74HC4016D,652
74HC4016D,652
    NEXPERIA(安世)
    SOIC14_150MIL
    四极单极单掷模拟开关
74HC4016D,652 数据手册
74HC4016 Quad single-pole single-throw analog switch Rev. 3 — 12 December 2016 Product data sheet 1. General description The 74HC4016 is a quad single pole, single throw analog switch. Each switch features two input/output terminals (nY and nZ) and an active HIGH enable input (nE). When nE is LOW, the analog switch is turned off. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Input levels nE inputs:  For 74HC4016: CMOS level  Typical ‘break before make’ built-in  Low ON resistance:  160  (typical) at VCC = 4.5 V  120  (typical) at VCC = 6.0 V  85  (typical) at VCC = 9.0 V  Specified in compliance with JEDEC standard no. 7A  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Specified from 40 C to +85 C and 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package 74HC4016D Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74HC4016PW 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74HC4016 Nexperia Quad single-pole single-throw analog switch 4. Functional diagram <  =     (   <  = <   = <        (      (      =          ;    ;    ;    ; (  D E DDG DDG Fig 1.   Logic symbol Fig 2. IEC logic symbol < 9(( 9&& 9(( 9&& 9&& 9(( = ( DDD Fig 3. Schematic diagram (one switch) 74HC4016 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 12 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 21 74HC4016 Nexperia Quad single-pole single-throw analog switch 5. Pinning information 5.1 Pinning +& <   9&& =   ( =   ( <   < (   = (   = *1'   < +& <  =   9&&  ( =   ( <   < (   = (   = *1'   < DDD Fig 4. DDD Pin configuration for SO14 Fig 5. Pin configuration for TSSOP14 5.2 Pin description Table 2. Pin description Symbol Pin Description 1Z, 2Z, 3Z, 4Z 2, 3, 9, 10 independent input or output 1Y, 2Y, 3Y, 4Y 1, 4, 8, 11 independent input or output GND 7 ground (0 V) 1E, 2E, 3E, 4E 13, 5, 6, 12 enable input (active HIGH) VCC 14 supply voltage 6. Functional description Table 3. Function table[1] Input nE Switch L OFF H ON [1] H = HIGH voltage level; L = LOW voltage level. 74HC4016 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 12 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 21 74HC4016 Nexperia Quad single-pole single-throw analog switch 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Min Max Unit VCC supply voltage 0.5 +11.0 V IIK input clamping current ISK switch clamping current VI < 0.5 V or VI > VCC + 0.5 V - 20 mA VSW < 0.5 V or VSW > VCC + 0.5 V - 20 mA ISW switch current VSW = 0.5 V to VCC + 0.5 V - 25 mA ICC supply current - +50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 500 mW - 100 mW total power dissipation Ptot Conditions [1] Tamb = 40 C to +125 C [2] SO14 and TSSOP14 packages P power dissipation per switch [1] To avoid drawing VCC current out of terminal nZ, when switch current flows in terminals nY, the voltage drop across the bidirectional switch must not exceed 0.4 V. If the switch current flows into terminal nZ, no VCC current will flow out of terminals nY. In this case there is no limit for the voltage drop across the switch, but the voltages at nY and nZ may not exceed VCC or GND. [2] For SO14 package: Ptot derates linearly with 8 mW/K above 70 C. For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage Conditions Min Typ Max Unit 2.0 5.0 10.0 V VI input voltage GND - VCC V VSW switch voltage GND - VCC V Tamb ambient temperature 40 +25 +125 C t/V input transition rise and fall rate - - 625 ns/V 74HC4016 Product data sheet VCC = 2.0 V VCC = 4.5 V - 1.67 139 ns/V VCC = 6.0 V - - 83 ns/V VCC = 10.0 V - - 35 ns/V All information provided in this document is subject to legal disclaimers. Rev. 3 — 12 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 21 74HC4016 Nexperia Quad single-pole single-throw analog switch 9. Static characteristics Table 6. RON resistance per switch VI = VIH or VIL; for test circuit see Figure 6. Vis is the input voltage at a nY or nZ terminal, whichever is assigned as an input. Vos is the output voltage at a nY or nZ terminal, whichever is assigned as an output. For 74HC4016: VCC  GND = 2.0 V, 4.5 V, 6.0 V and 9.0 V. Symbol Parameter +25 C Conditions Typ RON(peak) ON resistance Vis = VCC to GND (peak) VCC = 2.0 V; ISW = 0.1 mA RON(rail) 40 C to +85 C 40 C to +125 C Unit Max Min Max Min Max - - - - - -  VCC = 4.5 V; ISW = 1 mA 160 320 - 400 - 480  VCC = 6.0 V; ISW = 1 mA 120 240 - 300 - 360  VCC = 9.0 V; ISW = 1 mA 85 170 - 213 - 255  160 - - - - -  VCC = 4.5 V; ISW = 1 mA 80 160 - 200 - 240  VCC = 6.0 V; ISW = 1 mA 70 140 - 175 - 210  VCC = 9.0 V; ISW = 1 mA 60 120 - 150 - 180  170 - - - - -  VCC = 4.5 V; ISW = 1 mA 90 180 - 225 - 270  VCC = 6.0 V; ISW = 1 mA 80 160 - 200 - 240  VCC = 9.0 V; ISW = 1 mA 65 135 - 170 - 205  - - - - - -  16 - - - - -  12 - - - - -  9 - - - - -  ON resistance Vis = GND (rail) VCC = 2.0 V; ISW = 0.1 mA [1] [1] Vis = VCC VCC = 2.0 V; ISW = 0.1 mA RON ON resistance Vis = VCC to GND mismatch VCC = 2.0 V between VCC = 4.5 V channels VCC = 6.0 V VCC = 9.0 V [1] [1] [1] At supply voltages (VCC  GND) approaching 2 V, the analog switch ON resistance becomes extremely non-linear. Therefore it is recommended that these devices be used to transmit digital signals only, when using these supply voltages. 74HC4016 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 12 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 21 74HC4016 Nexperia Quad single-pole single-throw analog switch DDD  9&& 9 521 ȍ 96: 9  9&& 9 Q( 9,+ Q< 9LV Q= *1' ,6:       Vis = 0 V to VCC R ON Fig 6.  9LV 9 DDD Vis = 0 V to VCC V SW = ---------I SW Test circuit for measuring RON Fig 7. Typical RON as a function of input voltage Vis Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Vis is the input voltage at a nY or terminal, whichever is assigned as an input. Vos is the output voltage at a nY or nZ terminal, whichever is assigned as an output. Symbol Parameter Conditions Min Typ[1] Max Unit Tamb = +25 C VIH VIL II IS(OFF) HIGH-level input voltage LOW-level input voltage input leakage current OFF-state leakage current VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V VCC = 9.0 V 6.3 4.3 - V VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.80 V VCC = 9.0 V - 4.3 2.70 V VCC = 6.0 V - - 0.1 A VCC = 10.0 V - - 0.2 A - - 0.1 A - - 0.1 A VI = VCC or GND VCC = 10.0 V; VI = VIH or VIL; VSW = VCC  GND; see Figure 8 per channel IS(ON) ON-state leakage current 74HC4016 Product data sheet VCC = 10.0 V; VI = VIH or VIL; VSW = VCC  GND; see Figure 9 All information provided in this document is subject to legal disclaimers. Rev. 3 — 12 December 2016 © Nexperia B.V. 2017. All rights reserved 6 of 21 74HC4016 Nexperia Quad single-pole single-throw analog switch Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Vis is the input voltage at a nY or terminal, whichever is assigned as an input. Vos is the output voltage at a nY or nZ terminal, whichever is assigned as an output. Min Typ[1] Max Unit VCC = 6.0 V - - 2.0 A VCC = 10.0 V - - 4.0 A Symbol Parameter Conditions ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND CI input capacitance - 3.5 - pF Csw switch capacitance - 5 - pF VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 9.0 V 6.3 - - V VCC = 2.0 V - - 0.50 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.80 V VCC = 9.0 V - - 2.70 V VCC = 6.0 V - - 1.0 A VCC = 10.0 V - - 2.0 A - - 1.0 A - - 1.0 A VCC = 6.0 V - - 20.0 A VCC = 10.0 V - - 40.0 A Tamb = 40 C to +85 C VIH VIL II HIGH-level input voltage LOW-level input voltage input leakage current VI = VCC or GND IS(OFF) OFF-state leakage current VCC = 10.0 V; VI = VIH or VIL; VSW = VCC  GND; see Figure 8 IS(ON) ON-state leakage current VCC = 10.0 V; VI = VIH or VIL; VSW = VCC  GND; see Figure 9 ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND per channel Tamb = 40 C to +125 C VIH VIL II HIGH-level input voltage LOW-level input voltage input leakage current 74HC4016 Product data sheet VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 9.0 V 6.3 - - V VCC = 2.0 V - - 0.50 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.80 V VCC = 9.0 V - - 2.70 V VCC = 6.0 V - - 1.0 A VCC = 10.0 V - - 2.0 A VI = VCC or GND All information provided in this document is subject to legal disclaimers. Rev. 3 — 12 December 2016 © Nexperia B.V. 2017. All rights reserved 7 of 21 74HC4016 Nexperia Quad single-pole single-throw analog switch Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Vis is the input voltage at a nY or terminal, whichever is assigned as an input. Vos is the output voltage at a nY or nZ terminal, whichever is assigned as an output. Min Typ[1] Max Unit - - 1.0 A - - 1.0 A VCC = 6.0 V - - 40 A VCC = 10.0 V - - 80 A Symbol Parameter Conditions IS(OFF) OFF-state leakage current VCC = 10.0 V; VI = VIH or VIL; VSW = VCC  GND; see Figure 8 per channel IS(ON) ON-state leakage current VCC = 10.0 V; VI = VIH or VIL; VSW = VCC  GND; see Figure 9 ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND [1] Typical values are measured at Tamb = 25 C. 9&& 9&& ( 9,/ ,6: 9LV 9,+
74HC4016D,652 价格&库存
很抱歉,暂时无法提供与“74HC4016D,652”相匹配的价格&库存,您可以联系我们找货
