74LV4053D,118
74LV4053D,118
    NEXPERIA(安世)
    SOIC16_150MIL
    三次单极双掷模拟开关
74LV4053D,118 数据手册
74LV4053 Triple single-pole double-throw analog switch Rev. 6 — 17 March 2016 Product data sheet 1. General description The 74LV4053 is a triple single-pole double-throw (SPDT) analog switch, suitable for use as an analog or digital multiplexer/demultiplexer. It is a low-voltage Si-gate CMOS device and is pin and function compatible with the 74HC4053 and 74HCT4053. Each switch has a digital select input (Sn), two independent inputs/outputs (nY0 and nY1) and a common input/output (nZ). All three switches share an enable input (E). A HIGH on E causes all switches into the high-impedance OFF-state, independent of Sn. VCC and GND are the supply voltage connections for the digital control inputs (Sn and E). The VCC to GND range is 1 V to 6 V. The analog inputs/outputs (nY0, nY1 and nZ) can swing between VCC as a positive limit and VEE as a negative limit. VCC  VEE may not exceed 6 V. For operation as a digital multiplexer/demultiplexer, VEE is connected to GND (typically ground). VEE and VSS are the supply voltage connections for the switches. 2. Features and benefits  Optimized for low-voltage applications: 1.0 V to 3.6 V  Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V  Low ON resistance:  180  (typical) at VCC  VEE = 2.0 V  100  (typical) at VCC  VEE = 3.0 V  75  (typical) at VCC  VEE = 4.5 V  Logic level translation:  To enable 3 V logic to communicate with 3 V analog signals  Typical ‘break before make’ built in  ESD protection:  HBM JESD22-A114-C exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 74LV4053 Nexperia Triple single-pole double-throw analog switch 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV4053D 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74LV4053DB 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74LV4053PW 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74LV4053BQ 40 C to +125 C DHVQFN16 plastic dual-in line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm SOT763-1 4. Functional diagram 9&&  (
74LV4053D,118 价格&库存
很抱歉,暂时无法提供与“74LV4053D,118”相匹配的价格&库存,您可以联系我们找货
74LV4053D,118
  • 2500+1.244992500+0.16071
  • 5000+1.207245000+0.15583
  • 7500+1.188347500+0.15340
  • 12500+1.1673912500+0.15069
  • 17500+1.1551517500+0.14911
  • 25000+1.1433825000+0.14759
库存:3
74LV4053D,118
  • 1+2.920501+0.37698
  • 10+2.0347210+0.26265
  • 25+1.8083525+0.23343
  • 100+1.55878100+0.20121
  • 250+1.43885250+0.18573
  • 500+1.36684500+0.17644
  • 1000+1.307561000+0.16878
库存:3
