HEF4543BT,652
HEF4543BT,652
    NEXPERIA(安世)
    SOIC16_150MIL
    SOIC16 0.5~18V 1.4mA 100mW
HEF4543BT,652 数据手册
HEF4543B BCD to 7-segment latch/decoder/driver Rev. 7 — 1 April 2016 Product data sheet 1. General description The HEF4543B is a BCD to 7-segment latch/decoder/driver for liquid crystal and LED displays. It has four address inputs (D0 to D3), an active LOW latch enable input (LE), an active HIGH blanking input (BL), an active HIGH phase input (PH) and seven buffered segment outputs (Qa to Qg). The circuit provides the function of a 4-bit storage latch and an 8-4-2-1 BCD to 7-segment decoder/driver. It can invert the logic levels of the output combination. The phase (PH), blanking (BL) and latch enable (LE) inputs are used to reverse the function table phase, blank the display and store a BCD code, respectively. For liquid crystal displays, a square-wave is applied to PH and the electrical common back-plane of the display. The outputs of the device are directly connected to the segments of the liquid crystal. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits      Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +85 C Complies with JEDEC standard JESD 13-B 3. Ordering information Table 1. Ordering information All types operate from 40 C to +85 C Type number HEF4543BT Package Name Description Version SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver 4. Functional diagram     ' ' ' '  /( /$7&+(6  %/ '(&2'(5  3+ '5,9(56 4J 4I 4H 4G 4F 4E 4D        DDH Fig 1. Functional diagram HEF4543B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 2 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver %/ ' 4D ' 4E 4F ' 4G 4H ' 4I 4J /( 3+ Fig 2. DDH Logic diagram HEF4543B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 3 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver 5. Pinning information 5.1 Pinning +()% /(   9'' '   4I '   4J '   4H '   4G 3+   4F %/   4E 966   4D DDH Fig 3. Pin configuration 5.2 Pin description Table 2. Pin description Symbol Pin Description LE 1 latch enable input (active LOW) D0 to D3 5, 3, 2, 4 address (data) input PH 6 phase input (active HIGH) BL 7 blanking input (active HIGH) VSS 8 ground supply voltage Qa to Qg 9, 10, 11, 12, 13, 15, 14 segment output VDD 16 supply voltage HEF4543B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 4 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver 6. Functional description Function table [1] Table 3. Inputs Outputs LE BL PH X H H H [2] Display D3 D2 D1 D0 Qa Qb Qc Qd Qe Qf Qg L X X X X L L L L L L L L L L L L L H H H H H H L 0 L L L L L H L H H L L L L 1 H L L L L H L H H L H H L H 2 H L L L L H H H H H H L L H 3 H L L L H L L L H H L L H H 4 H L L L H L H H L H H L H H 5 H L L L H H L H L H H H H H 6 H L L L H H H H H H L L L L 7 H L L H L L L H H H H H H H 8 H L L H L L H H H H H L H H 9 H L L H L H X L L L L L L L blank H L L H H X X L L L L L L L blank L L L X X X X n.c. n.c as above H as above inverse of above as above [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; n.c. = no change. [2] For liquid crystal displays, apply a square-wave to PH; blank For common cathode LED displays, select PH = LOW; For common anode LED displays, select PH = HIGH. D I E J H G F DDM Fig 4. Seven segment digital display with segment designation 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDD Min Max Unit supply voltage 0.5 +18 V VI input voltage 0.5 VDD + 0.5 V II/O input/output current - 10 mA Tstg storage temperature 65 +150 C HEF4543B Product data sheet Conditions All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 5 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver Table 4. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Tamb ambient temperature Conditions Ptot total power dissipation SO16 package P power dissipation per output [1] Min Max Unit 40 +85 C - 500 mW - 100 mW [1] For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Min Typ Max VDD supply voltage Conditions 3 - 15 V Unit VI input voltage 0 - VDD V Tamb ambient temperature in free air 40 - +85 C t/V input transition rise and fall rate VDD = 5 V - - 3.75 s/V VDD = 10 V - - 0.5 s/V VDD = 15 V - - 0.08 s/V 9. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH HIGH-level input voltage LOW-level input voltage HIGH-level output current HEF4543B Product data sheet Tamb = 25 C Tamb = 85 C Max Min Max Min Max - 3.5 - 3.5 - V 7.0 - 7.0 - 7.0 - V 11.0 - 11.0 - 11.0 - V VDD Min IO < 1 A 5V 3.5 10 V 15 V IO < 1 A HIGH-level output voltage LOW-level output voltage Tamb = 40 C Conditions IO < 1 A Unit 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 V VO = 2.5 V 5V - 1.7 - 1.4 - 1.1 mA VO = 4.6 V 5V - 0.52 - 0.44 - 0.36 mA VO = 9.5 V 10 V - 1.3 - 1.1 - 0.9 mA VO = 13.5 V 15 V - 3.6 - 3.0 - 2.4 mA All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 6 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver Table 6. Static characteristics …continued VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter IOL LOW-level output current II input leakage current IDD supply current CI Conditions VDD Tamb = 40 C Tamb = 25 C Tamb = 85 C Min Max Min Max Min Max Unit VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA 15 V - 0.3 - 0.3 - 1.0 A 5V - 20 - 20 - 150 A 10 V - 40 - 40 - 300 A 15 V - 80 - 80 - 600 A - - - - 7.5 - - pF Extrapolation formula[1] Min Typ Max Unit IO = 0 A input capacitance 10. Dynamic characteristics Table 7. Dynamic characteristics VSS = 0 V; Tamb = 25 C; For test circuit see Figure 7;unless otherwise specified. Symbol Parameter Conditions VDD tPHL HIGH to LOW propagation delay Dn to Qn; see Figure 5 5V 153 ns + (0.55 ns/pF)CL - 180 360 ns 10 V 64 ns + (0.23 ns/pF)CL - 75 150 ns 15 V 47 ns + (0.16 ns/pF)CL - 55 110 ns 5V 143 ns + (0.55 ns/pF)CL - 170 340 ns 10 V 69 ns + (0.23 ns/pF)CL - 80 160 ns 15 V 52 ns + (0.16 ns/pF)CL - 60 120 ns 5V 118 ns + (0.55 ns/pF)CL - 145 290 ns 10 V 54 ns + (0.23 ns/pF)CL - 65 130 ns 15 V 37 ns + (0.16 ns/pF)CL - 45 90 ns 5V 153 ns + (0.55 ns/pF)CL - 180 360 ns 10 V 64 ns + (0.23 ns/pF)CL - 75 150 ns 15 V 47 ns + (0.16 ns/pF)CL - 55 110 ns 5V 163 ns + (0.55 ns/pF)CL - 190 380 ns 10 V 69 ns + (0.23 ns/pF)CL - 80 160 ns 15 V 52 ns + (0.16 ns/pF)CL - 60 120 ns 5V 98 ns + (0.55 ns/pF)CL - 125 250 ns 10 V 54 ns + (0.23 ns/pF)CL - 55 110 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 80 ns 5V 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL LE to Qn; see Figure 5 BL to Qn; see Figure 5 tPLH LOW to HIGH propagation delay Dn to Qn; see Figure 5 LE to Qn; see Figure 5 BL to Qn; see Figure 5 tt tsu transition time set-up time HEF4543B Product data sheet pin Qn; see Figure 5 Dn to LE; see Figure 6 - 20 40 ns 5V 40 20 - ns 10 V 20 5 - ns 15 V 15 0 - ns All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 7 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver Table 7. Dynamic characteristics …continued VSS = 0 V; Tamb = 25 C; For test circuit see Figure 7;unless otherwise specified. Symbol Parameter Conditions VDD th hold time Dn to LE; see Figure 6 pin LE HIGH; minimum width; see Figure 6 pulse width tW [1] Extrapolation formula[1] Min Typ Max Unit 5V 0 15 - ns 10 V 15 0 - ns 15 V 20 5 - ns 5V 60 30 - ns 10 V 30 15 - ns 15 V 20 10 - ns The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). Table 8. Dynamic power dissipation PD PD can be calculated from the formulas shown. VSS = 0 V; tr = tf  20 ns; Tamb = 25 C. Symbol Parameter VDD Typical formula for PD (W) PD dynamic power dissipation 5V PD = 2200  fi + (fo  CL)  VDD2 where: fi = input frequency in MHz, 10 V PD = 10400  fi + (fo  CL)  VDD2 fo = output frequency in MHz, 15 V PD = 33000  fi + (fo  CL)  VDD2 CL = output load capacitance in pF, VDD = supply voltage in V, (CL  fo) = sum of the outputs. 11. Waveforms 9, /( 90 90 966 9, 90 ' 966 9, 90 %/ 966 W3/+ W3+/ 92+ W3/+ W3+/ W3/+ W3+/  90 4J  92/ W7+/ W7/+ DDM Conditions: D3 = LOW and D0 = D1 = HIGH. Fig 5. Propagation delays and output transitions times HEF4543B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 8 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver 9, 90 /(LQSXW 966 W: 9, 'LQSXW 90 966 WVX WK 92+ 4JRXWSXW 92/ DDM Conditions: D3 = BL = LOW; D0 = D1 = LE = HIGH Fig 6. Waveforms showing minimum LE pulse width, set-up, and hold time for DC to LE HEF4543B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 9 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver W: 9,   QHJDWLYH SXOVH 90 90  9  WI WU WU WI 9,  SRVLWLYH SXOVH  90 90  9  W: DDM a. Input waveforms 9'' * 9, 92 '87 57 &/ DDJ b. Test circuit Test data is given in Table 9. Definitions for test circuit: RL = Load resistance; CL = Load capacitance including jig and probe capacitance; RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 7. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VDD VI VM tr, tf Load CL 5 V to 15 V VDD 0.5VI  20 ns 50 pF 12. Application information Some examples of applications for the HEF4543B are: • • • • • HEF4543B Product data sheet Driving LCD displays Driving LED displays Driving fluorescent displays Driving incandescent displays Driving gas discharge displays All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 10 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver 9'' FRPPRQDQRGH /(' +()% RXWSXW FRPPRQFDWKRGH /(' +()% 3+ RXWSXW 966 3+ a. common cathode DDH 9'' DDH b. common anode Bipolar transistors may be added for gain where VDD  10 V or IO  10 mA. Fig 8. Connection to LED display readout DSSURSULDWH YROWDJH +()% RXWSXW 3+ RQHRIVHYHQ VHJPHQWV FRPPRQ EDFNSODQH +()% RXWSXW 3+ VTXDUHZDYH 966WR9'' 966 DDH Fig 9. Connection to LCD readout DDH Fig 10. Connection to incandescent display readout DSSURSULDWH YROWDJH +()% RXWSXW +()% 3+ RXWSXW WR ILODPHQW VXSSO\ 966 3+ 966RUDSSURSULDWH YROWDJHEHORZ966 966 DDH DDH Fig 11. Connection to gas discharge display readout HEF4543B Product data sheet Fig 12. Connection to fluorescent display readout All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 11 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver 13. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 13. Package outline SOT109-1 (SO16) HEF4543B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 12 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver 14. Abbreviations Table 10. Abbreviations Acronym Description DUT Device Under Test 15. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4543B v.7 20160401 Product data sheet - HEF4543B v.6 Modifications: HEF4543B v.6 Modifications: HEF4543B v.5 • Type number HEF4543BP (SOT38-4) removed. 20111117 • • • Product data sheet - HEF4543B v.5 Section Applications removed Table 6: IOH minimum values changed to maximum Figure 6: signal LT removed; signal BL replaced by BL (inverted) 20091027 Product data sheet - HEF4543B v.4 HEF4543B v.4 20090317 Product data sheet - HEF4543B_CNV v.3 HEF4543B_CNV v.3 19950101 Product specification - HEF4543B_CNV v.2 HEF4543B_CNV v.2 19950101 Product specification - - HEF4543B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 13 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. HEF4543B Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 14 of 16 HEF4543B Nexperia BCD to 7-segment latch/decoder/driver Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com HEF4543B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 1 April 2016 © Nexperia B.V. 2017. All rights reserved 15 of 16 Nexperia HEF4543B BCD to 7-segment latch/decoder/driver 18. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Application information. . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 01 April 2016
HEF4543BT,652
物料型号:HEF4543B
器件简介: - HEF4543B是一款用于液晶和LED显示的BCD到7段锁存/解码/驱动器。 - 它具有4个地址输入(D0到D3)、一个低电平有效的锁存使能输入(LE)、一个高电平有效的消隐输入(BL)、一个高电平有效的相位输入(PH)和7个缓冲的段输出(Qa到Qg)。
引脚分配: - 引脚1: LE (锁存使能输入,低电平有效) - 引脚5至3: D0-D3 (地址/数据输入) - 引脚6: PH (相位输入,高电平有效) - 引脚7: BL (消隐输入,高电平有效) - 引脚8: Vss (地) - 引脚9至15: Qa至Qg (段输出) - 引脚16: VDD (供电电压)
参数特性: - 工作电压范围推荐为3V至15V。 - 支持全静态操作,具有5V、10V和15V的参数等级。 - 标准化的对称输出特性。 - 符合JEDEC标准JESD 13-B。
功能详解: - 该电路提供4位存储锁存器和8-4-2-1 BCD到7段解码/驱动器的功能。 - 可以反转输出组合的逻辑电平。 - 相位(PH)、消隐(BL)和锁存使能(LE)输入用于反转功能表相位、消隐显示和存储BCD代码。
应用信息: - 适用于驱动液晶显示器、LED显示器、荧光显示器、白炽灯显示器和气体放电显示器。
封装信息: - HEF4543BT的封装为SO16,即塑料小外形封装,16个引脚,体宽3.9毫米。
HEF4543BT,652 价格&库存
很抱歉,暂时无法提供与“HEF4543BT,652”相匹配的价格&库存,您可以联系我们找货
