74LVCV2G66GTX
74LVCV2G66GTX
    NEXPERIA(安世)
    XSON8_1.95X1MM
    允许过压双向开关
74LVCV2G66GTX 数据手册
74LVCV2G66 Overvoltage tolerant bilateral switch Rev. 8 — 5 November 2018 Product data sheet 1. General description The 74LVCV2G66 is a low-power, low-voltage, high-speed Si-gate CMOS device. The 74LVCV2G66 provides two single pole single throw analog or digital switches. Each switch includes an overvoltage tolerant input/output terminal (pin nZ), an output/input terminal (pin nY) and low-power active HIGH enable input (pin nE). The overvoltage tolerant switch terminals allow the switching of signals in excess of VCC. The low-power enable input eliminates the necessity of using current limiting resistors in portable applications when using control logic signals much lower than VCC. These inputs are also overvoltage tolerant. 2. Features and benefits • • • • • • • • • • • • Wide supply voltage range from 2.3 V to 5.5 V Ultra low-power operation Very low ON resistance: • 8.0 Ω (typical) at VCC = 2.7 V • 7.5 Ω (typical) at VCC = 3.3 V • 7.3 Ω (typical) at VCC = 5.0 V. 5 V tolerant input for interfacing with 5 V logic High noise immunity Switch handling capability of 32 mA CMOS low-power consumption Latch-up performance exceeds 250 mA Incorporates overvoltage tolerant analog switch technology Switch accepts voltages up to 5.5 V independent of VCC Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVCV2G66DC -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm SOT765-1 74LVCV2G66GT -40 °C to +125 °C XSON8 plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm SOT833-1 74LVCV2G66GM -40 °C to +125 °C XQFN8 plastic, extremely thin quad flat package; no leads; 8 terminals; body 1.6 x 1.6 x 0.5 mm SOT902-2 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch 4. Marking Table 2. Marking codes Type number Marking code[1] 74LVCV2G66DC Y66 74LVCV2G66GT Y66 74LVCV2G66GM Y66 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 1Y 1Z 1 1E # 2Z X1 2Y # 2E 1 X1 001aag497 Fig. 1. 1 1 001aah808 Logic symbol Fig. 2. IEC logic symbol Z Y E VCC Fig. 3. 001aaa532 Logic diagram (one switch) 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 2 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch 6. Pinning information 6.1. Pinning 74LVCV2G666 1Z 1 8 VCC 1Y 2 7 1E 2E 3 6 2Y GND 4 5 2Z 74LVCV2G66 1Z 1 8 VCC 1Y 2 7 1E 2E 3 6 2Y GND 4 5 2Z aaa-018593 Transparent top view 001aai213 Pin configuration SOT765-1 (VSSOP8) Fig. 5. Pin configuration SOT833-1 (XSON8) 74LVCV2G66 1E 1 2Y 2Z 8 VCC terminal 1 index area 7 1Z 2 6 1Y 3 5 2E GND 4 Fig. 4. aaa-018594 Transparent top view Fig. 6. Pin configuration SOT902-2 (XQFN8) 6.2. Pin description Table 3. Pin description Symbol Pin Description SOT765-1 and SOT833-1 SOT902-2 1Z 1 7 independent input or output (overvoltage tolerant) 1Y 2 6 independent input or output 2E 3 5 enable input (active HIGH) GND 4 4 ground (0 V) 2Z 5 3 independent input or output (overvoltage tolerant) 2Y 6 2 independent input or output 1E 7 1 enable input (active HIGH) VCC 8 8 supply voltage 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 3 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level. Input nE Switch L OFF-state H ON-state 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage IIK input clamping current VI < -0.5 V or VI > 6.5 V -50 - mA ISK switch clamping current VI < -0.5 V or VI > 6.5 V - ±50 mA VSW switch voltage enable and disable mode -0.5 +6.5 V ISW switch current VSW > -0.5 V or VSW < 6.5 V - ±50 mA ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW [1] [2] Conditions [1] Tamb = -40 °C to +125 °C [2] Min Max Unit -0.5 +6.5 V -0.5 +6.5 V The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For VSSOP8 package: above 110 °C, the value of Ptot derates linearly with 8 mW/K. For XSON8 and XQFN8 packages: above 118 °C, the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC supply voltage 2.3 - 5.5 V VI input voltage 0 - 5.5 V VSW switch voltage 0 - 5.5 V Tamb ambient temperature °C Δt/ΔV input transition rise and fall rate [1] [2] enable and disable mode [1] -40 - +125 VCC = 2.3 V to 2.7 V [2] - - 20 ns/V VCC = 2.7 V to 5.5 V [2] - - 10 ns/V To avoid sinking GND current from terminal nZ when switch current flows in terminal nY, the voltage drop across the bidirectional switch must not exceed 0.4 V. If the switch current flows into terminal nZ, no GND current flows from terminal nY. In this case, there is no limit for the voltage drop across the switch. Applies to control signal levels. 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 4 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH Conditions -40 °C to +125 °C Unit Min Typ[1] Max Min Max 0.6VCC - - 0.6VCC - V VCC = 3.0 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.55VCC - - 0.55VCC - V LOW-level input VCC = 2.3 V to 2.7 V voltage VCC = 3.0 V to 3.6 V - - 0.1VCC - - - 0.5 - VCC = 4.5 V to 5.5 V - - 0.15VCC - [2] - ±0.1 ±1 - ±1 μA HIGH-level input voltage VIL -40 °C to +85 °C VCC = 2.3 V to 2.7 V 0.5 V 0.15VCC V II input leakage current IS(OFF) OFF-state VCC = 2.3 V to 5.5 V; see Fig. 7 leakage current [2][3] - ±0.1 ±0.4 - ±1 μA IS(ON) ON-state VCC = 2.3 V to 5.5 V; see Fig. 8 leakage current [2][3] - ±0.1 ±2 - ±4 μA ICC supply current VI = 5.5 V or GND; VSW = GND or VCC; VCC = 2.3 V to 5.5 V [2] - 0.1 4 - 4 μA ΔICC additional supply current pin nE; VI = VCC - 0.6 V; VSW = GND or VCC; VCC = 3.0 V to 5.5 V [2] - 0.1 5 - 50 μA CI input capacitance - 2.5 - - - pF CS(OFF) OFF-state capacitance - 8.0 - - - pF CS(ON) - 16 - - - pF [1] [2] [3] pin nE; VI = 5.5 V or GND; VCC = 0 V to 5.5 V 0.1VCC V ON-state capacitance All typical values are measured at Tamb = 25 °C. These typical values are measured at VCC = 3.3 V. For overvoltage signals (VSW > VCC), the condition VY < VZ must be observed. 10.1. Test circuits VCC VCC nE VIL nZ VI nE VIH nY IS GND IS VO VI nZ nY GND VO 001aag488 001aag489 VI = GND and VO = GND or 5.5 V. Fig. 7. VI = 5.5 V or GND and VO = open circuit. Test circuit for measuring OFF-state leakage current 74LVCV2G66 Product data sheet Fig. 8. Test circuit for measuring ON-state leakage current All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 5 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch 10.2. ON resistance Table 8. Resistance RON At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graphs see Fig. 10 and Fig. 11. Symbol Parameter Conditions -40 °C to +85 °C Min Typ[1] Max RON(peak) RON(rail) ON resistance (peak) ON resistance (rail) -40 °C to +125 °C Unit Min Max VSW = GND to VCC; VI = VIH; see Fig. 9 ISW = 8 mA; VCC = 2.3 V to 2.7 V - 13 30 - 30 Ω ISW = 12 mA; VCC = 2.7 V ISW = 24 mA; VCC = 3.0 V to 3.6 V - 10 25 - 25 Ω - 8.3 20 - 20 Ω ISW = 32 mA; VCC = 4.5 V to 5.5 V - 7.4 15 - 15 Ω ISW = 8 mA; VCC = 2.3 V to 2.7 V - 8.5 20 - 20 Ω ISW = 12 mA; VCC = 2.7 V - 8.0 18 - 18 Ω ISW = 24 mA; VCC = 3.0 V to 3.6 V - 7.5 15 - 15 Ω ISW = 32 mA; VCC = 4.5 V to 5.5 V - 7.3 10 - 10 Ω ISW = 8 mA; VCC = 2.3 V to 2.7 V - 8.5 20 - 20 Ω ISW = 12 mA; VCC = 2.7 V - 7.2 18 - 18 Ω ISW = 24 mA; VCC = 3.0 V to 3.6 V - 6.5 15 - 15 Ω ISW = 32 mA; VCC = 4.5 V to 5.5 V - 5.7 10 - 10 Ω ISW = 8 mA; VCC = 2.5 V - 17 - - - Ω ISW = 12 mA; VCC = 2.7 V - 10 - - - Ω ISW = 24 mA; VCC = 3.3 V - 5 - - - Ω ISW = 32 mA; VCC = 5.0 V - 3 - - - Ω VSW = GND; VI = VIH; see Fig. 9 VSW = VCC; VI = VIH RON(flat) [1] [2] ON resistance (flatness) VSW = GND to VCC; VI = VIH [2] All typical values are measured at Tamb = 25 °C and nominal VCC. Flatness is defined as the difference between the maximum and minimum value of ON resistance measured at identical VCC and temperature. 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 6 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch 10.3. ON resistance test circuit and graphs 001aaa536 16 RON (Ω) VCC = 2.5 V 2.7 V 3.3 V 5.0 V 12 VSW 8 VCC nE VIH 4 nY VI nZ GND ISW 001aag490 VI = GND to 5.5 V; RON = VSW / ISW. Fig. 9. Test circuit for measuring ON resistance 74LVCV2G66 Product data sheet 0 0 2 4 VI (V) 6 VI = GND to 5.5 V; Tamb = 25 °C. Fig. 10. Typical ON resistance as a function of input voltage All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 7 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch 001aaa537 16 Tamb = +85 °C +25 °C - 40 °C +125 °C RON (Ω) 12 RON (Ω) 8 4 4 0 2 Tamb = +85 °C +25 °C - 40 °C +125 °C 12 8 0 001aaa538 16 4 0 6 VI (V) a. VCC = 2.5 V 0 2 4 VI (V) 6 b. VCC = 2.7 V 001aaa539 16 001aaa540 16 RON (Ω) RON (Ω) Tamb = +85 °C +25 °C - 40 °C +125 °C 12 12 8 8 4 4 0 0 c. VCC = 3.3 V 2 4 VI (V) 6 0 Tamb = +85 °C +25 °C - 40 °C +125 °C 0 2 4 VI (V) 6 d. VCC = 5.0 V Fig. 11. ON resistance as a function of input voltage at various supply voltages 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 8 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch 11. Dynamic characteristics Table 9. Dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit, see Fig. 14. Symbol Parameter Conditions -40 °C to +85 °C Min tpd enable time tdis disable time CPD [4] [5] [6] Typ[1] Max Min Max propagation delay nY to nZ or nZ to nY; see Fig. 12 [2][3] ten [1] [2] [3] -40 °C to +125 °C Unit power dissipation capacitance VCC = 2.3 V to 2.7 V - 0.4 1.2 - 2.0 ns VCC = 2.7 V - 0.4 1.0 - 1.5 ns VCC = 3.0 V to 3.6 V - 0.3 0.8 - 1.5 ns VCC = 4.5 V to 5.5 V - 0.2 0.6 - 1.0 ns VCC = 2.3 V to 2.7 V 1.0 4.7 12 1.0 15 ns VCC = 2.7 V 1.0 4.4 8.5 1.0 11 ns VCC = 3.0 V to 3.6 V 1.0 3.8 7.5 1.0 9.5 ns VCC = 4.5 V to 5.5 V 1.0 2.7 5.0 1.0 6.5 ns VCC = 2.3 V to 2.7 V 1.0 6.0 16 1.0 20 ns VCC = 2.7 V 1.0 7.9 15 1.0 19 ns VCC = 3.0 V to 3.6 V 1.0 6.5 13.5 1.0 17 ns VCC = 4.5 V to 5.5 V 1.0 4.4 9.0 1.0 11.5 ns nE to nY or nZ; see Fig. 13 [4] nE to nY or nZ; see Fig. 13 [5] CL = 50 pF; fi = 10 MHz; VI = GND to 5.5 V[6] VCC = 2.5 V - 9.7 - - - pF VCC = 3.3 V - 10.3 - - - pF VCC = 5.0 V - 11.3 - - - pF Typical values are measured at Tamb = 25 °C and nominal VCC. tpd is the same as tPLH and tPHL. Propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified capacitance when driven by an ideal voltage source (zero output impedance). ten is the same as tPZH and tPZL. tdis is the same as tPLZ and tPHZ. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC × fi x N + Σ{(CL + CS(ON)) x VCC x fo} where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; CS(ON) = maximum ON-state switch capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ{(CL + CS(ON)) x VCC x fo} = sum of the outputs. 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 9 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch 11.1. Waveforms and test circuit VI nY or nZ input VM VM GND t PLH t PHL VOH nZ or nY output VM VM VOL 001aaa541 Measurement points are given in Table 10. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 12. Input (nY or nZ) to output (nZ or nY) propagation delays VI nE input VM GND t PLZ nY or nZ output LOW-to-OFF OFF-to-LOW t PZL VCC VM VX VOL t PZH t PHZ nY or nZ output HIGH-to-OFF OFF-to-HIGH VOH VY VM GND switch enabled switch disabled switch enabled 001aaa542 Measurement points are given in Table 10. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 13. Enable and disable times Table 10. Measurement points Supply voltage Input Output VCC VM VM VX VY 2.3 V to 2.7 V 0.5VCC 0.5VCC VOL + 0.1VCC VOH - 0.1VCC 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 3.0 V to 3.6 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 4.5 V to 5.5 V 0.5VCC 0.5VCC VOL + 0.3 V VOH - 0.3 V 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 10 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch VEXT VCC VI G RL VO DUT RT CL RL mna616 Test data is given in Table 11. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. VEXT = External voltage for measuring switching times. Fig. 14. Test circuit for measuring switching times Table 11. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open GND 2VCC 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open GND 6.0 V 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open GND 6.0 V 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open GND 2VCC Load VEXT 11.2. Additional dynamic characteristics Table 12. Additional dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); Tamb = 25 °C. Symbol Parameter Conditions Min Typ Max THD total harmonic distortion fi = 1 kHz; RL = 10 kΩ; CL = 50 pF; see Fig. 15 Unit VCC = 2.3 V - 0.42 - % VCC = 3.0 V - 0.36 - % VCC = 4.5 V - 0.47 - % VCC = 2.3 V - 0.11 - % VCC = 3.0 V - 0.07 - % VCC = 4.5 V - 0.01 - % VCC = 2.3 V - 160 - MHz VCC = 3.0 V - 200 - MHz VCC = 4.5 V - 210 - MHz VCC = 2.3 V - 180 - MHz VCC = 3.0 V - 180 - MHz VCC = 4.5 V - 180 - MHz fi = 10 kHz; RL = 10 kΩ; CL = 50 pF; see Fig. 15 f(-3dB) -3 dB frequency response RL = 600 Ω; CL = 50 pF; see Fig. 16 RL = 50 Ω; CL = 5 pF; see Fig. 16 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 11 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch Symbol Parameter Conditions Min Typ Max αiso isolation (OFF-state) RL = 600 Ω; CL = 50 pF; fi = 1 MHz; see Fig. 17 Unit VCC = 2.3 V - -65 - dB VCC = 3.0 V - -65 - dB VCC = 4.5 V - -62 - dB VCC = 2.3 V - -37 - dB VCC = 3.0 V - -36 - dB VCC = 4.5 V - -36 - dB RL = 50 Ω; CL = 5 pF; fi = 1 MHz; see Fig. 17 Vct Xtalk crosstalk voltage between digital inputs and switch; RL = 600 Ω; CL = 50 pF; fi = 1 MHz; tr = tf = 2 ns; see Fig. 18 crosstalk VCC = 2.3 V - 91 - mV VCC = 3.0 V - 119 - mV VCC = 4.5 V - 205 - mV between switches; RL = 600 Ω; CL = 50 pF; fi = 1 MHz; see Fig. 19 VCC = 2.3 V - -56 - dB VCC = 3.0 V - -55 - dB VCC = 4.5 V - -55 - dB between switches; RL = 50 Ω; CL = 5 pF; fi = 1 MHz; see Fig. 19 Qinj charge injection VCC = 2.3 V - -29 - dB VCC = 3.0 V - -28 - dB VCC = 4.5 V - -28 - dB CL = 0.1 nF; Vgen = 0 V; Rgen = 0 Ω; fi = 1 MHz; RL = 1 MΩ; see Fig. 20 VCC = 2.5 V - < 0.003 - pC VCC = 3.3 V - 0.003 - pC VCC = 4.5 V - 0.0035 - pC VCC = 5.5 V - 0.0035 - pC 11.3. Test circuits VCC VIH nE nY/nZ fi 0.5VCC RL nZ/nY 600 Ω 10 µF VO D CL 001aag492 Test conditions: VCC = 2.3 V: Vi = 2 V (p-p). VCC = 3 V: Vi = 2.5 V (p-p). VCC = 4.5 V: Vi = 4 V (p-p). Fig. 15. Test circuit for measuring total harmonic distortion 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 12 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch VCC 0.5VCC nE VIH 0.1 µF fi RL nY/nZ nZ/nY VO 50 Ω dB CL 001aag491 To obtain 0 dBm level at the output, adjust fi voltage. Increase fi frequency until dB meter reads -3 dB. Fig. 16. Test circuit for measuring the frequency response when switch is in ON-state 0.5VCC VCC RL VIL 0.1 µF fi 0.5VCC nE RL nY/nZ nZ/nY VO CL dB 50 Ω 001aag493 To obtain 0 dBm level at the input, adjust fi voltage. Fig. 17. Test circuit for measuring isolation (OFF-state) VCC nE nY/nZ G logic input 50 Ω nZ/nY VO RL 600 Ω 0.5VCC CL 0.5VCC 001aag494 Fig. 18. Test circuit for measuring crosstalk voltage (between digital inputs and switch) 0.5VCC 1E VIH 0.1 µF Ri 1Y or 1Z 600 Ω fi RL 1Z or 1Y CHANNEL ON 50 Ω CL 50 pF VO1 0.5VCC 2E VIL RL 2Y or 2Z 2Z or 2Y CHANNEL OFF Ri 600 Ω CL 50 pF VO2 001aag496 20 log10 (VO2 / VO1) or 20 log10 (VO1 / VO2). Fig. 19. Test circuit for measuring crosstalk between switches 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 13 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch VCC nE Rgen G logic input nY/nZ nZ/nY VO RL 1 MΩ Vgen CL 0.1 nF 001aag495 a. Test circuit logic input (nE) off on off VO ΔVO mna675 b. Input and output pulse definitions Qinj = ΔVO x CL. ΔVO = output voltage variation. Rgen = generator resistance. Vgen = generator voltage. Fig. 20. Test circuit for measuring charge injection 12. Application information The 74LVCV2G66 is used to reduce component count and footprint in low-power portable applications. Typical ‘66’ devices do not have low-power enable inputs causing a high ΔICC. To reduce power consumption in portable (battery) applications, a current limiting resistor is used. (see Fig. 21a). The low-power enable inputs of the 74LVCV2G66 have much lower ΔICC, eliminating the necessity of the current limiting resistor (see Fig. 21b). 5V 5V 1 MΩ VCC 3V VCC nE 3V nZ nY '66' device nE nZ nY 74LVCV2G66 (a) (b) 001aaa550 Fig. 21. Application example 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 14 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch 13. Package outline VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A max. max nom min 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v w y 0.2 0.08 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Fig. 22. Package outline SOT765-1 (VSSOP8) 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 15 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm 1 2 SOT833-1 b 4 3 4× (2) L L1 e 8 7 6 e1 5 e1 e1 8× A (2) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max A1 max b D E e e1 L L1 mm 0.5 0.04 0.25 0.17 2.0 1.9 1.05 0.95 0.6 0.5 0.35 0.27 0.40 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT833-1 --- MO-252 --- EUROPEAN PROJECTION ISSUE DATE 07-11-14 07-12-07 Fig. 23. Package outline SOT833-1 (XSON8) 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 16 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch XQFN8: plastic, extremely thin quad flat package; no leads; 8 terminals; body 1.6 x 1.6 x 0.5 mm SOT902-2 X D B A terminal 1 index area E A A1 detail X e v w b 4 3 C C A B C y1 C y 5 e1 terminal 1 index area 2 6 L 1 7 k 8 L2 L k metal area not for soldering L3 L1 0 1 Dimensions Unit(1) mm max nom min 2 mm scale A 0.5 A1 b D E e e1 0.05 0.25 1.65 1.65 0.20 1.60 1.60 0.55 0.00 0.15 1.55 1.55 0.5 k 0.2 L L1 L2 L3 0.35 0.15 0.25 0.35 0.30 0.10 0.20 0.30 0.25 0.05 0.15 0.25 v 0.1 w y y1 0.05 0.05 0.05 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT902-2 --- MO-255 --- sot902-2_po European projection Issue date 16-07-14 16-11-08 Fig. 24. Package outline SOT902-2 (XQFN8) 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 17 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch 14. Abbreviations Table 13. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test 15. Revision history Table 14. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVCV2G66 v.8 20181105 Product data sheet - 74LVCV2G66 v.7 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74LVCV2G66GD (SOT996-2/XSON8) removed. 74LVCV2G66 v.7 20161215 Modifications: • • 74LVCV2G66 v.6 20150722 Modifications: • 74LVCV2G66 v.5 20130329 Modifications: • 74LVCV2G66 v.4 20111122 Modifications: • 74LVCV2G66 v.3 20100616 74LVCV2G66 v.2 74LVCV2G66 v.1 74LVCV2G66 Product data sheet Product data sheet - 74LVCV2G66 v.6 Table 7: The maximum limits for leakage current and supply current have changed. •Type number 74LVCV2G66DP (SOT505-2) removed. Product data sheet - 74LVCV2G66 v.5 Added type numbers 74LVCV2G66GT and.74LVCV2G66GM Product data sheet - 74LVCV2G66 v.4 For type number 74LVCV2G66GD XSON8U has changed to XSON8. Product data sheet - 74LVCV2G66 v.3 Product data sheet - 74LVCV2G66 v.2 20080703 Product data sheet - 74LVCV2G66 v.1 20040402 Product data sheet - - Legal pages updated. All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 18 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch 16. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVCV2G66 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 19 / 20 74LVCV2G66 Nexperia Overvoltage tolerant bilateral switch Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Marking.......................................................................... 2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 4 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................4 10. Static characteristics..................................................5 10.1. Test circuits................................................................5 10.2. ON resistance............................................................6 10.3. ON resistance test circuit and graphs........................7 11. Dynamic characteristics.............................................9 11.1. Waveforms and test circuit.......................................10 11.2. Additional dynamic characteristics........................... 11 11.3. Test circuits.............................................................. 12 12. Application information........................................... 14 13. Package outline........................................................ 15 14. Abbreviations............................................................ 18 15. Revision history........................................................18 16. Legal information......................................................19 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 5 November 2018 74LVCV2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 5 November 2018 © Nexperia B.V. 2018. All rights reserved 20 / 20
74LVCV2G66GTX 价格&库存
很抱歉,暂时无法提供与“74LVCV2G66GTX”相匹配的价格&库存,您可以联系我们找货
74LVCV2G66GTX
