74LVC1G384GXH
74LVC1G384GXH
    NEXPERIA(安世)
    X2SON5_0.8X0.8MM
    双向开关
74LVC1G384GXH 数据手册
74LVC1G384 Bilateral switch Rev. 7 — 7 December 2016 Product data sheet 1. General description The 74LVC1G384 provides one single pole, single throw analog switch function. It has two input/output terminals (Y and Z) and an active LOW enable input pin (E). When pin E is HIGH, the analog switch is turned off. Schmitt trigger action at the enable input makes the circuit tolerant of slower input rise and fall times across the entire VCC range from 1.65 V to 5.5 V. 2. Features and benefits  Wide supply voltage range from 1.65 V to 5.5 V  Very low ON resistance:  7.5  (typical) at VCC = 2.7 V  6.5  (typical) at VCC = 3.3 V  6  (typical) at VCC = 5 V  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Switch current capability of 32 mA  High noise immunity  CMOS low power consumption  TTL interface compatibility at 3.3 V  Latch-up performance meets requirements of JESD 78 Class I  Enable input accepts voltages up to 5.5 V  Inputs accept voltages up to 5 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name 74LVC1G384GW 40 C to +125 C Description Version TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1G384GV 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 74LVC1G384GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1.45  0.5 mm SOT886 74LVC1G384 Nexperia Bilateral switch Table 1. Ordering information …continued Type number Package Temperature range Name Description Version 74LVC1G384GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1  0.5 mm SOT891 74LVC1G384GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74LVC1G384GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 74LVC1G384GX 40 C to +125 C X2SON5 X2SON5: plastic thermal enhanced extremely thin small SOT1226 outline package; no leads; 5 terminals; body 0.8  0.8  0.35 mm 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G384GW YL 74LVC1G384GV YL 74LVC1G384GM YL 74LVC1G384GF YL 74LVC1G384GN YL 74LVC1G384GS YL 74LVC1G384GX YL [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram ( =   <  ; DDD DDJ Fig 1. Logic symbol Fig 2. IEC logic symbol = < ( 9&& DDD Fig 3. Logic diagram 74LVC1G384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 26 74LVC1G384 Nexperia Bilateral switch 6. Pinning information 6.1 Pinning /9&* <   9&& =   QF *1'   ( /9&* <  =  *1'   9&&  ( DDJ 7UDQVSDUHQWWRSYLHZ DDD Fig 4. Pin configuration SOT353-1 (TSSOP5) and SOT753 (SC-74A) Fig 5. Pin configuration SOT886 (XSON6) /9&* /9&* <   9&& =   QF *1'   ( 9&&  =  (  < *1' DDJ  DDD 7UDQVSDUHQWWRSYLHZ 7UDQVSDUHQWWRSYLHZ Fig 6.  Pin configuration SOT891 (XSON6), SOT1115 (XSON6) and SOT1202 (XSON6) Fig 7. Pin configuration SOT1226 (X2SON5) 6.2 Pin description Table 3. Symbol Pin description Pin Description TSSOP5 and SC-74 XSON6 X2SON5 Y 1 1 3 independent input or output Z 2 2 5 independent output or input GND 3 3 2 ground (0 V) E 4 4 4 enable input (active LOW) n.c. - 5 - not connected VCC 5 6 1 supply voltage 74LVC1G384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 26 74LVC1G384 Nexperia Bilateral switch 7. Functional description Table 4. Function table[1] Input E Switch L ON-state H OFF-state [1] H = HIGH voltage level; L = LOW voltage level. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions VI input voltage IIK input clamping current ISK switch clamping current VI < 0.5 V or VI > VCC + 0.5 V VSW switch voltage enable and disable mode ISW switch current VSW > 0.5 V or VSW < VCC + 0.5 V ICC [1] VI < 0.5 V or VI > VCC + 0.5 V Min Max Unit 0.5 +6.5 V 0.5 +6.5 V 50 - mA - 50 0.5 VCC + 0.5 - 50 mA supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 250 mW [2] Tamb = 40  C to +125 C [3] [1] The minimum input voltage rating may be exceeded if the input current rating is observed. [2] The minimum and maximum switch voltage ratings may be exceeded if the switch clamping current rating is observed. [3] mA V For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 and X2SON5 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VSW switch voltage Tamb ambient temperature t/V input transition rise and fall rate [1] Conditions Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V 0 - VCC V 40 - +125 C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V [1] To avoid sinking GND current from terminal Z when switch current flows in terminal Y, the voltage drop across the bidirectional switch must not exceed 0.4 V. If the switch current flows into terminal Z, no GND current will flow from terminal Y. In this case, there is no limit for the voltage drop across the switch. 74LVC1G384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 26 74LVC1G384 Nexperia Bilateral switch 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter HIGH-level input voltage VIH LOW-level input voltage VIL 40 C to +85 C Conditions VCC = 1.65 V to 1.95 V 40 C to +125 C Min Typ[1] Max Min Unit Max 0.65VCC - - 0.65 VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V VCC = 1.65 V to 1.95 V - - 0.35VCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V 0.35VCC V - - 0.3VCC - 0.3VCC V - 0.1 1 - 1 A II input leakage current pin E; VI = 5.5 V or GND; VCC = 0 V to 5.5 V [2] IS(OFF) OFF-state leakage current VCC = 5.5 V; see Figure 8 [2] - 0.1 0.2 - 0.5 A IS(ON) ON-state leakage current VCC = 5.5 V; see Figure 9 [2] - 0.1 1 - 2 A ICC supply current VI = 5.5 V or GND; VSW = GND or VCC; VCC = 1.65 V to 5.5 V [2] - 0.1 4 - 4 A ICC additional pin E; VI = VCC  0.6 V; supply current VSW = GND or VCC; VCC = 5.5 V [2] - 5 500 - 500 A CI input capacitance - 2.0 - - - pF CS(OFF) OFF-state capacitance - 5.0 - - - pF CS(ON) ON-state capacitance - 9.5 - - - pF [1] All typical values are measured at Tamb = 25 C. [2] These typical values are measured at VCC = 3.3 V. 74LVC1G384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 26 74LVC1G384 Nexperia Bilateral switch 10.1 Test circuits 9&& 9&& ( 9,+ = 9, ( 9,/ < ,6 ,6 *1' 92 = < *1' 9, 92 DDJ DDJ VI = VCC or GND and VO = GND or VCC. Fig 8. VI = VCC or GND and VO = open circuit. Test circuit for measuring OFF-state leakage current Fig 9. Test circuit for measuring ON-state leakage current 10.2 ON resistance Table 8. ON resistance At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graphs see Figure 11 to Figure 16. Symbol RON(peak) RON(rail) Parameter ON resistance (peak) ON resistance (rail) 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max ISW = 4 mA; VCC = 1.65 V to 1.95 V - 34.0 130 - 195  ISW = 8 mA; VCC = 2.3 V to 2.7 V - 12.0 30 - 45  ISW = 12 mA; VCC = 2.7 V - 10.4 25 - 38  ISW = 24 mA; VCC = 3 V to 3.6 V - 7.8 20 - 30  ISW = 32 mA; VCC = 4.5 V to 5.5 V - 6.2 15 - 23  ISW = 4 mA; VCC = 1.65 V to 1.95 V - 8.2 18 - 27  ISW = 8 mA; VCC = 2.3 V to 2.7 V - 7.1 16 - 24  ISW = 12 mA; VCC = 2.7 V - 6.9 14 - 21  VI = GND to VCC; see Figure 10 VI = GND; see Figure 10 ISW = 24 mA; VCC = 3 V to 3.6 V - 6.5 12 - 18  ISW = 32 mA; VCC = 4.5 V to 5.5 V - 5.8 10 - 15  VI = VCC; see Figure 10 74LVC1G384 Product data sheet - ISW = 4 mA; VCC = 1.65 V to 1.95 V - 10.4 30 - 45  ISW = 8 mA; VCC = 2.3 V to 2.7 V - 7.6 20 - 30  ISW = 12 mA; VCC = 2.7 V - 7.0 18 - 27  ISW = 24 mA; VCC = 3 V to 3.6 V - 6.1 15 - 23  ISW = 32 mA; VCC = 4.5 V to 5.5 V - 4.9 10 - 15  All information provided in this document is subject to legal disclaimers. Rev. 7 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 6 of 26 74LVC1G384 Nexperia Bilateral switch Table 8. ON resistance …continued At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graphs see Figure 11 to Figure 16. Symbol RON(flat) Parameter 40 C to +85 C Conditions ON resistance (flatness) 40 C to +125 C Unit Min Typ[1] Max Min Max ISW = 4 mA; VCC = 1.65 V to 1.95 V - 26.0 - - -  ISW = 8 mA; VCC = 2.3 V to 2.7 V - 5.0 - - -  ISW = 12 mA; VCC = 2.7 V - 3.5 - - -  [2] VI = GND to VCC ISW = 24 mA; VCC = 3 V to 3.6 V - 2.0 - - -  ISW = 32 mA; VCC = 4.5 V to 5.5 V - 1.5 - - -  [1] Typical values are measured at Tamb = 25 C and nominal VCC. [2] Flatness is defined as the difference between the maximum and minimum value of ON resistance measured at identical VCC and temperature. 10.3 ON resistance test circuit and graphs PQD  521 ȍ  96:    9&& ( 9,/     <  =   9, *1'   ,6:       RON = VSW / ISW.  9, 9 DDJ (1) VCC = 1.8 V. (2) VCC = 2.5 V. (3) VCC = 2.7 V. (4) VCC = 3.3 V. (5) VCC = 5.0 V. Fig 10. Test circuit for measuring ON resistance 74LVC1G384 Product data sheet Fig 11. Typical ON resistance as a function of input voltage; Tamb = 25 C All information provided in this document is subject to legal disclaimers. Rev. 7 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 7 of 26 74LVC1G384 Nexperia Bilateral switch DDD  521 ȍ DDD  521 ȍ                                 9, 9 (1) Tamb = 125 C. (1) Tamb = 125 C. (2) Tamb = 85 C. (2) Tamb = 85 C. (3) Tamb = 25 C. (3) Tamb = 25 C. (4) Tamb = 40 C. (4) Tamb = 40 C. Fig 12. ON resistance as a function of input voltage; VCC = 1.8 V DDD   9, 9 521 ȍ Fig 13. ON resistance as a function of input voltage; VCC = 2.5 V DDD  521 ȍ                       9, 9   (1) Tamb = 125 C. (2) Tamb = 85 C. (2) Tamb = 85 C. (3) Tamb = 25 C. (3) Tamb = 25 C. (4) Tamb = 40 C. (4) Tamb = 40 C. 74LVC1G384 Product data sheet   9, 9 (1) Tamb = 125 C. Fig 14. ON resistance as a function of input voltage; VCC = 2.7 V  Fig 15. ON resistance as a function of input voltage; VCC = 3.3 V All information provided in this document is subject to legal disclaimers. Rev. 7 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 8 of 26 74LVC1G384 Nexperia Bilateral switch DDD  521 ȍ               9, 9 (1) Tamb = 125 C. (2) Tamb = 85 C. (3) Tamb = 25 C. (4) Tamb = 40 C. Fig 16. ON resistance as a function of input voltage; VCC = 5.0 V 11. Dynamic characteristics Table 9. Dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 19. Symbol Parameter tpd ten 40 C to +85 C Conditions 74LVC1G384 Product data sheet Unit Min Max Min Max VCC = 1.65 V to 1.95 V - 0.8 2.0 - 3.0 ns VCC = 2.3 V to 2.7 V - 0.4 1.2 - 2.0 ns VCC = 2.7 V - 0.4 1.0 - 1.5 ns VCC = 3.0 V to 3.6 V - 0.3 0.8 - 1.5 ns VCC = 4.5 V to 5.5 V - 0.2 0.6 - 1.0 ns VCC = 1.65 V to 1.95 V 1.0 10.0 12.0 1.0 15.5 ns VCC = 2.3 V to 2.7 V 1.0 5.7 6.5 1.0 8.5 ns VCC = 2.7 V 1.0 5.4 6.0 1.0 8.0 ns VCC = 3.0 V to 3.6 V 1.0 4.8 5.0 1.0 6.5 ns VCC = 4.5 V to 5.5 V 1.0 3.3 4.2 1.0 5.5 ns propagation delay Y to Z or Z to Y; see Figure 17 enable time 40 C to +125 C Typ[1] E to Y or Z; see Figure 18 [2][3] [4] All information provided in this document is subject to legal disclaimers. Rev. 7 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 9 of 26 74LVC1G384 Nexperia Bilateral switch Table 9. Dynamic characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 19. Symbol Parameter 40 C to +85 C Conditions Min tdis disable time Max 40 C to +125 C Min Max Unit [5] E to Y or Z; see Figure 18 VCC = 1.65 V to 1.95 V 1.0 7.4 10.0 1.0 13.0 ns VCC = 2.3 V to 2.7 V 1.0 4.1 6.9 1.0 9.0 ns VCC = 2.7 V 1.0 4.9 7.5 1.0 9.5 ns VCC = 3.0 V to 3.6 V 1.0 5.4 6.5 1.0 8.5 ns 1.0 3.6 5.0 1.0 6.5 ns VCC = 2.5 V - 13.7 - - - pF VCC = 3.3 V - 15.2 - - - pF VCC = 5.0 V - 18.3 - - - pF VCC = 4.5 V to 5.5 V power dissipation capacitance CPD Typ[1] [6] CL = 50 pF; fi = 10 MHz; VI = GND to VCC [1] Typical values are measured at Tamb = 25 C and nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified capacitance when driven by an ideal voltage source (zero output impedance). [4] ten is the same as tPZH and tPZL. [5] tdis is the same as tPLZ and tPHZ. [6] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + {(CL + CS(ON))  VCC2  fo} where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; CS(ON) = maximum ON-state switch capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; {(CL + CS(ON))  VCC2  fo} = sum of the outputs. 11.1 Waveforms and test circuit 9, 90 500 - MHz VCC = 4.5 V - > 500 - MHz VCC = 1.65 V - 200 - MHz VCC = 2.3 V - 350 - MHz VCC = 3.0 V - 410 - MHz VCC = 4.5 V - 440 - MHz VCC = 1.65 V - 46 - dB VCC = 2.3 V - 46 - dB VCC = 3.0 V - 46 - dB VCC = 4.5 V - 46 - dB VCC = 1.65 V - 37 - dB VCC = 2.3 V - 37 - dB VCC = 3.0 V - 37 - dB VCC = 4.5 V - 37 - dB VCC = 1.65 V - 69 - mV VCC = 2.3 V - 87 - mV VCC = 3.0 V - 156 - mV VCC = 4.5 V - 302 - mV RL = 50 ; CL = 5 pF; see Figure 21 RL = 50 ; CL = 10 pF; see Figure 21 iso isolation (OFF-state) RL = 600 ; CL = 50 pF; fi = 1 MHz; see Figure 22 RL = 50 ; CL = 5 pF; fi = 1 MHz; see Figure 22 Vct crosstalk voltage between digital input and switch; RL = 600 ; CL = 50 pF; fi = 1 MHz; tr = tf = 2 ns; see Figure 23 74LVC1G384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 13 of 26 74LVC1G384 Nexperia Bilateral switch Table 12. Additional dynamic characteristics …continued At recommended operating conditions; typical values measured at Tamb = 25 C. Symbol Parameter Conditions Min Typ Max Qinj charge injection CL = 0.1 nF; Vgen = 0 V; Rgen = 0 ; fi = 1 MHz; RL = 1 M; see Section 11 Unit VCC = 1.8 V - 3.3 - pC VCC = 2.5 V - 4.1 - pC VCC = 3.3 V - 5.0 - pC VCC = 4.5 V - 6.4 - pC VCC = 5.5 V - 7.5 - pC 11.3 Test circuits 9&& ( 9,/ 5/
74LVC1G384GXH
物料型号:74LVC1G384
器件简介: 74LVC1G384是一款单极单掷模拟开关,具有两个输入/输出端(Y和Z)以及一个低电平有效的使能输入引脚(E)。当E引脚为高电平时,模拟开关关闭。该器件在1.65V至5.5V的整个VCC范围内提供施密特触发器动作,使电路能够容忍较慢的输入上升和下降时间。
引脚分配: - Y:独立输入或输出(引脚1) - Z:独立输出或输入(引脚2) - GND:地(0V)(引脚3) - E:使能输入(低电平有效)(引脚4) - n.c.:未连接(引脚5) - Vcc:供电电压(引脚5或6,根据封装类型)
参数特性: - 宽电源电压范围:1.65V至5.5V - 非常低的导通电阻:典型值在2.7V时为7.5Ω,3.3V时为6.5Ω,5V时为6Ω - ESD保护:HBM模型下超过2000V,MM模型下超过200V - 32mA的开关电流能力 - 高抗噪声性能 - CMOS低功耗 - 3.3V下的TTL接口兼容性 - 锁存性能满足JESD 78 Class I要求
功能详解: 当使能输入E为低电平时,开关处于导通状态,允许Y和Z之间传输信号。当E为高电平时,开关关闭,Y和Z之间断开连接。
应用信息: 该器件适用于多种应用,包括音频开关、多路复用器、电源管理等。
封装信息: 提供多种封装选项,包括: - TSSOP5(SOT353-1) - SC-74A(SOT753) - XSON6(SOT886) - XSON6(SOT891) - XSON6(SOT1115) - XSON6(SOT1202) - X2SON5(SOT1226)
每种封装都有其特定的温度范围和版本。例如,74LVC1G384GW封装的温度范围为-40°C至+125°C。
74LVC1G384GXH 价格&库存
很抱歉,暂时无法提供与“74LVC1G384GXH”相匹配的价格&库存,您可以联系我们找货
74LVC1G384GXH
  • 1+2.110511+0.27357
  • 10+1.4539110+0.18846
  • 25+1.2867725+0.16679
  • 100+1.10184100+0.14282
  • 250+1.01300250+0.13131
  • 500+0.95956500+0.12438
  • 1000+0.915491000+0.11867
  • 2500+0.891452500+0.11555
库存:4679
74LVC1G384GXH
    74LVC1G384GXH
    • 1+2.110291+0.27354
