PESD12VS2UQ
30
kV
PESD15VS2UQ
30
kV
PESD24VS2UQ
23
kV
10
kV
PESDxS2UQ series
MIL-STD-883
(human body model)
[1]
Device stressed with ten non-repetitive ESD pulses.
[2]
Table 7.
[1][2]
ESD standards compliance
Standard
Conditions
Per diode
> 15 kV (air); > 8 kV (contact)
MIL-STD-883; class 3 (human body model)
> 4 kV
PESDXS2UQ_SER_4
Product data sheet
3 of 13
PESDxS2UQ series
Nexperia
001aaa631
IPP
001aaa630
120
100 %
90 %
100 % IPP; 8 μs
IPP
80
e−t
50 % IPP; 20 μs
40
10 %
30 ns
40
t (μs)
Fig 1.
t
tr = 0.7 ns to 1 ns
60 ns
8/20 μs pulse waveform according to
IEC 61000-4-5
Fig 2.
ESD pulse waveform according to
IEC 61000-4-2
6. Characteristics
Table 8.
Characteristics
Tj = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
3.3
V
Per diode
VRWM
reverse standoff
voltage
PESD3V3S2UQ
IRM
VBR
PESD5V0S2UQ
5
V
PESD12VS2UQ
12
V
PESD15VS2UQ
15
V
PESD24VS2UQ
24
V
PESD3V3S2UQ
VRWM = 3.3 V
0.55
3
μA
PESD5V0S2UQ
VRWM = 5 V
50
300
nA
PESD12VS2UQ
VRWM = 12 V
很抱歉,暂时无法提供与“PESD3V3S2UQ,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.09026
- 50+0.86757
- 150+0.77220
- 500+0.65308
- 2500+0.60005
- 4000+0.56830
