PESD5V0S2BQAZ
PESD5V0S2BQAZ
    NEXPERIA(安世)
    SOT1215
    ESD VRWM=5 V VBR(Min)=5.5 V VC=11.5 V IPP=17.5 A SOT1215
PESD5V0S2BQAZ 数据手册
PESD5V0S2BQA Protection against high surge currents in ultra small DFN1010D-3 package 1 June 2016 Product data sheet 1. General description Two bidirectional ElectroStatic Discharge (ESD) protection diodes designed to protect two signal lines from the damage caused by ESD and other transients. The device is housed in a leadless ultra small DFN1010D-3 (SOT1215) Surface-Mounted Device (SMD) plastic package with visible and solderable side pads. 2. Features and benefits • • • • • • • Bidirectional ESD protection of two lines Ultra small SMD plastic package ESD protection up to 30 kV AEC-Q101 qualified IEC 61000-4-5 (surge): IPPM = 14 A IEC 61000-4-5 (surge): IPPM = 28 A combined lines Ultra low leakage current: IRM = 1 nA 3. Applications • • • • • Computers and peripherals Audio and video equipment Cellular handsets and accessories Communication systems Portable electronics 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 5 V Cd diode capacitance f = 1 MHz; VR = 0 V; Tamb = 25 °C; single line - 35 45 pF [1] Measured from pin 1 or 2 to pin 3. [1] PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K1 cathode 2 K2 cathode 3 CC common cathode 4 CC common cathode Simplified outline Graphic symbol K1 1 CC K2 4 3 aaa-023266 2 Transparent top view DFN1010D-3 (SOT1215) 6. Ordering information Table 3. Ordering information Type number Package PESD5V0S2BQA Name Description Version DFN1010D-3 DFN1010D-3: plastic thermal enhanced ultra thin small outline package; no leads; 3 terminals; body 1.1 x 1.0 x 0.37 mm SOT1215 7. Marking Table 4. Marking codes Type number Marking code PESD5V0S2BQA 00 01 10 MARKING CODE (EXAMPLE) READING DIRECTION YEAR DATE CODE VENDOR CODE PIN 1 INDICATION MARK MARK-FREE AREA READING EXAMPLE: 11 01 10 aaa-008041 Fig. 1. DFN1010D-3 (SOT1215) binary marking code description PESD5V0S2BQA Product data sheet All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 2 / 14 PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit IPPM peak pulse current tp = 8/20 µs; single line [1][2] - 14 A tp = 8/20 µs; combined lines [1][3] - 28 A tp = 8/20 µs; average measured; single line [1][2] - 17.5 A tp = 8/20 µs; average measured; combined [1][3] lines - 35 A Tj junction temperature - 150 °C Tamb ambient temperature -55 125 °C Tstg storage temperature -65 150 °C ESD maximum ratings VESD electrostatic discharge voltage contact discharge [4][2] - 30 kV air discharge [4][2] - 30 kV - 10 kV human body model (MIL-STD-883) [1] [2] [3] [4] Device stressed with non-repetitive current pulses (8/20 µs exponential decay waveform according to IEC 61000-4-5). Measured from pin 1 or 2 to pin 3. Measured from pin 1 and 2 to pin 3. Device stressed with ten non-repetitive ESD pulses. 001aaa631 001aaa630 120 IPP 100 % 100 % IPP; 8 µs IPP (%) 80 90 % e-t 50 % IPP; 20 µs 40 10 % 0 0 10 20 30 tp (µs) Fig. 2. 8/20 µs pulse waveform according to IEC 61000-4-5 PESD5V0S2BQA Product data sheet t tr = 0.6 ns to 1 ns 40 30 ns 60 ns Fig. 3. ESD pulse waveform according to IEC 61000-4-2 All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 3 / 14 PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 5 V VBR breakdown voltage IR = 5 mA; Tamb = 25 °C 5.5 7 9.5 V IRM reverse leakage current VR = 5 V; Tamb = 25 °C [1] - 1 50 nA Cd diode capacitance f = 1 MHz; VR = 0 V; Tamb = 25 °C; single line [1] - 35 45 pF f = 1 MHz; VR = 0 V; Tamb = 25 °C; combined lines [2] - 70 90 pF IPP = 1 A; Tamb = 25 °C; tp = 8/20 µs; single line [3][1] - 6.5 8.5 V IPPM = 14 A; Tamb = 25 °C; tp = 8/20 µs; single line [3][1] - - 11.5 V IPPM = 28 A; Tamb = 25 °C; tp = 8/20 µs; combined lines [4][2] - 11.5 - V IPPM = 16 A; Tamb = 25 °C; tp = TLP; single line [4][1] - 8.5 - V IPPM = 16 A; Tamb = 25 °C; tp = TLP; combined lines [4][2] - 7.6 - V IR = 10 A; Tamb = 25 °C; single line [4][1] - 0.12 - Ω IR = 10 A; Tamb = 25 °C; combined lines [4][2] - 0.07 - Ω VCL clamping voltage Rdyn [1] [2] [3] [4] dynamic resistance Measured from pin 1 or 2 to pin 3. Measured from pin 1 and 2 to pin 3. Device stressed with 8/20 μs exponential decay waveform according to IEC 61000-4-5. Non-repetitive current pulse, Transmission Line Pulse (TLP) tp = 100 ns; square pulse; ANSI / ESD STM5.5.1-2008. PESD5V0S2BQA Product data sheet All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 4 / 14 PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package IPP aaa-023194 102 IR (nA) 10 1 IR IRM - VCL - VBR - VRWM - IRM - IR VRWM VBR VCL 10-1 - + 10-2 - IPP 10-3 -75 006aaa676 Fig. 4. V-I characteristics for a bidirectional ESD protection diode 25 75 125 Tj (°C) 175 VRWM = 5 V Fig. 5. Relative variation of reverse leakage current as a function of ambient temperature; typical values aaa-023195 35 Cd (pF) 30 -25 aaa-023196 90 IPP (A) combined lines; Rdyn = 0.07 Ω 70 25 50 20 15 single line; Rdyn = 0.11 Ω 30 10 10 5 0 -5 -3 -1 1 3 VR (V) Single line; f = 1 MHz; VGS = 0 V; Tamb = 25 °C Fig. 6. Diode capacitance as a function of reverse voltage; typical values PESD5V0S2BQA Product data sheet -10 5 0 6 12 VCL (V) 18 tp = 100 ns; Transmission Line Pulse (TLP) Fig. 7. Dynamic resistance with positive clamping voltage; typical values All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 5 / 14 PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package aaa-023197 10 aaa-023198 12 IPP (A) VCL (V) -10 single line 8 -30 single line; Rdyn = 0.12 Ω combined lines combined lines; Rdyn = 0.05 Ω -50 4 -70 -90 -18 -12 -6 VCL (V) 0 0 tp = 100 ns; Transmission Line Pulse (TLP) Fig. 8. Dynamic resistance with negative clamping voltage; typical values 0 10 20 30 IPP (A) 40 tp = 8/20 µs; according to IEC 61000-4-5 Fig. 9. Dynamic resistance with positive clamping voltage; typical values aaa-023199 0 VCL (V) -4 -8 combined lines single line -12 -40 -30 -20 -10 IPP (A) 0 tp = 8/20 µs; according to IEC 61000-4-5 Fig. 10. Dynamic resistance with negative clamping voltage; typical values PESD5V0S2BQA Product data sheet All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 6 / 14 PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package ESD TESTER 4 GHz DIGITAL OSCILLOSCOPE RG 223/U 50 Ω coax Rd 40 dB ATTENUATOR Cs 50 Ω DUT (DEVICE UNDER TEST) IEC 61000-4-2 ed.2 Cs = 150 pF; Rd = 330 Ω 10 2 V (kV) 8 V (kV) 0 6 -2 4 -4 2 -6 0 -8 -2 -10 0 10 20 30 40 50 t (ns) 60 -10 -10 70 unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) 0 10 20 30 40 50 t (ns) 60 70 unclamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) aaa-003952 Fig. 11. ESD clamping test setup and waveforms aaa-023263 60 VCL (V) aaa-023264 60 VCL (V) 20 20 VCL at 30 ns = 6.7 V -20 -60 -10 VCL at 30 ns = -6 V -20 0 10 20 30 40 50 60 t (ns) Fig. 12. Clamped +8 kV pulse waveform (IEC 61000-4-2 network) PESD5V0S2BQA Product data sheet -60 -10 70 0 10 20 30 40 50 60 t (ns) 70 Fig. 13. Clamped -8 kV pulse waveform (IEC 61000-4-2 network) All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 7 / 14 PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package 10. Application information The device is designed for the protection of up to two bidirectional data lines from surge pulses and ESD damage. lines to be protected ESD protection diode GND 006aab332 Fig. 14. Application diagram Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. 2. 3. 4. 5. 6. 7. 8. Place the device as close to the input terminal or connector as possible. Minimize the path length between the device and the protected line. Keep parallel signal paths to a minimum. Avoid running protected conductors in parallel with unprotected conductors. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. Minimize the length of the transient return path to ground. Avoid using shared transient return paths to a common ground point. Use ground planes whenever possible. For multilayer PCBs, use ground vias. 11. Test information Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PESD5V0S2BQA Product data sheet All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 8 / 14 PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package 12. Package outline 0.87 0.95 0.75 1 0.95 1.05 0.22 0.30 2 0.16 0.24 0.1 3 0.04 max 0.34 0.40 Dimensions in mm 0.17 0.25 0.245 0.325 1.05 1.15 0.195 0.275 13-03-05 Fig. 15. Package outline DFN1010D-3 (SOT1215) PESD5V0S2BQA Product data sheet All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 9 / 14 PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package 13. Soldering Footprint information for reflow soldering of DFN1010D-3 package SOT1215 1.2 0.45 (2x) 0.3 1.1 0.35 (2x) 0.4 0.25 (2x) 0.75 0.3 0.5 1.5 1.4 0.4 0.5 0.4 0.3 0.5 1.3 0.4 0.3 0.4 0.5 1.3 solder land solder land plus solder paste occupied area solder resist Dimensions in mm Issue date 12-11-23 13-03-06 sot1215_fr Fig. 16. Reflow soldering footprint for DFN1010D-3 (SOT1215) PESD5V0S2BQA Product data sheet All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 10 / 14 PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package 14. Revision history Table 7. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PESD5V0S2BQA v.1 20160601 Product data sheet - - PESD5V0S2BQA Product data sheet All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 11 / 14 PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 15. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. PESD5V0S2BQA Product data sheet Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 12 / 14 PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PESD5V0S2BQA Product data sheet All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 13 / 14 PESD5V0S2BQA Nexperia Protection against high surge currents in ultra small DFN1010D-3 package 16. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Characteristics..............................................................4 10. Application information............................................. 8 11. Test information......................................................... 8 12. Package outline.......................................................... 9 13. Soldering................................................................... 10 14. Revision history........................................................11 15. Legal information..................................................... 12 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 01 June 2016 PESD5V0S2BQA Product data sheet All information provided in this document is subject to legal disclaimers. 1 June 2016 © Nexperia B.V. 2017. All rights reserved 14 / 14
PESD5V0S2BQAZ 价格&库存
很抱歉,暂时无法提供与“PESD5V0S2BQAZ”相匹配的价格&库存,您可以联系我们找货
PESD5V0S2BQAZ
  • 1+3.974441+0.51445
  • 10+2.4209910+0.31338
  • 100+1.52856100+0.19786
  • 500+1.13923500+0.14747
  • 1000+1.013331000+0.13117
  • 2000+0.907312000+0.11744
PESD5V0S2BQAZ
  • 5000+0.733675000+0.09497
  • 10000+0.6677910000+0.08644
  • 15000+0.6342315000+0.08210
  • 25000+0.6340625000+0.08208
