PESD12VS1ULD,315
PESD12VS1ULD,315
    NEXPERIA(安世)
    SOD-882D
    ESD VRWM=12 V VBR(Min)=14.7 V VC=35 V IPP=5 A Ppp=150 W SOD882D
PESD12VS1ULD,315 数据手册
PESD12VS1ULD Unidirectional ESD protection diode Rev. 1 — 11 May 2011 Product data sheet 1. Product profile 1.1 General description Unidirectional ElectroStatic Discharge (ESD) protection diode designed to protect one signal line from the damage caused by ESD and other transients. The device is housed in a SOD882D leadless ultra small Surface-Mounted Device (SMD) plastic package with visible and solderable side pads. 1.2 Features and benefits „ „ „ „ „ „ ESD protection of one line Ultra small SMD plastic package Solderable side pads Package height typ. 0.37 mm Low clamping voltage: VCL = 19 V AEC-Q101 qualified „ „ „ „ „ ESD protection up to 30 kV IEC 61000-4-2; level 4 (ESD) IEC 61000-4-5 (surge); IPP = 5 A Max. peak pulse power: PPP = 150 W Ultra low leakage current: IRM < 1 nA 1.3 Applications „ „ „ „ Computers and peripherals Audio and video equipment Communication systems Portable electronics 1.4 Quick reference data Table 1. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter VRWM reverse standoff voltage Cd diode capacitance Conditions f = 1 MHz; VR = 0 V Min Typ Max Unit - - 12 V - 38 75 pF PESD12VS1ULD Nexperia Unidirectional ESD protection diode 2. Pinning information Table 2. Pinning Pin Description 1 cathode 2 anode Simplified outline Graphic symbol [1] 1 2 1 2 006aaa152 Transparent top view [1] The marking bar indicates the cathode. 3. Ordering information Table 3. Ordering information Type number Package PESD12VS1ULD Name Description Version - leadless ultra small plastic package; 2 terminals; body 1 × 0.6 × 0.4 mm SOD882D 4. Marking Table 4. Marking codes Type number Marking code[1] PESD12VS1ULD 1010 0000 [1] For SOD882D binary marking code description, see Figure 1. 4.1 Binary marking code description CATHODE BAR READING DIRECTION VENDOR CODE READING EXAMPLE: 0111 1011 MARKING CODE (EXAMPLE) READING DIRECTION 006aac477 Fig 1. PESD12VS1ULD Product data sheet SOD882D binary marking code description All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 May 2011 © Nexperia B.V. 2017. All rights reserved 2 of 12 PESD12VS1ULD Nexperia Unidirectional ESD protection diode 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions peak pulse power tp = 8/20 μs [1] IPP peak pulse current tp = 8/20 μs [1] Tj junction temperature Tamb ambient temperature Tstg storage temperature PPP [1] Min Max Unit - 150 W - 5 A - 150 °C −55 +150 °C −65 +150 °C Non-repetitive current pulse 8/20 μs exponential decay waveform according to IEC 61000-4-5. Table 6. ESD maximum ratings Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions electrostatic discharge voltage VESD IEC 61000-4-2 (contact discharge) MIL-STD-883 (human body model) [1] Device stressed with ten non-repetitive ESD pulses. [2] Measured from pin 1 to 2. Table 7. Min Max Unit [1][2] - 30 kV [2] - 10 kV ESD standards compliance Standard Conditions IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3 (human body model) > 4 kV 001aaa631 IPP 001aaa630 120 100 % 90 % 100 % IPP; 8 μs IPP (%) 80 e−t 50 % IPP; 20 μs 40 10 % 0 10 20 30 30 ns 40 t (μs) Fig 2. t tr = 0.7 ns to 1 ns 0 8/20 μs pulse waveform according to IEC 61000-4-5 PESD12VS1ULD Product data sheet 60 ns Fig 3. ESD pulse waveform according to IEC 61000-4-2 All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 May 2011 © Nexperia B.V. 2017. All rights reserved 3 of 12 PESD12VS1ULD Nexperia Unidirectional ESD protection diode 6. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage - - 12 V IRM reverse leakage current VRWM = 12 V -
PESD12VS1ULD,315 价格&库存
很抱歉,暂时无法提供与“PESD12VS1ULD,315”相匹配的价格&库存,您可以联系我们找货
PESD12VS1ULD,315
  • 1+2.297051+0.29733
  • 10+1.4134910+0.18297
  • 100+0.87908100+0.11379
  • 500+0.64446500+0.08342
  • 1000+0.568481000+0.07359
  • 2000+0.504332000+0.06528
  • 5000+0.434645000+0.05626
PESD12VS1ULD,315
  • 1+0.37510
  • 500+0.25080
  • 5000+0.21780
  • 10000+0.19800
库存:8
PESD12VS1ULD,315
  • 10000+0.3624810000+0.04692
  • 20000+0.3288220000+0.04257
  • 30000+0.3116730000+0.04035
  • 50000+0.2993550000+0.03875
