74HC4053; 74HCT4053
Triple 2-channel analog multiplexer/demultiplexer
Rev. 9 — 10 February 2016
Product data sheet
1. General description
The 74HC4053; 74HCT4053 is a triple single-pole double-throw analog switch (3x SPDT)
suitable for use in analog or digital 2:1 multiplexer/demultiplexer applications. Each switch
features a digital select input (Sn), two independent inputs/outputs (nY0 and nY1) and a
common input/output (nZ). A digital enable input (E) is common to all switches. When E is
HIGH, the switches are turned off. Inputs include clamp diodes. This enables the use of
current limiting resistors to interface inputs to voltages in excess of VCC.
2. Features and benefits
Wide analog input voltage range from 5 V to +5 V
Complies with JEDEC standard no. 7A
Low ON resistance:
80 (typical) at VCC VEE = 4.5 V
70 (typical) at VCC VEE = 6.0 V
60 (typical) at VCC VEE = 9.0 V
Logic level translation: to enable 5 V logic to communicate with 5 V analog signals
Typical ‘break before make’ built-in
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
74HC4053; 74HCT4053
Nexperia
4. Ordering information
Table 1.
Type number
74HC4053D
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
40 C to +125 C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
40 C to +125 C
DHVQFN16 plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 16 terminals;
body 2.5 3.5 0.85 mm
74HCT4053D
74HC4053DB
74HCT4053DB
74HC4053PW
74HCT4053PW
74HC4053BQ
74HCT4053BQ
SOT763-1
5. Functional diagram
9&&
很抱歉,暂时无法提供与“74HCT4053D,118”相匹配的价格&库存,您可以联系我们找货
