PTVS30VP1UTP,115
PTVS30VP1UTP,115
    NEXPERIA(安世)
    SOD128
    ESD抑制器/TVS二极管 VRWM=30V VBR(Min)=33.3V VC=48.4V@ IPP=12.4A OD128
PTVS30VP1UTP,115 数据手册
PTVSxP1UTP series High-temperature 600 W Transient Voltage Suppressor Rev. 1 — 11 October 2011 Product data sheet 1. Product profile 1.1 General description 600 W unidirectional Transient Voltage Suppressor (TVS) in a SOD128 small and flat lead Surface-Mounted Device (SMD) plastic package, designed for transient overvoltage protection in high-temperature applications. 1.2 Features and benefits  Rated peak pulse power: PPPM = 600 W  High temperature stability Tj  185 C  Small plastic package suitable for  Reverse standoff voltage range: surface-mounted design VRWM = 3.3 V to 64 V  AEC-Q101 qualified  Reverse current: IRM = 0.001 A  Very low package height: 1 mm 1.3 Applications      Power supply protection Automotive application Industrial application Power management High-temperature applications 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter PPPM rated peak pulse power VRWM reverse standoff voltage [1] Conditions [1] In accordance with IEC 61643-321 (10/1000 s current waveform). Min Typ Max Unit - - 600 W 3.3 - 64 V PTVSxP1UTP series Nexperia High-temperature 600 W Transient Voltage Suppressor 2. Pinning information Table 2. Pinning Pin Description 1 cathode 2 anode Simplified outline Graphic symbol [1] 1 1 2 2 sym035 [1] The marking bar indicates the cathode. 3. Ordering information Table 3. Ordering information Type number[1] Package PTVSxP1UTP series [1] Name Description Version - plastic surface-mounted package; 2 leads SOD128 The series consists of 35 types with reverse standoff voltages from 3.3 V to 64 V. 4. Marking Table 4. PTVSXP1UTP_SER Product data sheet Marking codes Type number Marking code Type number Marking code PTVS3V3P1UTP C5 PTVS20VP1UTP CP PTVS5V0P1UTP C6 PTVS22VP1UTP CR PTVS6V0P1UTP C7 PTVS24VP1UTP CS PTVS6V5P1UTP C8 PTVS26VP1UTP CT PTVS7V0P1UTP C9 PTVS28VP1UTP CU PTVS7V5P1UTP CA PTVS30VP1UTP CV PTVS8V0P1UTP CB PTVS33VP1UTP CW PTVS8V5P1UTP CC PTVS36VP1UTP CX PTVS9V0P1UTP CD PTVS40VP1UTP CY PTVS10VP1UTP CE PTVS43VP1UTP CZ PTVS11VP1UTP CF PTVS45VP1UTP D1 PTVS12VP1UTP CG PTVS48VP1UTP D2 PTVS13VP1UTP CH PTVS51VP1UTP D3 PTVS14VP1UTP CJ PTVS54VP1UTP D4 PTVS15VP1UTP CK PTVS58VP1UTP D5 PTVS16VP1UTP CL PTVS60VP1UTP D6 PTVS17VP1UTP CM PTVS64VP1UTP D7 PTVS18VP1UTP CN - - All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 October 2011 © Nexperia B.V. 2017. All rights reserved 2 of 12 PTVSxP1UTP series Nexperia High-temperature 600 W Transient Voltage Suppressor 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Min Max Unit rated peak pulse power [1] - 600 W IPPM rated peak pulse current [1] - see Table 9 and 10 IFSM non-repetitive peak forward current - 100 A Tj junction temperature - 185 C Tamb ambient temperature 55 +185 C Tstg storage temperature 65 +185 C PPPM [1] Parameter Conditions single half-sine wave; tp = 8.3 ms In accordance with IEC 61643-321 (10/1000 s current waveform). Table 6. ESD maximum ratings Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions electrostatic discharge voltage IEC 61000-4-2, level 4 (contact discharge) Min Max Unit - 30 kV Per diode VESD [1] [1] Device stressed with ten non-repetitive ElectroStatic Discharge (ESD) pulses. Table 7. ESD standards compliance Standard Conditions Per diode IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3B (human body model) > 8 kV 6. Thermal characteristics Table 8. Symbol Rth(j-a) Rth(j-sp) PTVSXP1UTP_SER Product data sheet Thermal characteristics Parameter Conditions thermal resistance from junction to ambient in free air thermal resistance from junction to solder point Min Typ Max Unit [1] - - 200 K/W [2] - - 120 K/W [3] - - 60 K/W [4] - - 12 K/W [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. [4] Soldering point of cathode tab. All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 October 2011 © Nexperia B.V. 2017. All rights reserved 3 of 12 PTVSxP1UTP series Nexperia High-temperature 600 W Transient Voltage Suppressor 7. Characteristics Table 9. Characteristics per type; PTVS3V3P1UTP to PTVS7V0P1UTP Tj = 25 C unless otherwise specified. Type number PTVSxxx P1UTP Reverse standoff voltage Breakdown voltage VBR (V) Reverse leakage current VRWM (V) IR = 10 mA at VRWM Max Min 3V3 3.3 5.20 5.60 6.00 5 600 17 8.0 75.0 1.0 5V0 5.0 6.40 6.70 7.00 5 400 17 9.2 65.2 2.5 6V0 6.0 6.67 7.02 7.37 5 400 17 10.3 58.3 3.2 6V5 6.5 7.22 7.60 7.98 5 250 17 11.2 53.6 3.6 7V0 7.0 7.78 8.20 8.60 3 100 9 12.0 50.0 4.3 Typ Max IRM (A) Typ Clamping voltage VCL (V) at VRWM Tj = 150 C Max Typ Temperature coefficient SZ (mV/K) IZ = 5 mA Max IPPM (A) Typ Table 10. Characteristics per type; PTVS7V5P1UTP to PTVS64VP1UTP Tj = 25 C unless otherwise specified. Type number PTVSxxx P1UTP Reverse standoff voltage Breakdown voltage VBR (V) Reverse leakage current VRWM (V) IR = 1 mA at VRWM Max Min Typ Max Typ Max Typ Max IPPM (A) Typ 7V5 7.5 8.33 8.77 9.21 0.2 50 2.0 12.9 46.5 5.0 8V0 8.0 8.89 9.36 9.83 0.03 25 2.0 13.6 44.1 5.5 8V5 8.5 9.44 9.92 10.40 0.01 10 0.5 14.4 41.7 6.5 9V0 9.0 10.00 10.55 11.10 0.005 5 0.5 15.4 39.0 7.1 10V 10 11.10 11.70 12.30 0.005 2.5 0.5 17.0 35.3 8.1 11V 11 12.20 12.85 13.50 0.005 2.5 0.5 18.2 33.0 9.2 12V 12 13.30 14.00 14.70 0.005 2.5 0.5 19.9 30.2 10.3 13V 13 14.40 15.15 15.90 0.001 0.1 0.5 21.5 27.9 11.4 14V 14 15.60 16.40 17.20 0.001 0.1 0.5 23.2 25.9 13.2 15V 15 16.70 17.60 18.50 0.001 0.1 0.5 24.4 24.6 14.1 16V 16 17.80 18.75 19.70 0.001 0.1 0.5 26.0 23.1 15.9 17V 17 18.90 19.90 20.90 0.001 0.1 0.5 27.6 21.7 16.4 18V 18 20.00 21.00 22.10 0.001 0.1 0.5 29.2 20.5 18.5 20V 20 22.20 23.35 24.50 0.001 0.1 0.5 32.4 18.5 20.0 22V 22 24.40 25.60 26.90 0.001 0.1 0.5 35.5 16.9 23.8 24V 24 26.70 28.10 29.50 0.001 0.1 0.5 38.9 15.4 24.9 26V 26 28.90 30.40 31.90 0.001 0.1 0.5 42.1 14.3 29.1 28V 28 31.10 32.80 34.40 0.001 0.1 0.5 45.4 13.2 30.6 30V 30 33.30 35.10 36.80 0.001 0.1 0.5 48.4 12.4 34.4 33V 33 36.70 38.70 40.60 0.001 0.1 0.5 53.3 11.3 37.5 36V 36 40.00 42.10 44.20 0.001 0.1 0.5 58.1 10.3 42.3 PTVSXP1UTP_SER Product data sheet IRM (A) Clamping voltage VCL (V) at VRWM Tj = 150 C All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 October 2011 Temperature coefficient SZ (mV/K) IZ = 5 mA © Nexperia B.V. 2017. All rights reserved 4 of 12 PTVSxP1UTP series Nexperia High-temperature 600 W Transient Voltage Suppressor Table 10. Characteristics per type; PTVS7V5P1UTP to PTVS64VP1UTP …continued Tj = 25 C unless otherwise specified. Type number PTVSxxx P1UTP Reverse standoff voltage Breakdown voltage VBR (V) Reverse leakage current VRWM (V) IR = 1 mA at VRWM Max Min Typ Max Typ Max Typ Max IPPM (A) Typ 40V 40 44.40 46.80 49.10 0.001 0.1 0.5 64.5 9.3 48.1 43V 43 47.80 50.30 52.80 0.001 0.1 0.5 69.4 8.6 51.6 45V 45 50.00 52.65 55.30 0.001 0.1 0.5 72.7 8.3 55.2 48V 48 53.30 56.10 58.90 0.001 0.1 0.5 77.4 7.8 58.2 51V 51 56.70 59.70 62.70 0.001 0.1 0.5 82.4 7.3 62.5 54V 54 60.00 63.15 66.30 0.001 0.1 0.5 87.1 6.9 66.1 58V 58 64.40 67.80 71.20 0.001 0.1 0.5 93.6 6.4 71.4 60V 60 66.70 70.20 73.70 0.001 0.1 0.5 96.8 6.2 74.1 64V 64 71.10 74.85 78.60 0.001 0.1 0.5 103.0 5.8 80.0 PTVSXP1UTP_SER Product data sheet IRM (A) Clamping voltage VCL (V) at VRWM Tj = 150 C All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 October 2011 Temperature coefficient SZ (mV/K) IZ = 5 mA © Nexperia B.V. 2017. All rights reserved 5 of 12 PTVSxP1UTP series Nexperia High-temperature 600 W Transient Voltage Suppressor 006aab319 150 006aac765 1.2 PPPM IPP (%) PPPM(25°C) 100 % IPP; 10 μs 100 0.8 50 % IPP; 1000 μs 50 0.4 0 0.0 0 1.0 2.0 3.0 4.0 0 50 100 150 tp (ms) Fig 1. 10/1000 s pulse waveform according to IEC 61643-321 006aac172 105 200 Tj (°C) PPPM (W) Fig 2. Relative variation of rated peak pulse power as a function of junction temperature; typical values 006aac173 104 Cd (pF) 104 (1) 103 (2) (3) 103 102 102 10−1 1 10 102 103 (4) 10 104 1 tp (μs) 102 10 VR (V) Tamb = 25 C Tamb = 25 C; f = 1 MHz (1) PTVS5V0P1UTP (2) PTVS12VP1UTP (3) PTVS24VP1UTP (4) PTVS64VP1UTP Fig 3. Rated peak pulse power as a function of pulse duration; typical values PTVSXP1UTP_SER Product data sheet Fig 4. Diode capacitance as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 October 2011 © Nexperia B.V. 2017. All rights reserved 6 of 12 PTVSxP1UTP series Nexperia High-temperature 600 W Transient Voltage Suppressor I −VCL −VBR −VRWM V −IRM −IR − + P-N −IPP −IPPM Fig 5. 006aab324 V-I characteristics for a unidirectional TVS protection diode 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 2.7 2.3 1.1 0.9 0.6 0.3 1 5.0 4.4 4.0 3.6 2 1.9 1.6 Dimensions in mm Fig 6. PTVSXP1UTP_SER Product data sheet 0.22 0.10 07-09-12 Package outline SOD128 All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 October 2011 © Nexperia B.V. 2017. All rights reserved 7 of 12 PTVSxP1UTP series Nexperia High-temperature 600 W Transient Voltage Suppressor 10. Packing information Table 11. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number[2] Package Description Packing quantity 3000 PTVSxP1UTP series SOD128 4 mm pitch, 12 mm tape and reel -115 [1] For further information and the availability of packing methods, see Section 14. [2] The series consists of 35 types with reverse standoff voltages from 3.3 V to 64 V. 11. Soldering 6.2 4.4 4.2 solder lands solder resist 1.9 2.1 (2×) (2×) 3.4 2.5 solder paste occupied area Dimensions in mm 1.2 (2×) 1.4 (2×) sod128_fr Reflow soldering is the only recommended soldering method. Fig 7. PTVSXP1UTP_SER Product data sheet Reflow soldering footprint SOD128 All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 October 2011 © Nexperia B.V. 2017. All rights reserved 8 of 12 PTVSxP1UTP series Nexperia High-temperature 600 W Transient Voltage Suppressor 12. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes PTVSXP1UTP_SER v.1 20111011 Product data sheet - - PTVSXP1UTP_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 October 2011 © Nexperia B.V. 2017. All rights reserved 9 of 12 PTVSxP1UTP series Nexperia High-temperature 600 W Transient Voltage Suppressor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. PTVSXP1UTP_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 October 2011 © Nexperia B.V. 2017. All rights reserved 10 of 12 PTVSxP1UTP series Nexperia High-temperature 600 W Transient Voltage Suppressor Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PTVSXP1UTP_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 October 2011 © Nexperia B.V. 2017. All rights reserved 11 of 12 PTVSxP1UTP series Nexperia High-temperature 600 W Transient Voltage Suppressor 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7 Quality information . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Packing information . . . . . . . . . . . . . . . . . . . . . 8 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 October 2011
PTVS30VP1UTP,115
物料型号:PTVSxP1UTP系列
器件简介:这是一种高温度600W瞬态电压抑制二极管(TVS),采用SOD128小型贴装表面贴装设备(SMD)塑料封装,设计用于高温应用中的瞬态过电压保护。
引脚分配:文档中提供了引脚信息表,其中1号引脚为阴极,2号引脚为阳极。
参数特性: - 额定峰值脉冲功率(PPPM):600W - 高温度稳定性,结温(Tj) ≤ 185°C - 反向工作电压范围(VRWM):3.3V至64V - 反向电流(IRM):0.001μA - 非常低的封装高度:1mm
功能详解: - 该系列通过AEC-Q101认证,适用于多种应用,包括电源保护、汽车应用、工业应用、电源管理和高温应用。
应用信息: - 适用于电源保护、汽车、工业和高温应用。
封装信息:SOD128封装,具有2个引脚,适用于表面贴装设计。
PTVS30VP1UTP,115 价格&库存
很抱歉,暂时无法提供与“PTVS30VP1UTP,115”相匹配的价格&库存,您可以联系我们找货
PTVS30VP1UTP,115
  • 1+5.868271+0.73618
  • 10+3.6438410+0.45712
  • 100+2.33524100+0.29296
  • 500+1.77133500+0.22222
  • 1000+1.589411000+0.19939
库存:2896
PTVS30VP1UTP,115
  • 1+3.78105
  • 10+3.20969
  • 25+2.19301
  • 77+2.18461
  • 100+1.91573
  • 250+1.77289
  • 500+1.68887
  • 1000+1.52082
  • 3000+1.41999
库存:4
PTVS30VP1UTP,115
  • 3000+1.358073000+0.17037
  • 6000+1.241496000+0.15575
  • 9000+1.182099000+0.14830
  • 15000+1.1153415000+0.13992
  • 21000+1.0758021000+0.13496
  • 30000+1.0373730000+0.13014
  • 75000+1.0073475000+0.12638
库存:2896
