74HC4051PW-Q100,11
74HC4051PW-Q100,11
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    8路模拟多路复用器/解复用器
74HC4051PW-Q100,11 数据手册
74HC4051-Q100; 74HCT4051-Q100 8-channel analog multiplexer/demultiplexer Rev. 2 — 8 October 2012 Product data sheet 1. General description The 74HC4051-Q100; 74HCT4051-Q100 is a high-speed Si-gate CMOS device and is pin compatible with Low-power Schottky TTL (LSTTL). The device is specified in compliance with JEDEC standard no. 7A. The 74HC4051-Q100; 74HCT4051-Q100 is an 8-channel analog multiplexer/demultiplexer with three digital select inputs (S0 to S2), an active-LOW enable input (E), eight independent inputs/outputs (Y0 to Y7) and a common input/output (Z). With E LOW, one of the eight switches is selected (low impedance ON-state) by S0 to S2. With E HIGH, all switches are in the high-impedance OFF-state, independent of S0 to S2. VCC and GND are the supply voltage pins for the digital control inputs (S0 to S2, and E). The VCC to GND ranges are 2.0 V to 10.0 V for 74HC4051-Q100 and 4.5 V to 5.5 V for 74HCT4051-Q100. The analog inputs/outputs (Y0 to Y7, and Z) can swing between VCC as a positive limit and VEE as a negative limit. VCC  VEE may not exceed 10.0 V. For operation as a digital multiplexer/demultiplexer, VEE is connected to GND (typically ground). This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide analog input voltage range from 5 V to +5 V  Low ON resistance:  80  (typical) at VCC  VEE = 4.5 V  70  (typical) at VCC  VEE = 6.0 V  60  (typical) at VCC  VEE = 9.0 V  Logic level translation: to enable 5 V logic to communicate with 5 V analog signals  Typical ‘break before make’ built-in  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 )  CDM AEC-Q100-011 revision B exceeds 1000 V  Multiple package options 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer 3. Applications  Analog multiplexing and demultiplexing  Digital multiplexing and demultiplexing  Signal gating 4. Ordering information Table 1. Ordering information Type number 74HC4051D-Q100 Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 40 C to +125 C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm 74HCT4051D-Q100 74HC4051PW-Q100 74HCT4051PW-Q100 74HC4051BQ-Q100 74HCT4051BQ-Q100 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © SOT763-1 Nexperia B.V. 2017. All rights reserved 2 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer 5. Functional diagram VCC 16 13 Y0 S0 11 14 Y1 15 Y2 S1 10 12 Y3 LOGIC LEVEL CONVERSION 1 Y4 1-OF-8 DECODER S2 9 5 Y5 2 Y6 4 Y7 E 6 3 Z 8 GND Fig 1. 7 VEE 001aad543 Functional diagram 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 3 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer 11 10 9 6 13 S0 S1 S2 14 11 10 15 9 12 1 5 2 E 6 4 3 0 8X 2 G8 Y0 Y1 MUX/DMUX 0 Y2 13 14 1 Y3 15 2 Y4 12 3 3 Y5 1 4 Y6 5 5 Y7 2 6 4 7 Z 001aad541 Fig 2. 0 7 001aad542 Logic symbol Fig 3. IEC logic symbol Y VCC VEE VCC VCC VCC VEE from logic VEE Z 001aad544 Fig 4. Schematic diagram (one switch) 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 4 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer 6. Pinning information 6.1 Pinning 1 Y4 terminal 1 index area 74HC4051-Q100 74HCT4051-Q100 16 VCC 74HC4051-Q100 74HCT4051-Q100 Y6 2 15 Y2 Y4 1 16 VCC Z 3 14 Y1 Y6 2 15 Y2 Y7 4 13 Y0 Z 3 14 Y1 Y5 5 12 Y3 Y7 4 13 Y0 E 6 Y5 5 12 Y3 7 E 6 11 S0 VEE VEE 7 10 S1 GND 8 8 9 S2 S2 11 S0 10 S1 GND 9 VCC(1) aaa-003161 Transparent top view aaa-003160 (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to VCC. Fig 5. Pin configuration SO16 and TSSOP16 Fig 6. Pin configuration DHVQFN16 6.2 Pin description Table 2. Pin description Symbol Pin Description E 6 enable input (active LOW) VEE 7 supply voltage GND 8 ground supply voltage S0, S1, S2 11, 10, 9 select input Y0, Y1, Y2, Y3, Y4, Y5, Y6, Y7 13, 14, 15, 12, 1, 5, 2, 4 independent input or output Z 3 common output or input VCC 16 supply voltage 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 5 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer 7. Functional description 7.1 Function table Table 3. Function table[1] Input Channel ON E S2 S1 S0 L L L L Y0 to Z L L L H Y1 to Z L L H L Y2 to Z L L H H Y3 to Z L H L L Y4 to Z L H L H Y5 to Z L H H L Y6 to Z L H H H Y7 to Z H X X X switches off [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground). Symbol Parameter VCC supply voltage IIK input clamping current Conditions Min Max Unit 0.5 +11.0 V VI < 0.5 V or VI > VCC + 0.5 V - 20 mA [1] ISK switch clamping current VSW < 0.5 V or VSW > VCC + 0.5 V - 20 mA ISW switch current 0.5 V < VSW < VCC + 0.5 V - 25 mA IEE supply current - 20 mA ICC supply current - 50 mA IGND ground current - 50 mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 500 mW P power dissipation - 100 mW [2] per switch [1] To avoid drawing VCC current out of terminal Z, when switch current flows into terminals Yn, the voltage drop across the bidirectional switch must not exceed 0.4 V. If the switch current flows into terminal Z, no VCC current will flow out of terminals Yn, and in this case there is no limit for the voltage drop across the switch, but the voltages at Yn and Z may not exceed VCC or VEE. [2] For SO16 packages: above 70 C the value of Ptot derates linearly with 8 mW/K. For TSSOP16 package: above 60 C the value of Ptot derates linearly with 5.5 mW/K. For DHVQFN16 packages: above 60 C the value of Ptot derates linearly with 4.5 mW/K. 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 6 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions supply voltage VCC 74HC4051-Q100 74HCT4051-Q100 Unit Min Typ Max Min Typ Max VCC  GND 2.0 5.0 10.0 4.5 5.0 5.5 V VCC  VEE 2.0 5.0 10.0 2.0 5.0 10.0 V - VCC GND - VCC V see Figure 7 and Figure 8 VI input voltage GND VSW switch voltage VEE - VCC VEE - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V VCC = 10.0 V - - 31 - - - ns/V 001aad545 10 VCC − GND (V) 001aad546 10 VCC − GND (V) 8 8 6 6 operating area operating area 4 4 2 2 0 0 0 Fig 7. 2 4 6 8 10 VCC − VEE (V) Guaranteed operating area as a function of the supply voltages for 74HC4051-Q100 74HC_HCT4051_Q100 Product data sheet 0 Fig 8. 2 4 6 8 10 VCC − VEE (V) Guaranteed operating area as a function of the supply voltages for 74HCT4051-Q100 All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 7 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer 10. Static characteristics Table 6. RON resistance per switch for 74HC4051-Q100 and 74HCT4051-Q100 VI = VIH or VIL; for test circuit see Figure 9. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. For 74HC4051-Q100: VCC  GND or VCC  VEE = 2.0 V, 4.5 V, 6.0 V and 9.0 V. For 74HCT4051-Q100: VCC  GND = 4.5 V and 5.5 V, VCC  VEE = 2.0 V, 4.5 V, 6.0 V and 9.0 V. Symbol Parameter Conditions Min Typ Max Unit - - -  VCC = 4.5 V; VEE = 0 V; ISW = 1000 A - 100 180  VCC = 6.0 V; VEE = 0 V; ISW = 1000 A - 90 160  VCC = 4.5 V; VEE = 4.5 V; ISW = 1000 A - 70 130  - 150 -  - 80 140  Tamb = 25 C RON(peak) ON resistance (peak) Vis = VCC to VEE VCC = 2.0 V; VEE = 0 V; ISW = 100 A RON(rail) ON resistance (rail) [1] Vis = VEE VCC = 2.0 V; VEE = 0 V; ISW = 100 A [1] VCC = 4.5 V; VEE = 0 V; ISW = 1000 A VCC = 6.0 V; VEE = 0 V; ISW = 1000 A - 70 120  VCC = 4.5 V; VEE = 4.5 V; ISW = 1000 A - 60 105  - 150 -  VCC = 4.5 V; VEE = 0 V; ISW = 1000 A - 90 160  VCC = 6.0 V; VEE = 0 V; ISW = 1000 A - 80 140  VCC = 4.5 V; VEE = 4.5 V; ISW = 1000 A - 65 120  Vis = VCC VCC = 2.0 V; VEE = 0 V; ISW = 100 A RON ON resistance mismatch between channels [1] Vis = VCC to VEE - - -  VCC = 4.5 V; VEE = 0 V - 9 -  VCC = 6.0 V; VEE = 0 V - 8 -  VCC = 4.5 V; VEE = 4.5 V - 6 -  - - -  VCC = 4.5 V; VEE = 0 V; ISW = 1000 A - - 225  VCC = 6.0 V; VEE = 0 V; ISW = 1000 A - - 200  VCC = 4.5 V; VEE = 4.5 V; ISW = 1000 A - - 165  VCC = 2.0 V; VEE = 0 V [1] Tamb = 40 C to +85 C RON(peak) ON resistance (peak) Vis = VCC to VEE VCC = 2.0 V; VEE = 0 V; ISW = 100 A 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 [1] © Nexperia B.V. 2017. All rights reserved 8 of 31 Nexperia 74HC4051-Q100; 74HCT4051-Q100 8-channel analog multiplexer/demultiplexer Table 6. RON resistance per switch for 74HC4051-Q100 and 74HCT4051-Q100 …continued VI = VIH or VIL; for test circuit see Figure 9. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. For 74HC4051-Q100: VCC  GND or VCC  VEE = 2.0 V, 4.5 V, 6.0 V and 9.0 V. For 74HCT4051-Q100: VCC  GND = 4.5 V and 5.5 V, VCC  VEE = 2.0 V, 4.5 V, 6.0 V and 9.0 V. Symbol Parameter Conditions Min Typ Max Unit RON(rail) ON resistance (rail) Vis = VEE - - -  VCC = 4.5 V; VEE = 0 V; ISW = 1000 A - - 175  VCC = 6.0 V; VEE = 0 V; ISW = 1000 A - - 150  VCC = 4.5 V; VEE = 4.5 V; ISW = 1000 A - - 130  VCC = 2.0 V; VEE = 0 V; ISW = 100 A [1] Vis = VCC VCC = 2.0 V; VEE = 0 V; ISW = 100 A - - -  VCC = 4.5 V; VEE = 0 V; ISW = 1000 A - - 200  VCC = 6.0 V; VEE = 0 V; ISW = 1000 A - - 175  VCC = 4.5 V; VEE = 4.5 V; ISW = 1000 A - - 150  - - -  VCC = 4.5 V; VEE = 0 V; ISW = 1000 A - - 270  VCC = 6.0 V; VEE = 0 V; ISW = 1000 A - - 240  VCC = 4.5 V; VEE = 4.5 V; ISW = 1000 A - - 195  - - -  VCC = 4.5 V; VEE = 0 V; ISW = 1000 A - - 210  VCC = 6.0 V; VEE = 0 V; ISW = 1000 A - - 180  VCC = 4.5 V; VEE = 4.5 V; ISW = 1000 A - - 160  [1] Tamb = 40 C to +125 C RON(peak) ON resistance (peak) Vis = VCC to VEE VCC = 2.0 V; VEE = 0 V; ISW = 100 A RON(rail) ON resistance (rail) [1] Vis = VEE VCC = 2.0 V; VEE = 0 V; ISW = 100 A [1] Vis = VCC VCC = 2.0 V; VEE = 0 V; ISW = 100 A [1] - - -  VCC = 4.5 V; VEE = 0 V; ISW = 1000 A - - 240  VCC = 6.0 V; VEE = 0 V; ISW = 1000 A - - 210  VCC = 4.5 V; VEE = 4.5 V; ISW = 1000 A - - 180  [1] When supply voltages (VCC  VEE) near 2.0 V the analog switch ON resistance becomes extremely non-linear. When using a supply of 2 V, it is recommended to use these devices only for transmitting digital signals. 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 9 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer mnb047 110 (1) RON (Ω) 90 70 (2) Vsw V (3) 50 VCC from select input Sn Vis 30 Z Yn GND VEE Isw 10 0 1.8 3.6 5.4 7.2 9.0 Vis (V) 001aan389 Vis = 0 V to (VCC  VEE). Vis = 0 V to (VCC  VEE). (1) VCC = 4.5 V V sw R ON = -------I sw (2) VCC = 6 V (3) VCC = 9 V Fig 9. Test circuit for measuring RON Fig 10. Typical RON as a function of input voltage Vis Table 7. Static characteristics for 74HC4051-Q100 Voltages are referenced to GND (ground = 0 V). Vis is the input voltage at pins Yn or Z, whichever is assigned as an input. Vos is the output voltage at pins Z or Yn, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V Tamb = 25 C VIH VIL II IS(OFF) IS(ON) HIGH-level input voltage LOW-level input voltage input leakage current OFF-state leakage current ON-state leakage current 74HC_HCT4051_Q100 Product data sheet VCC = 6.0 V 4.2 3.2 - V VCC = 9.0 V 6.3 4.7 - V VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.8 V VCC = 9.0 V - 4.3 2.7 V VCC = 6.0 V - - 0.1 A VCC = 10.0 V - - 0.2 A per channel - - 0.1 A all channels - - 0.4 A - - 0.4 A VEE = 0 V; VI = VCC or GND VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; VSW = VCC  VEE; see Figure 11 VI = VIH or VIL; VSW = VCC  VEE; VCC = 10.0 V; VEE = 0 V; see Figure 12 All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 10 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer Table 7. Static characteristics for 74HC4051-Q100 …continued Voltages are referenced to GND (ground = 0 V). Vis is the input voltage at pins Yn or Z, whichever is assigned as an input. Vos is the output voltage at pins Z or Yn, whichever is assigned as an output. Symbol Parameter Conditions ICC supply current VEE = 0 V; VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE CI input capacitance Csw switch capacitance Min Typ Max Unit VCC = 6.0 V - - 8.0 A VCC = 10.0 V - - 16.0 A - 3.5 - pF independent pins Yn - 5 - pF common pins Z - 25 - pF VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 9.0 V 6.3 - - V Tamb = 40 C to +85 C VIH VIL II IS(OFF) HIGH-level input voltage LOW-level input voltage input leakage current OFF-state leakage current VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V VCC = 9.0 V - - 2.7 V VCC = 6.0 V - - 1.0 A VCC = 10.0 V - - 2.0 A per channel - - 1.0 A all channels - - 4.0 A - - 4.0 A VCC = 6.0 V - - 80.0 A VCC = 10.0 V - - 160.0 A VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 9.0 V 6.3 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V VCC = 9.0 V - - 2.7 V VEE = 0 V; VI = VCC or GND VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; VSW = VCC  VEE; see Figure 11 IS(ON) ON-state leakage current VI = VIH or VIL; VSW = VCC  VEE; VCC = 10.0 V; VEE = 0 V; see Figure 12 ICC supply current VEE = 0 V; VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE Tamb = 40 C to +125 C VIH VIL HIGH-level input voltage LOW-level input voltage 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 11 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer Table 7. Static characteristics for 74HC4051-Q100 …continued Voltages are referenced to GND (ground = 0 V). Vis is the input voltage at pins Yn or Z, whichever is assigned as an input. Vos is the output voltage at pins Z or Yn, whichever is assigned as an output. Symbol Parameter Conditions II input leakage current VEE = 0 V; VI = VCC or GND IS(OFF) OFF-state leakage current Min Typ Max Unit VCC = 6.0 V - - 1.0 A VCC = 10.0 V - - 2.0 A per channel - - 1.0 A all channels - - 4.0 A - - 4.0 A VCC = 6.0 V - - 160.0 A VCC = 10.0 V - - 320.0 A Conditions Min Typ Max Unit VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; VSW = VCC  VEE; see Figure 11 IS(ON) ON-state leakage current VI = VIH or VIL; VSW = VCC  VEE; VCC = 10.0 V; VEE = 0 V; see Figure 12 ICC supply current VEE = 0 V; VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE Table 8. Static characteristics for 74HCT4051-Q100 Voltages are referenced to GND (ground = 0 V). Vis is the input voltage at pins Yn or Z, whichever is assigned as an input. Vos is the output voltage at pins Z or Yn, whichever is assigned as an output. Symbol Parameter Tamb = 25 C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V; VEE = 0 V - - 0.1 A IS(OFF) OFF-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; VSW = VCC  VEE; see Figure 11 per channel - - 0.1 A all channels - - 0.4 A - - 0.4 A IS(ON) ON-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; VSW = VCC  VEE; see Figure 12 ICC supply current VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE ICC additional supply current CI input capacitance Csw switch capacitance 74HC_HCT4051_Q100 Product data sheet VCC = 5.5 V; VEE = 0 V - - 8.0 A VCC = 5.0 V; VEE = 5.0 V - - 16.0 A - 50 180 A per input; VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; VEE = 0 V - 3.5 - pF independent pins Yn - 5 - pF common pins Z - 25 - pF All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 12 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer Table 8. Static characteristics for 74HCT4051-Q100 …continued Voltages are referenced to GND (ground = 0 V). Vis is the input voltage at pins Yn or Z, whichever is assigned as an input. Vos is the output voltage at pins Z or Yn, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max Unit Tamb = 40 C to +85 C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V; VEE = 0 V - - 1.0 A IS(OFF) OFF-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; VSW = VCC  VEE; see Figure 11 per channel - - 1.0 A all channels - - 4.0 A - - 4.0 A VCC = 5.5 V; VEE = 0 V - - 80.0 A VCC = 5.0 V; VEE = 5.0 V - - 160.0 A per input; VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; VEE = 0 V - - 225 A IS(ON) ON-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; VSW = VCC  VEE; see Figure 12 ICC supply current VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE ICC additional supply current Tamb = 40 C to +125 C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V; VEE = 0 V - - 1.0 A IS(OFF) OFF-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; VSW = VCC  VEE; see Figure 11 per channel - - 1.0 A all channels - - 4.0 A - - 4.0 A IS(ON) ON-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; VSW = VCC  VEE; see Figure 12 ICC supply current VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE ICC additional supply current 74HC_HCT4051_Q100 Product data sheet VCC = 5.5 V; VEE = 0 V - - 160.0 A VCC = 5.0 V; VEE = 5.0 V - - 320.0 A - - 245 A per input; VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; VEE = 0 V All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 13 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer VCC from select input Sn Isw A Isw nZ nYn GND Vis A VEE Vos 001aah827 Vis = VCC and Vos = VEE. Vis = VEE and Vos = VCC. Fig 11. Test circuit for measuring OFF-state current VCC HIGH from select input Sn Isw A nZ nYn Vis GND Vos VEE 001aah828 Vis = VCC and Vos = open-circuit. Vis = VEE and Vos = open-circuit. Fig 12. Test circuit for measuring ON-state current 11. Dynamic characteristics Table 9. Dynamic characteristics for 74HC4051-Q100 GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Figure 15. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max Unit Tamb = 25 C tpd propagation delay Vis to Vos; RL =  ; see Figure 13 74HC_HCT4051_Q100 Product data sheet [1] VCC = 2.0 V; VEE = 0 V - 14 60 ns VCC = 4.5 V; VEE = 0 V - 5 12 ns VCC = 6.0 V; VEE = 0 V - 4 10 ns VCC = 4.5 V; VEE = 4.5 V - 4 8 ns All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 14 of 31 Nexperia 74HC4051-Q100; 74HCT4051-Q100 8-channel analog multiplexer/demultiplexer Table 9. Dynamic characteristics for 74HC4051-Q100 …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Figure 15. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol ton Parameter Conditions Min Typ Max Unit turn-on time E to Vos; RL =  ; see Figure 14 VCC = 2.0 V; VEE = 0 V - 72 345 ns VCC = 4.5 V; VEE = 0 V - 29 69 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 22 - ns [2] VCC = 6.0 V; VEE = 0 V - 21 59 ns VCC = 4.5 V; VEE = 4.5 V - 18 51 ns VCC = 2.0 V; VEE = 0 V - 66 345 ns VCC = 4.5 V; VEE = 0 V - 28 69 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 20 - ns VCC = 6.0 V; VEE = 0 V - 19 59 ns - 16 51 ns VCC = 2.0 V; VEE = 0 V - 58 290 ns VCC = 4.5 V; VEE = 0 V - 31 58 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 18 - ns Sn to Vos; RL =  ; see Figure 14 [2] VCC = 4.5 V; VEE = 4.5 V toff turn-off time E to Vos; RL = 1 k; see Figure 14 [3] VCC = 6.0 V; VEE = 0 V - 17 49 ns VCC = 4.5 V; VEE = 4.5 V - 18 42 ns VCC = 2.0 V; VEE = 0 V - 61 290 ns VCC = 4.5 V; VEE = 0 V - 25 58 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 19 - ns VCC = 6.0 V; VEE = 0 V - 18 49 ns - 18 42 ns - 25 - pF Sn to Vos; RL = 1 k; see Figure 14 [3] VCC = 4.5 V; VEE = 4.5 V CPD power dissipation per switch; VI = GND to VCC capacitance [4] Tamb = 40 C to +85 C tpd propagation delay Vis to Vos; RL =  ; see Figure 13 74HC_HCT4051_Q100 Product data sheet [1] VCC = 2.0 V; VEE = 0 V - - 75 ns VCC = 4.5 V; VEE = 0 V - - 15 ns VCC = 6.0 V; VEE = 0 V - - 13 ns VCC = 4.5 V; VEE = 4.5 V - - 10 ns All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 15 of 31 Nexperia 74HC4051-Q100; 74HCT4051-Q100 8-channel analog multiplexer/demultiplexer Table 9. Dynamic characteristics for 74HC4051-Q100 …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Figure 15. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol ton Parameter Conditions Min Typ Max Unit turn-on time E to Vos; RL =  ; see Figure 14 VCC = 2.0 V; VEE = 0 V - - 430 ns VCC = 4.5 V; VEE = 0 V - - 86 ns VCC = 6.0 V; VEE = 0 V - - 73 ns - - 64 ns VCC = 2.0 V; VEE = 0 V - - 430 ns VCC = 4.5 V; VEE = 0 V - - 86 ns VCC = 6.0 V; VEE = 0 V - - 73 ns VCC = 4.5 V; VEE = 4.5 V - - 64 ns VCC = 2.0 V; VEE = 0 V - - 365 ns VCC = 4.5 V; VEE = 0 V - - 73 ns VCC = 6.0 V; VEE = 0 V - - 62 ns - - 53 ns [2] VCC = 4.5 V; VEE = 4.5 V Sn to Vos; RL =  ; see Figure 14 toff turn-off time E to Vos; RL = 1 k; see Figure 14 [2] [3] VCC = 4.5 V; VEE = 4.5 V Sn to Vos; RL = 1 k; see Figure 14 [3] VCC = 2.0 V; VEE = 0 V - - 365 ns VCC = 4.5 V; VEE = 0 V - - 73 ns VCC = 6.0 V; VEE = 0 V - - 62 ns VCC = 4.5 V; VEE = 4.5 V - - 53 ns VCC = 2.0 V; VEE = 0 V - - 90 ns VCC = 4.5 V; VEE = 0 V - - 18 ns VCC = 6.0 V; VEE = 0 V - - 15 ns VCC = 4.5 V; VEE = 4.5 V - - 12 ns VCC = 2.0 V; VEE = 0 V - - 520 ns VCC = 4.5 V; VEE = 0 V - - 104 ns VCC = 6.0 V; VEE = 0 V - - 88 ns - - 77 ns Tamb = 40 C to +125 C tpd ton propagation delay Vis to Vos; RL =  ; see Figure 13 turn-on time E to Vos; RL =  ; see Figure 14 [1] [2] VCC = 4.5 V; VEE = 4.5 V Sn to Vos; RL =  ; see Figure 14 74HC_HCT4051_Q100 Product data sheet [2] VCC = 2.0 V; VEE = 0 V - - 520 ns VCC = 4.5 V; VEE = 0 V - - 104 ns VCC = 6.0 V; VEE = 0 V - - 88 ns VCC = 4.5 V; VEE = 4.5 V - - 77 ns All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 16 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer Table 9. Dynamic characteristics for 74HC4051-Q100 …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Figure 15. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol toff Parameter turn-off time Conditions Min Typ Max Unit VCC = 2.0 V; VEE = 0 V - - 435 ns VCC = 4.5 V; VEE = 0 V - - 87 ns VCC = 6.0 V; VEE = 0 V - - 74 ns - - 72 ns VCC = 2.0 V; VEE = 0 V - - 435 ns VCC = 4.5 V; VEE = 0 V - - 87 ns VCC = 6.0 V; VEE = 0 V - - 74 ns VCC = 4.5 V; VEE = 4.5 V - - 72 ns Min Typ Max Unit - 5 12 ns - 4 8 ns VCC = 4.5 V; VEE = 0 V - 26 55 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 22 - ns - 16 39 ns VCC = 4.5 V; VEE = 0 V - 28 55 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 24 - ns VCC = 4.5 V; VEE = 4.5 V - 16 39 ns E to Vos; RL = 1 k; see Figure 14 [3] VCC = 4.5 V; VEE = 4.5 V Sn to Vos; RL = 1 k; see Figure 14 [1] tpd is the same as tPHL and tPLH. [2] ton is the same as tPZH and tPZL. [3] toff is the same as tPHZ and tPLZ. [4] [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + {(CL + Csw)  VCC2  fo} where: fi = input frequency in MHz; fo = output frequency in MHz; N = number of inputs switching; {(CL + Csw)  VCC2  fo} = sum of outputs; CL = output load capacitance in pF; Csw = switch capacitance in pF; VCC = supply voltage in V. Table 10. Dynamic characteristics for 74HCT4051-Q100 GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Figure 15. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter Conditions Tamb = 25 C tpd propagation delay Vis to Vos; RL =  ; see Figure 13 [1] VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = 4.5 V ton turn-on time E to Vos; RL = 1 k; see Figure 14 [2] VCC = 4.5 V; VEE = 4.5 V Sn to Vos; RL = 1 k; see Figure 14 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 [2] © Nexperia B.V. 2017. All rights reserved 17 of 31 Nexperia 74HC4051-Q100; 74HCT4051-Q100 8-channel analog multiplexer/demultiplexer Table 10. Dynamic characteristics for 74HCT4051-Q100 …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Figure 15. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol toff Parameter turn-off time Conditions Min Typ Max Unit VCC = 4.5 V; VEE = 0 V - 19 45 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 16 - ns - 16 32 ns VCC = 4.5 V; VEE = 0 V - 23 45 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 20 - ns - 16 32 ns - 25 - pF E to Vos; RL = 1 k; see Figure 14 [3] VCC = 4.5 V; VEE = 4.5 V Sn to Vos; RL = 1 k; see Figure 14 [3] VCC = 4.5 V; VEE = 4.5 V CPD power dissipation per switch; VI = GND to VCC  1.5 V capacitance [4] Tamb = 40 C to +85 C tpd ton propagation delay Vis to Vos; RL =  ; see Figure 13 turn-on time [1] VCC = 4.5 V; VEE = 0 V - - 15 ns VCC = 4.5 V; VEE = 4.5 V - - 10 ns - - 69 ns - - 49 ns - - 69 ns - - 49 ns - - 56 ns - - 40 ns E to Vos; RL = 1 k; see Figure 14 [2] VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = 4.5 V Sn to Vos; RL = 1 k; see Figure 14 [2] VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = 4.5 V toff turn-off time E to Vos; RL = 1 k; see Figure 14 [3] VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = 4.5 V Sn to Vos; RL = 1 k; see Figure 14 [3] VCC = 4.5 V; VEE = 0 V - - 56 ns VCC = 4.5 V; VEE = 4.5 V - - 40 ns Tamb = 40 C to +125 C tpd ton propagation delay Vis to Vos; RL =  ; see Figure 13 turn-on time [1] VCC = 4.5 V; VEE = 0 V - - 18 ns VCC = 4.5 V; VEE = 4.5 V - - 12 ns - - 83 ns - - 59 ns VCC = 4.5 V; VEE = 0 V - - 83 ns VCC = 4.5 V; VEE = 4.5 V - - 59 ns E to Vos; RL = 1 k; see Figure 14 [2] VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = 4.5 V Sn to Vos; RL = 1 k; see Figure 14 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 [2] © Nexperia B.V. 2017. All rights reserved 18 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer Table 10. Dynamic characteristics for 74HCT4051-Q100 …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Figure 15. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol toff Parameter turn-off time Conditions E to Vos; RL = 1 k; see Figure 14 VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = 4.5 V tpd is the same as tPHL and tPLH. [2] ton is the same as tPZH and tPZL. [3] toff is the same as tPHZ and tPLZ. [4] Typ Max Unit - - 68 ns - - 48 ns [3] Sn to Vos; RL = 1 k; see Figure 14 [1] Min [3] VCC = 4.5 V; VEE = 0 V - - 68 ns VCC = 4.5 V; VEE = 4.5 V - - 48 ns CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + {(CL + Csw)  VCC2  fo} where: fi = input frequency in MHz; fo = output frequency in MHz; N = number of inputs switching; {(CL + Csw)  VCC2  fo} = sum of outputs; CL = output load capacitance in pF; Csw = switch capacitance in pF; VCC = supply voltage in V. Vis input 50 % tPLH Vos output tPHL 50 % 001aad555 Fig 13. Input (Vis) to output (Vos) propagation delays 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 19 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer VI VM E, Sn inputs 0V tPLZ tPZL 50 % Vos output 10 % tPHZ tPZH 90 % 50 % Vos output switch ON switch ON switch OFF 001aad556 For 74HC4051-Q100: VM = 0.5  VCC. For 74HCT4051-Q100: VM = 1.3 V. Fig 14. Turn-on and turn-off times VI tW 90 % negative pulse VM 0V VI tf tr tr tf 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC Vis PULSE GENERATOR VI VCC Vos RL S1 open DUT RT CL GND VEE 001aae382 Definitions for test circuit; see Table 11: RT = termination resistance should be equal to the output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. RL = load resistance. S1 = Test selection switch. Fig 15. Test circuit for measuring AC performance 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 20 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer Table 11. Test data Test Input VI Load Vis tr, tf S1 position CL RL at fmax other[1] tPHL, tPLH [2] pulse < 2 ns 6 ns 50 pF 1 k open tPZH, tPHZ [2] VCC < 2 ns 6 ns 50 pF 1 k VEE tPZL, tPLZ [2] VEE < 2 ns 6 ns 50 pF 1 k VCC [1] [2] tr = tf = 6 ns; when measuring fmax, there is no constraint to tr and tf with 50 % duty factor. VI values: a) For 74HC4051-Q100: VI = VCC b) For 74HCT4051-Q100: VI = 3 V 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 21 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer 11.1 Additional dynamic characteristics Table 12. Additional dynamic characteristics Recommended conditions and typical values; GND = 0 V; Tamb = 25 C; CL = 50 pF. Vis is the input voltage at pins nYn or nZ, whichever is assigned as an input. Vos is the output voltage at pins nYn or nZ, whichever is assigned as an output. Symbol Parameter Conditions dsin sine-wave distortion fi = 1 kHz; RL = 10 k; see Figure 16 Min Typ Max Unit Vis = 4.0 V (p-p); VCC = 2.25 V; VEE = 2.25 V - 0.04 - % Vis = 8.0 V (p-p); VCC = 4.5 V; VEE = 4.5 V - 0.02 - % Vis = 4.0 V (p-p); VCC = 2.25 V; VEE = 2.25 V - 0.12 - % Vis = 8.0 V (p-p); VCC = 4.5 V; VEE = 4.5 V - 0.06 - % fi = 10 kHz; RL = 10 k; see Figure 16 iso RL = 600 ; fi = 1 MHz; see Figure 17 isolation (OFF-state) crosstalk voltage Vct f(3dB) VCC = 2.25 V; VEE = 2.25 V [1] - 50 - dB VCC = 4.5 V; VEE = 4.5 V [1] - 50 - dB VCC = 4.5 V; VEE = 0 V - 110 - mV VCC = 4.5 V; VEE = 4.5 V - 220 - mV peak-to-peak value; between control and any switch; RL = 600 ; fi = 1 MHz; E or Sn square wave between VCC and GND; tr = tf = 6 ns; see Figure 18 3 dB frequency response RL = 50 ; see Figure 19 VCC = 2.25 V; VEE = 2.25 V [2] - 170 - MHz VCC = 4.5 V; VEE = 4.5 V [2] - 180 - MHz [1] Adjust input voltage Vis to 0 dBm level (0 dBm = 1 mW into 600 ). [2] Adjust input voltage Vis to 0 dBm level at Vos for 1 MHz (0 dBm = 1 mW into 50 ). VCC Sn 10 μF Vis Yn/Z Z/Yn VEE GND Vos RL CL dB 001aan385 Fig 16. Test circuit for measuring sine-wave distortion 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 22 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer VCC Sn 0.1 μF Yn/Z Vis Z/Yn VEE GND Vos RL CL dB 001aan386 VCC = 4.5 V; GND = 0 V; VEE = 4.5 V; RL = 600 ; RS = 1 k. a. Test circuit 001aae332 0 αiso (dB) −20 −40 −60 −80 −100 102 10 103 104 105 106 fi (kHz) b. Isolation (OFF-state) as a function of frequency Fig 17. Test circuit for measuring isolation (OFF-state) 2RL 2RL VCC Sn, E Vct Yn G 2RL Z VEE GND 2RL oscilloscope 001aan387 Fig 18. Test circuit for measuring crosstalk between control input and any switch 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 23 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer VCC Sn 10 μF Vis Yn/Z Z/Yn VEE GND Vos RL CL dB 001aan385 VCC = 4.5 V; GND = 0 V; VEE = 4.5 V; RL = 50 ; RS = 1 k. a. Test circuit 001aad551 5 Vos (dB) 3 1 −1 −3 −5 10 102 103 104 105 106 f (kHz) b. Typical frequency response Fig 19. Test circuit for frequency response 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 24 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 20. Package outline SOT109-1 (SO16) 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 25 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 E D A X c y HE v M A Z 9 16 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 8 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 21. Package outline SOT403-1 (TSSOP16) 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 26 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 7 y y1 C v M C A B w M C b L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A(1) max. A1 b 1 0.05 0.00 0.30 0.18 c D (1) Dh E (1) Eh 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 22. Package outline SOT763-1 (DHVQFN16) 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 27 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer 13. Abbreviations Table 13. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic MIL Military 14. Revision history Table 14. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT4051_Q100 v.2 20121008 - 74HC_HCT4051_Q100 v.1 - - Modifications: 74HC_HCT4051_Q100 v.1 74HC_HCT4051_Q100 Product data sheet • Product data sheet CDM added to features. 20120709 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 28 of 31 74HC4051-Q100; 74HCT4051-Q100 Nexperia 8-channel analog multiplexer/demultiplexer 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT4051_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 29 of 31 Nexperia 74HC4051-Q100; 74HCT4051-Q100 8-channel analog multiplexer/demultiplexer No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT4051_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 8 October 2012 © Nexperia B.V. 2017. All rights reserved 30 of 31 Nexperia 74HC4051-Q100; 74HCT4051-Q100 8-channel analog multiplexer/demultiplexer 17. Contents 1 2 3 4 5 6 6.1 6.2 7 7.1 8 9 10 11 11.1 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 3 Pinning information . . . . . . . . . . . . . . . . . . . . . . 5 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5 Functional description . . . . . . . . . . . . . . . . . . . 6 Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 7 Static characteristics. . . . . . . . . . . . . . . . . . . . . 8 Dynamic characteristics . . . . . . . . . . . . . . . . . 14 Additional dynamic characteristics . . . . . . . . . 22 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 25 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 28 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 28 Legal information. . . . . . . . . . . . . . . . . . . . . . . 29 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 29 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 30 Contact information. . . . . . . . . . . . . . . . . . . . . 30 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 08 October 2012
74HC4051PW-Q100,11 价格&库存
很抱歉,暂时无法提供与“74HC4051PW-Q100,11”相匹配的价格&库存,您可以联系我们找货
74HC4051PW-Q100,11
    • 2500+1.08715
    库存:7500
    74HC4051PW-Q100,11
    • 1+2.46150
    库存:10
    74HC4051PW-Q100,11
    • 1+3.212441+0.38571
    • 10+2.2507910+0.27025
    • 25+2.0039825+0.24062
    • 100+1.73056100+0.20779
    • 250+1.60078250+0.19220
    • 500+1.52241500+0.18279
    • 1000+1.458021000+0.17506
    库存:6343
    74HC4051PW-Q100,11
    • 2500+1.389952500+0.16689
    • 5000+1.348935000+0.16196
    • 7500+1.328397500+0.15950
    • 12500+1.3056412500+0.15677
    • 17500+1.2923317500+0.15517
    • 25000+1.2795325000+0.15363
    • 62500+1.2519862500+0.15032
    库存:6343
    74HC4051PW-Q100,11
    • 1+1.99378
    • 10+1.89884
    • 100+1.41720
    • 1000+1.14956
    • 1250+1.02839
    • 2500+1.01739
    库存:1485
    74HC4051PW-Q100,11
    • 1+1.26450
    • 10+1.16710
    • 100+1.06990
    • 1000+0.97260
    库存:2580
    74HC4051PW-Q100,11
      • 5+1.81343
      • 50+1.45498
      • 150+1.30130
      • 500+1.07631
      • 2500+0.99355
      • 5000+0.94389
      库存:1825
