HEF4016B
Quad single-pole single-throw analog switch
Rev. 4 — 24 October 2016
Product data sheet
1. General description
The HEF4016B provides four single-pole, single-throw analog switch functions. Each
switch has two input/output terminals (nY and nZ) and an active HIGH enable input (nE).
When nE is LOW, the analog switch is turned off.
2. Features and benefits
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Inputs and outputs are protected against electrostatic effects
Specified from 40 C to +85 C
Complies with JEDEC standard JESD 13-B
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
4. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
HEF4016BT
40 C to +85 C
SO14
plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
HEF4016B
Nexperia
5. Functional diagram
Q<
9''
9''
Q(
966
9''
966
Q=
DDJ
Fig 1.
966
DDD
Functional diagram
Fig 2.
Logic diagram (one switch)
6. Pinning information
6.1 Pinning
9&&
*1'
DDD
Fig 3.
Pin configuration
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1Y, 2Y, 3Y, 4Y
1, 4, 8, 11
independent input or output
1Z, 2Z, 3Z, 4Z
2, 3, 9, 10
1E, 2E, 3E, 4E
13, 5, 6, 12
enable input (active HIGH)
VSS
7
ground (0 V)
VDD
14
supply voltage
HEF4016B
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
HEF4016B
Nexperia
7. Functional description
Table 3.
Function table[1]
Input nE
Switch
H
ON
L
OFF
[1]
H = HIGH voltage level; L = LOW voltage level.
8. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground).
Symbol
Parameter
VDD
supply voltage
IIK
input clamping current
VI
input voltage
Conditions
VI < 0.5 V or VI > VDD + 0.5 V
Min
Max
Unit
0.5
+18
V
10
mA
0.5
VDD + 0.5 V
II/O
input/output current
10
mA
Tstg
storage temperature
65
+150
C
Tamb
ambient temperature
40
+85
C
Ptot
total power dissipation
500
mW
100
mW
[1]
Tamb = 40 C to +85 C
SO14
P
power dissipation
[2]
per switch
[1]
To avoid drawing VDD current out of terminal nZ, when switch current flows into terminals nY, the voltage drop across the bidirectional
switch must not exceed 0.4 V. If the switch current flows into terminal nZ, no VDD current will flow out of terminals nY, in this case there
is no limit for the voltage drop across the switch, but the voltages at nY and nZ may not exceed VDD or VSS.
[2]
For SO14 packages: above Tamb = 70 C, Ptot derates linearly with 8 mW/K.
9. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDD
supply voltage
3
15
V
VI
input voltage
VDD
V
Tamb
ambient temperature
in free air
40
+85
C
t/V
input transition rise and fall
rate
VDD = 5 V
3.75
s/V
HEF4016B
Product data sheet
VDD = 10 V
0.5
s/V
VDD = 15 V
0.08
s/V
3 of 15
HEF4016B
Nexperia
10. Static characteristics
Table 6.
VSS = 0 V; VI = VSS or VDD unless otherwise specified.
Symbol
Parameter
Conditions
Tamb = 40 C
VDD
Min
VIH
VIL
HIGH-level input IO < 1 A
voltage
LOW-level input
voltage
IO < 1 A
Max
Tamb = 25 C
Tamb = 85 C
Min
Min
Max
Unit
Max
5V
3.5
3.5
3.5
V
10 V
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
V
15 V
0.3
1.0
A
II
input leakage
current
IS(OFF)
OFF-state
leakage current
per channel;
see Figure 4
15 V
200
nA
IDD
supply current
all valid input
combinations
5V
1.0
1.0
7.5
A
10 V
2.0
2.0
15.0
A
15 V
4.0
4.0
30.0
A
7.5
pF
CI
input
capacitance
nE input
10.1 Test circuit
9''
Q(
9,/
Q=
9,
Q<
,6
966
92
DDN
Fig 4.
Test circuit for measuring OFF-state leakage current
HEF4016B
Product data sheet
4 of 15
HEF4016B
Nexperia
10.2 ON resistance
Table 7.
ON resistance
Tamb = 25 C; ISW = 100 A; VSS = 0 V.
Symbol
Parameter
Conditions
VDD
Typ
Max
RON(peak)
ON resistance (peak)
VI = 0 V to VDD; see Figure 5 and
Figure 6
5V
8000
10 V
230
690
15 V
115
350
5V
140
425
10 V
65
195
RON(rail)
ON resistance (rail)
VI = 0 V; see Figure 5 and Figure 6
VI = VDD; see Figure 5 and Figure 6
RON
ON resistance mismatch
between channels
Unit
15 V
50
145
5V
170
515
10 V
95
285
15 V
75
220
5V
200
10 V
15
15 V
10
10.2.1 ON resistance waveform and test circuit
DDD
521
ȍ
96:
9''
Q(
9,+
Q<
9,
Q=
966
,6:
9,9
DDN
ISW = 100 A.
RON = VSW / ISW.
(1) VDD = 10 V
(2) VDD = 15 V
Fig 5.
Test circuit for measuring RON
HEF4016B
Product data sheet
Fig 6.
Typical RON as a function of input voltage
5 of 15
HEF4016B
Nexperia
11. Dynamic characteristics
Table 8.
Tamb = 25 C; VSS = 0 V; for test circuit see Figure 9.
Symbol
Parameter
tPHL
HIGH to LOW propagation delay nY, nZ to nZ, nY; see Figure 7
tPLH
tPHZ
tPLZ
tPZH
tPZL
Conditions
LOW to HIGH propagation delay nY, nZ to nZ, nY; see Figure 7
HIGH to OFF-state
propagation delay
nE to nY, nZ; see Figure 8
LOW to OFF-state
propagation delay
OFF-state to HIGH
propagation delay
OFF-state to LOW
propagation delay
VDD
Typ
Max
Unit
5V
25
50
ns
10 V
10
ns
15 V
5
10
ns
5V
ns
10 V
10
ns
15 V
5
10
ns
5V
90
130
ns
10 V
80
110
ns
15 V
75
100
ns
5V
85
120
ns
10 V
75
100
ns
15 V
75
100
ns
5V
40
80
ns
10 V
ns
15 V
15
30
ns
5V
40
80
ns
10 V
ns
15 V
15
30
ns
Table 9.
Dynamic power dissipation PD
PD can be calculated from the formulas shown; VSS = 0 V; tr = tf 20 ns; Tamb = 25 C.
Symbol
PD
Parameter
dynamic power
dissipation
VDD
Typical formula for PD (W)
where:
5V
PD = 550 fi + (fo CL) VDD
10 V
PD = 2600 fi + (fo CL) VDD2
fo = output frequency in MHz;
15 V
PD = 6500 fi + (fo CL) VDD
CL = output load capacitance in pF;
2
fi = input frequency in MHz;
2
VDD = supply voltage in V;
(fo CL) = sum of the outputs.
HEF4016B
Product data sheet
6 of 15
HEF4016B
Nexperia
11.1 Waveforms and test circuit
9,
90
90
W3/+
W3+/
LQSXWQ
很抱歉,暂时无法提供与“HEF4016BT,653”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.58560
- 10+2.85120
- 30+2.53800
- 100+2.14920
- 500+1.96560
- 1000+1.86840
- 国内价格
- 2500+1.76330
- 12500+1.58700
