74HC4016
Quad single-pole single-throw analog switch
Rev. 3 — 12 December 2016
Product data sheet
1. General description
The 74HC4016 is a quad single pole, single throw analog switch. Each switch features
two input/output terminals (nY and nZ) and an active HIGH enable input (nE). When nE is
LOW, the analog switch is turned off. Inputs include clamp diodes. This enables the use of
current limiting resistors to interface inputs to voltages in excess of VCC.
2. Features and benefits
Input levels nE inputs:
For 74HC4016: CMOS level
Typical ‘break before make’ built-in
Low ON resistance:
160 (typical) at VCC = 4.5 V
120 (typical) at VCC = 6.0 V
85 (typical) at VCC = 9.0 V
Specified in compliance with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Specified from 40 C to +85 C and 40 C to +125 C
3. Ordering information
Table 1.
Type number Package
74HC4016D
Temperature range
Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
74HC4016PW 40 C to +125 C
TSSOP14 plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74HC4016
Nexperia
4. Functional diagram
D
E
DDG
DDG
Fig 1.
Logic symbol
Fig 2.
IEC logic symbol
9((
9&&
9((
9&&
9&&
9((
DDD
Fig 3.
Schematic diagram (one switch)
74HC4016
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 21
74HC4016
Nexperia
5. Pinning information
5.1 Pinning
9&&
*1'
9&&
*1'
DDD
Fig 4.
DDD
Pin configuration for SO14
Fig 5.
Pin configuration for TSSOP14
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1Z, 2Z, 3Z, 4Z
2, 3, 9, 10
independent input or output
1Y, 2Y, 3Y, 4Y
1, 4, 8, 11
GND
7
ground (0 V)
1E, 2E, 3E, 4E
13, 5, 6, 12
enable input (active HIGH)
VCC
14
supply voltage
6. Functional description
Table 3.
Function table[1]
Input nE
Switch
L
OFF
H
ON
[1]
H = HIGH voltage level;
L = LOW voltage level.
74HC4016
Product data sheet
3 of 21
74HC4016
Nexperia
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
0.5
+11.0
V
IIK
input clamping current
ISK
switch clamping current
VI < 0.5 V or VI > VCC + 0.5 V
mA
VSW < 0.5 V or VSW > VCC + 0.5 V
mA
ISW
switch current
VSW = 0.5 V to VCC + 0.5 V
25
mA
ICC
supply current
+50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
500
mW
100
mW
total power dissipation
Ptot
Conditions
[1]
Tamb = 40 C to +125 C
[2]
SO14 and TSSOP14 packages
P
power dissipation
per switch
[1]
To avoid drawing VCC current out of terminal nZ, when switch current flows in terminals nY, the voltage drop across the bidirectional
switch must not exceed 0.4 V. If the switch current flows into terminal nZ, no VCC current will flow out of terminals nY. In this case there
is no limit for the voltage drop across the switch, but the voltages at nY and nZ may not exceed VCC or GND.
[2]
For SO14 package: Ptot derates linearly with 8 mW/K above 70 C.
For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Typ
Max
Unit
2.0
5.0
10.0
V
VI
input voltage
GND
VCC
V
VSW
switch voltage
GND
VCC
V
Tamb
ambient temperature
40
+25
+125
C
t/V
input transition rise and fall
rate
625
ns/V
74HC4016
Product data sheet
VCC = 2.0 V
VCC = 4.5 V
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
VCC = 10.0 V
35
ns/V
4 of 21
74HC4016
Nexperia
9. Static characteristics
Table 6.
RON resistance per switch
VI = VIH or VIL; for test circuit see Figure 6.
Vis is the input voltage at a nY or nZ terminal, whichever is assigned as an input.
Vos is the output voltage at a nY or nZ terminal, whichever is assigned as an output.
For 74HC4016: VCC GND = 2.0 V, 4.5 V, 6.0 V and 9.0 V.
Symbol
Parameter
+25 C
Conditions
Typ
RON(peak) ON resistance Vis = VCC to GND
(peak)
VCC = 2.0 V; ISW = 0.1 mA
RON(rail)
40 C to +85 C 40 C to +125 C Unit
Max
Min
Max
Min
Max
VCC = 4.5 V; ISW = 1 mA
160
320
400
480
VCC = 6.0 V; ISW = 1 mA
120
240
300
360
VCC = 9.0 V; ISW = 1 mA
85
170
213
255
160
80
160
200
240
70
140
175
210
60
120
150
180
170
90
180
225
270
80
160
200
240
65
135
170
205
16
12
9
ON resistance Vis = GND
(rail)
[1]
[1]
Vis = VCC
RON
mismatch
VCC = 2.0 V
between
VCC = 4.5 V
channels
VCC = 6.0 V
VCC = 9.0 V
[1]
[1]
[1]
At supply voltages (VCC GND) approaching 2 V, the analog switch ON resistance becomes extremely non-linear. Therefore it is
recommended that these devices be used to transmit digital signals only, when using these supply voltages.
74HC4016
Product data sheet
5 of 21
74HC4016
Nexperia
DDD
9&& 9
521
ȍ
96:
9
9&&
9
Q(
9,+
Q<
9LV
Q=
*1'
,6:
Vis = 0 V to VCC
R ON
Fig 6.
9LV9
DDD
Vis = 0 V to VCC
V SW
= ---------I SW
Test circuit for measuring RON
Fig 7.
Typical RON as a function of input voltage Vis
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Vis is the input voltage at a nY or terminal, whichever is assigned as an input.
Symbol
Parameter
Conditions
Min
Typ[1]
Max
Unit
Tamb = +25 C
VIH
VIL
II
IS(OFF)
HIGH-level input voltage
LOW-level input voltage
input leakage current
OFF-state leakage current
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
VCC = 9.0 V
6.3
4.3
V
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.80
V
VCC = 9.0 V
4.3
2.70
V
VCC = 6.0 V
0.1
A
VCC = 10.0 V
0.2
A
0.1
A
0.1
A
VI = VCC or GND
VCC = 10.0 V; VI = VIH or VIL;
VSW = VCC GND; see Figure 8
per channel
IS(ON)
ON-state leakage current
74HC4016
Product data sheet
VSW = VCC GND; see Figure 9
6 of 21
74HC4016
Nexperia
Table 7.
Min
Typ[1]
Max
Unit
VCC = 6.0 V
2.0
A
VCC = 10.0 V
4.0
A
Symbol
Parameter
Conditions
ICC
supply current
VI = VCC or GND; Vis = GND or VCC;
Vos = VCC or GND
CI
input capacitance
3.5
pF
Csw
switch capacitance
5
pF
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 9.0 V
6.3
V
VCC = 2.0 V
0.50
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.80
V
VCC = 9.0 V
2.70
V
VCC = 6.0 V
1.0
A
VCC = 10.0 V
2.0
A
1.0
A
1.0
A
VCC = 6.0 V
20.0
A
VCC = 10.0 V
40.0
A
Tamb = 40 C to +85 C
VIH
VIL
II
VI = VCC or GND
IS(OFF)
IS(ON)
ICC
supply current
Vos = VCC or GND
per channel
VIH
VIL
II
74HC4016
Product data sheet
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 9.0 V
6.3
V
VCC = 2.0 V
0.50
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.80
V
VCC = 9.0 V
2.70
V
VCC = 6.0 V
1.0
A
VCC = 10.0 V
2.0
A
VI = VCC or GND
7 of 21
74HC4016
Nexperia
Table 7.
Min
Typ[1]
Max
Unit
1.0
A
1.0
A
VCC = 6.0 V
40
A
VCC = 10.0 V
80
A
Symbol
Parameter
Conditions
IS(OFF)
per channel
IS(ON)
ICC
supply current
Vos = VCC or GND
[1]
Typical values are measured at Tamb = 25 C.
9&&
9&&
9,/
,6:
9LV
9,+
很抱歉,暂时无法提供与“74HC4016PW,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.896011+0.50360
- 国内价格 香港价格
- 1+3.883361+0.50197
- 10+2.7172810+0.35124
- 25+2.4243325+0.31337
