Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
HV
QF
N3
2
IP4788CZ32
DVI and HDMI interface ESD and overcurrent protection,
DDC/CEC buffering, hot plug detect and backdrive protection
Rev. 2 — 24 November 2014
Product data sheet
1. Product profile
1.1 General description
The IP4788CZ32 is designed to protect High-Definition Multimedia Interface (HDMI)
transmitter host interfaces. It includes HDMI 5 V overcurrent / overvoltage protection,
Display Data Channel (DDC) buffering and decoupling, hot plug detect, backdrive
protection, Consumer Electronic Control (CEC) buffering and decoupling, and 14 kV
contact ElectroStatic Discharge (ESD) protection for all external I/Os, far exceeding the
IEC 61000-4-2, level 4 standard.
The IP4788CZ32 incorporates Transmission Line Clamping (TLC) technology on the
high-speed Transition Minimized Differential Signaling (TMDS) lines to simplify routing
and help reducing impedance discontinuities. All TMDS lines are protected by an
impedance-matched diode configuration that minimizes impedance discontinuities caused
by typical shunt diodes.
The enhanced 60 mA overcurrent / overvoltage linear regulator guarantees
HDMI-compliant 5 V output voltage levels with up to 6.5 V inputs.
The DDC lines use a new buffering concept which decouples the internal capacitive load
from the external capacitive load for use with standard Complementary Metal Oxide
Semiconductor (CMOS) or Low Voltage Transistor-Transistor Logic (LVTTL) I/O cells
down to 1.8 V. This buffering also redrives the DDC and CEC signals, allowing the use of
longer or cheaper HDMI cables with a higher capacitance. The internal hot plug detect
module simplifies the application of the HDMI transmitter to control the hot plug signal.
All lines provide appropriate integrated pull-ups and pull-downs for HDMI compliance and
backdrive protection to guarantee that HDMI interface signals are not pulled down when
the system is powered down or enters Standby mode. Only a single external capacitor is
required for operation.
1.2 Features and benefits
HDMI 2.0 and all backward compatible standards are supported
6.0 Gbps TMDS Bit Rate (600 Mcsc TMDS Character Rate) compatible
Supports Ultra High-Definition (UHD) 4K (2160p) 60 Hz display modes
Impedance matched 100 differential transmission line ESD protection for
TMDS lines (10 ). No Printed-Circuit Board (PCB) pre-compensation required
Simplified flow-through routing utilizing less overall PCB space
DDC capacitive decoupling between system side and HDMI connector side and
buffering to drive cable with high capacitive load (> 700 pF/25 m)
IP4788CZ32
NXP Semiconductors
All external I/O lines with ESD protection of at least 14 kV, exceeding the
Hot plug detect module
CEC buffering and isolation, with integrated backdrive-protected 26 k pull-up
Robust ESD protection without degradation after repeated ESD strikes
Highest integration in a small footprint, PCB level, optimized RF routing,
32-pin HVQFN leadless package
1.3 Applications
The IP4788CZ32 can be used for a wide range of HDMI source devices, consumer
and computing electronics:
High-Definition (HD) and Standard-Definition (SD) Blu-ray and DVD players
Set-top box
PC graphic card
Game console
HDMI picture performance quality enhancer module
Digital Visual Interface (DVI)
2. Pinning information
&(&B&21
9&&6
很抱歉,暂时无法提供与“IP4788CZ32J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+22.82040
- 10+22.52880
- 30+22.34520
- 100+22.15080
