74AHCT1G66GW-Q100H
74AHCT1G66GW-Q100H
    NEXPERIA(安世)
    TSSOP5_2X1.25MM
    单刀单投模拟开关
74AHCT1G66GW-Q100H 数据手册
74AHC1G66-Q100; 74AHCT1G66-Q100 Single-pole single-throw analog switch Rev. 1 — 27 January 2015 Product data sheet 1. General description 74AHC1G66-Q100 and 74AHCT1G66-Q100 are high-speed Si-gate CMOS devices. They are single-pole single-throw analog switches. The switch has two input/output pins (Y and Z) and an active HIGH enable input pin (E). When pin E is LOW, the analog switch is turned off. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Very low ON resistance:  26  (typ.) at VCC = 3.0 V  16  (typ.) at VCC = 4.5 V  14  (typ.) at VCC = 5.5 V  High noise immunity  Low power dissipation  Balanced propagation delays  Multiple package options  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 3. Ordering information Table 1. Ordering information Type number 74AHC1G66GW-Q100 Package Temperature range Name Description Version 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 74AHCT1G66GW-Q100 74AHC1G66GV-Q100 74AHCT1G66GV-Q100 74AHC1G66-Q100; 74AHCT1G66-Q100 Nexperia Single-pole single-throw analog switch 4. Marking Table 2. Marking codes Type number Marking 74AHC1G66GW-Q100 AL 74AHCT1G66GW-Q100 CL 74AHC1G66GV-Q100 A66 74AHCT1G66GV-Q100 C66 5. Functional diagram = ( < ( = < 9&& DDJ Fig 1. Logic symbol Fig 2. PQD Logic diagram 6. Pinning information 6.1 Pinning $+&*4 $+&7*4 <  =  *1'   9&&  ( DDD Fig 3. Pin configuration SOT353-1 and SOT753 74AHC_AHCT1G66_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 January 2015 © Nexperia B.V. 2017. All rights reserved 2 of 18 74AHC1G66-Q100; 74AHCT1G66-Q100 Nexperia Single-pole single-throw analog switch 6.2 Pin description Table 3. Pin description Symbol Pin Description Y 1 independent input or output Z 2 independent input or output GND 3 ground (0 V) E 4 enable input (active HIGH) VCC 5 supply voltage 7. Functional description Table 4. Function table[1] Input E Switch L OFF H ON [1] H = HIGH voltage level; L = LOW voltage level. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK Conditions input clamping current VI < 0.5 V [1] [1] ISK switch clamping current VI < 0.5 V or VI > VCC + 0.5 V ISW switch current 0.5 V < VO < VCC + 0.5 V ICC Min Max Unit 0.5 +7.0 V 20 - mA - 20 mA - 25 mA supply current - 75 mA IGND ground current 75 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 250 mW Tamb = 40 C to +125 C [2] [1] The input and output voltage ratings may be exceeded if the input and output voltage ratings are observed. [2] For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V).[1] Symbol Parameter Conditions 74AHC1G66-Q100 74AHCT1G66-Q100 Unit Min Typ Max Min Typ Max 2.0 5.0 5.5 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - 5.5 0 - 5.5 V VSW switch voltage 0 - VCC 0 - VCC V 74AHC_AHCT1G66_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 January 2015 © Nexperia B.V. 2017. All rights reserved 3 of 18 74AHC1G66-Q100; 74AHCT1G66-Q100 Nexperia Single-pole single-throw analog switch Table 6. Recommended operating conditions …continued Voltages are referenced to GND (ground = 0 V).[1] Symbol Parameter Conditions 74AHC1G66-Q100 Tamb ambient temperature t/V input transition rise and VCC = 3.3  0.3 V fall rate VCC = 5.0  0.5 V 74AHCT1G66-Q100 Min Typ Max Min Typ Max +125 Unit 40 +25 +125 40 +25 [2] C - - 100 - - - ns/V [2] - - 20 - - 20 ns/V [1] To avoid drawing VCC current from pin Z, when switch-current flows in pin Y, the voltage drop across the bidirectional switch must not exceed 0.4 V. If switch-current flows into pin Z, no VCC current flows out of terminal Y. In this case, there is no limit for the voltage drop across the switch. However, the voltage at pins Y and Z may not exceed VCC or GND. [2] Applies to control signal levels. 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max 1.5 - - 1.5 - 1.5 - 74AHC1G66-Q100 VIH VIL HIGH-level input voltage LOW-level input voltage VCC = 2.0 V V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V II input leakage current VI = 5.5 V or GND; VCC = 5.5 V - - 0.1 - 1.0 - 2.0 A IS(OFF) OFF-state leakage current Y or Z; VCC = 5.5 V; see Figure 4 - - 0.1 - 1.0 - 4.0 A IS(ON) ON-state leakage current Y or Z; VCC = 5.5 V; see Figure 5 - - 0.1 - 1.0 - 4.0 A ICC supply current E, Y or Z = VCC or GND; VCC = 5.5 V - - 1.0 - 10 - 40 A CI input capacitance E input - 2.0 10 - 10 - 10 pF CS(ON) ON-state capacitance Y or Z input or output - 4.0 10 - 10 - 10 pF 74AHCT1G66-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V II input leakage current VI = 5.5 V or GND; VCC = 5.5 V - - 0.1 - 1.0 - 2.0 A 74AHC_AHCT1G66_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 January 2015 © Nexperia B.V. 2017. All rights reserved 4 of 18 74AHC1G66-Q100; 74AHCT1G66-Q100 Nexperia Single-pole single-throw analog switch Table 7. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max IS(OFF) OFF-state leakage current Y or Z; VCC = 5.5 V; see Figure 4 - - 0.1 - 1.0 - 4.0 A IS(ON) ON-state leakage current Y or Z; VCC = 5.5 V; see Figure 5 - - 0.1 - 1.0 - 4.0 A ICC supply current E, Y or Z = VCC or GND; VCC = 5.5 V - - 1.0 - 10 - 40 A ICC additional per input pin; VI = 3.4 V; supply current other inputs at VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance E input - 2.0 10 - 10 - 10 pF CS(ON) ON-state capacitance Y or Z input or output - 4.0 10 - 10 - 10 pF 10.1 Test circuits 9&& 9&& ( 9,/ ,6 9, ( 9,+ < = ,6 ,6 *1' 92 9, < = *1' 92 DDL DDL VI = VCC or GND and VO = GND or VCC. Fig 4. Test circuit for measuring OFF-state leakage current 74AHC_AHCT1G66_Q100 Product data sheet VI = VCC or GND and VO = open circuit. Fig 5. Test circuit for measuring ON-state leakage current All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 January 2015 © Nexperia B.V. 2017. All rights reserved 5 of 18 74AHC1G66-Q100; 74AHCT1G66-Q100 Nexperia Single-pole single-throw analog switch 10.2 ON resistance Table 8. ON resistance At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graph see Figure 7 [1]. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Typ max Max Max 148[1] - - -  ISW = 10 mA; VCC = 3.0 V to 3.6 V 28 50 70 110  ISW = 10 mA; VCC = 4.5 V to 5.5 V 15 30 40 60  ISW = 1.0 mA; VCC = 2.0 V 30 - - -  ISW = 10 mA; VCC = 3.0 V to 3.6 V 20 50 65 90  ISW = 10 mA; VCC = 4.5 V to 5.5 V 15 22 26 40  ISW = 1.0 mA; VCC = 2.0 V 28 - - -  ISW = 10 mA; VCC = 3.0 V to 3.6 V 18 50 65 90  ISW = 10 mA; VCC = 4.5 V to 5.5 V 13 22 26 40  74AHC1G66-Q100 and 74AHCT1G66-Q100 RON(peak) ON resistance (peak) RON(rail) ON resistance (rail) VI = VCC to GND; see Figure 6 ISW = 1.0 mA; VCC = 2.0 V VI = GND; see Figure 6 VI = VCC; see Figure 6 [1] At supply voltages approaching 2 V, the analog switch ON resistance becomes extremely non-linear. Therefore it is recommended that these devices be used to transmit digital signals only, when using this supply voltage. 10.3 ON resistance test circuit and graphs PQD   521 ȍ   9&& 9 96:   9&& 9 Q< 9,   Q= *1' ,6:    DDJ Test circuit for measuring ON resistance 74AHC_AHCT1G66_Q100 Product data sheet   9, 9  Tamb = 25 C. RON = VSW / ISW. Fig 6. 9 Q( 9,+ Fig 7. Typical ON resistance as a function of input voltage All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 January 2015 © Nexperia B.V. 2017. All rights reserved 6 of 18 Nexperia 74AHC1G66-Q100; 74AHCT1G66-Q100 Single-pole single-throw analog switch 11. Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF; unless otherwise specified; For test circuit, see Figure 10. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Typ[1] max Max Max VCC = 2.0 V 2.2 5.0 6.0 7.0 ns VCC = 3.0 V to 3.6 V 1.0 2.0 3.0 4.0 ns 0.6 1.0 2.0 3.0 ns VCC = 2.0 V; CL = 15 pF 7.0 25.0 33.0 40.0 ns VCC = 2.0 V 11.0 35.0 46.0 57.0 ns VCC = 3.0 V to 3.6 V; CL = 15 pF 4.0 11.0 14.0 18.0 ns VCC = 3.0 V to 3.6 V 5.8 15.0 20.0 25.0 ns VCC = 4.5 V to 5.5 V; CL = 15 pF 3.0 8.0 10.0 13.0 ns 4.0 11.0 13.0 17.0 ns VCC = 2.0 V; CL = 15 pF 9.0 25.0 33.0 40.0 ns 74AHC1G66-Q100 tpd propagation delay Y to Z or Z to Y; see Figure 8 [2] VCC = 4.5 V to 5.5 V ten enable time E to Y or Z; see Figure 9 [2] VCC = 4.5 V to 5.5 V tdis disable time E to Y or Z; see Figure 9 [2] VCC = 2.0 V 13.0 35.0 46.0 57.0 ns VCC = 3.0 V to 3.6 V; CL = 15 pF 6.0 11.0 14.0 18.0 ns VCC = 3.0 V to 3.6 V 8.4 15.0 20.0 25.0 ns VCC = 4.5 V to 5.5 V; CL = 15 pF 5.0 8.0 10.0 13.0 ns 6.1 11.0 13.0 17.0 ns 13 - - - pF 0.7 1.0 2.0 3.0 ns 3.0 7.0 10.0 13.0 ns 4.7 10.0 13.0 17.0 ns VCC = 4.5 V to 5.5 V; CL = 15 pF 5.0 8.0 10.0 13.0 ns VCC = 4.5 V to 5.5 V 6.5 11.0 13.0 17.0 ns VCC = 4.5 V to 5.5 V CPD power dissipation capacitance VI = GND to VCC [3] [2] 74AHCT1G66-Q100 tpd propagation delay Y to Z or Z to Y; see Figure 8 ten enable time E to Y or Z; see Figure 9 VCC = 4.5 V to 5.5 V [2] VCC = 4.5 V to 5.5 V; CL = 15 pF VCC = 4.5 V to 5.5 V tdis disable time 74AHC_AHCT1G66_Q100 Product data sheet E to Y or Z; see Figure 9 [2] All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 January 2015 © Nexperia B.V. 2017. All rights reserved 7 of 18 74AHC1G66-Q100; 74AHCT1G66-Q100 Nexperia Single-pole single-throw analog switch Table 9. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF; unless otherwise specified; For test circuit, see Figure 10. Symbol Parameter CPD power dissipation capacitance 25 C Conditions max Max Max 15 - - - [3] VI = GND to VCC 40 C to +85 C 40 C to +125 C Unit Typ[1] [1] All typical values are measured at VCC = 2.0 V, VCC = 3.3 V, VCC = 5.0 V and Tamb = 25 C. [2] tpd is the same as tPLH and tPHL. pF ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. [3] CPD is used to determine the dynamic power dissipation PD (W). PD = CPD  VCC2  fi +  ((CL  CSW)  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; CSW = maximum switch capacitance in pF (see Table 7); VCC = supply voltage in Volt;  ((CL  CSW)  VCC2  fo) = sum of outputs. 11.1 Waveforms and test circuit 9, 90
74AHCT1G66GW-Q100H 价格&库存
很抱歉,暂时无法提供与“74AHCT1G66GW-Q100H”相匹配的价格&库存,您可以联系我们找货
