NCR402UX
NCR402UX
    NEXPERIA(安世)
    SC74-6
    LED 驱动器 IC 1 输出 线性 调光 20mA 6-TSOP
NCR402UX 数据手册
NCR402U 20 mA LED driver in SOT457 Rev. 1 — 10 December 2013 Product data sheet 1. Product profile 1.1 General description LED driver consisting of resistor-equipped PNP transistor with two diodes on one chip in an SOT457 (SC-74) plastic package. 1.2 Features and benefits        Stabilized output current of 20 mA High current accuracy at supply voltage variation Low voltage overhead of 1.4 V Qualified according to AEC-Q101 Reduces component count and board space High power dissipation of 750 mW Stabilized output current adjustable up to 65 mA when an external resistor is used 1.3 Applications  Constant current LED driver  Generic constant current source  Automotive applications 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit Iout stabilized output current VS = 10 V; Vout = 8.6 V 17 20 23 mA VS supply voltage - - 40 V NCR402U Nexperia 20 mA LED driver 2. Pinning information Table 2. Pinning Pin Symbol Description Simplified outline 1 GND ground 2 IOUT output current 3 IOUT output current 4 VS supply voltage 5 IOUT output current 6 REXT external resistor 6 5 4 1 2 3 Graphic symbol 6 5 1 2 4 3 aaa-010101 3. Ordering information Table 3. Ordering information Type number NCR402U Package Name Description Version SC-74 (TSOP6) plastic surface-mounted package; 6 leads SOT457 4. Marking Table 4. NCR402U Product data sheet Marking codes Type number Marking code NCR402U DB All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 2 of 15 NCR402U Nexperia 20 mA LED driver 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Iout Conditions Min Max Unit stabilized output current if external resistor is used - 65 mA VS supply voltage - 40 V Vout output voltage VS = 40 V - 38 V [1] - 0.5 V Tamb  25 C [2] - 475 mW Tamb  25 C [3] - 650 mW Tamb  25 C [4] - 750 mW Tamb  25 C [5] - 1100 mW reverse voltage VR total power dissipation Ptot Tj junction temperature - 150 C Tamb ambient temperature 55 +150 C Tstg storage temperature 65 +150 C [1] Between all terminals. [2] Device mounted on an FR4 Printed-Circuit Board (PCB); single-sided copper; tin-plated and standard footprint. [3] Device mounted on an FR4 PCB; single-sided copper; tin-plated and mounting pad for output 1 cm2. [4] Device mounted on an FR4 PCB; 4-layer copper; tin-plated and standard footprint. [5] Device mounted on an FR4 PCB; 4-layer copper; tin-plated and mounting pad for output 1 cm2. aaa-010053 1 Ptot (W) 0.8 (1) 0.6 (2) 0.4 0.2 0 -75 -25 25 75 125 175 Tamb (°C) (1) FR4 PCB, 4-layer copper; standard footprint. (2) FR4 PCB, single-sided copper; standard footprint. Fig 1. NCR402U Product data sheet Power derating curve All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 3 of 15 NCR402U Nexperia 20 mA LED driver 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions thermal resistance from junction to ambient Rth(j-a) thermal resistance from junction to solder point Rth(j-sp) in free air Min Typ Max Unit [1] - - 265 K/W [2] - - 190 K/W [3] - - 165 K/W [4] - - 115 K/W - - 50 K/W in free air [1] Device mounted on an FR4 PCB; single-sided copper; tin-plated and standard footprint. [2] Device mounted on an FR4 PCB; single-sided copper; tin-plated and mounting pad for output 1 cm2. [3] Device mounted on an FR4 PCB; single-sided copper; tin-plated and standard footprint. [4] Device mounted on an FR4 PCB; 4-layer copper; tin-plated and mounting pad for output 1 cm2. aaa-010054 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.2 0.1 10 0.05 0.02 0.01 0 1 -5 10 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, single-sided copper, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values NCR402U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 4 of 15 NCR402U Nexperia 20 mA LED driver aaa-010055 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.2 0.1 10 0.05 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, 4-layer copper, standard footprint Fig 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values NCR402U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 5 of 15 NCR402U Nexperia 20 mA LED driver 7. Characteristics Table 7. Characteristics Tamb = 25 C; pulse test: tP  300 s;  = 0.02; unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Iout stabilized output current VS = 10 V; Vout = 8.6 V 17 20 23 mA IGND ground current VS = 10 V; Iout = 0 A 340 420 500 A Rint internal resistance IRint = 20 mA 36 42 52  VRint voltage drop at internal resistance Rint Iout = 20 mA - 0.85 - V VSmin lowest sufficient supply voltage overhead VS  Vout Iout > 17 mA - 1.4 - V Iout / (Iout  Tamb) stabilized output current change over ambient temperature VS = 10 V; Vout = 8.6 V - 0.3 - %/K Iout / (Iout  VS) VS = 10 V; VS  Vout = 1.4 V - 0.8 - %/V stabilized output current change over supply voltage aaa-010056 102 IGND (mA) Rext = 24 Ω Iout (mA) aaa-010057 2.4 Tamb = 80 °C Rext = 75 Ω 1.6 Rext = open Tamb = 25 °C 10 0.8 Tamb = -40 °C 1 0 10 20 30 VS (V) 0 40 VS  Vout = 1.4 V; Tamb = 25 C Fig 4. Product data sheet 10 20 30 VS (V) 40 Iout = 0 mA Output current as a function of supply voltage; typical values NCR402U 0 Fig 5. Ground current as a function of supply voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 6 of 15 NCR402U Nexperia 20 mA LED driver aaa-010058 25 aaa-010059 30 VS - Vout = 1.4 V -2 V Iout (mA) Iout (mA) 20 Tamb = -40 °C VS - Vout = 1 V Tamb = 25 °C 20 15 Tamb = 80 °C 10 10 5 0 0 0 10 20 30 VS (V) 40 Rext = open; Tamb = 25 C Fig 6. 0 10 20 30 VS (V) 40 VS  Vout = 1.4 V; Rext = open Output current as a function of supply voltage; typical values Fig 7. Output current as a function of supply voltage; typical values aaa-010098 100 Iout (mA) Tamb = -40 °C Tamb = 25 °C Tamb = 80 °C 10 0 50 100 150 Rext (Ω) 200 VS = 10 V; Vout = 8.6 V Fig 8. Output current as a function of external resistor; typical values NCR402U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 7 of 15 NCR402U Nexperia 20 mA LED driver 8. Application information Figure 9 shows a typical application circuit for an LED driver. The constant current ensures a constant LED brightness. The output current can be adjusted between 20 mA and 65 mA by connecting an external resistor Rext. Figure 8 gives a first indication for choosing the external resistor Rext. The output current slightly decreases when the power load at LED driver increases. This effect is due to the self heating of the device and the negative thermal coefficient of the output current. VS VCC Rint Rext REXT IOUT Iout LED GND aaa-010022 Fig 9. LED driver application diagram The output can be switched ON and OFF by connecting a Resistor-Equipped Transistor (RET), e.g. PDTC124XU; see Figure 10. VS VCC Rext REXT IOUT GND Iout OUT IN / OUT LED GND 006aaa025 Fig 10. Switching the current ON/OFF; application diagram NCR402U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 8 of 15 NCR402U Nexperia 20 mA LED driver 9. Test information 9.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. NCR402U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 9 of 15 NCR402U Nexperia 20 mA LED driver 10. Package outline Plastic surface-mounted package (TSOP6); 6 leads D SOT457 E B y A HE 6 5 X v M A 4 Q pin 1 index A A1 c 1 2 3 Lp bp e w M B detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.1 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT457 JEITA EUROPEAN PROJECTION ISSUE DATE 05-11-07 06-03-16 SC-74 Fig 11. Package outline SOT457 (SC-74) NCR402U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 10 of 15 NCR402U Nexperia 20 mA LED driver 11. Soldering 3.45 1.95 0.45 0.55 (6×) (6×) 0.95 solder lands solder resist 3.3 2.825 0.95 solder paste occupied area 0.7 (6×) Dimensions in mm 0.8 (6×) 2.4 sot457_fr Fig 12. Reflow soldering footprint for SOT457 (SC-74) 5.3 1.5 (4×) solder lands 1.475 solder resist 0.45 (2×) 5.05 occupied area 1.475 Dimensions in mm preferred transport direction during soldering 1.45 (6×) 2.85 sot457_fw Fig 13. Wave soldering footprint for SOT457 (SC-74) NCR402U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 11 of 15 NCR402U Nexperia 20 mA LED driver 12. Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes NCR402U v.1 20131210 Product data sheet - - NCR402U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 12 of 15 NCR402U Nexperia 20 mA LED driver 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. NCR402U Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 13 of 15 NCR402U Nexperia 20 mA LED driver No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 13.4 Trademarks Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com NCR402U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 10 December 2013 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia NCR402U 20 mA LED driver 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Application information. . . . . . . . . . . . . . . . . . . 8 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Quality information . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 December 2013
NCR402UX 价格&库存
很抱歉,暂时无法提供与“NCR402UX”相匹配的价格&库存,您可以联系我们找货
NCR402UX
  • 1+1.916271+0.24040
  • 10+1.2753910+0.16000
  • 25+1.1254925+0.14120
  • 100+0.96176100+0.12066
  • 250+0.88234250+0.11069
  • 500+0.83441500+0.10468
  • 1000+0.795071000+0.09975
库存:525
