74HCT4511D,653
74HCT4511D,653
    NEXPERIA(安世)
    SOIC16_150MIL
    BCD到7段锁存器/解码器/驱动器
74HCT4511D,653 数据手册
74HC4511; 74HCT4511 BCD to 7-segment latch/decoder/driver Rev. 3 — 15 November 2016 Product data sheet 1. General description The 74HC4511; 74HCT4511 is a BCD to 7-segment latch/decoder/driver with four address inputs (A, B, C, D), a latch enable input (LE), a ripple blanking input (BI), a lamp test input (LT), and seven segment outputs (a to g). When LE is LOW, the state of the segment outputs (a to g) is determined by the data on A to D. When LE goes HIGH, the last data present on A to D are stored in the latches and the segment outputs remain stable. When LT is LOW, all the segment outputs are HIGH independent of all other input conditions. With LT HIGH, a LOW on BI forces all segment outputs LOW. The inputs LT and BI do not affect the latch circuit. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Complies with JEDEC standard no. 7A  Input levels:  For 74HC4511: CMOS level  For 74HCT4511: TTL level  Latch storage of BCD inputs  Blanking input  Lamp test input  Driving common cathode LED displays  Guaranteed 10 mA drive capability per output  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Specified from 40 C to +85 C and 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range 74HC4511D 74HCT4511D Name Description 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm Version SOT109-1 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver 4. Functional diagram  $  /(  %,   %  &  ' /$7&+(6 '(&2'(5 /7 '5,9(56 J  I  H  G  F  E  D   $ D   % E   & F   ' G   /7 H   %, I   /( J  DDD Fig 1. DDD Functional diagram Fig 2.   %&'6(*>7@ 9>/7@ *>%,@ D E      Logic symbol & F ' G ' H ' I ' J        DDD Fig 3. IEC logic symbol 74HC_HCT4511 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 2 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver % $ & ' %, /DWFK ' 4 /DWFK ' 4 /DWFK ' 4 /DWFK ' 4 &3 &3 &3 &3 4 4 4 4 /( /7 J I H G F E D DDD Fig 4. Logic diagram 74HC_HCT4511 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 3 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver 5. Pinning information 5.1 Pinning +& +&7 %   9&& &   I /7   J %,   D /(   E '   F $   G *1'   H DDD Fig 5. Pin configuration SO16 5.2 Pin description Table 2. Pin description Symbol Pin Description LT 3 lamp test input (active LOW) BI 4 ripple blanking input (active low) LE 5 latch enable input (active low) A, B, C, D 7, 1, 2, 6 BCD address inputs GND 8 ground (0 V) a, b, c, d, e, f, g 13, 12, 11, 10, 9, 15, 14 segments outputs VCC 16 supply voltage 74HC_HCT4511 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 4 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver 6. Functional description Function table[1] Table 3. Inputs Outputs Display LE BI LT D C B A a b c d e f g X X L X X X X H H H H H H H 8 X L H X X X X L L L L L L L blank L H H L L L L H H H H H H L 0 L H H L L L H L H H L L L L 1 L H H L L H L H H L H H L H 2 L H H L L H H H H H H L L H 3 L H H L H L L L H H L L H H 4 L H H L H L H H L H H L H H 5 L H H L H H L L L H H H H H 6 L H H L H H H H H H L L L L 7 L H H H L L L H H H H H H H 8 L H H H L L H H H H L L H H 9 L H H H L H L L L L L L L L blank L H H H L H H L L L L L L L blank L H H H H L L L L L L L L L blank L H H H H L H L L L L L L L blank L H H H H H L L L L L L L L blank L L L L L L blank L H H H H H H L H H H X X X X [2] [1] [2] H = HIGH voltage level; L = LOW voltage level; X = don’t care [2] Depends upon the BCD-code applied during the LOW-to-HIGH transition of LE. D I E J F H G DDD Fig 6. Segment designation 74HC_HCT4511 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 5 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver DDD Fig 7. Display 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current IOK Conditions Min Max Unit 0.5 +7.0 V VI < 0.5 V or VI > VCC + 0.5 V - 20 mA output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA 0.5 V < VO < VCC + 0.5 V IO output current - 25 mA ICC supply current - +50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot [1] [1] SO16 package For SO16 packages: above 70 C the value of Ptot derates linearly at 8 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter VCC supply voltage Conditions 74HC4511 74HCT4511 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate - - 625 - - - VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 74HC_HCT4511 Product data sheet VCC = 2.0 V All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © ns/V Nexperia B.V. 2017. All rights reserved 6 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V 74HC4511 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V HIGH-level VI = VIH or VIL output voltage IO = 7.5 mA; VCC = 4.5 V 3.98 - - 3.84 - 3.7 - V IO = 10 mA; VCC = 4.5 V 3.6 - - 3.35 - 3.1 - V IO = 7.5 mA; VCC = 6.0 V 5.6 - - 5.45 - 5.35 - V IO = 10 mA; VCC = 6.0 V 5.48 - - 5.34 - 5.2 - V IO = 15 mA; VCC = 6.0 V 4.8 - - 4.5 - 4.2 - V LOW-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V - - 0.1 - 1.0 - 1.0 A II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 A CI input capacitance - 3.5 - - - - - pF 74HC_HCT4511 Product data sheet VI = VCC or GND; VCC = 6.0 V All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 7 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max 74HCT4511 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 7.5 mA 3.98 - - 3.84 - 3.7 - V 3.6 - - 3.35 - 3.1 - V IO = 10 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA - 0.15 0.26 - 0.33 - 0.4 V VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 A - - 8.0 - 80 - 160 A LT, LE inputs - 150 540 - 675 - 735 A BI, A, B, C, D inputs - 30 108 - 135 - 147 A - 3.5 - - - - - pF II input leakage current ICC supply current VI = VCC or GND; VCC = 5.5 V; IO = 0 A ICC additional per input pin; supply current VCC = 4.5 V to 5.5 V; VI = VCC  2.1 V; IO = 0 A; other inputs at VCC or GND CI input capacitance 74HC_HCT4511 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 8 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 12. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 77 300 - 375 - 450 ns - 28 60 - 75 - 90 ns 74HC4511 tpd [1] propagation A-D to a-g; see Figure 8 delay VCC = 2.0 V VCC = 4.5 V VCC = 5.0 V; CL = 15 pF - 24 - - - - - ns VCC = 6.0 V - 22 51 - 64 - 77 ns VCC = 2.0 V - 74 270 - 330 - 405 ns LE to a-g; see Figure 9 VCC = 4.5 V - 27 54 - 68 - 81 ns VCC = 5.0 V; CL = 15 pF - 23 - - - - - ns VCC = 6.0 V - 22 46 - 58 - 69 ns VCC = 2.0 V - 61 220 - 275 - 330 ns VCC = 4.5 V - 22 44 - 55 - 66 ns VCC = 5.0 V; CL = 15 pF - 19 - - - - - ns VCC = 6.0 V - 18 37 - 47 - 56 ns VCC = 2.0 V - 41 150 - 190 - 225 ns VCC = 4.5 V - 15 30 - 38 - 45 ns VCC = 5.0 V; CL = 15 pF - 12 - - - - - ns - 12 26 - 33 - 38 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 2.0 V 80 11 - 100 - 120 - ns VCC = 4.5 V 16 4 - 20 - 24 - ns VCC = 6.0 V 14 3 - 17 - 20 - ns VCC = 2.0 V 60 14 - 75 - 90 - ns VCC = 4.5 V 12 5 - 15 - 18 - ns VCC = 6.0 V 10 4 - 13 - 15 - ns BI to a-g; see Figure 10 LT to a-g; see Figure 8 VCC = 6.0 V tt tW tsu transition time pulse width set-up time 74HC_HCT4511 Product data sheet see Figure 8, Figure 9 and Figure 10 [2] LE LOW; see Figure 9 A-D to LE; see Figure 11 All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 9 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 12. Symbol Parameter th hold time 25 C Conditions Min Typ Max Min Max Min Max VCC = 2.0 V 0 11 - 0 - 0 - ns VCC = 4.5 V 0 4 - 0 - 0 - ns 0 3 - 0 0 - ns - 64 - - - - - pF - 28 60 - 75 - 90 ns - 24 - - - - - ns VCC = 4.5 V - 27 54 - 68 - 81 ns VCC = 5.0 V; CL = 15 pF - 24 - - - - - ns VCC = 4.5 V - 23 44 - 55 - 66 ns VCC = 5.0 V; CL = 15 pF - 20 - - - - - ns - 16 30 - 38 - 45 ns - 13 - - - - - ns - 7 15 - 19 - 22 ns 16 5 - 20 - 24 - ns 12 5 - 15 - 18 - ns 0 4 - 0 - 0 - ns - 64 - - - - - pF A-D to LE; see Figure 11 VCC = 6.0 V power VI = GND to VCC; VCC = 5 V; dissipation fi = 1 MHz capacitance CPD 40 C to +85 C 40 C to +125 C Unit [3] 74HCT4511 [1] propagation A-D to a-g; see Figure 8 delay VCC = 4.5 V tpd VCC = 5.0 V; CL = 15 pF LE to a-g; see Figure 9 BI to a-g; see Figure 10 LT to a-g; see Figure 8 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF transition time tt see Figure 8, Figure 9 and Figure 10 [2] VCC = 4.5 V pulse width tW LE LOW; see Figure 9 VCC = 4.5 V set-up time tsu A-D to LE; see Figure 11 VCC = 4.5 V hold time th A-D to LE; see Figure 11 VCC = 4.5 V power VI = GND to VCC  1.5 V; dissipation VCC = 5 V; fi = 1 MHz capacitance CPD [1] [3] tpd is the same as tPHL and tPLH. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC_HCT4511 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 10 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver 11. Waveforms IPD[ 9, /(LQSXW 9, $'/7LQSXW 90 90 *1' W: *1' W3/+ W3+/ 92+ W3+/  92+  90 DJRXWSXW  92/ W7+/   90 DJRXWSXW  W3/+  92/ W 7/+  W7+/ W7/+ DDD Fig 8. DDD Measurement points are given in Table 8. Measurement points are given in Table 8. Logic levels VOL and VOH are typical output voltage levels that occur with the output load. Logic levels VOL and VOH are typical output voltage levels that occur with the output load. Waveforms showing the input (A-D, LT) to output (a-g) propagation delays and the output transition times Fig 9. Waveforms showing the input (LE) to output (a-g) propagation delays; the latch enable pulse width and the output transition times 9, %,LQSXW 90 9, *1' 92+ *1'   90 DJRXWSXW 92/ 90 $'LQSXW W3/+ W3+/ WVX 9,   W7+/ /(LQSXW W7/+ WVX WK WK 90 *1' DDD DDD Measurement points are given in Table 8. Measurement points are given in Table 8. Logic levels VOL and VOH are typical output voltage levels that occur with the output load. The shaded areas indicate when the input is permitted to change for predictable output performance. Fig 10. Waveforms showing the input (BI) to output (a-g) propagation delays and the output transition times Table 8. Fig 11. Waveforms showing the data set-up and hold times for a-g input to LE input Measurement points Type Input Output VM VI VM 74HC4511 0.5  VCC GND to VCC 0.5  VCC 74HCT4511 1.3 V GND to 3 V 1.3 V 74HC_HCT4511 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 11 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver 9, W:  QHJDWLYH SXOVH 90 9 9, WI WU WU WI  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 6 RSHQ '87 &/ 57 DDG Test data is given in Table 9. Test circuit definitions: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistance. S1 = Test selection switch Fig 12. Test circuit for measuring switching times Table 9. Test data Type Input VI tr, tf CL RL tPHL, tPLH 74HC4511 VCC 6 ns 15 pF, 50 pF 1 k open 74HCT4511 3V 6 ns 15 pF, 50 pF 1 k open 74HC_HCT4511 Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 S1 position © Nexperia B.V. 2017. All rights reserved 12 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver 12. Application information 9&& 9&& +& +&7 RXWSXW *1' 9 FRPPRQFDWKRGH /(' FRPPRQDQRGH /(' +& +&7 RXWSXW 9 *1' DDD DDD Fig 13. Connection to common cathode LED display readout Fig 14. Connection to common anode LED display readout H[FLWDWLRQ VTXDUHZDYH *1'WR9&& 9&& +& +&7 RXWSXW +&+&7 *1' DDD Direct DC drive is not recommended as it can shorten the life of LCD displays Fig 15. Connection to LCD display readout 74HC_HCT4511 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 13 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver 13. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 16. Package outline SOT109-1 (SO16) 74HC_HCT4511 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 14 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver 14. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT4511 v.3 20161115 Product data sheet - 74HC_HCT4511 v.2 Modifications: 74HC_HCT4511 v.2 74HC_HCT4511 Product data sheet • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type numbers 74HC4511N, 74HCT4511N removed. 19901201 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 - © Nexperia B.V. 2017. All rights reserved 15 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT4511 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 16 of 18 74HC4511; 74HCT4511 Nexperia BCD to 7-segment latch/decoder/driver Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT4511 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2016 © Nexperia B.V. 2017. All rights reserved 17 of 18 Nexperia 74HC4511; 74HCT4511 BCD to 7-segment latch/decoder/driver 18. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Application information. . . . . . . . . . . . . . . . . . 13 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Contact information. . . . . . . . . . . . . . . . . . . . . 17 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 November 2016
74HCT4511D,653 价格&库存
很抱歉,暂时无法提供与“74HCT4511D,653”相匹配的价格&库存,您可以联系我们找货
74HCT4511D,653
  • 1+8.114791+1.05515
  • 10+5.7933810+0.75330
  • 25+5.2169225+0.67835
  • 100+4.58630100+0.59635
  • 250+4.28521250+0.55720
  • 500+4.10374500+0.53360
  • 1000+3.969271000+0.51612
库存:2024
74HCT4511D,653
    • 1+6.46920
    • 10+5.63760
    • 30+5.22720
    • 100+4.81680
    • 500+4.57920
    • 1000+4.44960
    74HCT4511D,653
    • 2500+3.796702500+0.49368
    • 5000+3.701655000+0.48132
    • 7500+3.654037500+0.47513
    • 12500+3.6012912500+0.46827
    • 17500+3.5704817500+0.46426
    库存:2024
