74HC4066-Q100;
74HCT4066-Q100
Quad single-pole single-throw analog switch
Rev. 4 — 14 April 2020
Product data sheet
1. General description
The 74HC4066-Q100; 74HCT4066-Q100 is a quad single pole, single throw analog switch. Each
switch features two input/output terminals (nY and nZ) and an active HIGH enable input (nE).
When nE is LOW, the analog switch is turned off. Inputs include clamp diodes. This enables the
use of current limiting resistors to interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Input levels nE inputs:
• For 74HC4066-Q100: CMOS level
• For 74HCT4066-Q100: TTL level
Low ON resistance:
• 50 Ω (typical) at VCC = 4.5 V
• 45 Ω (typical) at VCC = 6.0 V
• 35 Ω (typical) at VCC = 9.0 V
Specified in compliance with JEDEC standard no. 7A
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
Multiple package options
DHVQFN package with Side-Wettable Flanks enabling Automatic Optical Inspection (AOI) of
solder joints
3. Ordering information
Table 1. Ordering information
Type number
Package
74HC4066D-Q100
Temperature range Name
Description
Version
-40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
-40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package;
14 leads; body width 4.4 mm
SOT402-1
-40 °C to +125 °C
DHVQFN14 plastic dual in-line compatible thermal
enhanced very thin quad flat package; no leads;
14 terminals; body 2.5 × 3 × 0.85 mm
74HCT4066D-Q100
74HC4066PW-Q100
74HCT4066PW-Q100
74HC4066BQ-Q100
74HCT4066BQ-Q100
SOT762-1
Nexperia
4. Functional diagram
1Y
1
1Z
1
2
13 #
1E
13
2Y
4
1
2Z
4
3Y
8
3
9
8
8
9
11
4Z
10
11
10
12 #
12 #
4E
12
6#
6#
4Y
11
5#
5#
3Z
3E
6
4
13 #
3
2E
5
2
1
1
X1
1
1
3
X1
1
1
9
X1
1
1
10
X1
(a)
(b)
001aad270
001aad269
Fig. 1.
2
Logic symbol
Fig. 2.
IEC logic symbol
nY
nE
VCC
VCC
GND
nZ
001aad271
Fig. 3.
Schematic diagram (one switch)
5. Pinning information
1
1Y
terminal 1
index area
1Y
1
14 VCC
1Z
2
13 1E
4
2E
5
3E
6
9
3Z
GND
7
8
3Y
4066
Product data sheet
4
4066
11 4Y
2E
5
VCC(1)
10 4Z
3E
6
9
10 4Z
3Z
001aac116
Transparent top view
Pin configuration SOT108-1 (SO14) and
SOT402-1 (TSSOP14)
74HC_HCT4066_Q100
2Y
11 4Y
(1) This is not a supply pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to VCC.
001aad268
Fig. 4.
13 1E
12 4E
8
2Y
3
3Y
12 4E
2
2Z
7
3
1Z
GND
2Z
14 VCC
5.1. Pinning
Fig. 5.
Pin configuration SOT762-1 (DHVQFN14)
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2020. All rights reserved
2 / 20
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1Z, 2Z, 3Z, 4Z
2, 3, 9, 10
independent input or output
1Y, 2Y, 3Y, 4Y
1, 4, 8, 11
GND
7
ground (0 V)
1E, 2E, 3E, 4E
13, 5, 6, 12
enable input (active HIGH)
VCC
14
supply voltage
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level.
Input nE
Switch
L
OFF
H
ON
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
ISK
switch clamping current
VSW < -0.5 V or VSW > VCC + 0.5 V
ISW
switch current
VSW = -0.5 V to VCC + 0.5 V
ICC
supply current
IGND
ground current
Tstg
storage temperature
Ptot
total power dissipation
Tamb = -40 °C to +125 °C
P
power dissipation
per switch
[1]
[2]
Conditions
[1]
[2]
Min
Max
Unit
-0.5
+11.0
V
±20
mA
±20
mA
±25
mA
50
mA
-50
mA
-65
+150
°C
500
mW
100
mW
To avoid drawing VCC current out of terminal Z, when switch current flows in terminals Yn, the voltage drop across the bidirectional
switch must not exceed 0.4 V. If the switch current flows into terminal Z, no VCC current will flow out of terminals Yn. In this case there
is no limit for the voltage drop across the switch, but the voltages at Yn and Z may not exceed VCC or GND.
For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C.
For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C.
For SOT762-1 (DHVQFN14) package: Ptot derates linearly with 9.6 mW/K above 98 °C.
74HC_HCT4066_Q100
Product data sheet
3 / 20
Nexperia
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC4066-Q100
74HCT4066-Q100
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
10.0
4.5
5.0
5.5
V
VCC
GND
VCC
V
VCC
supply voltage
VI
input voltage
GND
VSW
switch voltage
GND
VCC
GND
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise
and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
VCC = 10.0 V
35
ns/V
9. Static characteristics
Table 6. RON resistance per switch for types 74HC4066-Q100 and 74HCT4066-Q100
VI = VIH or VIL; for test circuit see Fig. 6.
Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input.
Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output.
For 74HC4066-Q100: VCC - GND = 2.0 V, 4.5 V, 6.0 V and 9.0 V.
For 74HCT4066-Q100: VCC - GND = 4.5 V.
Symbol
Parameter
RON(peak) ON resistance (peak)
Conditions
-40 °C to +85 °C
Min
Typ[1]
Max
Min
Max
Ω
VCC = 4.5 V; ISW = 1000 μA
54
118
142
Ω
VCC = 6.0 V; ISW = 1000 μA
42
105
126
Ω
VCC = 9.0 V; ISW = 1000 μA
32
88
105
Ω
80
Ω
35
95
115
Ω
27
82
100
Ω
85
Ω
100
Ω
42
106
128
Ω
35
94
113
Ω
95
Ω
Vis = VCC to GND
VCC = 2.0 V; ISW = 100 μA
RON(rail)
ON resistance (rail)
-40 °C to +125 °C Unit
[2]
Vis = GND
[2]
Vis = VCC
74HC_HCT4066_Q100
Product data sheet
[2]
4 / 20
Nexperia
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
ΔRON
[1]
[2]
Typ[1]
Max
Min
Max
Vis = VCC to GND
ON resistance
mismatch between
channels
VCC = 2.0 V
Ω
VCC = 4.5 V
[2]
5
Ω
VCC = 6.0 V
4
Ω
VCC = 9.0 V
3
Ω
Typical values are measured at Tamb = 25 °C.
At supply voltages (VCC - GND) approaching 2 V, the analog switch ON resistance becomes extremely non-linear. Therefore it is
recommended that these devices be used to transmit digital signals only, when using these supply voltages.
aaa-003459
60
RON
(Ω)
VCC = 4.5 V
50
VSW
VCC
6V
40
9V
nE
VIH
nY
Vis
30
nZ
GND
ISW
aaa-003458
10
Vis = 0 V to VCC
3.6
5.4
7.2
Vis (V)
9.0
Vis = 0 V to VCC
Fig. 6.
Test circuit for measuring RON
Fig. 7.
Typical RON as a function of input voltage Vis
Table 7. Static characteristics 74HC4066-Q100
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
Unit
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
VCC = 9.0 V
6.3
4.7
V
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.80
V
VCC = 9.0 V
4.3
2.70
V
VCC = 6.0 V
±1.0
μA
VCC = 10.0 V
±2.0
μA
±1.0
μA
Tamb = -40 °C to +85 °C
VIH
VIL
II
IS(OFF)
HIGH-level input voltage
LOW-level input voltage
input leakage current
OFF-state leakage current
VI = VCC or GND
VCC = 10.0 V; VI = VIH or VIL;
|VSW| = VCC - GND; see Fig. 8
per channel
74HC_HCT4066_Q100
Product data sheet
5 / 20
Nexperia
Symbol Parameter
Conditions
Min
Typ[1]
Max
Unit
IS(ON)
ON-state leakage current
|VSW| = VCC - GND; see Fig. 9
±1.0
μA
ICC
supply current
VI = VCC or GND; Vis = GND or VCC;
Vos = VCC or GND
VCC = 6.0 V
20.0
μA
VCC = 10.0 V
40.0
μA
CI
input capacitance
3.5
pF
Csw
switch capacitance
8
pF
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 9.0 V
6.3
V
VCC = 2.0 V
0.50
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.80
V
VCC = 9.0 V
2.70
V
VCC = 6.0 V
±1.0
μA
VCC = 10.0 V
±2.0
μA
±1.0
μA
±1.0
μA
VCC = 6.0 V
40
μA
VCC = 10.0 V
80
μA
VIH
VIL
II
IS(OFF)
VI = VCC or GND
per channel
IS(ON)
ICC
supply current
Vos = VCC or GND
[1]
74HC_HCT4066_Q100
Product data sheet
6 / 20
Nexperia
Table 8. Static characteristics 74HCT4066-Q100
Symbol
Parameter
Conditions
Min
Typ[1]
Max
Unit
V
VIH
VCC = 4.5 V to 5.5 V
2.0
1.6
VIL
1.2
0.8
V
II
VI = VCC or GND; VCC = 5.5 V
±1.0
μA
IS(OFF)
VCC = 5.5 V; VI = VIH or VIL;
±1.0
μA
IS(ON)
±1.0
μA
ICC
supply current
Vos = VCC or GND; VCC = 4.5 V to 5.5 V
20.0
μA
ΔICC
additional supply current
per input pin; VI = VCC - 2.1 V; other inputs
at VCC or GND; VCC = 4.5 V to 5.5 V
100
450
μA
CI
input capacitance
3.5
pF
Csw
switch capacitance
8
pF
per channel
VIH
2.0
V
VIL
0.8
V
II
±1.0
μA
IS(OFF)
±1.0
μA
per channel
IS(ON)
±1.0
μA
ICC
supply current
40
μA
ΔICC
490
μA
[1]
VCC
VCC
E
VIL
ISW
Vis
VIH
Yn
Z
GND
ISW
ISW
Vos
E
Z
Yn
Vos
Vis
GND
aaa-003456
aaa-003457
Vis = VCC and Vos = GND
Vis = GND and Vos = VCC
Fig. 8.
Vis = VCC and Vos = open
Vis = GND and Vos = open
Test circuit for measuring OFF-state leakage
current
74HC_HCT4066_Q100
Product data sheet
Fig. 9.
Test circuit for measuring ON-state leakage
current
7 / 20
Nexperia
10. Dynamic characteristics
Table 9. Dynamic characteristics 74HC4066-Q100
GND = 0 V; tr = tf = 6 ns; CL = 50 pF unless specified otherwise; for test circuit see Fig. 12.
Symbol Parameter
tpd
toff
ton
Conditions
-40 °C to +85 °C
Typ[1]
Max
Min
Max
VCC = 2.0 V
8
75
90
ns
VCC = 4.5 V
3
15
18
ns
VCC = 6.0 V
2
13
15
ns
VCC = 9.0 V
2
10
12
ns
VCC = 2.0 V
44
190
225
ns
VCC = 4.5 V
16
38
45
ns
VCC = 5.0 V; CL = 15 pF
13
ns
VCC = 6.0 V
13
33
38
ns
VCC = 9.0 V
16
26
30
ns
VCC = 2.0 V
36
125
150
ns
VCC = 4.5 V
13
25
30
ns
11
ns
VCC = 6.0 V
10
21
26
ns
8
16
ns
11
pF
propagation delay nY to nZ or nZ to nY; RL = ∞ Ω;
see Fig. 10
turn-off time
turn-on time
nE to nY or nZ; see Fig. 11
[2]
[3]
[4]
VCC = 9.0 V
CPD
[1]
[2]
[3]
[4]
[5]
power dissipation
capacitance
Min
per switch; VI = GND to VCC
[5]
tpd is the same as tPHL and tPLH.
toff is the same as tPZH and tPZL.
ton is the same as tPHZ and tPLZ.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi + ∑{(CL + Csw) x VCC x fo} where:
fi = input frequency in MHz;
fo = output frequency in MHz;
2
∑{(CL + Csw) x VCC x fo} = sum of outputs;
CL = output load capacitance in pF;
Csw = switch capacitance in pF;
VCC = supply voltage in V.
74HC_HCT4066_Q100
Product data sheet
8 / 20
Nexperia
Table 10. Dynamic characteristics 74HCT4066-Q100
Symbol Parameter
tpd
propagation
delay
Conditions
-40 °C to +85 °C
Min
Typ[1]
Max
Min
Max
3
15
18
ns
53
ns
16
ns
VCC = 4.5 V
12
30
36
ns
12
ns
12
pF
see Fig. 10
[2]
VCC = 4.5 V
toff
turn-off time
[3]
VCC = 4.5 V
ton
CPD
[1]
[2]
[3]
[4]
[5]
turn-on time
[4]
power dissipation per switch;
capacitance
VI = GND to (VCC - 1.5 V)
[5]
2
2
2
10.1. Waveforms and test circuit
Vis input
50 %
tPLH
tPHL
50 %
Vos output
001aad555
Fig. 10. Input (Vis) to output (Vos) propagation delays
74HC_HCT4066_Q100
Product data sheet
9 / 20
Nexperia
VI
VM
E input
0V
tPLZ
tPZL
50 %
Vos output
10 %
tPHZ
tPZH
90 %
50 %
Vos output
switch ON
switch OFF
switch ON
aaa-003460
Measurement points are shown in Table 11.
Fig. 11. Turn-on and turn-off times
Table 11. Measurement points
Type
VI
VM
74HC4066-Q100
VCC
0.5VCC
74HCT4066-Q100
3.0 V
1.3 V
VI
negative
pulse
tW
90 %
VM
0V
tf
0V
tr
tr
VI
positive
pulse
VM
10 %
tf
90 %
VM
VM
10 %
tW
VCC Vis
PULSE
GENERATOR
VI
VCC
Vos
RL
DUT
RT
S1
open
CL
GND
001aag732
Test data is given in Table 12.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig. 12. Test circuit for measuring switching times
74HC_HCT4066_Q100
Product data sheet
10 / 20
Nexperia
Table 12. Test data
Test
Input
Output
Control E
Switch Yn (Z)
tr, tf
S1 position
Switch Z (Yn)
VI[1]
Vis
CL
RL
tPHL, tPLH
GND
GND to VCC
6 ns
50 pF
open
tPHZ, tPZH
GND to VCC
VCC
6 ns
50 pF, 15 pF
1 kΩ
GND
tPLZ, tPZL
GND to VCC
GND
6 ns
50 pF, 15 pF
1 kΩ
VCC
[1]
For 74HCT4066-Q100: maximum input voltage VI = 3.0 V.
11. Additional dynamic characteristics
Table 13. Additional dynamic characteristics
Recommended conditions and typical values; GND = 0 V; Tamb = 25 °C.
Symbol Parameter
THD
Min
Conditions
Typ
Max
total harmonic distortion fi = 1 kHz; RL = 10 kΩ; CL = 50 pF; see Fig. 13
Unit
VCC = 4.5 V; VI = 4.0 V (p-p)
0.04
VCC = 9.0 V; VI = 8.0 V (p-p)
0.02
0.12
0.06
VCC = 4.5 V
180
MHz
VCC = 9.0 V
200
MHz
VCC = 4.5 V
-50
dB
VCC = 9.0 V
-50
dB
110
mV
220
mV
VCC = 4.5 V
-60
dB
VCC = 9.0 V
-60
dB
fi = 10 kHz; RL = 10 kΩ; CL = 50 pF; see Fig. 13
f(-3dB)
αiso
-3 dB frequency
response
isolation (OFF-state)
Vct
crosstalk voltage
RL = 50 Ω; CL = 10 pF; see Fig. 14
RL = 600 Ω; CL = 50 pF; fi = 1 MHz; see Fig. 15
[1]
[2]
between digital input and switch (peak to
peak value); RL = 600 Ω; CL = 50 pF; fi = 1 MHz;
see Fig. 16
VCC = 4.5 V
VCC = 9.0 V
Xtalk
[1]
[2]
crosstalk
between switches; RL = 600 Ω; CL = 50 pF;
fi = 1 MHz; see Fig. 17
[2]
Adjust input voltage Vis to 0 dBm level at Vos for fi = 1 MHz (0 dBm = 1 mW into 50 Ω). After set-up, fi is increased to obtain a reading
of -3 dB at Vos.
Adjust input voltage Vis to 0 dBm level (0 dBm = 1 mW into 600 Ω).
74HC_HCT4066_Q100
Product data sheet
11 / 20
Nexperia
VCC
VCC
nE
VIH
2RL
10 µF
nY/nZ
nZ/nY
fi
VO
2RL
D
CL
001aaj468
Fig. 13. Test circuit for measuring total harmonic distortion
mna083
5
(dB)
10
102
103
104
105
fi (kHz)
106
a. Typical -3 dB frequency response
VCC
VCC
nE
VIH
2RL
0.1 µF
nY/nZ
nZ/nY
fi
VO
2RL
CL
dB
001aaj469
b. Test circuit
VCC = 4.5 V; GND = 0 V; RL = 50 Ω; Rsource = 1 kΩ.
Fig. 14. -3 dB frequency response as a function of frequency
74HC_HCT4066_Q100
Product data sheet
12 / 20
Nexperia
mna082
(dB)
- 20
- 40
- 60
- 80
- 100
10
102
103
104
105
fi (kHz)
106
a. Isolation (OFF-state)
VCC
VCC
nE
VIL
2RL
0.1 µF
nY/nZ
nZ/nY
fi
VO
CL
2RL
dB
001aaj470
b. Test circuit
VCC = 4.5 V; GND = 0 V; RL = 600 Ω; Rsource = 1 kΩ.
Fig. 15. Isolation (OFF-state) as a function of frequency
VCC
nE
VCC
GND
2RL
nY/nZ
VCC
2RL
DUT
2RL
2RL
CL
nZ/nY
oscilloscope
GND
mnb011
a. Test circuit
V(p- p)
mnb012
b. Crosstalk voltage
Fig. 16. Test circuit for measuring crosstalk voltage (between the digital input and the switch)
74HC_HCT4066_Q100
Product data sheet
13 / 20
Nexperia
VCC
1E
VIH
0.1 µF
RL
2RL
1Y or 1Z
1Z or 1Y
CHANNEL
ON
fi
2RL
CL
V
VO1
V
VO2
2E
VIL
VCC
VCC
2RL
2RL
2Y or 2Z
2RL
2Z or 2Y
CHANNEL
OFF
2RL
CL
001aai846
Fig. 17. Test circuit for measuring crosstalk (between the switches)
74HC_HCT4066_Q100
Product data sheet
14 / 20
Nexperia
12. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 18. Package outline SOT108-1 (SO14)
74HC_HCT4066_Q100
Product data sheet
15 / 20
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
D
SOT402-1
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
7
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 19. Package outline SOT402-1 (TSSOP14)
74HC_HCT4066_Q100
Product data sheet
16 / 20
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
14 terminals; body 2.5 x 3 x 0.85 mm
B
D
SOT762-1
A
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
v
w
b
2
6
C A B
C
y
y1 C
L
1
7
14
8
Eh
e
k
13
9
Dh
X
k
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
1
A1
b
0.05 0.30
0.02 0.25
0.00 0.18
4 mm
scale
c
D(1)
Dh
E(1)
Eh
e
e1
0.2
3.1
3.0
2.9
1.65
1.50
1.35
2.6
2.5
2.4
1.15
1.00
0.85
0.5
2
k
L
v
0.2
0.5
0.4
0.3
0.1
w
y
0.05 0.05
y1
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Outline
version
References
IEC
SOT762-1
JEDEC
JEITA
sot762-1_po
European
projection
Issue date
15-04-10
15-05-05
MO-241
Fig. 20. Package outline SOT762-1 (DHVQFN14)
13. Abbreviations
74HC_HCT4066_Q100
Product data sheet
17 / 20
Nexperia
Table 14. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 15. Revision history
Document ID
Release date
Data sheet status Change notice
Supersedes
74HC_HCT4066_Q100 v.4
20200414
Product data sheet -
74HC_HCT4066_Q100 v.3
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Table 4: Derating values for Ptot total power dissipation have been updated.
Table 9: CPD value of 74HC4066-Q100 moved to typical column.
Package outline drawing of SOT762-1 (Fig. 20) updated.
20131216
Modifications:
74HC_HCT4066_Q100 v.2
20130404
Modifications:
74HC_HCT4066_Q100 v.1
20120712
74HC_HCT4066_Q100
Product data sheet
Features and benefits updated (errata).
Descriptive title corrected (errata).
New general description (errata).
18 / 20
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74HC_HCT4066_Q100
Product data sheet
19 / 20
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................2
5.1. Pinning.........................................................................2
5.2. Pin description............................................................. 3
6. Functional description................................................. 3
7. Limiting values............................................................. 3
8. Recommended operating conditions..........................4
9. Static characteristics....................................................4
10. Dynamic characteristics............................................ 8
10.1. Waveforms and test circuit........................................ 9
11. Additional dynamic characteristics.........................11
12. Package outline........................................................ 15
13. Abbreviations............................................................ 17
14. Revision history........................................................18
15. Legal information......................................................19
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 14 April 2020
74HC_HCT4066_Q100
Product data sheet
20 / 20
