74HC4067PW,112
74HC4067PW,112
    NEXPERIA(安世)
    TSSOP24_7.8X4.4MM
    16通道模拟多路复用器/解复用器
74HC4067PW,112 数据手册
74HC4067; 74HCT4067 16-channel analog multiplexer/demultiplexer Rev. 7 — 2 June 2020 Product data sheet 1. General description The 74HC4067; 74HCT4067 is a single-pole 16-throw analog switch (SP16T) suitable for use in analog or digital 16:1 multiplexer/demultiplexer applications. The switch features four digital select inputs (S0, S1, S2 and S3), sixteen independent inputs/outputs (Yn), a common input/output (Z) and a digital enable input (E). When E is HIGH, the switches are turned off. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • • • • • Wide supply voltage range from 2.0 V to 10.0 V Input levels S0, S1, S2, S3 and E inputs: • For 74HC4067: CMOS level • For 74HCT4067: TTL level CMOS low power dissipation High noise immunity Low ON resistance: • 80 Ω (typical) at VCC = 4.5 V • 70 Ω (typical) at VCC = 6.0 V • 60 Ω (typical) at VCC = 9.0 V Complies with JEDEC standards: • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V) Latch-up performance exceeds 100 mA per JESD 78 Class II Level B ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V • CDM JESD22-C101E exceeds 1000 V Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C Typical ‘break before make’ built-in 3. Applications • • • Analog multiplexing and demultiplexing Digital multiplexing and demultiplexing Signal gating 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 4. Ordering information Table 1. Ordering information Type number Package 74HC4067D Temperature range Name Description Version -40 °C to +125 °C SO24 plastic small outline package; 24 leads; body width 7.5 mm SOT137-1 -40 °C to +125 °C SSOP24 plastic shrink small outline package; 24 leads; body width 5.3 mm SOT340-1 -40 °C to +125 °C TSSOP24 plastic thin shrink small outline package; 24 leads; SOT355-1 body width 4.4 mm -40 °C to +125 °C DHVQFN24 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 24 terminals; body 3.5 x 5.5 x 0.85 mm 74HCT4067D 74HC4067DB 74HCT4067DB 74HC4067PW 74HCT4067PW 74HC4067BQ 74HCT4067BQ SOT815-1 5. Functional diagram 9 S0 S1 S2 S3 10 8 11 7 14 6 13 5 4 3 2 23 22 21 20 19 18 17 E 15 16 1 10 11 14 13 Y0 15 Y1 Y2 Y3 Y4 Y5 1 Y6 Y7 Y8 Y9 Y10 Y11 Y12 Y13 Y14 Y15 Z 0 16 × 3 G16 MUX/DMUX 9 0 8 1 7 2 6 3 5 4 4 5 3 6 2 7 23 8 22 9 21 10 20 11 19 12 18 13 17 14 16 15 001aag726 001aag725 Fig. 1. Logic symbol 74HC_HCT4067 Product data sheet 0 15 Fig. 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 2 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer Yn VCC VCC Z GND from logic Fig. 3. 001aag729 Schematic diagram (one switch) 9 Y0 8 Y1 S0 10 7 Y2 6 Y3 S1 11 5 Y4 4 Y5 S2 14 3 Y6 2 Y7 S3 13 23 Y8 1-OF-16 DECODER 22 Y9 21 Y10 20 Y11 19 Y12 18 Y13 17 Y14 E 15 16 Y15 1 Z 001aag727 Fig. 4. Functional diagram 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 3 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer Y0 Y1 Y2 Y3 Y4 S0 Y5 Y6 Y7 S1 Y8 Y9 Y10 S2 Y11 Y12 Y13 S3 Y14 Y15 E Z 001aag728 Fig. 5. Logic diagram 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 4 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 6. Pinning information 6.1. Pinning 1 Z terminal 1 index area 24 VCC 74HC4067 74HCT4067 74HC4067 74HCT4067 24 VCC Y7 2 23 Y8 Y6 3 22 Y9 Y5 4 21 Y10 Y4 5 20 Y11 Y3 6 19 Y12 Y2 7 18 Y13 Y1 8 17 Y14 Y0 9 16 Y15 S0 10 15 E S1 11 14 S2 GND 12 13 S3 22 Y9 Y5 4 21 Y10 Y4 5 20 Y11 Y3 6 19 Y12 Y2 7 18 Y13 Y1 8 17 Y14 Y0 9 S0 10 16 Y15 VCC(1) 15 E S1 11 14 S2 001aag731 Transparent top view (1) This is not a supply pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to VCC. 001aag730 Fig. 6. 23 Y8 3 S3 13 1 2 Y6 GND 12 Z Y7 Pin configuration SOT137-1 (SO24), SOT340-1 (SSOP24) and SOT355-1 (TSSOP24) Fig. 7. Pin configuration SOT815-1 (DHVQFN24) 6.2. Pin description Table 2. Pin description Symbol Pin Description Z 1 common input or output Y7, Y6, Y5, Y4, Y3, Y2, Y1, Y0, Y15, Y14, Y13, Y12, Y11, Y10, Y9, Y8 2, 3, 4, 5, 6, 7, 8, 9, 16, 17, 18, 19, 20, 21, 22, 23 independent input or output S0, S1, S2, S3 10, 11, 14, 13 address input GND 12 ground (0 V) E 15 enable input (active LOW) VCC 24 supply voltage 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 5 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 7. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care. Inputs Channel ON E S3 S2 S1 S0 L L L L L Y0 to Z L L L L H Y1 to Z L L L H L Y2 to Z L L L H H Y3 to Z L L H L L Y4 to Z L L H L H Y5 to Z L L H H L Y6 to Z L L H H H Y7 to Z L H L L L Y8 to Z L H L L H Y9 to Z L H L H L Y10 to Z L H L H H Y11 to Z L H H L L Y12 to Z L H H L H Y13 to Z L H H H L Y14 to Z L H H H H Y15 to Z H X X X X - 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current ISK switch clamping current ISW switch current ICC Min Max Unit -0.5 +11.0 V VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA VSW < -0.5 V or VSW > VCC + 0.5 V - ±20 mA VSW = -0.5 V to VCC + 0.5 V - ±25 mA supply current - +50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation Tamb = -40 °C to +125 °C - 500 mW P power dissipation per switch - 100 mW [1] [2] Conditions [1] [2] To avoid drawing VCC current out of terminal Z, when switch current flows in terminals Yn, the voltage drop across the bidirectional switch must not exceed 0.4 V. If the switch current flows into terminal Z, no VCC current will flow out of terminals Yn. In this case there is no limit for the voltage drop across the switch, but the voltages at Yn and Z may not exceed VCC or GND. For SOT137-1 (SO24) package: Ptot derates linearly with 16.2 mW/K above 119 °C. For SOT340-1 (SSOP24) packages: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT355-1 (TSSOP24) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT815-1 (DHVQFN24) package: Ptot derates linearly with 15.0 mW/K above 117 °C. 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 6 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions VCC supply voltage VI input voltage VSW switch voltage Δt/ΔV input transition rise and fall rate Tamb 74HC4067 74HCT4067 Unit Min Typ Max Min Typ Max 2.0 5.0 10.0 4.5 5.0 5.5 V GND - VCC GND - VCC V GND - VCC GND - VCC V VCC = 2.0 V - - 625 - - - ns VCC = 4.5 V - 1.67 139 - 1.67 139 ns VCC = 6.0 V - - 83 - - - ns VCC = 10.0 V - - 31 - - - ns -40 +25 +125 -40 +25 +125 °C ambient temperature 10. Static characteristics Table 6. RON resistance per switch for types 74HC4067 and 74HCT4067 VI = VIH or VIL; for test circuit see Fig. 8. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. For 74HC4067: VCC - GND = 2.0 V, 4.5 V, 6.0 V and 9.0 V. For 74HCT4067: VCC - GND = 4.5 V. Symbol Parameter Conditions 25 °C Typ RON(peak) ON resistance (peak) ON resistance (rail) [1] Max Max (85 °C) (125 °C) - - - - Ω VCC = 4.5 V; ISW = 1000 μA 110 180 225 270 Ω VCC = 6.0 V; ISW = 1000 μA 95 160 200 240 Ω VCC = 9.0 V; ISW = 1000 μA 75 130 165 195 Ω [1] Vis = GND or VCC VCC = 2.0 V; ISW = 100 μA ΔRON Max Vis = VCC to GND VCC = 2.0 V; ISW = 100 μA RON(rail) -40 °C to +125 °C Unit 150 - - - VCC = 4.5 V; ISW = 1000 μA 90 160 200 240 Ω VCC = 6.0 V; ISW = 1000 μA 80 140 175 210 Ω VCC = 9.0 V; ISW = 1000 μA 70 120 150 180 Ω ON resistance mismatch Vis = VCC to GND between channels VCC = 2.0 V [1] - - - - Ω VCC = 4.5 V [1] 9 - - - Ω VCC = 6.0 V 8 - - - Ω VCC = 9.0 V 6 - - - Ω At supply voltages (VCC - GND) approaching 2 V, the analog switch ON resistance becomes extremely non-linear. Therefore it is recommended that these devices be used to transmit digital signals only, when using these supply voltages. 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 7 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer mnb047 110 (1) RON (Ω) 90 70 (2) VSW VCC E VIL Yn Vis 30 Z GND 10 ISW 0 1.8 3.6 5.4 7.2 Vis (V) 9.0 Vis = 0 V to VCC (1) VCC = 4.5 V (2) VCC = 6.0 V (3) VCC = 9.0 V 001aag733 Vis = 0 V to VCC Fig. 8. (3) 50 Test circuit for measuring RON Fig. 9. Typical RON as a function of input voltage Vis Table 7. Static characteristics 74HC4067 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V VCC = 9.0 V 6.3 4.7 - V VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.80 V VCC = 9.0 V - 4.3 2.70 V VCC = 6.0 V - - ±0.1 μA VCC = 10.0 V - - ±0.2 μA per channel - - ±0.1 μA all channels - - ±0.8 μA - - ±0.8 μA VCC = 6.0 V - - 8.0 μA VCC = 10.0 V - - 16.0 μA - 3.5 - pF Tamb = 25 °C VIH VIL II IS(OFF) HIGH-level input voltage LOW-level input voltage input leakage current OFF-state leakage current VI = VCC or GND VCC = 10.0 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 10 IS(ON) ON-state leakage current VCC = 10.0 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 11 ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND CI input capacitance 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 8 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 9.0 V 6.3 - - V VCC = 2.0 V - - 0.50 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.80 V VCC = 9.0 V - - 2.70 V VCC = 6.0 V - - ±1.0 μA VCC = 10.0 V - - ±2.0 μA per channel - - ±1.0 μA all channels - - ±8.0 μA - - ±8.0 μA VCC = 6.0 V - - 80.0 μA VCC = 10.0 V - - 160 μA VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 9.0 V 6.3 - - V VCC = 2.0 V - - 0.50 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.80 V VCC = 9.0 V - - 2.70 V VCC = 6.0 V - - ±1.0 μA VCC = 10.0 V - - ±2.0 μA per channel - - ±1.0 μA all channels - - ±8.0 μA - - ±8.0 μA VCC = 6.0 V - - 160 μA VCC = 10.0 V - - 320 μA Tamb = -40 °C to +85 °C VIH VIL II IS(OFF) HIGH-level input voltage LOW-level input voltage input leakage current OFF-state leakage current VI = VCC or GND VCC = 10.0 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 10 IS(ON) ON-state leakage current VCC = 10.0 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 11 ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND Tamb = -40 °C to +125 °C VIH VIL II IS(OFF) HIGH-level input voltage LOW-level input voltage input leakage current OFF-state leakage current VI = VCC or GND VCC = 10.0 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 10 IS(ON) ON-state leakage current VCC = 10.0 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 11 ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 9 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer Table 8. Static characteristics 74HCT4067 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max Unit - V Tamb = 25 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 μA IS(OFF) OFF-state leakage current VCC = 5.5 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 10 per channel - - ±0.1 μA all channels - - ±0.8 μA IS(ON) ON-state leakage current VCC = 5.5 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 11 - - ±0.8 μA ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND; VCC = 4.5 V to 5.5 V - - 8.0 μA ΔICC additional supply current per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V pin E - 60 216 μA pin Sn - 50 180 μA - 3.5 - pF CI input capacitance Tamb = -40 °C to +85 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±1.0 μA IS(OFF) OFF-state leakage current VCC = 5.5 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 10 per channel - - ±1.0 μA all channels - - ±8.0 μA IS(ON) ON-state leakage current VCC = 5.5 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 11 - - ±8.0 μA ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND; VCC = 4.5 V to 5.5 V - - 80.0 μA ΔICC additional supply current per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V pin E - - 270 μA pin Sn - - 225 μA 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 10 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer Symbol Parameter Conditions Min Typ Max Unit - V Tamb = -40 °C to +125 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±1.0 μA IS(OFF) OFF-state leakage current VCC = 5.5 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 10 per channel - - ±1.0 μA all channels - - ±8.0 μA IS(ON) ON-state leakage current VCC = 5.5 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 11 - - ±8.0 μA ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND; VCC = 4.5 V to 5.5 V - - 160 μA ΔICC additional supply current per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V pin E - - 294 μA pin Sn - - 245 μA VCC VCC E VIH ISW Vis VIL Yn Z GND ISW ISW E Z Yn Vos Vis Vos GND 001aag735 001aag734 Vis = VCC and Vos = GND Vis = GND and Vos = VCC Vis = VCC and Vos = open Vis = GND and Vos = open Fig. 10. Test circuit for measuring OFF-state leakage current 74HC_HCT4067 Product data sheet Fig. 11. Test circuit for measuring ON-state leakage current All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 11 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 11. Dynamic characteristics Table 9. Dynamic characteristics 74HC4067 GND = 0 V; tr = tf = 6 ns; CL = 50 pF unless specified otherwise; for test circuit see Fig. 14. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter tpd propagation delay Conditions 25 °C -40 °C to +125 °C Unit Typ Max VCC = 2.0 V 25 75 95 110 ns VCC = 4.5 V 9 15 19 22 ns VCC = 6.0 V 7 13 16 19 ns VCC = 9.0 V 5 9 11 14 ns VCC = 2.0 V 18 60 75 90 ns VCC = 4.5 V 6 12 15 18 ns VCC = 6.0 V 5 10 13 15 ns VCC = 9.0 V 4 8 10 12 ns VCC = 2.0 V 74 250 315 375 ns VCC = 4.5 V 27 50 63 75 ns VCC = 5.0 V; CL = 15 pF 27 - - - ns VCC = 6.0 V 22 43 54 64 ns VCC = 9.0 V 20 38 48 57 ns VCC = 2.0 V 83 250 315 375 ns VCC = 4.5 V 30 50 63 75 ns VCC = 5.0 V; CL = 15 pF 29 - - - ns VCC = 6.0 V 24 43 54 64 ns VCC = 9.0 V 21 38 48 57 ns VCC = 2.0 V 85 275 345 415 ns VCC = 4.5 V 31 55 69 83 ns VCC = 6.0 V 25 47 59 71 ns VCC = 9.0 V 24 42 53 63 ns VCC = 2.0 V 94 290 365 435 ns VCC = 4.5 V 34 58 73 87 ns VCC = 6.0 V 27 47 62 74 ns VCC = 9.0 V 25 45 56 68 ns Yn to Z; see Fig. 12 Max Max (85 °C) (125 °C) [1][2] Z to Yn toff turn-off time E to Yn; see Fig. 13 [3] Sn to Yn E to Z Sn to Z 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 12 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer Symbol Parameter ton turn-on time Conditions 25 °C -40 °C to +125 °C Unit Typ Max VCC = 2.0 V 80 275 345 415 ns VCC = 4.5 V 29 55 69 83 ns VCC = 5.0 V; CL = 15 pF 26 - - - ns VCC = 6.0 V 23 47 59 71 ns VCC = 9.0 V 17 42 53 63 ns VCC = 2.0 V 88 300 375 450 ns VCC = 4.5 V 32 60 75 90 ns VCC = 5.0 V; CL = 15 pF 29 - - - ns VCC = 6.0 V 26 51 64 77 ns VCC = 9.0 V 18 45 56 68 ns VCC = 2.0 V 85 275 345 415 ns VCC = 4.5 V 31 55 69 83 ns VCC = 6.0 V 25 47 59 71 ns VCC = 9.0 V 18 42 53 63 ns VCC = 2.0 V 94 300 375 450 ns VCC = 4.5 V 34 60 75 90 ns VCC = 6.0 V 27 51 64 77 ns VCC = 9.0 V 19 45 56 68 ns 29 - - - pF E to Yn; see Fig. 13 Max Max (85 °C) (125 °C) [4] Sn to Yn E to Z Sn to Z CPD [1] [2] [3] [4] [5] power dissipation capacitance per switch; VI = GND to VCC [5] tpd is the same as tPHL and tPLH. Due to higher Z terminal capacitance (16 switches versus 1) the delay figures to the Z terminal are higher than those to the Y terminal. ton is the same as tPHZ and tPLZ. toff is the same as tPZH and tPZL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi + ∑{(CL + Csw) x VCC x fo} where: fi = input frequency in MHz; fo = output frequency in MHz; 2 ∑{(CL + Csw) x VCC x fo} = sum of outputs; CL = output load capacitance in pF; Csw = switch capacitance in pF; VCC = supply voltage in V. 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 13 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer Table 10. Dynamic characteristics 74HCT4067 GND = 0 V; tr = tf = 6 ns; CL = 50 pF unless specified otherwise; for test circuit see Fig. 14. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter tpd propagation delay Conditions 25 °C -40 °C to +125 °C Unit Typ Max 9 15 19 22 ns 6 12 15 18 ns VCC = 4.5 V 26 55 69 83 ns VCC = 5.0 V; CL = 15 pF 26 - - - ns VCC = 4.5 V 31 55 69 83 ns VCC = 5.0 V; CL = 15 pF 30 - - - ns 30 60 75 90 ns 35 60 75 90 ns VCC = 4.5 V 32 60 75 90 ns VCC = 5.0 V; CL = 15 pF 32 - - - ns VCC = 4.5 V 35 60 75 90 ns VCC = 5.0 V; CL = 15 pF 33 - - - ns 38 65 81 98 ns 38 65 81 98 ns 29 - - - pF Yn to Z; see Fig. 12 Max Max (85 °C) (125 °C) [1][2] VCC = 4.5 V Z to Yn VCC = 4.5 V toff turn-off time E to Yn; see Fig. 13 [3] Sn to Yn E to Z VCC = 4.5 V Sn to Z VCC = 4.5 V ton turn-on time E to Yn; see Fig. 13 [4] Sn to Yn E to Z VCC = 4.5 V Sn to Z VCC = 4.5 V CPD [1] [2] [3] [4] [5] power dissipation capacitance per switch; VI = GND to (VCC - 1.5 V) [5] tpd is the same as tPHL and tPLH. Due to higher Z terminal capacitance (16 switches versus 1) the delay figures to the Z terminal are higher than those to the Y terminal. ton is the same as tPHZ and tPLZ. toff is the same as tPZH and tPZL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi + ∑{(CL + Csw) x VCC x fo} where: fi = input frequency in MHz; fo = output frequency in MHz; 2 ∑{(CL + Csw) x VCC x fo} = sum of outputs; CL = output load capacitance in pF; Csw = switch capacitance in pF; VCC = supply voltage in V. 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 14 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 11.1. Waveforms and test circuit 50 % Vis input tPLH tPHL 50 % Vos output 001aad555 Fig. 12. Input (Vis) to output (Vos) propagation delays VI VM E, Sn inputs 0V tPLZ tPZL 50 % Vos output 10 % tPHZ tPZH 90 % 50 % Vos output switch ON switch ON switch OFF 001aad556 Measurement points are shown in Table 11. Fig. 13. Turn-on and turn-off times Table 11. Measurement points Type VI VM 74HC4067 VCC 0.5VCC 74HCT4067 3.0 V 1.3 V 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 15 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC Vis PULSE GENERATOR VI VCC Vos RL DUT RT S1 open CL GND 001aag732 Test data is given in Table 12. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig. 14. Test circuit for measuring switching times Table 12. Test data Test Input Output S1 position Control E Address Sn Switch Yn (Z) tr, tf Switch Z (Yn) VI[1] VI[1] Vis CL RL tPHL, tPLH GND GND or VCC GND to VCC 6 ns 50 pF - open tPHZ, tPZH GND to VCC GND to VCC VCC 6 ns 50 pF, 15 pF 1 kΩ GND tPLZ, tPZL GND to VCC GND to VCC GND 6 ns 50 pF, 15 pF 1 kΩ VCC [1] For 74HCT4067: maximum input voltage VI = 3.0 V. 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 16 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 12. Additional dynamic characteristics Table 13. Additional dynamic characteristics Recommended conditions and typical values; GND = 0 V. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter THD total harmonic distortion Conditions 25 °C Unit Min Typ Max VCC = 4.5 V; Vis(p-p) = 4.0 V - 0.04 - % VCC = 9.0 V; Vis(p-p) = 8.0 V - 0.02 - % VCC = 4.5 V; Vis(p-p) = 4.0 V - 0.12 - % VCC = 9.0 V; Vis(p-p) = 8.0 V - 0.06 - % VCC = 4.5 V - -50 - dB VCC = 9.0 V - -50 - dB VCC = 4.5 V - 90 - MHz VCC = 9.0 V - 100 - MHz independent pins Y - 5 - pF common pin Z - 45 - pF RL = 10 kΩ; CL = 50 pF; see Fig. 15 fi = 1 kHz fi = 10 kHz αiso isolation (OFF-state) f(-3dB) Csw [1] [2] -3 dB frequency response switch capacitance RL = 600 Ω; CL = 50 pF; see Fig. 16 [1] RL = 50 Ω; CL = 10 pF; see Fig. 17 [2] Adjust input voltage Vis to 0 dBm level (0 dBm = 1 mW into 600 Ω). Adjust input voltage Vis to 0 dBm level at Vos for fi = 1 MHz (0 dBm = 1 mW into 50 Ω). After set-up, fi is increased to obtain a reading of -3 dB at Vos. VCC VCC E VIL 2RL Vis 10 µF Yn fi Z GND Vos 2RL CL D 001aag736 Fig. 15. Test circuit for measuring total harmonic distortion 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 17 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 001aae332 0 α iso (dB) - 20 - 40 - 60 - 80 - 100 10 102 103 104 105 fi (kHz) 106 a. Isolation (OFF-state) VCC VIH VCC E 2RL Vis 0.1 µF Yn Z GND fi Vos 2RL CL dB 001aag737 b. Test circuit VCC = 4.5 V; GND = 0 V; RL = 600 Ω; Rsource = 1 kΩ. Fig. 16. Isolation (OFF-state) as a function of frequency 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 18 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 001aag739 5 Vos (dB) 0 -5 10 102 103 104 105 fi (kHz) 106 a. Typical -3 dB frequency response VCC VCC E VIL 2RL Vis 0.1 µF Yn Z GND fi Vos 2RL CL dB 001aag738 b. Test circuit VCC = 4.5 V; GND = 0 V; RL = 50 Ω; Rsource = 1 kΩ. Fig. 17. -3 dB frequency response 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 19 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 13. Package outline SO24: plastic small outline package; 24 leads; body width 7.5 mm SOT137-1 D E A X c HE y v M A Z 24 13 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 12 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 15.6 15.2 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.9 0.4 inches 0.1 0.012 0.096 0.004 0.089 0.01 0.019 0.013 0.014 0.009 0.61 0.60 0.30 0.29 0.05 0.419 0.043 0.043 0.055 0.394 0.016 0.039 0.01 0.01 0.004 0.035 0.016 Z (1) θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT137-1 075E05 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 18. Package outline SOT137-1 (SO24) 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 20 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer SSOP24: plastic shrink small outline package; 24 leads; body width 5.3 mm D SOT340-1 E A X c HE y v M A Z 24 13 Q A2 pin 1 index A (A 3 ) A1 θ Lp L 1 12 bp e detail X w M 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 8.4 8.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 0.8 0.4 8o 0o Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. OUTLINE VERSION SOT340-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig. 19. Package outline SOT340-1 (SSOP24) 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 21 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer TSSOP24: plastic thin shrink small outline package; 24 leads; body width 4.4 mm D SOT355-1 E A X c HE y v M A Z 13 24 Q A2 (A 3 ) A1 pin 1 index A θ Lp 1 L 12 bp e detail X w M 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 7.9 7.7 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT355-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig. 20. Package outline SOT355-1 (TSSOP24) 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 22 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer DHVQFN24: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 24 terminals; body 3.5 x 5.5 x 0.85 mm D B SOT815-1 A A E A1 c detail X terminal 1 index area C e1 terminal 1 index area e 2 y1 C v M C A B w M C b 11 y L 12 1 e2 Eh 24 13 23 14 X Dh 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 e2 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 5.6 5.4 4.25 3.95 3.6 3.4 2.25 1.95 0.5 4.5 1.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT815-1 --- --- --- EUROPEAN PROJECTION ISSUE DATE 03-04-29 Fig. 21. Package outline SOT815-1 (DHVQFN24) 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 23 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 14. Abbreviations Table 14. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 15. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT4067 v.7 20200602 Product data sheet - 74HC_HCT4067 v.6 Modifications: • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 2 updated. Table 4: Derating values for Ptot total power dissipation have been updated. 74HC_HCT4067 v.6 20150522 Modifications: • • 74HC_HCT4067 v.5 20111213 Modifications: • 74HC_HCT4067 v.4 20110518 74HC_HCT4067 v.3 20071015 Product data sheet - 74HC_HCT4067 v.5 Type numbers 74HC4067N and 74HCT4067N (SOT101-1) removed. Fig. 8, Fig. 9: Figure note Vis = 0 V to (VCC-GND) changed to Vis = 0 V to VCC Product data sheet - 74HC_HCT4067 v.4 Product data sheet - 74HC_HCT4067 v.3 Product data sheet - 74HC_HCT4067_CNV v.2 Product specification - - Legal pages updated. 74HC_HCT4067_CNV v.2 19970901 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 24 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer 16. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT4067 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 25 / 26 74HC4067; 74HCT4067 Nexperia 16-channel analog multiplexer/demultiplexer Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................2 5. Functional diagram.......................................................2 6. Pinning information......................................................5 6.1. Pinning.........................................................................5 6.2. Pin description............................................................. 5 7. Functional description................................................. 6 8. Limiting values............................................................. 6 9. Recommended operating conditions..........................7 10. Static characteristics..................................................7 11. Dynamic characteristics...........................................12 11.1. Waveforms and test circuit.......................................15 12. Additional dynamic characteristics........................ 17 13. Package outline........................................................ 20 14. Abbreviations............................................................ 24 15. Revision history........................................................24 16. Legal information......................................................25 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 2 June 2020 74HC_HCT4067 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 2 June 2020 © Nexperia B.V. 2020. All rights reserved 26 / 26
74HC4067PW,112 价格&库存
很抱歉,暂时无法提供与“74HC4067PW,112”相匹配的价格&库存,您可以联系我们找货
