NUP1301,215
NUP1301,215
    NEXPERIA(安世)
    SOT-23
    ESD VRWM=80V Ipp=11A VBR=100V Ppp=220W Vc=20V SOT23
NUP1301,215 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia NUP1301 Ultra low capacitance ESD protection array Rev. 01 — 11 May 2009 Product data sheet 1. Product profile 1.1 General description Ultra low capacitance ElectroStatic Discharge (ESD) protection array in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package designed to protect one signal line in rail-to-rail configuration from the damage caused by ESD and other transients. 1.2 Features n n n n n n n ESD protection of one signal line (rail-to-rail configuration) Ultra low diode capacitance: Cd = 0.6 pF Very low reverse leakage current: ≤ 30 nA ESD protection up to 30 kV IEC 61000-4-2; level 4 (ESD) IEC 61000-4-5 (surge); IPP = 11 A at tp = 8/20 µs AEC-Q101 qualified 1.3 Applications n n n n n n n Telecommunication networks Video line protection Microcontroller protection I2C-bus protection Antenna power supply Analog audio Class-D amplifier 1.4 Quick reference data Table 1. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit - - 80 V Per diode VRRM repetitive peak reverse voltage Cd diode capacitance f = 1 MHz; VR = 0 V - 0.6 0.75 pF IR reverse current VR = 80 V - - 100 nA NUP1301 NXP Semiconductors Ultra low capacitance ESD protection array 2. Pinning information Table 2. Pinning Pin Symbol Description 1 GND ground 2 VCC supply voltage 3 I/O input/output Simplified outline Graphic symbol 3 1 3 2 1 2 006aaa763 3. Ordering information Table 3. Ordering information Type number NUP1301 Package Name Description Version - plastic surface-mounted package; 3 leads SOT23 4. Marking Table 4. Marking Type number Marking code[1] NUP1301 LJ* [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit - 80 V - 80 V - 215 mA - 500 mA Per diode VRRM repetitive peak reverse voltage VR reverse voltage IF forward current IFRM repetitive peak forward current [1] tp ≤ 1 ms; δ ≤ 0.25 NUP1301_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 May 2009 2 of 13 NUP1301 NXP Semiconductors Ultra low capacitance ESD protection array Table 5. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol IFSM Parameter Conditions non-repetitive peak forward current Min Max Unit tp = 1 µs - 4 A tp = 1 ms - 1 A tp = 1 s - 0.5 A square wave [2] Per device peak pulse power tp = 8/20 µs [3][4] - 220 W IPP peak pulse current tp = 8/20 µs [3][4] - 11 A Ptot total power dissipation Tamb ≤ 25 °C [5][6] - 250 mW Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C PPP [1] Pulse test: tp ≤ 300 µs; δ ≤ 0.02. [2] Tj = 25 °C prior to surge. [3] Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC 61000-4-5. [4] Measured from pin 3 to pins 1 and 2 (pins 1 and 2 are connected). [5] Single diode loaded. [6] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. Table 6. ESD maximum ratings Symbol Parameter Conditions VESD electrostatic discharge voltage IEC 61000-4-2 (contact discharge) Min Max Unit - 30 kV machine model - 400 V MIL-STD-883 (human body model) - 10 kV [1] Device stressed with ten non-repetitive ESD pulses. [2] Measured from pin 3 to pins 1 and 2 (pins 1 and 2 are connected). Table 7. ESD standards compliance Standard Conditions IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3B (human body model) > 8 kV NUP1301_1 Product data sheet [1][2] © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 May 2009 3 of 13 NUP1301 NXP Semiconductors Ultra low capacitance ESD protection array 001aaa631 IPP 001aaa630 120 100 % 90 % 100 % IPP; 8 µs IPP (%) 80 e−t 50 % IPP; 20 µs 40 10 % 0 10 20 30 30 ns 40 t (µs) Fig 1. t tr = 0.7 ns to 1 ns 0 60 ns 8/20 µs pulse waveform according to IEC 61000-4-5 Fig 2. ESD pulse waveform according to IEC 61000-4-2 6. Thermal characteristics Table 8. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) thermal resistance from junction to solder point Min Typ Max Unit - - 500 K/W - - 360 K/W Per device [1] Single diode loaded. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. NUP1301_1 Product data sheet [1][2] © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 May 2009 4 of 13 NUP1301 NXP Semiconductors Ultra low capacitance ESD protection array 7. Characteristics Table 9. Electrical characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VBR breakdown voltage IR = 100 µA VF forward voltage 100 - - V IF = 1 mA - - 715 mV IF = 10 mA - - 855 mV IF = 50 mA - - 1 V IF = 150 mA - - 1.25 V VR = 25 V - - 30 nA VR = 80 V - - 100 nA VR = 25 V; Tj = 150 °C - - 25 µA VR = 80 V; Tj = 150 °C - - 35 µA diode capacitance f = 1 MHz; VR = 0 V - 0.6 0.75 pF clamping voltage IPP = 1 A [2][3] - - 3 V IPP = 11 A [2][3] - - 20 V Per diode [1] reverse current IR Cd Per device VCL [1] Pulse test: tp ≤ 300 µs; δ ≤ 0.02. [2] Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC 61000-4-5. [3] Measured from pin 3 to pins 1 and 2 (pins 1 and 2 are connected). NUP1301_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 May 2009 5 of 13 NUP1301 NXP Semiconductors Ultra low capacitance ESD protection array 006aab132 103 mbg704 102 IF (mA) IFSM (A) 102 10 10 1 (1) (2) (3) (4) 1 10−1 10−1 0 0.2 0.4 0.6 0.8 1.0 1 1.2 1.4 VF (V) 10 102 103 104 tp (µs) (1) Tamb = 150 °C Based on square wave currents. (2) Tamb = 85 °C Tj = 25 °C; prior to surge (3) Tamb = 25 °C (4) Tamb = −40 °C Fig 3. Forward current as a function of forward voltage; typical values Fig 4. 006aab133 102 IR (µA) 10 (1) 1 (2) Non-repetitive peak forward current as a function of pulse duration; typical values mbg446 0.8 Cd (pF) 0.6 10−1 0.4 (3) 10−2 10−3 0.2 10−4 (4) 10−5 0 0 20 40 60 80 0 100 4 8 VR (V) (1) Tamb = 150 °C 12 VR (V) 16 Tamb = 25 °C; f = 1 MHz (2) Tamb = 85 °C (3) Tamb = 25 °C (4) Tamb = −40 °C Fig 5. Reverse current as a function of reverse voltage; typical values Fig 6. Diode capacitance as a function of reverse voltage; typical values NUP1301_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 May 2009 6 of 13 NUP1301 NXP Semiconductors Ultra low capacitance ESD protection array ESD TESTER acc. to IEC 61000-4-2 CZ = 150 pF; RZ = 330 Ω 4 GHz DIGITAL OSCILLOSCOPE 450 Ω RZ RG 223/U 50 Ω coax 10× ATTENUATOR 50 Ω CZ DUT (DEVICE UNDER TEST) vertical scale = 10 V/div horizontal scale = 15 ns/div vertical scale = 10 A/div horizontal scale = 15 ns/div GND GND clamped +8 kV ESD pulse waveform (IEC 61000-4-2 network), pin 3 to 1 and 2 unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) vertical scale = 10 V/div horizontal scale = 15 ns/div vertical scale = 10 A/div horizontal scale = 15 ns/div GND GND clamped −8 kV ESD pulse waveform (IEC 61000-4-2 network), pin 3 to 1 and 2 unclamped −8 kV ESD pulse waveform (IEC 61000-4-2 network) Fig 7. 006aab567 ESD clamping test setup and waveforms NUP1301_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 May 2009 7 of 13 NUP1301 NXP Semiconductors Ultra low capacitance ESD protection array 8. Application information Protection of a single (high-speed) data line in rail-to-rail configuration. The protected data line is connected to pin 3. Pin 1 is connected to ground (GND) and pin 2 is connected to the supply rail (supply voltage VCC.) When the transient voltage exceeds the forward voltage drop of one diode, the transient is directed either to the supply rail or to GND. The advantages of these solutions are: low line capacitance (0.6 pF typically), fast response time, and low clamping voltage. VCC VCC D1 NUP1301 Audio interface D2 NUP1301 006aab568 Fig 8. Typical application for the protection of one signal line Circuit board layout and protection device placement: Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. Place the NUP1301 as close to the input terminal or connector as possible. 2. The path length between the NUP1301 and the protected line should be minimized. 3. Keep parallel signal paths to a minimum. 4. Avoid running protected conductors in parallel with unprotected conductors. 5. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. 6. Minimize the length of the transient return path to ground. 7. Avoid using shared transient return paths to a common ground point. 8. Ground planes should be used whenever possible. For multilayer PCBs, use ground vias. 9. Test information 9.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. NUP1301_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 May 2009 8 of 13 NUP1301 NXP Semiconductors Ultra low capacitance ESD protection array 10. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 1.9 0.48 0.38 Dimensions in mm Fig 9. 0.15 0.09 04-11-04 Package outline SOT23 (TO-236AB) 11. Packing information Table 10. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number NUP1301 [1] Package SOT23 Description 4 mm pitch, 8 mm tape and reel 3000 10000 -215 -235 For further information and the availability of packing methods, see Section 15. NUP1301_1 Product data sheet Packing quantity © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 May 2009 9 of 13 NUP1301 NXP Semiconductors Ultra low capacitance ESD protection array 12. Soldering 3.3 2.9 1.9 solder lands solder resist 3 2 1.7 solder paste 0.6 (3×) 0.7 (3×) occupied area Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot023_fr Fig 10. Reflow soldering footprint SOT23 (TO-236AB) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Fig 11. Wave soldering footprint SOT23 (TO-236AB) NUP1301_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 May 2009 10 of 13 NUP1301 NXP Semiconductors Ultra low capacitance ESD protection array 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes NUP1301_1 20090511 Product data sheet - - NUP1301_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 May 2009 11 of 13 NUP1301 NXP Semiconductors Ultra low capacitance ESD protection array 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 14.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 15. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com NUP1301_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 11 May 2009 12 of 13 NUP1301 NXP Semiconductors Ultra low capacitance ESD protection array 16. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 10 11 12 13 14 14.1 14.2 14.3 14.4 15 16 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics. . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Application information. . . . . . . . . . . . . . . . . . . 8 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 8 Quality information . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Packing information. . . . . . . . . . . . . . . . . . . . . . 9 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 11 May 2009 Document identifier: NUP1301_1
NUP1301,215 价格&库存
很抱歉,暂时无法提供与“NUP1301,215”相匹配的价格&库存,您可以联系我们找货
NUP1301,215
    NUP1301,215
    • 5+0.57516
    库存:13
    NUP1301,215
      • 3000+0.95590
      • 15000+0.94640
