HEF4053BTT,118
HEF4053BTT,118
    NEXPERIA(安世)
    TSSOP-16
    三次单极双掷模拟开关
HEF4053BTT,118 数据手册
HEF4053B Triple single-pole double-throw analog switch Rev. 12 — 25 March 2016 Product data sheet 1. General description The HEF4053B is a triple single-pole double-throw (SPDT) analog switch, suitable for use as an analog or digital multiplexer/demultiplexer. Each switch has a digital select input (Sn), two independent inputs/outputs (nY0 and nY1) and a common input/output (nZ). All three switches share an enable input (E). A HIGH on E causes all switches into the high-impedance OFF-state, independent of Sn. VDD and VSS are the supply voltage connections for the digital control inputs (Sn and E). The VDD to VSS range is 3 V to 15 V. The analog inputs/outputs (nY0, nY1 and nZ) can swing between VDD as a positive limit and VEE as a negative limit. VDD  VEE may not exceed 15 V. Unused inputs must be connected to VDD, VSS, or another input. For operation as a digital multiplexer/demultiplexer, VEE is connected to VSS (typically ground). VEE and VSS are the supply voltage connections for the switches. 2. Features and benefits      Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +125 C Complies with JEDEC standard JESD 13-B 3. Applications  Analog multiplexing and demultiplexing  Digital multiplexing and demultiplexing  Signal gating 4. Ordering information Table 1. Ordering information All types operate from 40 C to +125 C. Type number Package Name Description Version HEF4053BT SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4053BTT TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 HEF4053B Nexperia Triple single-pole double-throw analog switch 5. Functional diagram (  9''
HEF4053BTT,118 价格&库存
很抱歉,暂时无法提供与“HEF4053BTT,118”相匹配的价格&库存,您可以联系我们找货
HEF4053BTT,118
HEF4053BTT,118
  • 1+1.87850
库存:250
HEF4053BTT,118
  • 1+3.355671+0.43074
  • 10+2.3062210+0.29603
  • 25+2.0501725+0.26317
  • 100+1.77103100+0.22734
  • 250+1.63813250+0.21028
  • 500+1.55772500+0.19996
  • 1000+1.491521000+0.19146
库存:2009
HEF4053BTT,118
  • 2500+1.421652500+0.18249
  • 5000+1.379575000+0.17709
  • 7500+1.358477500+0.17438
  • 12500+1.3351112500+0.17138
  • 17500+1.3214517500+0.16963
  • 25000+1.3083225000+0.16794
库存:2009
