74LV4052PW,118
74LV4052PW,118
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    双4通道模拟多路复用器/解复用器
74LV4052PW,118 数据手册
74LV4052 Dual 4-channel analog multiplexer/demultiplexer Rev. 5 — 17 March 2016 Product data sheet 1. General description The 74LV4052 is a low-voltage CMOS device and is pin and function compatible with the 74HC/HCT4052. The 74LV4052 is a dual 4-channel analog multiplexer/demultiplexer with a common select logic. Each multiplexer has four independent inputs/outputs (nY0 to nY3) and a common input/output (nZ). The common channel select logics include two digital select inputs (S0 and S1) and an active LOW enable input (E). With E LOW, one of the four switches is selected (low impedance ON-state) by S0 and S1. With E HIGH, all switches are in the high impedance OFF-state, independent of S0 and S1. VCC and GND are the supply voltage pins for the digital control inputs (S0, S1 and E). The VCC to GND ranges are 1.0 V to 6.0 V. The analog inputs/outputs (nY0, to nY3, and nZ) can swing between VCC as a positive limit and VEE as a negative limit. VCC - VEE may not exceed 6.0 V. For operation as a digital multiplexer/demultiplexer, VEE is connected to GND (typically ground). 2. Features and benefits  Optimized for low-voltage applications: 1.0 V to 6.0 V  Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V  Low ON resistance:  145  (typical) at VCC  VEE = 2.0 V  90  (typical) at VCC  VEE = 3.0 V  60  (typical) at VCC  VEE = 4.5 V  Logic level translation:  To enable 3 V logic to communicate with 3 V analog signals  Typical ‘break before make’ built in  ESD protection:  HBM JESD22-A114E exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 74LV4052 Nexperia Dual 4-channel analog multiplexer/demultiplexer 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV4052D 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74LV4052DB 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74LV4052PW 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 4. Functional diagram 9&&      6 (  /2*,& /(9(/ &219(56,21
74LV4052PW,118 价格&库存
很抱歉,暂时无法提供与“74LV4052PW,118”相匹配的价格&库存,您可以联系我们找货
74LV4052PW,118
  • 1+1.32096
库存:8
74LV4052PW,118
  • 5+2.12890
  • 50+1.67454
  • 150+1.47982
  • 500+1.22456
  • 2500+1.11743
  • 5000+1.05317
库存:412
74LV4052PW,118
  • 1+1.44560
  • 10+1.33440
  • 100+1.22320
  • 1000+1.11200
库存:13779
74LV4052PW,118
    • 2500+0.942902500+0.11433
    • 5000+0.924595000+0.11211
    • 7500+0.915437500+0.11100
    • 10000+0.9090310000+0.11023
    • 12500+0.8879712500+0.10767
    库存:2500
    74LV4052PW,118
    • 1+1.32000
    • 100+1.01090
    • 1250+0.85690
    • 2500+0.72600
    库存:13779
    74LV4052PW,118
    • 1+2.735361+0.33168
    • 10+1.9034010+0.23080
    • 25+1.6866425+0.20452
    • 100+1.45377100+0.17628
    • 250+1.34159250+0.16268
    • 500+1.27414500+0.15450
    • 1000+1.218571000+0.14776
    库存:4607
    74LV4052PW,118
    • 1+2.900521+0.35170
    • 10+2.0148810+0.24432
    • 25+1.7857325+0.21653
    • 100+1.53996100+0.18673
    • 250+1.42214250+0.17244
    • 500+1.35113500+0.16383
    • 1000+1.292751000+0.15675
    库存:4607
    74LV4052PW,118
    • 2500+1.159892500+0.14065
    • 5000+1.124535000+0.13636
    • 7500+1.106807500+0.13421
    • 12500+1.0871712500+0.13183
    • 17500+1.0757017500+0.13044
    • 25000+1.0646725000+0.12910
    • 62500+1.0409262500+0.12622
    库存:4607
    74LV4052PW,118
    • 1+1.78910
    库存:85
